[Geoprisma-users] bdga config.xml
Yves Moisan yves.moisan at boreal-is.com
Thu Nov 26 11:19:26 EST 2009
Le jeudi 26 novembre 2009 à 09:18 -0500, Alexandre Dube a écrit :
> Yves Moisan wrote:
> > One thing that refrains us now from easily packaging samples whose
> > templates are not in /src/client/templates is that one can't use a
> > parameter in <xsl:include>.
> Isn't this because the directory structure changes for the bundles ?  If
> we had the exact same structure for both bundles and trunk, would that
> work ?
Right.  If we had parameters ...  We can discuss that later, unless you
think it's absolutely critical.
Yves
> In either case, that would be more logic to have everything the same.
> If it's important to keep the revision number of a certain project, why
> not putting it in a .txt file instead of changing the directory name to
> theproject-rXXX ?  Would that be cool ?
> Cheers everyone,
More information about the Geoprisma-users mailing list
