[Geoprisma-users] GeoPrisma 1.2.2. release
Alexandre Dube
adube at mapgears.com
Thu Apr 12 10:12:03 EDT 2012
The GeoPrisma Development Team is proud to announce the release of
GeoPrisma 1.2.2, which closes 2 tickets.
The GeoPrisma 1.2.2 source code can be downloaded from:
http://geoprisma.org/download/geoprisma-1.2.2.tar.gz
or using SVN at :
https://svn.osgeo.org/geoprisma/projects/geoprisma/tags/rel-1-2-2/
The GeoPrisma 1.2.2 documentation is available at :
http://geoprisma.org/docs/1.2/
The 1.2.2 release contains minor fixes. Here's the copy of the
HISTORY.TXT log :
- Fixed MapFishPrintProxy. Doesn't strip slashes anymore for the spec
json sent to the service. (#439)
- Fixed OpenLayers.Map.zoomToMaxExtent method, overridden with fixed
proposed in http://trac.osgeo.org/openlayers/ticket/2178. Fix must be
removed when we use an OpenLayers version with it. (#435)
Please help out by testing your applications with this new code base.
Thanks! - The GeoPrisma Team
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-users
