[geos-commits] r2161 - in trunk/source: algorithm algorithm/locate geom/util index/intervalrtree noding
svn_geos at osgeo.org svn_geos at osgeo.org
Mon Aug 18 12:29:09 EDT 2008
Author: mloskot
Date: 2008-08-18 12:29:09 -0400 (Mon, 18 Aug 2008)
New Revision: 2161
   trunk/source/algorithm/RayCrossingCounter.cpp
   trunk/source/algorithm/locate/IndexedPointInAreaLocator.cpp
   trunk/source/algorithm/locate/PointOnGeometryLocator.cpp
   trunk/source/geom/util/ComponentCoordinateExtracter.cpp
   trunk/source/index/intervalrtree/IntervalRTreeBranchNode.cpp
   trunk/source/index/intervalrtree/IntervalRTreeLeafNode.cpp
   trunk/source/index/intervalrtree/IntervalRTreeNode.cpp
   trunk/source/index/intervalrtree/SortedPackedIntervalRTree.cpp
   trunk/source/noding/FastSegmentSetIntersectionFinder.cpp
   trunk/source/noding/MCIndexSegmentSetMutualIntersector.cpp
   trunk/source/noding/NodedSegmentString.cpp
   trunk/source/noding/SegmentIntersectionDetector.cpp
   trunk/source/noding/SegmentStringUtil.cpp
Fixed svn:keywords.
Modified: trunk/source/algorithm/RayCrossingCounter.cpp
--- trunk/source/algorithm/RayCrossingCounter.cpp	2008-08-18 16:27:58 UTC (rev 2160)
+++ trunk/source/algorithm/RayCrossingCounter.cpp	2008-08-18 16:29:09 UTC (rev 2161)
@@ -1,5 +1,5 @@
- * $Id:
+ * $Id$
  * GEOS - Geometry Engine Open Source
  * http://geos.refractions.net
Modified: trunk/source/algorithm/locate/IndexedPointInAreaLocator.cpp
--- trunk/source/algorithm/locate/IndexedPointInAreaLocator.cpp	2008-08-18 16:27:58 UTC (rev 2160)
+++ trunk/source/algorithm/locate/IndexedPointInAreaLocator.cpp	2008-08-18 16:29:09 UTC (rev 2161)
@@ -1,5 +1,5 @@
- * $Id:
+ * $Id$
Modified: trunk/source/algorithm/locate/PointOnGeometryLocator.cpp
--- trunk/source/algorithm/locate/PointOnGeometryLocator.cpp	2008-08-18 16:27:58 UTC (rev 2160)
+++ trunk/source/algorithm/locate/PointOnGeometryLocator.cpp	2008-08-18 16:29:09 UTC (rev 2161)
@@ -1,5 +1,5 @@
- * $Id:
+ * $Id$
Modified: trunk/source/geom/util/ComponentCoordinateExtracter.cpp
--- trunk/source/geom/util/ComponentCoordinateExtracter.cpp	2008-08-18 16:27:58 UTC (rev 2160)
+++ trunk/source/geom/util/ComponentCoordinateExtracter.cpp	2008-08-18 16:29:09 UTC (rev 2161)
@@ -1,5 +1,5 @@
- * $Id:
+ * $Id$
Modified: trunk/source/index/intervalrtree/IntervalRTreeBranchNode.cpp
--- trunk/source/index/intervalrtree/IntervalRTreeBranchNode.cpp	2008-08-18 16:27:58 UTC (rev 2160)
+++ trunk/source/index/intervalrtree/IntervalRTreeBranchNode.cpp	2008-08-18 16:29:09 UTC (rev 2161)
@@ -1,5 +1,5 @@
- * $Id:
+ * $Id$
Modified: trunk/source/index/intervalrtree/IntervalRTreeLeafNode.cpp
--- trunk/source/index/intervalrtree/IntervalRTreeLeafNode.cpp	2008-08-18 16:27:58 UTC (rev 2160)
+++ trunk/source/index/intervalrtree/IntervalRTreeLeafNode.cpp	2008-08-18 16:29:09 UTC (rev 2161)
@@ -1,5 +1,5 @@
- * $Id:
+ * $Id$
Modified: trunk/source/index/intervalrtree/IntervalRTreeNode.cpp
--- trunk/source/index/intervalrtree/IntervalRTreeNode.cpp	2008-08-18 16:27:58 UTC (rev 2160)
+++ trunk/source/index/intervalrtree/IntervalRTreeNode.cpp	2008-08-18 16:29:09 UTC (rev 2161)
@@ -1,5 +1,5 @@
- * $Id:
+ * $Id$
Modified: trunk/source/index/intervalrtree/SortedPackedIntervalRTree.cpp
--- trunk/source/index/intervalrtree/SortedPackedIntervalRTree.cpp	2008-08-18 16:27:58 UTC (rev 2160)
+++ trunk/source/index/intervalrtree/SortedPackedIntervalRTree.cpp	2008-08-18 16:29:09 UTC (rev 2161)
@@ -1,5 +1,5 @@
- * $Id:
+ * $Id$
Modified: trunk/source/noding/FastSegmentSetIntersectionFinder.cpp
--- trunk/source/noding/FastSegmentSetIntersectionFinder.cpp	2008-08-18 16:27:58 UTC (rev 2160)
+++ trunk/source/noding/FastSegmentSetIntersectionFinder.cpp	2008-08-18 16:29:09 UTC (rev 2161)
@@ -1,5 +1,5 @@
- * $Id:
+ * $Id$
Modified: trunk/source/noding/MCIndexSegmentSetMutualIntersector.cpp
--- trunk/source/noding/MCIndexSegmentSetMutualIntersector.cpp	2008-08-18 16:27:58 UTC (rev 2160)
+++ trunk/source/noding/MCIndexSegmentSetMutualIntersector.cpp	2008-08-18 16:29:09 UTC (rev 2161)
@@ -1,5 +1,5 @@
- * $Id:
+ * $Id$
Modified: trunk/source/noding/NodedSegmentString.cpp
--- trunk/source/noding/NodedSegmentString.cpp	2008-08-18 16:27:58 UTC (rev 2160)
+++ trunk/source/noding/NodedSegmentString.cpp	2008-08-18 16:29:09 UTC (rev 2161)
@@ -1,5 +1,5 @@
- * $Id:
+ * $Id$
Modified: trunk/source/noding/SegmentIntersectionDetector.cpp
--- trunk/source/noding/SegmentIntersectionDetector.cpp	2008-08-18 16:27:58 UTC (rev 2160)
+++ trunk/source/noding/SegmentIntersectionDetector.cpp	2008-08-18 16:29:09 UTC (rev 2161)
@@ -1,5 +1,5 @@
- * $Id:
+ * $Id$
Modified: trunk/source/noding/SegmentStringUtil.cpp
--- trunk/source/noding/SegmentStringUtil.cpp	2008-08-18 16:27:58 UTC (rev 2160)
+++ trunk/source/noding/SegmentStringUtil.cpp	2008-08-18 16:29:09 UTC (rev 2161)
@@ -1,5 +1,5 @@
- * $Id:
+ * $Id$
More information about the geos-commits mailing list
