[geos-commits] r2063 - in trunk/source/geom: . prep
svn_geos at osgeo.org svn_geos at osgeo.org
Fri Dec 21 15:40:27 EST 2007
Author: benjubb
Date: 2007-12-21 15:40:27 -0500 (Fri, 21 Dec 2007)
New Revision: 2063
Added:
   trunk/source/geom/prep/
   trunk/source/geom/prep/AbstractPreparedPolygonContains.cpp
   trunk/source/geom/prep/BasicPreparedGeometry.cpp
   trunk/source/geom/prep/PreparedGeometry.cpp
   trunk/source/geom/prep/PreparedGeometryFactory.cpp
   trunk/source/geom/prep/PreparedLineString.cpp
   trunk/source/geom/prep/PreparedLineStringIntersects.cpp
   trunk/source/geom/prep/PreparedPoint.cpp
   trunk/source/geom/prep/PreparedPolygon.cpp
   trunk/source/geom/prep/PreparedPolygonContains.cpp
   trunk/source/geom/prep/PreparedPolygonContainsProperly.cpp
   trunk/source/geom/prep/PreparedPolygonCovers.cpp
   trunk/source/geom/prep/PreparedPolygonIntersects.cpp
   trunk/source/geom/prep/PreparedPolygonLineIntersection.cpp
   trunk/source/geom/prep/PreparedPolygonPredicate.cpp
Added from JTS 1.9 to support prepared geometry
Added: trunk/source/geom/prep/AbstractPreparedPolygonContains.cpp
--- trunk/source/geom/prep/AbstractPreparedPolygonContains.cpp	                        (rev 0)
+++ trunk/source/geom/prep/AbstractPreparedPolygonContains.cpp	2007-12-21 20:40:27 UTC (rev 2063)
@@ -0,0 +1,192 @@
+ * $Id:
+ * GEOS - Geometry Engine Open Source
+ * http://geos.refractions.net
+ * Copyright (C) 2001-2002 Vivid Solutions Inc.
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+#include <geos/geom/prep/AbstractPreparedPolygonContains.h>
+#include <geos/geom/prep/PreparedPolygon.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/Polygon.h>
+#include <geos/geom/MultiPolygon.h>
+#include <geos/noding/SegmentString.h>
+#include <geos/noding/SegmentStringUtil.h>
+#include <geos/noding/SegmentIntersectionDetector.h>
+#include <geos/noding/FastSegmentSetIntersectionFinder.h>
+#include <geos/algorithm/LineIntersector.h>
+namespace geos {
+namespace geom { // geos::geom
+namespace prep { // geos::geom::prep
+// private:
+bool
+AbstractPreparedPolygonContains::isProperIntersectionImpliesNotContainedSituation( const geom::Geometry * testGeom)
+	// If the test geometry is polygonal we have the A/A situation.
+	// In this case, a proper intersection indicates that
+	// the Epsilon-Neighbourhood Exterior Intersection condition exists.
+	// This condition means that in some small
+	// area around the intersection point, there must exist a situation
+	// where the interior of the test intersects the exterior of the target.
+	// This implies the test is NOT contained in the target.
+	if (	testGeom->getGeometryTypeId() == GeometryTypeId::GEOS_MULTIPOLYGON
+		||	testGeom->getGeometryTypeId() == GeometryTypeId::GEOS_POLYGON )
+		return true;
+	// A single shell with no holes allows concluding that
+	// a proper intersection implies not contained
+	// (due to the Epsilon-Neighbourhood Exterior Intersection condition)
+	if ( isSingleShell( prepPoly->getGeometry()) )
+		return true;
+	return false;
+bool
+AbstractPreparedPolygonContains::isSingleShell( const geom::Geometry & geom)
+	// handles single-element MultiPolygons, as well as Polygons
+	if ( geom.getNumGeometries() != 1)
+		return false;
+	const geom::Polygon * poly = (Polygon *)geom.getGeometryN( 0);
+	int numHoles = poly->getNumInteriorRing();
+	return (numHoles == 0);
+void
+AbstractPreparedPolygonContains::findAndClassifyIntersections( const geom::Geometry * geom)
+	noding::SegmentString::ConstVect lineSegStr;
+	noding::SegmentStringUtil::extractSegmentStrings( geom, lineSegStr);
+	algorithm::LineIntersector * li;
+	li = new algorithm::LineIntersector();
+	noding::SegmentIntersectionDetector * intDetector;
+	intDetector = new noding::SegmentIntersectionDetector( li);
+	intDetector->setFindAllIntersectionTypes( true);
+	prepPoly->getIntersectionFinder()->intersects( &lineSegStr, intDetector);
+	hasSegmentIntersection = intDetector->hasIntersection();
+	hasProperIntersection = intDetector->hasProperIntersection();
+	hasNonProperIntersection = intDetector->hasNonProperIntersection();
+	delete intDetector;
+	delete li;
+	for ( size_t i = 0, ni = lineSegStr.size(); i < ni; i++ )
+		delete lineSegStr[ i ];
+// protected:
+bool
+AbstractPreparedPolygonContains::eval( const geom::Geometry * geom)
+	// Do point-in-poly tests first, since they are cheaper and may result
+	// in a quick negative result.
