[geos-commits] r2158 - trunk/source/geom/prep
svn_geos at osgeo.org svn_geos at osgeo.org
Mon Aug 18 12:24:18 EDT 2008
Author: mloskot
Date: 2008-08-18 12:24:18 -0400 (Mon, 18 Aug 2008)
New Revision: 2158
   trunk/source/geom/prep/AbstractPreparedPolygonContains.cpp
   trunk/source/geom/prep/BasicPreparedGeometry.cpp
   trunk/source/geom/prep/PreparedGeometry.cpp
   trunk/source/geom/prep/PreparedGeometryFactory.cpp
   trunk/source/geom/prep/PreparedLineString.cpp
   trunk/source/geom/prep/PreparedLineStringIntersects.cpp
   trunk/source/geom/prep/PreparedPoint.cpp
   trunk/source/geom/prep/PreparedPolygon.cpp
   trunk/source/geom/prep/PreparedPolygonContains.cpp
   trunk/source/geom/prep/PreparedPolygonContainsProperly.cpp
   trunk/source/geom/prep/PreparedPolygonCovers.cpp
   trunk/source/geom/prep/PreparedPolygonIntersects.cpp
   trunk/source/geom/prep/PreparedPolygonPredicate.cpp
geom/prep: Refactored kamikaze casts to more readable form. Fixed svn:keywords.
Modified: trunk/source/geom/prep/AbstractPreparedPolygonContains.cpp
--- trunk/source/geom/prep/AbstractPreparedPolygonContains.cpp	2008-08-12 00:25:16 UTC (rev 2157)
+++ trunk/source/geom/prep/AbstractPreparedPolygonContains.cpp	2008-08-18 16:24:18 UTC (rev 2158)
@@ -1,5 +1,5 @@
- * $Id:
+ * $Id$
  * GEOS - Geometry Engine Open Source
  * http://geos.refractions.net
Modified: trunk/source/geom/prep/BasicPreparedGeometry.cpp
--- trunk/source/geom/prep/BasicPreparedGeometry.cpp	2008-08-12 00:25:16 UTC (rev 2157)
+++ trunk/source/geom/prep/BasicPreparedGeometry.cpp	2008-08-18 16:24:18 UTC (rev 2158)
@@ -1,5 +1,5 @@
- * $Id:
+ * $Id$
Modified: trunk/source/geom/prep/PreparedGeometry.cpp
--- trunk/source/geom/prep/PreparedGeometry.cpp	2008-08-12 00:25:16 UTC (rev 2157)
+++ trunk/source/geom/prep/PreparedGeometry.cpp	2008-08-18 16:24:18 UTC (rev 2158)
@@ -1,5 +1,5 @@
- * $Id:
+ * $Id$
Modified: trunk/source/geom/prep/PreparedGeometryFactory.cpp
--- trunk/source/geom/prep/PreparedGeometryFactory.cpp	2008-08-12 00:25:16 UTC (rev 2157)
+++ trunk/source/geom/prep/PreparedGeometryFactory.cpp	2008-08-18 16:24:18 UTC (rev 2158)
@@ -1,5 +1,5 @@
- * $Id:
+ * $Id$
Modified: trunk/source/geom/prep/PreparedLineString.cpp
--- trunk/source/geom/prep/PreparedLineString.cpp	2008-08-12 00:25:16 UTC (rev 2157)
+++ trunk/source/geom/prep/PreparedLineString.cpp	2008-08-18 16:24:18 UTC (rev 2158)
@@ -1,5 +1,5 @@
- * $Id:
+ * $Id$
@@ -46,9 +46,14 @@
 bool
 PreparedLineString::intersects(const geom::Geometry * g) const
-	if (! envelopesIntersect(g)) return false;
-	return PreparedLineStringIntersects::intersects( *(const_cast<PreparedLineString*>(this)), g);
+	if (! envelopesIntersect(g))
+        return false;
+    PreparedLineString& prep = *(const_cast<PreparedLineString*>(this));
+    return PreparedLineStringIntersects::intersects(prep, g);
 } // namespace geos.geom.prep
@@ -59,3 +64,4 @@
  * $Log$
Modified: trunk/source/geom/prep/PreparedLineStringIntersects.cpp
