[geos-commits] r2312 - in trunk/source: algorithm headers/geos/algorithm
svn_geos at osgeo.org svn_geos at osgeo.org
Tue Apr 7 04:14:25 EDT 2009
Author: strk
Date: 2009-04-07 04:14:25 -0400 (Tue, 07 Apr 2009)
New Revision: 2312
   trunk/source/algorithm/HCoordinate.cpp
   trunk/source/headers/geos/algorithm/HCoordinate.h
Sync HCoordinate class to JTS-1.9 (rev 1.18)
Modified: trunk/source/algorithm/HCoordinate.cpp
--- trunk/source/algorithm/HCoordinate.cpp	2009-04-03 15:27:05 UTC (rev 2311)
+++ trunk/source/algorithm/HCoordinate.cpp	2009-04-07 08:14:25 UTC (rev 2312)
@@ -14,7 +14,7 @@
- * Last port: algorithm/HCoordinate.java rev. 1.17 (JTS-1.7)
+ * Last port: algorithm/HCoordinate.java rev. 1.18 (JTS-1.9)
@@ -42,6 +42,74 @@
 namespace geos {
 namespace algorithm { // geos.algorithm
+///*public static*/
+//void
+//HCoordinate::OLDintersection(const Coordinate &p1, const Coordinate &p2,
+//	const Coordinate &q1, const Coordinate &q2, Coordinate &ret)
+//#if GEOS_DEBUG
+//	cerr << __FUNCTION__ << ":" << endl
+//	     << setprecision(20)
+//	     << " p1: " << p1 << endl
+//	     << " p2: " << p2 << endl
+//	     << " q1: " << q1 << endl
+//	     << " q2: " << q2 << endl;
+//#endif
+//        HCoordinate hc1p1(p1);
+//#if GEOS_DEBUG
+//	cerr << "HCoordinate(p1): "
+//	     << hc1p1 << endl;
+//#endif
+//        HCoordinate hc1p2(p2);
+//#if GEOS_DEBUG
+//	cerr << "HCoordinate(p2): "
+//	     << hc1p2 << endl;
+//#endif
+//        HCoordinate l1(hc1p1, hc1p2);
+//#if GEOS_DEBUG
+//	cerr << "L1 - HCoordinate(HCp1, HCp2): "
+//	     << l1 << endl;
+//#endif
+//        HCoordinate hc2q1(q1);
+//#if GEOS_DEBUG
+//	cerr << "HCoordinate(q1): "
+//	     << hc2q1 << endl;
+//#endif
+//        HCoordinate hc2q2(q2);
+//#if GEOS_DEBUG
+//	cerr << "HCoordinate(q2): "
+//	     << hc2q2 << endl;
+//#endif
+//        HCoordinate l2(hc2q1, hc2q2);
+//#if GEOS_DEBUG
+//	cerr << "L2 - HCoordinate(HCq1, HCq2): "
+//	     << l2 << endl;
+//#endif
+//        HCoordinate intHCoord(l1, l2);
+//#if GEOS_DEBUG
+//	cerr << "HCoordinate(L1, L2): "
+//	     << intHCoord << endl;
+//#endif
+//        intHCoord.getCoordinate(ret);
 /*public static*/
 void
 HCoordinate::intersection(const Coordinate &p1, const Coordinate &p2,
@@ -57,57 +125,29 @@
 #endif
-        HCoordinate hc1p1(p1);
+	// unrolled computation
-#if GEOS_DEBUG
-	cerr << "HCoordinate(p1): "
-	     << hc1p1 << endl;
-#endif
+	double px = p1.y - p2.y;
+	double py = p2.x - p1.x;
+	double pw = p1.x * p2.y - p2.x * p1.y;
-        HCoordinate hc1p2(p2);
+	double qx = q1.y - q2.y;
+	double qy = q2.x - q1.x;
+	double qw = q1.x * q2.y - q2.x * q1.y;
-#if GEOS_DEBUG
-	cerr << "HCoordinate(p2): "
-	     << hc1p2 << endl;
-#endif
+	double x = py * qw - qy * pw;
+	double y = qx * pw - px * qw;
+	double w = px * qy - qx * py;
-        HCoordinate l1(hc1p1, hc1p2);
+	double xInt = x/w;
+	double yInt = y/w;
-#if GEOS_DEBUG
-	cerr << "L1 - HCoordinate(HCp1, HCp2): "
-	     << l1 << endl;
-#endif
+	if ( (!FINITE(xInt)) || (!FINITE(yInt)) )
+		throw new NotRepresentableException();
-        HCoordinate hc2q1(q1);
-#if GEOS_DEBUG
-	cerr << "HCoordinate(q1): "
-	     << hc2q1 << endl;
-#endif
-        HCoordinate hc2q2(q2);
-#if GEOS_DEBUG
-	cerr << "HCoordinate(q2): "
