[Geoprisma-users] Scale Widget
louis.rocheleau louis.rocheleau at boreal-is.com
Thu Nov 26 14:19:50 EST 2009
Actually I thought they had to be in both the Resources and Workspace. But
Yves informed me that they should only be in the workspace. That said, when
I put this widget into the workspace, that is exactly when GP is crashing...
In summary :
- Defined only in the Resources, the widget does not seem to be loaded.
- Defined in both the Resources and the Workspaces, GP is crashing.
Thanks
Louis
Alexandre Dube wrote:
> If you're using the XMLWorkspaceConfig, the widgets must be defined in
> the workspace instead of the resources.  See the workspace example.
> Let me know if that helped,
> Alexandre
> louis.rocheleau wrote:
>> Hi Alexandre,
>> it is, as I showed earlier:
>> "When I define this widget in Resources, nothing happens, but GP is
>> running.
>> When I define it in the workspace, GP is crashing.
>>         <resource>
>>             <name>Res_LaserImagery</name>
>>             <datastores>
>>                 <datastore>DS_LaserImagery</datastore>
>>                 <datastore>DS_LaserImagery_TC</datastore>
>>             </datastores>
>>             <widgets>
>>                 <widget>Toolbar</widget>
>>                 <widget>ScaleWidget</widget>
>>             </widgets>
>>         </resource>
>> Louis
>>>> Do I need to include it into the Toolbar Widget ?
>>> No, but it must be included in at least any one Resource (pick one that
>>> all the users have access to).  Try this and report back please,
>>> Alexandre Dubé
>>> Mapgears
>>> www.mapgears.com
>>> Geoprisma-users mailing list
>>> Geoprisma-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geoprisma-users
> Alexandre Dubé
> Mapgears
> www.mapgears.com
View this message in context: http://n3.nabble.com/Scale-Widget-tp41246p41551.html
Sent from the GeoPrisma-users mailing list archive at Nabble.com.
More information about the Geoprisma-users mailing list
