[Geoprisma-users] Scale Widget
louis.rocheleau louis.rocheleau at boreal-is.com
Thu Nov 26 09:20:32 EST 2009
Hi Alexandre,
thanks for your answer.
- Actually ctrl+u makes me think the widget is NOT included, as
"ScaleWidget" does not appear anywhere. It does not appear in Firebug
neither.
- Concerning GP crash, it comes when I activate the Widget into one layer in
the workspace:
replacing the line
<!--widget>ScaleWidget</widget-->
by
<widget>ScaleWidget</widget>
If I leave <!--widget>ScaleWidget</widget-->, my map layers and all the
others widgets are working fine.
There is no error message, on the screen or in FireBug. GP window is
becoming blank. Actually since we see the Widget was not included at first,
it may be why the screen becomes white.
The definition I have put in the widget section is the following:
        <scale>
            <name>ScaleWidget</name>
            <options>
            </options>
        </scale>
Do I need to include it into the Toolbar Widget ?
Cheers
Louis
Alexandre Dube wrote:
> Hi Louis,
> louis.rocheleau wrote:
>> When I define this widget in Resources, nothing happens, but GP is
>> running.
> One good trick to see if your widget was included, see the source of the
> page (ctrl+u in Firefox) and search for "ScaleWidget".
>> When I define it in the workspace, GP is crashing.
> What config diver are you using ? Is there an error message ?
> Regards,
> Alexandre Dubé
> Mapgears
> www.mapgears.com
> Geoprisma-users mailing list
> Geoprisma-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geoprisma-users
View this message in context: http://n3.nabble.com/Scale-Widget-tp41246p41381.html
Sent from the GeoPrisma-users mailing list archive at Nabble.com.
More information about the Geoprisma-users mailing list
