[geos-commits] r2156 - in trunk/tests/unit: algorithm algorithm/CGAlgorithms geom/prep operation
svn_geos at osgeo.org svn_geos at osgeo.org
Mon Aug 11 20:23:44 EDT 2008
Author: mloskot
Date: 2008-08-11 20:23:44 -0400 (Mon, 11 Aug 2008)
New Revision: 2156
   trunk/tests/unit/algorithm/CGAlgorithms/computeOrientationTest.cpp
   trunk/tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp
   trunk/tests/unit/algorithm/ConvexHullTest.cpp
   trunk/tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp
   trunk/tests/unit/operation/IsSimpleOpTest.cpp
Fixed EOL to LF in trunk/tests.
Modified: trunk/tests/unit/algorithm/CGAlgorithms/computeOrientationTest.cpp
--- trunk/tests/unit/algorithm/CGAlgorithms/computeOrientationTest.cpp	2008-08-12 00:09:34 UTC (rev 2155)
+++ trunk/tests/unit/algorithm/CGAlgorithms/computeOrientationTest.cpp	2008-08-12 00:23:44 UTC (rev 2156)
@@ -1,85 +1,85 @@
-// $Id$
-// Test Suite for CGAlgorithms::computeOrientation() function
-// Ported from JTS junit/algorithm/ComputeOrientationTest.java
-// tut
-#include <tut.h>
-// geos
-#include <geos/algorithm/CGAlgorithms.h>
-#include <geos/geom/Coordinate.h>
-#include <geos/geom/CoordinateSequence.h>
-#include <geos/geom/CoordinateArraySequence.h>
-#include <geos/geom/Geometry.h>
-#include <geos/geom/Polygon.h>
-#include <geos/io/WKTReader.h>
-// std
-#include <string>
-#include <memory>
-using namespace geos::geom;
-using namespace geos::algorithm;
-namespace tut
-    // Test Group
-    struct test_computeorientation_data
-        geos::io::WKTReader reader_;
-        test_computeorientation_data() {}
-    typedef test_group<test_computeorientation_data> group;
-    typedef group::object object;
-    group test_computeorientation_group("geos::algorithm::CGAlgorithms::computeOrientation");
-    // Test Cases
-    // 1 - Test CCW orientation
-    template<>
-    template<>
-    void object::test<1>()
-        const std::string wkt("LINESTRING ( 0 0, 0 1, 1 1)");
-        Geometry::AutoPtr geom(reader_.read(wkt));
-        CoordinateSequence::AutoPtr pts(geom->getCoordinates());
-        int const a = CGAlgorithms::computeOrientation(pts->getAt(0), pts->getAt(1), pts->getAt(2));
-        int const b = CGAlgorithms::computeOrientation(pts->getAt(0), pts->getAt(1), pts->getAt(2));
-        int const c = CGAlgorithms::computeOrientation(pts->getAt(0), pts->getAt(1), pts->getAt(2));
-        ensure_equals( a, b );
-        ensure_equals( a, c );
-    // 2 - Test CCW orientation
-    template<>
-    template<>
-    void object::test<2>()
-        Coordinate c1(1.0000000000004998, -7.989685402102996);
-        Coordinate c2(10.0, -7.004368924503866);
-        Coordinate c3(1.0000000000005, -7.989685402102996);
-        CoordinateArraySequence pts;
-        pts.add(c1);
-        pts.add(c2);
-        pts.add(c3);
-        int const a = CGAlgorithms::computeOrientation(pts[0], pts[1], pts[2]);
-        int const b = CGAlgorithms::computeOrientation(pts[0], pts[1], pts[2]);
-        int const c = CGAlgorithms::computeOrientation(pts[0], pts[1], pts[2]);
-} // namespace tut
+// $Id$
+// Test Suite for CGAlgorithms::computeOrientation() function
+// Ported from JTS junit/algorithm/ComputeOrientationTest.java
+// tut
+#include <tut.h>
+// geos
+#include <geos/algorithm/CGAlgorithms.h>
+#include <geos/geom/Coordinate.h>
+#include <geos/geom/CoordinateSequence.h>
+#include <geos/geom/CoordinateArraySequence.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/Polygon.h>
+#include <geos/io/WKTReader.h>
+// std
+#include <string>
+#include <memory>
+using namespace geos::geom;
+using namespace geos::algorithm;
+namespace tut
+    // Test Group
+    struct test_computeorientation_data
+        geos::io::WKTReader reader_;
+        test_computeorientation_data() {}
+    typedef test_group<test_computeorientation_data> group;
+    typedef group::object object;