+	// If a point of any test components does not lie in target, result is false
+	bool isAllInTargetArea = isAllTestComponentsInTargetArea( geom);
+	if ( !isAllInTargetArea )
+		return false;
+	// If the test geometry consists of only Points,
+	// then it is now sufficient to test if any of those
+	// points lie in the interior of the target geometry.
+	// If so, the test is contained.
+	// If not, all points are on the boundary of the area,
+	// which implies not contained.
+	if ( requireSomePointInInterior && geom->getDimension() == 0 )
+		bool isAnyInTargetInterior = isAnyTestComponentInTargetInterior( geom);
+		return isAnyInTargetInterior;
+	// Check if there is any intersection between the line segments
+	// in target and test.
+	// In some important cases, finding a proper interesection implies that the
+	// test geometry is NOT contained.
+	// These cases are:
+	// - If the test geometry is polygonal
+	// - If the target geometry is a single polygon with no holes
+	// In both of these cases, a proper intersection implies that there
+	// is some portion of the interior of the test geometry lying outside
+	// the target, which means that the test is not contained.
+	bool properIntersectionImpliesNotContained = isProperIntersectionImpliesNotContainedSituation( geom);
+	// find all intersection types which exist
+	findAndClassifyIntersections( geom);
+	if ( properIntersectionImpliesNotContained && hasProperIntersection )
+		return false;
+	// If all intersections are proper
+	// (i.e. no non-proper intersections occur)
+	// we can conclude that the test geometry is not contained in the target area,
+	// by the Epsilon-Neighbourhood Exterior Intersection condition.
+	// In real-world data this is likely to be by far the most common situation,
+	// since natural data is unlikely to have many exact vertex segment intersections.
+	// Thus this check is very worthwhile, since it avoid having to perform
+	// a full topological check.
+	// (If non-proper (vertex) intersections ARE found, this may indicate
+	// a situation where two shells touch at a single vertex, which admits
+	// the case where a line could cross between the shells and still be wholely contained in them.
+	if ( hasSegmentIntersection && !hasNonProperIntersection )
+		return false;
+	// If there is a segment intersection and the situation is not one
+	// of the ones above, the only choice is to compute the full topological
+	// relationship.  This is because contains/covers is very sensitive
+	// to the situation along the boundary of the target.
