[Geoprisma-users] FeatureServer, OL, GP ack!
Stephen Woodbridge woodbri at swoodbridge.com
Fri Nov 20 09:08:23 EST 2009
So you said tinyOWS was not supported in GP yet.
So I installed FS and started reading your past threads on implementing
FS with OL, then looked at http://dev4.mapgears.com/bdga-fs/
Now my head is ready to explode :) And this was easier then adding
support of tinyOWS?
ok I know that is rhetorical, but I'm just saying ...
Anyway, this may be a little OT, but my GP use case is a web based GIS
systems or something close to that. And I have all data layers loaded in
postGIS, I can create a Mapserver mapfile to display these, I already
have one displaying them from the shapefiles. And I'm trying to figure
out how to integrate FS and how this fits into the bigger design.
In OL, I will likely have Mapserver (WMS? or not) base layer, and Google
base layer. Then I need to be able to select one of the layers to be
editable (I'm assuming only one can be editable at a time) and it will
then get overdrawn via FS so edits can take place.
I'm not sure the best way to select the layer for editing. It probably
means hacking OL.layerswitcher so that the layers are in a radio button
field that also selects the layer as editable and only one can be on at
a time. This probably means the select control needs to be notified
maybe it is listening for a layer switch change event.
Seems like the draw/edit tools needs to be selected based on the layer
type polygon, line, point.
So I guess I need to pick apart the bdga-fs demo. And ideas on how to
find out what the layer type is?
And finally (or not) GP needs to be wrapped around all of this.
I think someone mentioned that a future enhancement was to be able to
upload a shapefile and install it under GP. I assume that would get
loaded into postGIS, then a mapfile generated, FS cfg fragment would be
generated and added to featureserver.cfg or something along these lines.
Where does this stand in your plans? I'm assuming this is all initiated
from an OL application so when the server is ready with the new data, it
response to OL and the code there will dynamically add a new OL layer to
the map and refresh the page. Also any GP config files also need to be
updated. Since a lot of stuff needs to get changed, I might make sense
that the yours needs to reload the browser page before the changes are
visible instead of trying to dynamically update the page.
Thoughts, examples, help appreciated.
-Steve
More information about the Geoprisma-users mailing list