+    group test_computeorientation_group("geos::algorithm::CGAlgorithms::computeOrientation");
+    // Test Cases
+    // 1 - Test CCW orientation
+    template<>
+    template<>
+    void object::test<1>()
+        const std::string wkt("LINESTRING ( 0 0, 0 1, 1 1)");
+        Geometry::AutoPtr geom(reader_.read(wkt));
+        CoordinateSequence::AutoPtr pts(geom->getCoordinates());
+        int const a = CGAlgorithms::computeOrientation(pts->getAt(0), pts->getAt(1), pts->getAt(2));
+        int const b = CGAlgorithms::computeOrientation(pts->getAt(0), pts->getAt(1), pts->getAt(2));
+        int const c = CGAlgorithms::computeOrientation(pts->getAt(0), pts->getAt(1), pts->getAt(2));
+        ensure_equals( a, b );
+        ensure_equals( a, c );
+    // 2 - Test CCW orientation
+    template<>
+    template<>
+    void object::test<2>()
+        Coordinate c1(1.0000000000004998, -7.989685402102996);
+        Coordinate c2(10.0, -7.004368924503866);
+        Coordinate c3(1.0000000000005, -7.989685402102996);
+        CoordinateArraySequence pts;
+        pts.add(c1);
+        pts.add(c2);
+        pts.add(c3);
+        int const a = CGAlgorithms::computeOrientation(pts[0], pts[1], pts[2]);
+        int const b = CGAlgorithms::computeOrientation(pts[0], pts[1], pts[2]);
+        int const c = CGAlgorithms::computeOrientation(pts[0], pts[1], pts[2]);
+} // namespace tut
Modified: trunk/tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp
--- trunk/tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp	2008-08-12 00:09:34 UTC (rev 2155)
+++ trunk/tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp	2008-08-12 00:23:44 UTC (rev 2156)
@@ -1,83 +1,83 @@
-// $Id$
-// Test Suite for CGAlgorithms::isCCW() function
-// Ported from JTS junit/algorithm/IsCCWTest.java
-// tut
-#include <tut.h>
-// geos
-// std
-#include <string>
-#include <memory>
-namespace tut
-    // Test Group
-    struct test_isccw_data
-	    typedef std::auto_ptr<geos::geom::Geometry> GeometryPtr;
-        test_isccw_data() {}
-    typedef test_group<test_isccw_data> group;
-    group test_isccw_group("geos::algorithm::CGAlgorithms::isCCW");
-    // Test Cases
-    // 1 - Test if coordinates of polygon are counter-clockwise oriented
-    template<>
-    template<>
-        const std::string wkt("POLYGON ((60 180, 140 240, 140 240, 140 240, 200 180, 120 120, 60 180))");
-		GeometryPtr geom(reader_.read(wkt));
-        bool isCCW = CGAlgorithms::isCCW(geom->getCoordinates());
-        ensure_equals( false, isCCW );
-    // 2 - Test if coordinates of polygon are counter-clockwise oriented
-    template<>
-    template<>
-        const std::string wkt("POLYGON ((60 180, 140 120, 100 180, 140 240, 60 180))");
-        ensure_equals( true, isCCW );
-    // 3 - Test the same polygon as in test No 2 but with duplicated top point
-    template<>
-    template<>
-    void object::test<3>()
-        const std::string wkt("POLYGON ((60 180, 140 120, 100 180, 140 240, 140 240, 60 180))");
-} // namespace tut
+// $Id$
+// Test Suite for CGAlgorithms::isCCW() function
+// Ported from JTS junit/algorithm/IsCCWTest.java
+// tut
+#include <tut.h>
+// geos
+// std
+#include <string>
+#include <memory>
+namespace tut
+    // Test Group
+    struct test_isccw_data
+	    typedef std::auto_ptr<geos::geom::Geometry> GeometryPtr;
+        test_isccw_data() {}
+    typedef test_group<test_isccw_data> group;
+    group test_isccw_group("geos::algorithm::CGAlgorithms::isCCW");
+    // Test Cases
+    // 1 - Test if coordinates of polygon are counter-clockwise oriented
+    template<>
+    template<>
+        const std::string wkt("POLYGON ((60 180, 140 240, 140 240, 140 240, 200 180, 120 120, 60 180))");
+		GeometryPtr geom(reader_.read(wkt));
+        bool isCCW = CGAlgorithms::isCCW(geom->getCoordinates());
+        ensure_equals( false, isCCW );
+    // 2 - Test if coordinates of polygon are counter-clockwise oriented
+    template<>