+	if ( hasSegmentIntersection )
+		return fullTopologicalPredicate( geom);
+	// This tests for the case where a ring of the target lies inside
+	// a test polygon - which implies the exterior of the Target
+	// intersects the interior of the Test, and hence the result is false
+	if (	geom->getGeometryTypeId() == GeometryTypeId::GEOS_MULTIPOLYGON
+		||	geom->getGeometryTypeId() == GeometryTypeId::GEOS_POLYGON )
+		// TODO: generalize this to handle GeometryCollections
+		bool isTargetInTestArea = isAnyTargetComponentInTestArea( geom, prepPoly->getRepresentativePoints());
+		if ( isTargetInTestArea )
+			return false;
+	return true;
+// public:
+} // geos::geom::prep
+} // geos::geom
+} // geos
+ * $Log$
Property changes on: trunk/source/geom/prep/AbstractPreparedPolygonContains.cpp
___________________________________________________________________
   + text/plain
   + Id
   + native
Added: trunk/source/geom/prep/BasicPreparedGeometry.cpp
--- trunk/source/geom/prep/BasicPreparedGeometry.cpp	                        (rev 0)
+++ trunk/source/geom/prep/BasicPreparedGeometry.cpp	2007-12-21 20:40:27 UTC (rev 2063)
@@ -0,0 +1,149 @@
+ * $Id:
+#include <geos/geom/prep/BasicPreparedGeometry.h>
+#include <geos/geom/Coordinate.h>
+#include <geos/algorithm/PointLocator.h>
+#include <geos/geom/util/ComponentCoordinateExtracter.h>
+namespace geos {
+namespace geom { // geos.geom
+namespace prep { // geos.geom.prep
+ * protected: *
+void
+BasicPreparedGeometry::setGeometry( const geom::Geometry * geom )
+	baseGeom = geom;
+	geom::util::ComponentCoordinateExtracter::getCoordinates(*baseGeom, representativePts);
+bool
+BasicPreparedGeometry::envelopesIntersect( const geom::Geometry* g) const
+	return baseGeom->getEnvelopeInternal()->intersects(g->getEnvelopeInternal());
+bool
+BasicPreparedGeometry::envelopeCovers( const geom::Geometry* g) const
+	return baseGeom->getEnvelopeInternal()->covers(g->getEnvelopeInternal());
+ * public:
+BasicPreparedGeometry::BasicPreparedGeometry( const Geometry * geom)
+	setGeometry( geom);
+BasicPreparedGeometry::~BasicPreparedGeometry( )
+bool
+BasicPreparedGeometry::isAnyTargetComponentInTest( const geom::Geometry * testGeom) const
+	algorithm::PointLocator *locator = new algorithm::PointLocator();
+	for (size_t i=0, n=representativePts.size(); i<n; i++)
+		geom::Coordinate c = *(representativePts[i]);
+		if ( locator->intersects( c, testGeom) )
+		return true;
+	return false;
+bool
+BasicPreparedGeometry::contains(const geom::Geometry * g) const
+	return baseGeom->contains(g);
+bool
+BasicPreparedGeometry::containsProperly(const geom::Geometry * g)	const
+	return baseGeom->relate(g, "T**FF*FF*");
+bool
+BasicPreparedGeometry::coveredBy(const geom::Geometry * g) const
+	return baseGeom->coveredBy(g);
+bool
+BasicPreparedGeometry::covers(const geom::Geometry * g) const
+	return baseGeom->covers(g);
+bool
+BasicPreparedGeometry::crosses(const geom::Geometry * g) const
+	return baseGeom->crosses(g);
+bool
+BasicPreparedGeometry::disjoint(const geom::Geometry * g)	const
+	return ! intersects(g);
+bool
+BasicPreparedGeometry::intersects(const geom::Geometry * g) const
+	return baseGeom->intersects(g);
+bool
+BasicPreparedGeometry::overlaps(const geom::Geometry * g)	const
+	return baseGeom->overlaps(g);
+bool
+BasicPreparedGeometry::touches(const geom::Geometry * g) const
+	return baseGeom->touches(g);
+bool
+BasicPreparedGeometry::within(const geom::Geometry * g) const
+	return baseGeom->within(g);
+std::string
+BasicPreparedGeometry::toString()
+	return baseGeom->toString();