--- trunk/source/geom/prep/PreparedLineStringIntersects.cpp	2008-08-12 00:25:16 UTC (rev 2157)
+++ trunk/source/geom/prep/PreparedLineStringIntersects.cpp	2008-08-18 16:24:18 UTC (rev 2158)
@@ -1,5 +1,5 @@
- * $Id:
+ * $Id$
Modified: trunk/source/geom/prep/PreparedPoint.cpp
--- trunk/source/geom/prep/PreparedPoint.cpp	2008-08-12 00:25:16 UTC (rev 2157)
+++ trunk/source/geom/prep/PreparedPoint.cpp	2008-08-18 16:24:18 UTC (rev 2158)
@@ -1,5 +1,5 @@
- * $Id:
+ * $Id$
Modified: trunk/source/geom/prep/PreparedPolygon.cpp
--- trunk/source/geom/prep/PreparedPolygon.cpp	2008-08-12 00:25:16 UTC (rev 2157)
+++ trunk/source/geom/prep/PreparedPolygon.cpp	2008-08-18 16:24:18 UTC (rev 2158)
@@ -1,5 +1,5 @@
- * $Id:
+ * $Id$
@@ -91,7 +91,12 @@
     // optimization for rectangles
     if ( isRectangle )
-		return operation::predicate::RectangleContains::contains( *((geom::Polygon *)&getGeometry()), *g);
+        geom::Geometry const& geom = getGeometry();
+        geom::Polygon const& poly = static_cast<geom::Polygon const&>(geom);
+        return operation::predicate::RectangleContains::contains(poly, *g);
 	return PreparedPolygonContains::contains( this, g);
@@ -132,7 +137,12 @@
     if ( isRectangle )
-		return operation::predicate::RectangleIntersects::intersects( *((geom::Polygon *)&getGeometry()), *g);
+        return operation::predicate::RectangleIntersects::intersects(poly, *g);
 	return PreparedPolygonIntersects::intersects( this, g);
@@ -145,3 +155,4 @@
  * $Log$
Modified: trunk/source/geom/prep/PreparedPolygonContains.cpp
--- trunk/source/geom/prep/PreparedPolygonContains.cpp	2008-08-12 00:25:16 UTC (rev 2157)
+++ trunk/source/geom/prep/PreparedPolygonContains.cpp	2008-08-18 16:24:18 UTC (rev 2158)
@@ -1,5 +1,5 @@
- * $Id:
+ * $Id$
Modified: trunk/source/geom/prep/PreparedPolygonContainsProperly.cpp
--- trunk/source/geom/prep/PreparedPolygonContainsProperly.cpp	2008-08-12 00:25:16 UTC (rev 2157)
+++ trunk/source/geom/prep/PreparedPolygonContainsProperly.cpp	2008-08-18 16:24:18 UTC (rev 2158)
@@ -1,5 +1,5 @@
- * $Id:
+ * $Id$
Modified: trunk/source/geom/prep/PreparedPolygonCovers.cpp
--- trunk/source/geom/prep/PreparedPolygonCovers.cpp	2008-08-12 00:25:16 UTC (rev 2157)
+++ trunk/source/geom/prep/PreparedPolygonCovers.cpp	2008-08-18 16:24:18 UTC (rev 2158)
@@ -1,5 +1,5 @@
- * $Id:
+ * $Id$
Modified: trunk/source/geom/prep/PreparedPolygonIntersects.cpp
--- trunk/source/geom/prep/PreparedPolygonIntersects.cpp	2008-08-12 00:25:16 UTC (rev 2157)
+++ trunk/source/geom/prep/PreparedPolygonIntersects.cpp	2008-08-18 16:24:18 UTC (rev 2158)
@@ -1,5 +1,5 @@
- * $Id:
+ * $Id$
Modified: trunk/source/geom/prep/PreparedPolygonPredicate.cpp
--- trunk/source/geom/prep/PreparedPolygonPredicate.cpp	2008-08-12 00:25:16 UTC (rev 2157)
+++ trunk/source/geom/prep/PreparedPolygonPredicate.cpp	2008-08-18 16:24:18 UTC (rev 2158)
@@ -1,5 +1,5 @@
- * $Id:
+ * $Id$
More information about the geos-commits mailing list