+    template<>
+        const std::string wkt("POLYGON ((60 180, 140 120, 100 180, 140 240, 60 180))");
+        ensure_equals( true, isCCW );
+    // 3 - Test the same polygon as in test No 2 but with duplicated top point
+    template<>
+    template<>
+    void object::test<3>()
+        const std::string wkt("POLYGON ((60 180, 140 120, 100 180, 140 240, 140 240, 60 180))");
+} // namespace tut
Modified: trunk/tests/unit/algorithm/ConvexHullTest.cpp
--- trunk/tests/unit/algorithm/ConvexHullTest.cpp	2008-08-12 00:09:34 UTC (rev 2155)
+++ trunk/tests/unit/algorithm/ConvexHullTest.cpp	2008-08-12 00:23:44 UTC (rev 2156)
@@ -1,191 +1,191 @@
-// $Id$
-// Test Suite for geos::algorithm::ConvexHull
-// Ported from JTS junit/algorithm/ConvexHullTest.java
-// tut
-#include <tut.h>
-#include <utility.h>
-// geos
-#include <geos/algorithm/ConvexHull.h>
-#include <geos/geom/LineString.h>
-#include <geos/geom/Dimension.h>
-#include <geos/geom/GeometryFactory.h>
-#include <geos/geom/PrecisionModel.h>
-// std
-#include <sstream>
-#include <memory>
-namespace geos {
-	namespace geom {
-		class Geometry;
-using namespace geos::geom; // for Location
-namespace tut
-	// Test Group
-	// dummy data, not used
-	struct test_convexhull_data
-		// Typedefs used as short names by test cases
-        typedef std::auto_ptr<geos::geom::Geometry> GeometryAPtr;
-        typedef std::auto_ptr<geos::geom::LineString> LineStringAPtr;
-        geos::geom::PrecisionModel pm_;
-        geos::geom::GeometryFactory factory_;
-        test_convexhull_data()
-			: pm_(1), factory_(&pm_, 0), reader_(&factory_)
-	typedef test_group<test_convexhull_data> group;
-    group test_convexhull_group("geos::algorithm::ConvexHull");
-	// Test Cases
-	// 1 - Test convex hull of linestring
-	template<>
-    template<>
-        using geos::geom::LineString;
-        using utility::dynamic_cast_auto_ptr;
-        GeometryAPtr lineGeom(reader_.read("LINESTRING (30 220, 240 220, 240 220)"));
-        LineStringAPtr line(dynamic_cast_auto_ptr<LineString>(lineGeom));
-        ensure(0 != line.get());
-        GeometryAPtr hullGeom(reader_.read("LINESTRING (30 220, 240 220)"));
-        LineStringAPtr convexHull(dynamic_cast_auto_ptr<LineString>(hullGeom));
-        ensure(0 != convexHull.get());
-        ensure( convexHull->equalsExact(line->convexHull()) );
-	// 2 - Test convex hull of multipoint
-	template<>
-    template<>
-        GeometryAPtr geom(reader_.read("MULTIPOINT (130 240, 130 240, 130 240, 570 240, 570 240, 570 240, 650 240)"));
-        ensure(0 != geom.get());
-        GeometryAPtr hullGeom(reader_.read("LINESTRING (130 240, 650 240)"));
-        ensure( convexHull->equalsExact(geom->convexHull()) );
-	// 3 - Test convex hull of multipoint
-	template<>
-    template<>
-        GeometryAPtr geom(reader_.read("MULTIPOINT (0 0, 0 0, 10 0)"));
-        GeometryAPtr hullGeom(reader_.read("LINESTRING (0 0, 10 0)"));
-	// 4 - Test convex hull of multipoint
-	template<>
-    template<>
-    void object::test<4>()
-        GeometryAPtr geom(reader_.read("MULTIPOINT (0 0, 10 0, 10 0)"));
-	// 5 - Test convex hull of multipoint
-	template<>
-    template<>
-    void object::test<5>()
-        GeometryAPtr geom(reader_.read("MULTIPOINT (0 0, 5 0, 10 0)"));
-	// 6 - Test convex hull of multipoint exported to string form
-	template<>
-    template<>
-    void object::test<6>()
-        GeometryAPtr geom(reader_.read("MULTIPOINT (0 0, 5 1, 10 0)"));
-        GeometryAPtr hullGeom(geom->convexHull());
-        ensure(0 != hullGeom.get());
-        GeometryAPtr expectedHull(reader_.read("POLYGON ((0 0, 5 1, 10 0, 0 0))"));
-        ensure(0 != expectedHull.get());
-        ensure_equals( hullGeom->toString(), expectedHull->toString() );
-	// 7 - Test convex hull of multipoint
-	template<>
-    template<>
-    void object::test<7>()
-        GeometryAPtr geom(reader_.read("MULTIPOINT (0 0, 0 0, 5 0, 5 0, 10 0, 10 0)"));
