[geos-commits] r2196 - in trunk/source: headers/geos/noding noding
svn_geos at osgeo.org svn_geos at osgeo.org
Sat Oct 4 14:14:09 EDT 2008
Author: pramsey
Date: 2008-10-04 14:14:09 -0400 (Sat, 04 Oct 2008)
New Revision: 2196
   trunk/source/headers/geos/noding/MCIndexSegmentSetMutualIntersector.h
   trunk/source/noding/MCIndexSegmentSetMutualIntersector.cpp
Memory leak fix for prepared geometry, from Hartmut Kaiser. (#207)
Modified: trunk/source/headers/geos/noding/MCIndexSegmentSetMutualIntersector.h
--- trunk/source/headers/geos/noding/MCIndexSegmentSetMutualIntersector.h	2008-09-29 19:24:06 UTC (rev 2195)
+++ trunk/source/headers/geos/noding/MCIndexSegmentSetMutualIntersector.h	2008-10-04 18:14:09 UTC (rev 2196)
@@ -98,7 +98,11 @@
 	int processCounter;
 	// statistics
 	int nOverlaps;
+	// memory management helper
+      typedef std::vector<std::vector<index::chain::MonotoneChain*>*> chainstore_mm_type;
+      chainstore_mm_type chainStore;
 	void addToIndex( SegmentString * segStr);
 	void intersectChains();
Modified: trunk/source/noding/MCIndexSegmentSetMutualIntersector.cpp
--- trunk/source/noding/MCIndexSegmentSetMutualIntersector.cpp	2008-09-29 19:24:06 UTC (rev 2195)
+++ trunk/source/noding/MCIndexSegmentSetMutualIntersector.cpp	2008-10-04 18:14:09 UTC (rev 2196)
@@ -39,25 +39,14 @@
     std::vector<MonotoneChain*>* segChains = 0;
     segChains = MonotoneChainBuilder::getChains(segStr->getCoordinates(), segStr);
+    chainStore.push_back(segChains);
     for (std::size_t i = 0, n = segChains->size(); i < n; i++)
         MonotoneChain * mc = (*segChains)[i];
         mc->setId(indexCounter++);
         index->insert(mc->getEnvelope(), mc);
-    // FIXME - BWJ: seems to cause some tests of prepared predicates to fail, but leaving
-    // this out probably causes a memory leak.  more research needed
-    // NOTE - mloskot: segChains can not be deleted because index composed above will later
-    // use (refer to) MonotoneChain objects, elements originally stored in segChains collection.
-    // However, then segChains allocated by MonotoneChainBuilder::getChains gets never deallocated,
-    // so memory leaks. This looks like a design bug and not-synchronized lifetime of related objects.
-    // This bug really seems not to be easy to fix.
-    //for (std::vector<MonotoneChain*>::iterator it = segChains->begin(), e = segChains->end(); it != e; ++it)
-    //	delete *it;
-    //delete segChains;
 void
@@ -90,14 +79,14 @@
     for (std::size_t i = 0, ni = segChains->size(); i < ni; i++)
         MonotoneChain* mc = (*segChains)[i];
         mc->setId( processCounter++ );
         monoChains->push_back(mc);
-    delete segChains;
@@ -116,11 +105,19 @@
 MCIndexSegmentSetMutualIntersector::~MCIndexSegmentSetMutualIntersector()
     delete index;
-    for (std::size_t i = 0, ni = monoChains->size(); i < ni; i++ )
-        delete (*monoChains)[ i ];
     delete monoChains;
+    chainstore_mm_type::iterator end = chainStore.end();
+    for (chainstore_mm_type::iterator it = chainStore.begin(); it != end; ++it)
+        typedef std::vector<index::chain::MonotoneChain*> chainstore_type;
+        chainstore_type::iterator csend = (*it)->end();
+        for (chainstore_type::iterator csit = (*it)->begin(); csit != csend; ++csit)
+            delete *csit;
+        delete *it;
 void
More information about the geos-commits mailing list
