[geos-commits] r2186 - trunk/build/msvc80/geos_unit
svn_geos at osgeo.org svn_geos at osgeo.org
Tue Sep 16 16:55:42 EDT 2008
Author: mloskot
Date: 2008-09-16 16:55:42 -0400 (Tue, 16 Sep 2008)
New Revision: 2186
   trunk/build/msvc80/geos_unit/geos_unit.vcproj
Added PreparedGeometryFactoryTest to geos_unit.vcproj.
Modified: trunk/build/msvc80/geos_unit/geos_unit.vcproj
--- trunk/build/msvc80/geos_unit/geos_unit.vcproj	2008-09-16 20:15:33 UTC (rev 2185)
+++ trunk/build/msvc80/geos_unit/geos_unit.vcproj	2008-09-16 20:55:42 UTC (rev 2186)
@@ -1,7 +1,7 @@
 <?xml version="1.0" encoding="windows-1250"?>
 <VisualStudioProject
 	ProjectType="Visual C++"
-	Version="8.00"
+	Version="8,00"
 	Name="geos_unit"
 	ProjectGUID="{30461863-CCA4-4A8F-8BEE-1AB57060D5C2}"
 	RootNamespace="geos_unit"
@@ -92,7 +92,7 @@
 			<Tool
 				Name="VCPostBuildEventTool"
 				Description="Running regression tests using $(ProjectName)d.exe..."
-				CommandLine="cd $(OutDir)&#x0D;&#x0A;$(ProjectName)d.exe"
+				CommandLine="cd $(OutDir)&#x0D;&#x0A;$(ProjectName)d.exe&#x0D;&#x0A;"
 		</Configuration>
 		<Configuration
@@ -280,6 +280,14 @@
 				</File>
 			</Filter>
+			<Filter
+				Name="prep"
+				<File
+					RelativePath="..\..\..\tests\unit\geom\prep\PreparedGeometryFactoryTest.cpp"
+				</File>
+			</Filter>
 		</Filter>
 		<Filter
 			Name="noding"
More information about the geos-commits mailing list