-	     << hc2q2 << endl;
-#endif
-        HCoordinate l2(hc2q1, hc2q2);
-#if GEOS_DEBUG
-	cerr << "L2 - HCoordinate(HCq1, HCq2): "
-	     << l2 << endl;
-#endif
-        HCoordinate intHCoord(l1, l2);
-#if GEOS_DEBUG
-	cerr << "HCoordinate(L1, L2): "
-	     << intHCoord << endl;
-#endif
-        intHCoord.getCoordinate(ret);
+	ret = Coordinate(xInt, yInt);
 /*public*/
@@ -138,6 +178,34 @@
 /*public*/
+HCoordinate::HCoordinate(const Coordinate& p1, const Coordinate& p2)
+	// optimization when it is known that w = 1
+	x ( p1.y - p2.y ),
+	y ( p2.x - p1.x ),
+	w ( p1.x * p2.y - p2.x * p1.y )
+/*public*/
+HCoordinate::HCoordinate(const Coordinate& p1, const Coordinate& p2,
+			 const Coordinate& q1, const Coordinate& q2)
+	x = py * qw - qy * pw;
+	y = qx * pw - px * qw;
+	w = px * qy - qx * py;
+/*public*/
 #ifndef STORE_INTERMEDIATE_COMPUTATION_VALUES
 HCoordinate::HCoordinate(const HCoordinate &p1, const HCoordinate &p2)
@@ -185,7 +253,8 @@
 	long double a = x/w;
-    if (std::fabs(a) > std::numeric_limits<double>::max())
+	//if (std::fabs(a) > std::numeric_limits<double>::max())
+	if ( !FINITE(a) )
 		throw  NotRepresentableException();
@@ -198,7 +267,8 @@
 	long double a = y/w;
+	if ( !FINITE(a) )
Modified: trunk/source/headers/geos/algorithm/HCoordinate.h
--- trunk/source/headers/geos/algorithm/HCoordinate.h	2009-04-03 15:27:05 UTC (rev 2311)
+++ trunk/source/headers/geos/algorithm/HCoordinate.h	2009-04-07 08:14:25 UTC (rev 2312)
@@ -14,7 +14,7 @@
@@ -47,17 +47,20 @@
 	friend std::ostream& operator<< (std::ostream& o, const HCoordinate& c);
 	/** \brief
-	 * Computes the (approximate) intersection point between two line segments
-	 * using homogeneous coordinates.
+	 * Computes the (approximate) intersection point between two line
+	 * segments using homogeneous coordinates.
 	 * Note that this algorithm is
 	 * not numerically stable; i.e. it can produce intersection points which
 	 * lie outside the envelope of the line segments themselves.  In order
-	 * to increase the precision of the calculation input points should be normalized
-	 * before passing them to this routine.
+	 * to increase the precision of the calculation input points should be
+	 * normalized before passing them to this routine.
-	static void intersection(const geom::Coordinate &p1, const geom::Coordinate &p2,
-		const geom::Coordinate &q1, const geom::Coordinate &q2, geom::Coordinate &ret);
+	static void intersection(const geom::Coordinate &p1,
+				 const geom::Coordinate &p2,
+				 const geom::Coordinate &q1,
+				 const geom::Coordinate &q2,
+				 geom::Coordinate &ret);
 	long double x,y,w;
@@ -67,6 +70,19 @@
 	HCoordinate(const geom::Coordinate& p);
+	/** \brief
+	 * Constructs a homogeneous coordinate which is the intersection
+	 * of the lines define by the homogenous coordinates represented
+	 * by two {@link Coordinate}s.
+	 * @param p1
+	 * @param p2
+	HCoordinate(const geom::Coordinate& p1, const geom::Coordinate& p2);
+	HCoordinate(const geom::Coordinate& p1, const geom::Coordinate& p2,
+		    const geom::Coordinate& q1, const geom::Coordinate& q2);
 	HCoordinate(const HCoordinate &p1, const HCoordinate &p2);
 	long double getX() const;
More information about the geos-commits mailing list