+} // namespace geos.geom.prep
+ * $Log$
Property changes on: trunk/source/geom/prep/BasicPreparedGeometry.cpp
   + text/plain
   + Id
   + native
Added: trunk/source/geom/prep/PreparedGeometry.cpp
--- trunk/source/geom/prep/PreparedGeometry.cpp	                        (rev 0)
+++ trunk/source/geom/prep/PreparedGeometry.cpp	2007-12-21 20:40:27 UTC (rev 2063)
@@ -0,0 +1,30 @@
+ * $Id:
+#include <geos/geom/prep/PreparedGeometry.h>
+namespace geos {
+ * $Log$
Property changes on: trunk/source/geom/prep/PreparedGeometry.cpp
   + text/plain
   + Id
   + native
Added: trunk/source/geom/prep/PreparedGeometryFactory.cpp
--- trunk/source/geom/prep/PreparedGeometryFactory.cpp	                        (rev 0)
+++ trunk/source/geom/prep/PreparedGeometryFactory.cpp	2007-12-21 20:40:27 UTC (rev 2063)
@@ -0,0 +1,72 @@
+ * $Id:
+#include <geos/geom/Point.h>
+#include <geos/geom/MultiPoint.h>
+#include <geos/geom/LineString.h>
+#include <geos/geom/LinearRing.h>
+#include <geos/geom/MultiLineString.h>
+#include <geos/geom/prep/PreparedGeometryFactory.h>
+#include <geos/geom/prep/PreparedLineString.h>
+#include <geos/geom/prep/PreparedPoint.h>
+namespace geos {
+const PreparedGeometry *
+PreparedGeometryFactory::create( const geom::Geometry * g) const
+	PreparedGeometry * pg;
+	switch ( g->getGeometryTypeId() )
+		case geom::GeometryTypeId::GEOS_MULTIPOINT:
+		case geom::GeometryTypeId::GEOS_POINT:
+			pg = new PreparedPoint( g);
+			break;
+		case geom::GeometryTypeId::GEOS_LINEARRING:
+		case geom::GeometryTypeId::GEOS_LINESTRING:
+		case geom::GeometryTypeId::GEOS_MULTILINESTRING:
+			pg = new PreparedLineString( g);
+			break;
+		case geom::GeometryTypeId::GEOS_POLYGON:
+		case geom::GeometryTypeId::GEOS_MULTIPOLYGON:
+			pg = new PreparedPolygon( g);
+			break;
+		default:
+			pg = new BasicPreparedGeometry( g);
+	return pg;
+ * $Log$
Property changes on: trunk/source/geom/prep/PreparedGeometryFactory.cpp
   + text/plain
   + Id
   + native
Added: trunk/source/geom/prep/PreparedLineString.cpp
--- trunk/source/geom/prep/PreparedLineString.cpp	                        (rev 0)
+++ trunk/source/geom/prep/PreparedLineString.cpp	2007-12-21 20:40:27 UTC (rev 2063)
@@ -0,0 +1,61 @@
+ * $Id:
+#include <geos/geom/prep/PreparedLineStringIntersects.h>
+namespace geos {
+ * public:
+noding::FastSegmentSetIntersectionFinder *
+PreparedLineString::getIntersectionFinder()
+	if (! segIntFinder)
+		noding::SegmentString::ConstVect ss;
+		noding::SegmentStringUtil::extractSegmentStrings( &getGeometry(), ss );
+		segIntFinder = new noding::FastSegmentSetIntersectionFinder( &ss );
+		for ( size_t i = 0, ni = ss.size(); i < ni; i++ )
+			delete ss[ i ];
+	return segIntFinder;
+bool
+PreparedLineString::intersects(const geom::Geometry * g) const
+	if (! envelopesIntersect(g)) return false;
+	return PreparedLineStringIntersects::intersects( *(const_cast<PreparedLineString*>(this)), g);
+ * $Log$
Property changes on: trunk/source/geom/prep/PreparedLineString.cpp
   + text/plain
   + Id
   + native
Added: trunk/source/geom/prep/PreparedLineStringIntersects.cpp
--- trunk/source/geom/prep/PreparedLineStringIntersects.cpp	                        (rev 0)
+++ trunk/source/geom/prep/PreparedLineStringIntersects.cpp	2007-12-21 20:40:27 UTC (rev 2063)
@@ -0,0 +1,91 @@
+ * $Id:
+namespace geos {
+	bool PreparedLineStringIntersects::isAnyTestPointInTarget(const geom::Geometry * testGeom) const
+		 * This could be optimized by using the segment index on the lineal target.
+		 * However, it seems like the L/P case would be pretty rare in practice.
