[geos-commits] r2166 - trunk/tests/unit/algorithm/CGAlgorithms
svn_geos at osgeo.org svn_geos at osgeo.org
Mon Aug 18 20:05:04 EDT 2008
Author: mloskot
Date: 2008-08-18 20:05:04 -0400 (Mon, 18 Aug 2008)
New Revision: 2166
   trunk/tests/unit/algorithm/CGAlgorithms/isPointInRingTest.cpp
tests/unit/algorithm/CGAlgorithms: Fixed memory leaks.
Modified: trunk/tests/unit/algorithm/CGAlgorithms/isPointInRingTest.cpp
--- trunk/tests/unit/algorithm/CGAlgorithms/isPointInRingTest.cpp	2008-08-18 23:45:34 UTC (rev 2165)
+++ trunk/tests/unit/algorithm/CGAlgorithms/isPointInRingTest.cpp	2008-08-19 00:05:04 UTC (rev 2166)
@@ -9,8 +9,9 @@
 // GEOS
 #include <geos/algorithm/CGAlgorithms.h>
 #include <geos/geom/Polygon.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/CoordinateSequence.h>
 #include <geos/geom/Coordinate.h>
-#include <geos/geom/Geometry.h>
 #include <geos/io/WKTReader.h>
 using namespace geos::algorithm;
@@ -25,9 +26,20 @@
 	    typedef std::auto_ptr<geos::geom::Geometry> GeomPtr;
+        geos::geom::CoordinateSequence* cs_;
         geos::io::WKTReader reader_;
-        test_ispointinring_data() {}
+        test_ispointinring_data()
+            : cs_(0)
+            assert(0 == cs_);
+        ~test_ispointinring_data()
+            delete cs_;
+            cs_ = 0;
     typedef test_group<test_ispointinring_data> group;
@@ -49,7 +61,8 @@
         geos::geom::Coordinate pt(10, 10);
-        bool isInRing = CGAlgorithms::isPointInRing(pt, geom->getCoordinates());
+        cs_ = geom->getCoordinates();
+        bool isInRing = CGAlgorithms::isPointInRing(pt, cs_);
         ensure_equals( true, isInRing );
@@ -66,10 +79,11 @@
         geos::geom::Coordinate pt(0, 0);
+} // namespace tut
-} // namespace tut
More information about the geos-commits mailing list
