[Geoprisma-users] GeoPrisma and existing application
Alexandre Dube adube at mapgears.com
Wed Jan 25 16:38:17 EST 2012
Be sure to checkout the trunk version of GeoPrisma using subversion if
you want to send a patch with your modifications.  You can create a
ticket on trac.osgeo.org/geoprisma when ready.
Regards,
Alexandre
On 12-01-25 11:53 AM, Gabriel Vatin wrote:
> Thank you Alexandre. I think I will try your 2nd option, knowing that
> most of my tools have their specific JavaScript file.
> Gabriel
> On 16/01/2012 15:23, Alexandre Dube wrote:
>> Hi Gabriel,
>>   There is currently no easy way to accomplish that in GeoPrisma.  It
>> would be possible with some modifications to the server 'core'.
>> Here's some ideas :
>> === Use proxy only ===
>>   In GeoPrisma, there are 2 main parts : the proxy (server) and the
>> templating system (auto-builds the client app).  In your case, you
>> could only pick the server part.  You would only need to setup the
>> php files and config and instead of using the UI auto-generation (see
>> an index.php in any sample), you would only setup a proxy.php.
>>   In your client application, change the hosts of your layers to
>> point to proxy.php and by adding "osmservice" and "osmresource"
>> parameters.  Using firebug, look at any layer generated url to see an
>> example of a call using the proxy.
>>   Then, the only thing remaining would be to add/remove tools
>> depending on the user rights.  You could create a small php file that
>> would read the config and acl, browse them and return a JSON
>> representing the rights of the currently logged user.  You'd need to
>> look at the core php files to see how they work.  You would then use
>> that JSON in your app to add/remove wanted/unwanted tools.
>> === Create a new "box" widget ===
>>   This idea would focus more in using both parts : proxy and
>> templating system.
>>   There is currently no widget in GeoPrisma that has the purpose of
>> loading complete external files and treat them as widgets.  It could
>> be a good idea to create one that would do the following :
>>  * manually list the resources needing it
>>  * in xslt, it would check if the resource is existant in the config
>> (has the ACL rights) and execute the included code for it
>>  * each resource+widget could have a unique js file to include
>>  * it could also be unbound, i.e. could simply load source not
>> related to resource (like a widget adding some static feature in the
>> app)
>>   In my opinion, this would be a simpler idea than the first one.
>>   Anybody else have other ideas ?
>> Kind regards,
>> Alexandre
> Geoprisma-users mailing list
> Geoprisma-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geoprisma-users
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-users mailing list
