[Geoprisma-users] QueryOnClick Configuration
louis.rocheleau louis.rocheleau at boreal-is.com
Thu Nov 26 04:51:02 EST 2009
Philippe,
this is it. Thanks !
I think it may be a good idea to put some mapfile information into the
widget documentation (in the case of a user with a mapfile)
 - "gml_include_items" "all" into the WEB section (under METADATA)
 - "gml_include_items" "all" into the LAYER section (under METADATA)
 - DUMP true into the LAYER section
Cheers
Louis
Your problem seems to be on the mapfile side of things. For a layer to
output GML on a query on click, you need to have the "DUMP true" line
inside the LAYER object.
Hope this helps.
Philippe
View this message in context: http://n3.nabble.com/QueryOnClick-Configuration-tp41241p41257.html
Sent from the GeoPrisma-users mailing list archive at Nabble.com.
More information about the Geoprisma-users mailing list
