[Geoprisma-users] Back to GP again
Stephen Woodbridge woodbri at swoodbridge.com
Wed Nov 25 15:35:21 EST 2009
Alexandre,
The new doc is a great improvement!
Here are some random comments:
1) Looking at the Widget list
http://geoprisma.org/dist/naturaldoc/files2/featurepanel/form/Form-txt.html
I think it would be very helpful to standardize Widget names a little
bit with the client project. This is already done for some of the
MapFish widgets:
FeaturePanel_Form         => ExtFeaturePanel_Form
FeaturePanel_Selector     => ExtFeaturePanel_Selector
GeoExtToolbar             => GeoExtNavToolbar
GetMousePosition          => GPGetMousePosition
MapFishLayerTree          => MapFishLayerTree
MapFishRecenter           => MapFishRecenter
Merge                     => PGMerge
MeasureTool               => GPMeasureTool
MousePosition             => OLMousePosition
PopUp                     => OLPopUp
QueryOnClick              => GeoExtQueryOnClick
QuickZoom                 => Use Shortcut Widget **No Docs*
ResultExtGrid             => ExtResultGrid
Scale                     => OLScale
Split                     => PGSplit
Toolbar                   => MapFishNavToolbar
EditFeature_Create        => GeoExtEditFeature_Create
EditFeature_Delete        => GeoExtEditFeature_Delete
EditFeature_Update        => GeoExtEditFeature_Update
Why bother you might ask? :)
Maybe this is not the way to do it, but you already started with this
naming conventions and I think is has some value in making sensible
widget choices. For example if I don't want to add in all the MapFish
stuff then I can avoid using those widgets. I assume that over time and
growth of the wisget library this will become more and more useful.
Obviously there are other ways to do this and if you use the EditFeature
tools then you are already commited to using the MapFish protocol which
I assume means using some of there JS files?
2) Reading through the tutorial and trying to implement a project.
http://geoprisma.org/dist/build/html/tutorials/create-your-own-geoprisma-project.html#services-datastores-and-resources-list
section 1. 2nd bullet needs a link to the list of widgets which got me
side tracked to the above comment.
In this section, you talk about making a list. It would be helpful to
show and example list and to comment that it will be used below in
another step (I haven't gotten to that step yet).
In general, the current doc is a little bit abstract, and would benefit
from being a little more concrete. I would suggest defining a specific
example for the Tutorial and referring to that example to explain each
step, like:
1) a city wants to setup a GP service and has the following resouces:
citylimits - polygon shapefile
lakes      - polygon shapefile with object names
parcels    - polygon shapefile with lots of attribute
streets    - line shapefile with moderate number of attributes
The example data can be downloaded from HERE(link).
The citylimits layer is a reference only layer
The lakes layer is also a reference only layer
The parcels layer is managed by the city tax department which needs to
make sure it is updated as things change, but the public needs to be
able to view it.
The streets layer is managed by the highway department which needs to
mantain it, and add new streets as new subdivision are created. The
public needs to view this as a reference layer also.
2) we have loaded all these layers into postgis database
3) we have configured mapserver to serve WMS maps from the database
    - show a sample mapfile for the above
4) we have featureserver installed
    - show a sample config file for the above
Now based on this, show the services, DataStores and Resource Lists and
follow through with this example in the tutorial. This way when the user
is finished with the tutorial they will have a working example. Also
making it concrete like this will make it much easier to write up the
docs because you will have an example to show what you are talking about.
Still wading through the tutorial. It is a really good start and I'll
probably add to this as I progress through it.
Thanks for the amazing amount of additional work you have done on the docs.
-Steve
More information about the Geoprisma-users mailing list
