[geos-commits] r2314 - trunk/source/operation/valid
svn_geos at osgeo.org
Tue Apr 7 05:56:44 EDT 2009
Author: strk
Date: 2009-04-07 05:56:43 -0400 (Tue, 07 Apr 2009)
New Revision: 2314
Added:
trunk/source/operation/valid/IndexedNestedRingTester.cpp
trunk/source/operation/valid/IndexedNestedRingTester.h
trunk/source/operation/valid/IsValidOp.cpp
trunk/source/operation/valid/Makefile.am
Port IndexedNestedRingTester and have IsValidOp use it, syncing the operation to JTS-1.9
Added: trunk/source/operation/valid/IndexedNestedRingTester.cpp
--- trunk/source/operation/valid/IndexedNestedRingTester.cpp (rev 0)
+++ trunk/source/operation/valid/IndexedNestedRingTester.cpp 2009-04-07 09:56:43 UTC (rev 2314)
@@ -0,0 +1,109 @@
+ * $Id$
+ * GEOS - Geometry Engine Open Source
+ * http://geos.refractions.net
+ * Copyright (C) 2009 Safe Software Inc.
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+ * Last port: operation/valid/IndexedNestedRingTester.java rev. 1.1 (JTS-1.9)
+#include "IndexedNestedRingTester.h"
+#include <geos/geom/LinearRing.h> // for use
+#include <geos/algorithm/CGAlgorithms.h> // for use
+#include <geos/operation/valid/IsValidOp.h> // for use (findPtNotNode)
+#include <geos/index/strtree/STRtree.h> // for use
+// Forward declarations
+namespace geos {
+ namespace geom {
+ class CoordinateSequence;
+ class Envelope;
+namespace geos {
+namespace operation { // geos.operation
+namespace valid { // geos.operation.valid
+bool
+IndexedNestedRingTester::isNonNested()
+ buildIndex();
+ for (size_t i=0, n=rings.size(); i<n; ++i)
+ const geom::LinearRing* innerRing = rings[i];
+ const geom::CoordinateSequence *innerRingPts=innerRing->getCoordinates();
+ std::vector<void*> results;
+ index->query(innerRing->getEnvelopeInternal(), results);
+ for (size_t j=0, jn=results.size(); j<jn; ++j)
+ geom::LinearRing* searchRing = static_cast<geom::LinearRing*>(results[j]);
+ geom::CoordinateSequence *searchRingPts=searchRing->getCoordinates();
+ if (innerRing==searchRing)
+ continue;
+ if (!innerRing->getEnvelopeInternal()->intersects(
+ searchRing->getEnvelopeInternal()))
+ continue;
+ const geom::Coordinate *innerRingPt =
+ IsValidOp::findPtNotNode(innerRingPts,
+ searchRing,
+ graph);
+ // Unable to find a ring point not a node of
+ // the search ring
+ assert(innerRingPt!=NULL);
+ bool isInside = algorithm::CGAlgorithms::isPointInRing(
+ *innerRingPt, searchRingPts);
+ if (isInside) {
+ nestedPt = innerRingPt;
+ return false;
+ return true;
+IndexedNestedRingTester::~IndexedNestedRingTester()
+ delete index;
+ //delete totalEnv;
+void
+IndexedNestedRingTester::buildIndex()
+ delete index;
+ index = new index::strtree::STRtree();
+ const geom::LinearRing* ring = rings[i];
+ const geom::Envelope* env = ring->getEnvelopeInternal();
+ index->insert(env, (void*)ring);
+} // namespace geos.operation.valid
Added: trunk/source/operation/valid/IndexedNestedRingTester.h
--- trunk/source/operation/valid/IndexedNestedRingTester.h (rev 0)
+++ trunk/source/operation/valid/IndexedNestedRingTester.h 2009-04-07 09:56:43 UTC (rev 2314)
@@ -0,0 +1,113 @@
+ * $Id$
+#ifndef GEOS_OP_VALID_OFFSETCURVEVERTEXLIST_H
+#define GEOS_OP_VALID_OFFSETCURVEVERTEXLIST_H
+#include <vector> // for composition
+namespace geos {
+ namespace geom {
+ //class Envelope;
+ class Coordinate;
+ class LinearRing;
+ namespace index {
+ class SpatialIndex;
+ namespace geomgraph {
+ class GeometryGraph;
+namespace geos {
+/** \brief
+ * Tests whether any of a set of {@link LinearRing}s are
+ * nested inside another ring in the set, using a spatial
+ * index to speed up the comparisons.