+		PointLocator * locator = new PointLocator();
+		geom::Coordinate::ConstVect coords;
+		ComponentCoordinateExtracter::getCoordinates( *testGeom, coords);
+		for (size_t i=0, n=coords.size(); i<n; i++)
+			geom::Coordinate c = *(coords[i]);
+			if ( locator->intersects( c, &(prepLine.getGeometry()) ))
+				return true;
+		return false;
+	//bool PreparedLineStringIntersects::intersects( const PreparedLineString * const prep, const geom::Geometry * geom )
+	//	PreparedLineStringIntersects op = new PreparedLineStringIntersects( prep);
+	//	return op.intersects_( geom);
+	bool PreparedLineStringIntersects::intersects(const geom::Geometry * g) const
+		// If any segments intersect, obviously intersects = true
+		noding::SegmentStringUtil::extractSegmentStrings( g, lineSegStr);
+		noding::FastSegmentSetIntersectionFinder * fssif = prepLine.getIntersectionFinder();
+		bool segsIntersect = fssif->intersects( &lineSegStr);// prepLine.getIntersectionFinder()->intersects(lineSegStr);
+		if ( segsIntersect ) return true;
+		// For L/L case we are done
+		if ( g->getDimension() == 1 )
+			return false;
+		// For L/A case, need to check for proper inclusion of the target in the test
+		if (	g->getDimension() == 2
+			&&	prepLine.isAnyTargetComponentInTest(g) )
+			return true;
+		// For L/P case, need to check if any points lie on line(s)
+		if ( g->getDimension() == 0 )
+			return isAnyTestPointInTarget(g);
+		return false;
+ * $Log$
Property changes on: trunk/source/geom/prep/PreparedLineStringIntersects.cpp
   + text/plain
   + Id
   + native
Added: trunk/source/geom/prep/PreparedPoint.cpp
--- trunk/source/geom/prep/PreparedPoint.cpp	                        (rev 0)
+++ trunk/source/geom/prep/PreparedPoint.cpp	2007-12-21 20:40:27 UTC (rev 2063)
@@ -0,0 +1,39 @@
+ * $Id:
+namespace geos {
+bool
+PreparedPoint::intersects( geom::Geometry* g)
+	if (! envelopesIntersect( g)) return false;
+	// This avoids computing topology for the test geometry
+	return isAnyTargetComponentInTest( g);
+ * $Log$
Property changes on: trunk/source/geom/prep/PreparedPoint.cpp
   + text/plain
   + Id
   + native
Added: trunk/source/geom/prep/PreparedPolygon.cpp
--- trunk/source/geom/prep/PreparedPolygon.cpp	                        (rev 0)
+++ trunk/source/geom/prep/PreparedPolygon.cpp	2007-12-21 20:40:27 UTC (rev 2063)
@@ -0,0 +1,145 @@
+ * $Id:
+#include <geos/geom/prep/PreparedPolygonContains.h>
+#include <geos/geom/prep/PreparedPolygonContainsProperly.h>
+#include <geos/geom/prep/PreparedPolygonCovers.h>
+#include <geos/geom/prep/PreparedPolygonIntersects.h>
+#include <geos/geom/prep/PreparedPolygonLineIntersection.h>
+#include <geos/geom/prep/PreparedPolygonPredicate.h>
+#include <geos/operation/predicate/RectangleContains.h>
+#include <geos/operation/predicate/RectangleIntersects.h>
+#include <geos/algorithm/locate/PointOnGeometryLocator.h>
+#include <geos/algorithm/locate/IndexedPointInAreaLocator.h>
+namespace geos {
+// public:
+PreparedPolygon::
+PreparedPolygon( const geom::Geometry * geom)
+:	BasicPreparedGeometry( geom),
+	segIntFinder( NULL),
+	ptOnGeomLoc( NULL)
+	isRectangle = getGeometry().isRectangle();
+PreparedPolygon::
+~PreparedPolygon( )
+	delete segIntFinder;
+	delete ptOnGeomLoc;
+	for ( size_t i = 0, ni = segStrings.size(); i < ni; i++ )
+		delete segStrings[ i ];
+PreparedPolygon::
+getIntersectionFinder() const
+		noding::SegmentStringUtil::extractSegmentStrings( &getGeometry(), segStrings );
+		segIntFinder = new noding::FastSegmentSetIntersectionFinder( &segStrings );
+algorithm::locate::PointOnGeometryLocator *
+PreparedPolygon::
+getPointLocator() const
+	if (! ptOnGeomLoc)
+		ptOnGeomLoc = new algorithm::locate::IndexedPointInAreaLocator( getGeometry() );
+	return ptOnGeomLoc;
+bool
+PreparedPolygon::