-} // namespace tut
+// $Id$
+// Test Suite for geos::algorithm::ConvexHull
+// Ported from JTS junit/algorithm/ConvexHullTest.java
+// tut
+#include <tut.h>
+#include <utility.h>
+// geos
+#include <geos/algorithm/ConvexHull.h>
+#include <geos/geom/LineString.h>
+#include <geos/geom/Dimension.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/PrecisionModel.h>
+// std
+#include <sstream>
+#include <memory>
+namespace geos {
+	namespace geom {
+		class Geometry;
+using namespace geos::geom; // for Location
+namespace tut
+	// Test Group
+	// dummy data, not used
+	struct test_convexhull_data
+		// Typedefs used as short names by test cases
+        typedef std::auto_ptr<geos::geom::Geometry> GeometryAPtr;
+        typedef std::auto_ptr<geos::geom::LineString> LineStringAPtr;
+        geos::geom::PrecisionModel pm_;
+        geos::geom::GeometryFactory factory_;
+        test_convexhull_data()
+			: pm_(1), factory_(&pm_, 0), reader_(&factory_)
+	typedef test_group<test_convexhull_data> group;
+    group test_convexhull_group("geos::algorithm::ConvexHull");
+	// Test Cases
+	// 1 - Test convex hull of linestring
+	template<>
+    template<>
+        using geos::geom::LineString;
+        using utility::dynamic_cast_auto_ptr;
+        GeometryAPtr lineGeom(reader_.read("LINESTRING (30 220, 240 220, 240 220)"));
+        LineStringAPtr line(dynamic_cast_auto_ptr<LineString>(lineGeom));
+        ensure(0 != line.get());
+        GeometryAPtr hullGeom(reader_.read("LINESTRING (30 220, 240 220)"));
+        LineStringAPtr convexHull(dynamic_cast_auto_ptr<LineString>(hullGeom));
+        ensure(0 != convexHull.get());
+        ensure( convexHull->equalsExact(line->convexHull()) );
+	// 2 - Test convex hull of multipoint
+	template<>
+    template<>
+        GeometryAPtr geom(reader_.read("MULTIPOINT (130 240, 130 240, 130 240, 570 240, 570 240, 570 240, 650 240)"));
+        ensure(0 != geom.get());
+        GeometryAPtr hullGeom(reader_.read("LINESTRING (130 240, 650 240)"));
+        ensure( convexHull->equalsExact(geom->convexHull()) );
+	// 3 - Test convex hull of multipoint
+	template<>
+    template<>
+        GeometryAPtr geom(reader_.read("MULTIPOINT (0 0, 0 0, 10 0)"));
+        GeometryAPtr hullGeom(reader_.read("LINESTRING (0 0, 10 0)"));
+	// 4 - Test convex hull of multipoint
+	template<>
+    template<>
+    void object::test<4>()
+        GeometryAPtr geom(reader_.read("MULTIPOINT (0 0, 10 0, 10 0)"));
+	// 5 - Test convex hull of multipoint
+	template<>
+    template<>
+    void object::test<5>()
+        GeometryAPtr geom(reader_.read("MULTIPOINT (0 0, 5 0, 10 0)"));
+	// 6 - Test convex hull of multipoint exported to string form
+	template<>
+    template<>
+    void object::test<6>()
+        GeometryAPtr geom(reader_.read("MULTIPOINT (0 0, 5 1, 10 0)"));
+        GeometryAPtr hullGeom(geom->convexHull());
+        ensure(0 != hullGeom.get());
+        GeometryAPtr expectedHull(reader_.read("POLYGON ((0 0, 5 1, 10 0, 0 0))"));
+        ensure(0 != expectedHull.get());
+        ensure_equals( hullGeom->toString(), expectedHull->toString() );
+	// 7 - Test convex hull of multipoint
+	template<>
+    template<>
+    void object::test<7>()
+        GeometryAPtr geom(reader_.read("MULTIPOINT (0 0, 0 0, 5 0, 5 0, 10 0, 10 0)"));
+} // namespace tut
Modified: trunk/tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp
--- trunk/tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp	2008-08-12 00:09:34 UTC (rev 2155)
+++ trunk/tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp	2008-08-12 00:23:44 UTC (rev 2156)
@@ -43,6 +43,7 @@
         prep::PreparedGeometryFactory pgf;
+        (void)pgf;
     // Test passing null-pointer to prepare static method
@@ -60,6 +61,7 @@
+        (void)pgf;
         // FIXME: null pointer throws segfault (Ticket #197)
         // ensure(0 == pgf.create(0));