+class IndexedNestedRingTester
+public:
+ // @param newGraph : ownership retained by caller
+ IndexedNestedRingTester(geomgraph::GeometryGraph* newGraph)
+ graph(newGraph),
+ //totalEnv(0),
+ index(0),
+ nestedPt(0)
+ ~IndexedNestedRingTester();
+ * Be aware that the returned Coordinate (if != NULL)
+ * will point to storage owned by one of the LinearRing
+ * previously added. If you destroy them, this
+ * will point to an invalid memory address.
+ const geom::Coordinate* getNestedPoint() const
+ return nestedPt;
+ /// @param ring : ownership retained by caller
+ void add(const geom::LinearRing* ring)
+ rings.push_back(ring);
+ bool isNonNested();
+private:
+ /// Externally owned
+ geomgraph::GeometryGraph* graph;
+ /// Ownership of this vector elements are externally owned
+ std::vector<const geom::LinearRing*> rings;
+ // CHECK: Owned by (seems unused)?
+ //geom::Envelope* totalEnv;
+ // Owned by us (use auto_ptr ?)
+ geos::index::SpatialIndex* index; // 'index' in JTS
+ // Externally owned, if not null
+ const geom::Coordinate *nestedPt;
+ void buildIndex();
+#endif // GEOS_OP_VALID_OFFSETCURVEVERTEXLIST_H
+ * $Log$
Modified: trunk/source/operation/valid/IsValidOp.cpp
--- trunk/source/operation/valid/IsValidOp.cpp 2009-04-07 09:55:45 UTC (rev 2313)
+++ trunk/source/operation/valid/IsValidOp.cpp 2009-04-07 09:56:43 UTC (rev 2314)
@@ -14,14 +14,16 @@
- * Last port: operation/valid/IsValidOp.java rev. 1.39 (JTS-1.7)
+ * Last port: operation/valid/IsValidOp.java rev. 1.41 (JTS-1.9)
#include <geos/operation/valid/ConsistentAreaTester.h>
-#include <geos/operation/valid/QuadtreeNestedRingTester.h>
#include <geos/operation/valid/ConnectedInteriorTester.h>
+#include <geos/operation/valid/ConnectedInteriorTester.h>
#include <geos/util/UnsupportedOperationException.h>
#include <geos/geomgraph/index/SegmentIntersector.h>
#include <geos/geomgraph/GeometryGraph.h>
@@ -401,7 +403,8 @@
//SimpleNestedRingTester nestedTester(graph);
//SweeplineNestedRingTester nestedTester(graph);
- QuadtreeNestedRingTester nestedTester(graph);
+ //QuadtreeNestedRingTester nestedTester(graph);
+ IndexedNestedRingTester nestedTester(graph);
int nholes=p->getNumInteriorRing();
for(int i=0; i<nholes; ++i)
Modified: trunk/source/operation/valid/Makefile.am
--- trunk/source/operation/valid/Makefile.am 2009-04-07 09:55:45 UTC (rev 2313)
+++ trunk/source/operation/valid/Makefile.am 2009-04-07 09:56:43 UTC (rev 2314)
@@ -16,7 +16,9 @@
RepeatedPointTester.cpp \
SimpleNestedRingTester.cpp \
SweeplineNestedRingTester.cpp \
- TopologyValidationError.cpp
+ TopologyValidationError.cpp \
+ IndexedNestedRingTester.cpp \
+ IndexedNestedRingTester.h
libopvalid_la_LIBADD =
More information about the geos-commits