+contains( const geom::Geometry * g) const
+    // short-circuit test
+    if ( !envelopeCovers( g) )
+		return false;
+    // optimization for rectangles
+    if ( isRectangle )
+		return operation::predicate::RectangleContains::contains( *((geom::Polygon *)&getGeometry()), *g);
+	return PreparedPolygonContains::contains( this, g);
+bool
+PreparedPolygon::
+containsProperly( const geom::Geometry* g) const
+		return false;
+	return PreparedPolygonContainsProperly::containsProperly( this, g);
+bool
+PreparedPolygon::
+covers( const geom::Geometry* g) const
+		return false;
+    // optimization for rectangle arguments
+    if ( isRectangle)
+		return true;
+	return PreparedPolygonCovers::covers( this, g);
+bool
+PreparedPolygon::
+intersects( const geom::Geometry* g) const
+  	// envelope test
+  	if ( !envelopesIntersect( g) )
+		return false;
+		return operation::predicate::RectangleIntersects::intersects( *((geom::Polygon *)&getGeometry()), *g);
+	return PreparedPolygonIntersects::intersects( this, g);
+ * $Log$
Property changes on: trunk/source/geom/prep/PreparedPolygon.cpp
   + text/plain
   + Id
   + native
Added: trunk/source/geom/prep/PreparedPolygonContains.cpp
--- trunk/source/geom/prep/PreparedPolygonContains.cpp	                        (rev 0)
+++ trunk/source/geom/prep/PreparedPolygonContains.cpp	2007-12-21 20:40:27 UTC (rev 2063)
@@ -0,0 +1,48 @@
+ * $Id:
+namespace geos {
+// private:
+// protected:
+bool
+PreparedPolygonContains::fullTopologicalPredicate( const geom::Geometry * geom)
+	bool isContained = prepPoly->getGeometry().contains( geom);
+	return isContained;
+// public:
+ * $Log$
Property changes on: trunk/source/geom/prep/PreparedPolygonContains.cpp
   + text/plain
   + Id
   + native
Added: trunk/source/geom/prep/PreparedPolygonContainsProperly.cpp
--- trunk/source/geom/prep/PreparedPolygonContainsProperly.cpp	                        (rev 0)
+++ trunk/source/geom/prep/PreparedPolygonContainsProperly.cpp	2007-12-21 20:40:27 UTC (rev 2063)
@@ -0,0 +1,81 @@
+ * $Id:
+namespace geos {
+// private:
+// protected:
+// public:
+bool
+PreparedPolygonContainsProperly::containsProperly( const geom::Geometry * geom)
+	bool isAllInPrepGeomArea = isAllTestComponentsInTargetInterior( geom);
+	if ( !isAllInPrepGeomArea )
+		return false;
+	// If any segments intersect, result is false
+	bool segsIntersect = prepPoly->getIntersectionFinder()->intersects( &lineSegStr);
+	if (segsIntersect)
+		return false;
+		bool isTargetGeomInTestArea = isAnyTargetComponentInTestArea( geom, prepPoly->getRepresentativePoints());
+		if (isTargetGeomInTestArea)
+			return false;
+	return true;
+ * $Log$
Property changes on: trunk/source/geom/prep/PreparedPolygonContainsProperly.cpp
   + text/plain
   + Id
   + native
Added: trunk/source/geom/prep/PreparedPolygonCovers.cpp
--- trunk/source/geom/prep/PreparedPolygonCovers.cpp	                        (rev 0)
+++ trunk/source/geom/prep/PreparedPolygonCovers.cpp	2007-12-21 20:40:27 UTC (rev 2063)
@@ -0,0 +1,49 @@
+ * $Id:
+namespace geos {
+// private:
+// protected:
+bool
+PreparedPolygonCovers::fullTopologicalPredicate( const geom::Geometry * geom)
+	bool result = prepPoly->getGeometry().covers( geom);
+	return result;
+// public:
+ * $Log$
Property changes on: trunk/source/geom/prep/PreparedPolygonCovers.cpp
   + text/plain
   + Id
   + native
Added: trunk/source/geom/prep/PreparedPolygonIntersects.cpp
--- trunk/source/geom/prep/PreparedPolygonIntersects.cpp	                        (rev 0)
+++ trunk/source/geom/prep/PreparedPolygonIntersects.cpp	2007-12-21 20:40:27 UTC (rev 2063)
@@ -0,0 +1,84 @@
+ * $Id:
+namespace geos {
+// private:
+// protected:
+// public:
+bool
+PreparedPolygonIntersects::intersects( const geom::Geometry * geom)
+	// in a quick positive result.
