[geos-commits] r2042 - in trunk: . source
svn_geos at osgeo.org svn_geos at osgeo.org
Mon Dec 17 16:52:13 EST 2007
Author: mloskot
Date: 2007-12-17 16:52:13 -0500 (Mon, 17 Dec 2007)
New Revision: 2042
   trunk/ChangeLog
   trunk/source/Makefile.vc
source\Makefile.vc: Fixed MSVC_VER condition for Microsoft Visual C++ 2008 (9.0).
Modified: trunk/ChangeLog
--- trunk/ChangeLog	2007-12-13 16:11:53 UTC (rev 2041)
+++ trunk/ChangeLog	2007-12-17 21:52:13 UTC (rev 2042)
@@ -1,5 +1,10 @@
 $Id$
+2007-12-17 Mateusz Loskot <mateusz at loskot.net>
+	* source\Makefile.vc: fixed MSVC_VER condition for
+	  Microsoft Visual C++ 2008 (9.0), compiler version 1500
 2007-12-13 Mateusz Loskot <mateusz at loskot.net>
 	* ChangeLog: added Id keyword at the top of the file.
Modified: trunk/source/Makefile.vc
--- trunk/source/Makefile.vc	2007-12-13 16:11:53 UTC (rev 2041)
+++ trunk/source/Makefile.vc	2007-12-17 21:52:13 UTC (rev 2042)
@@ -1,7 +1,7 @@
 # $Id$
-# 	Building on Win32 with Visual Studio
+# Building on Win32 with Visual C++ 7.0, 7.1, 8.0 or 9.0
 # Produces:
 #  geos.lib: static library for use of C or C++ API.
@@ -10,54 +10,6 @@
 # This makefile mostly maintained by Frank Warmerdam <warmerdam at pobox.com>
-# $Log$
-# Revision 1.15  2006/06/03 22:31:22  hobu
-# update to track latest removals
-# Revision 1.14  2006/05/03 16:22:40  hobu
-# tweak clean target
-# Revision 1.13  2006/05/03 16:21:18  hobu
-# Build the C API and shared lib separate from the normal lib
-# Add missing files
-# Revision 1.12  2006/05/03 15:49:12  hobu
-# add additional files and change names where necessary
-# Revision 1.11  2006/04/04 01:54:31  hobu
-# Add in changes/missing from previous rearranging.
-# Revision 1.10  2006/04/04 01:28:44  hobu
-# remove objects that no longer exist
-# default to MSVC_VER=1310
-# Revision 1.9  2006/03/10 10:48:28  strk
-# Bug #58 - Patch to makefile.vc after big refactoring commit
-# Revision 1.8  2006/03/01 16:42:47  strk
-# Fixed include name (Bug#41)
-# Revision 1.7  2006/03/01 11:47:51  strk
-# Applied patch by Mateusz Loskot (Bug #39)
-# Revision 1.6  2006/01/31 21:42:01  strk
-# Added DepthSegment object
-# Revision 1.5  2005/10/21 02:44:31  frank
-# added a wee readme
-# Revision 1.4  2005/10/21 02:41:25  frank
-# added DLL building, and geostest.exe
-# Revision 1.3  2005/10/21 01:57:08  frank
-# updated for 3.0.0 and added C API
-# Revision 1.2  2004/12/04 01:20:20  frank
-# removed dll delete
-# Revision 1.1  2004/12/03 16:25:47  frank
-# New
 !INCLUDE dirlist.mk
 # Commands
@@ -73,7 +25,7 @@
 MSVC_VER=1310
 !ENDIF
-!IF $(MSVC_VER) == 1400
+!IF $(MSVC_VER) >= 1400
 MSVC_CPPFLAGS = /EHs /D "_CRT_SECURE_NO_DEPRECATE"
 !ELSE
 MSVC_CPPFLAGS = /GX
More information about the geos-commits mailing list