Modified: trunk/tests/unit/operation/IsSimpleOpTest.cpp
--- trunk/tests/unit/operation/IsSimpleOpTest.cpp	2008-08-12 00:09:34 UTC (rev 2155)
+++ trunk/tests/unit/operation/IsSimpleOpTest.cpp	2008-08-12 00:23:44 UTC (rev 2156)
@@ -1,102 +1,102 @@
-// $Id$
-// Test Suite for geos::operation::IsSimpleOp class
-// Ported from JTS junit/operation/IsSimpleTest.java
-// tut
-#include <tut.h>
-// geos
-#include <geos/operation/IsSimpleOp.h>
-// std
-#include <string>
-#include <memory>
-using namespace geos::operation;
-namespace tut
-    // Test Group
-    struct test_issimpleop_data
-        double tolerance_;
-        test_issimpleop_data()
-			: pm_(1), factory_(&pm_, 0), reader_(&factory_), tolerance_(0.00005)
-    typedef test_group<test_issimpleop_data> group;
-    group test_issimpleop_group("geos::operation::IsSimpleOp");
-    // Test Cases
-    // 1 - Test cross
-    template<>
-    template<>
-        const std::string wkt("MULTILINESTRING ((20 120, 120 20), (20 20, 120 120))");
-        const Geometry::AutoPtr geom(reader_.read(wkt));
-        // TODO - mloskot: What about support of new features of BoundaryNodeRule, in JTS
-        IsSimpleOp op;
-        bool simple = op.isSimpleLinearGeometry(geom.get());
-        ensure( false == simple );
-        // There are missing features not (re)implemented in IsSimpleOp, in GEOS.
-        // So, all tests in this suite have been simplified in comparison to original JTS tests.
-        //Coordinate loc(70, 70);
-        //Coordinate nonSimpleLoc = op.getNonSimpleLocation();
-        //loc.distance(nonSimpleLoc) < TOLERANCE
-    // 2 - Test MultiLineString with ring touching at the end point
-    template<>
-    template<>
-        const std::string wkt("MULTILINESTRING ((100 100, 20 20, 200 20, 100 100), (100 200, 100 100))");
-        IsSimpleOp op;
-    // 3 - Test simple LineString
-    template<>
-    template<>
-        const std::string wkt("LINESTRING (100 100, 20 20, 200 20, 100 100)");
-        IsSimpleOp op;
-        ensure( true == simple );
-} // namespace tut
+// $Id$
+// Test Suite for geos::operation::IsSimpleOp class
+// Ported from JTS junit/operation/IsSimpleTest.java
+// tut
+#include <tut.h>
+// geos
+#include <geos/operation/IsSimpleOp.h>
+// std
+#include <string>
+#include <memory>
+using namespace geos::operation;
+namespace tut
+    // Test Group
+    struct test_issimpleop_data
+        double tolerance_;
+        test_issimpleop_data()
+			: pm_(1), factory_(&pm_, 0), reader_(&factory_), tolerance_(0.00005)
+    typedef test_group<test_issimpleop_data> group;
+    group test_issimpleop_group("geos::operation::IsSimpleOp");
+    // Test Cases
+    // 1 - Test cross
+    template<>
+    template<>
+        const std::string wkt("MULTILINESTRING ((20 120, 120 20), (20 20, 120 120))");
+        const Geometry::AutoPtr geom(reader_.read(wkt));
+        // TODO - mloskot: What about support of new features of BoundaryNodeRule, in JTS
+        IsSimpleOp op;
+        bool simple = op.isSimpleLinearGeometry(geom.get());
+        ensure( false == simple );
+        // There are missing features not (re)implemented in IsSimpleOp, in GEOS.
+        // So, all tests in this suite have been simplified in comparison to original JTS tests.
+        //Coordinate loc(70, 70);
+        //Coordinate nonSimpleLoc = op.getNonSimpleLocation();
+        //loc.distance(nonSimpleLoc) < TOLERANCE
+    // 2 - Test MultiLineString with ring touching at the end point
+    template<>
+    template<>
+        const std::string wkt("MULTILINESTRING ((100 100, 20 20, 200 20, 100 100), (100 200, 100 100))");
+        IsSimpleOp op;
+    // 3 - Test simple LineString
+    template<>
+    template<>
+        const std::string wkt("LINESTRING (100 100, 20 20, 200 20, 100 100)");
+        IsSimpleOp op;
+        ensure( true == simple );
+} // namespace tut
More information about the geos-commits mailing list