+	// If a point of any test components lie in target, result is true
+	bool isInPrepGeomArea = isAnyTestComponentInTargetArea( geom);
+	if ( isInPrepGeomArea )
+		return true;
+	// If any segments intersect, result is true
+	noding::SegmentStringUtil::extractSegmentStrings( geom, lineSegStr );
+	//delete lineSegStr;
+		return true;
+	// If the test has dimension = 2 as well, it is necessary to
+	// test for proper inclusion of the target.
+	// Since no segments intersect, it is sufficient to test representative points.
+	if ( geom->getDimension() == 2)
+		bool isPrepGeomInArea = isAnyTargetComponentInTestArea( geom, prepPoly->getRepresentativePoints());
+		if ( isPrepGeomInArea )
+			return true;
+	return false;
+} // geos::geom
+} // geos
+ * $Log$
Property changes on: trunk/source/geom/prep/PreparedPolygonIntersects.cpp
   + text/plain
   + Id
   + native
Added: trunk/source/geom/prep/PreparedPolygonLineIntersection.cpp
--- trunk/source/geom/prep/PreparedPolygonLineIntersection.cpp	                        (rev 0)
+++ trunk/source/geom/prep/PreparedPolygonLineIntersection.cpp	2007-12-21 20:40:27 UTC (rev 2063)
@@ -0,0 +1,30 @@
+ * $Id:
+namespace geos {
+ * $Log$
Property changes on: trunk/source/geom/prep/PreparedPolygonLineIntersection.cpp
   + text/plain
   + Id
   + native
Added: trunk/source/geom/prep/PreparedPolygonPredicate.cpp
--- trunk/source/geom/prep/PreparedPolygonPredicate.cpp	                        (rev 0)
+++ trunk/source/geom/prep/PreparedPolygonPredicate.cpp	2007-12-21 20:40:27 UTC (rev 2063)
@@ -0,0 +1,127 @@
+ * $Id:
+#include <geos/geom/Location.h>
+#include <geos/algorithm/locate/SimplePointInAreaLocator.h>
+namespace geos {
+// private:
+// protected:
+bool
+PreparedPolygonPredicate::isAllTestComponentsInTargetArea( const geom::Geometry * testGeom)
+	geom::Coordinate::ConstVect pts;
+	geom::util::ComponentCoordinateExtracter::getCoordinates( *testGeom, pts);
+	for ( size_t i = 0, ni = pts.size(); i < ni; i++ )
+		const geom::Coordinate * pt = pts[ i ];
+		int loc = prepPoly->getPointLocator()->locate( pt );
+		if ( loc == geom::Location::EXTERIOR )
+			return false;
+	return true;
+bool
+PreparedPolygonPredicate::isAllTestComponentsInTargetInterior( const geom::Geometry * testGeom)
+		if ( loc != geom::Location::INTERIOR )
+			return false;
+	return true;
+bool
+PreparedPolygonPredicate::isAnyTestComponentInTargetArea( const geom::Geometry * testGeom)
+		const Coordinate * pt = pts[ i ];
+		if ( loc != geom::Location::EXTERIOR )
+			return true;
+	return false;
+bool
+PreparedPolygonPredicate::isAnyTestComponentInTargetInterior( const geom::Geometry * testGeom)
+		if ( loc == geom::Location::INTERIOR)
+			return true;
+	return false;
+bool
+PreparedPolygonPredicate::isAnyTargetComponentInTestArea( const geom::Geometry * testGeom, const geom::Coordinate::ConstVect * targetRepPts)
+	algorithm::locate::PointOnGeometryLocator * piaLoc;
+	piaLoc = new algorithm::locate::SimplePointInAreaLocator( testGeom);
+	for ( size_t i = 0, ni = targetRepPts->size(); i < ni; i++ )
+		const geom::Coordinate * pt = (*targetRepPts)[ i ];
+		int loc = piaLoc->locate( pt);
+			return true;
+	return false;
+// public:
+ * $Log$
Property changes on: trunk/source/geom/prep/PreparedPolygonPredicate.cpp
   + text/plain
   + Id
   + native
More information about the geos-commits mailing list
