[geos-commits] r2317 - in trunk/source: headers/geos/noding/snapround noding/snapround
svn_geos at osgeo.org svn_geos at osgeo.org
Tue Apr 7 07:11:33 EDT 2009
Author: strk
Date: 2009-04-07 07:11:33 -0400 (Tue, 07 Apr 2009)
New Revision: 2317
   trunk/source/headers/geos/noding/snapround/HotPixel.h
   trunk/source/headers/geos/noding/snapround/HotPixel.inl
   trunk/source/noding/snapround/HotPixel.cpp
Sync HotPixel to JTS-1.9 (rev 1.3); fix a few bugs and use standard algorithms for min/max
Modified: trunk/source/headers/geos/noding/snapround/HotPixel.h
--- trunk/source/headers/geos/noding/snapround/HotPixel.h	2009-04-07 10:48:10 UTC (rev 2316)
+++ trunk/source/headers/geos/noding/snapround/HotPixel.h	2009-04-07 11:11:33 UTC (rev 2317)
@@ -13,7 +13,7 @@
- * Last port: noding/snapround/HotPixel.java rev. 1.2 (JTS-1.7)
+ * Last port: noding/snapround/HotPixel.java rev. 1.3 (JTS-1.9)
@@ -33,6 +33,9 @@
 	namespace algorithm {
 		class LineIntersector;
+	namespace noding {
+		class NodedSegmentString;
 namespace geos {
@@ -60,6 +63,9 @@
 	const geom::Coordinate& originalPt;
 	geom::Coordinate ptScaled;
+	mutable geom::Coordinate p0Scaled;
+	mutable geom::Coordinate p1Scaled;
 	double scaleFactor;
 	double minx;
@@ -151,6 +157,15 @@
 	bool intersects(const geom::Coordinate& p0,
 			const geom::Coordinate& p1) const;
+	 * Adds a new node (equal to the snap pt) to the specified segment
+	 * if the segment passes through the hot pixel
+	 * @param segStr
+	 * @param segIndex
+	 * @return true if a node was added to the segment
+	bool addSnappedNode(NodedSegmentString& segStr, size_t segIndex);
Modified: trunk/source/headers/geos/noding/snapround/HotPixel.inl
--- trunk/source/headers/geos/noding/snapround/HotPixel.inl	2009-04-07 10:48:10 UTC (rev 2316)
+++ trunk/source/headers/geos/noding/snapround/HotPixel.inl	2009-04-07 11:11:33 UTC (rev 2317)
@@ -11,6 +11,10 @@
  * by the Free Software Foundation.
  * See the COPYING file for more information.
 #ifndef GEOS_NODING_SNAPROUND_HOTPIXEL_INL
Modified: trunk/source/noding/snapround/HotPixel.cpp
--- trunk/source/noding/snapround/HotPixel.cpp	2009-04-07 10:48:10 UTC (rev 2316)
+++ trunk/source/noding/snapround/HotPixel.cpp	2009-04-07 11:11:33 UTC (rev 2317)
@@ -13,11 +13,12 @@
 #include <geos/noding/snapround/HotPixel.h>
+#include <geos/noding/NodedSegmentString.h>
 #include <geos/algorithm/LineIntersector.h>
 #include <geos/geom/Coordinate.h>
@@ -25,6 +26,7 @@
 # include "geos/noding/snapround/HotPixel.inl"
 #endif
+#include <algorithm> // for std::min and std::max
 #include <cassert>
 #include <memory>
@@ -74,7 +76,12 @@
 	maxx = pt.x + tolerance;
 	miny = pt.y - tolerance;
 	maxy = pt.y + tolerance;
-	corner.assign(4, Coordinate(minx, maxy));
+	corner.resize(4);
+	corner[0] = Coordinate(maxx, maxy);
+	corner[1] = Coordinate(minx, maxy);
+	corner[2] = Coordinate(minx, miny);
+	corner[4] = Coordinate(maxx, maxy);
 bool
@@ -83,9 +90,6 @@
 	if (scaleFactor == 1.0) return intersectsScaled(p0, p1);
-	Coordinate p0Scaled;
-	Coordinate p1Scaled;
 	copyScaled(p0, p0Scaled);
 	copyScaled(p1, p1Scaled);
@@ -97,13 +101,11 @@
 		const Coordinate& p1) const
-#define MIN(x,y) (x)<(y)?(x):(y)
+	double segMinx = std::min(p0.x, p1.x);
+	double segMaxx = std::max(p0.x, p1.x);
+	double segMiny = std::min(p0.y, p1.y);
+	double segMaxy = std::max(p0.y, p1.y);
-	double segMinx = MIN(p0.x, p1.x);
-	double segMaxx = MIN(p0.x, p1.x);
-	double segMiny = MIN(p0.y, p1.y);
-	double segMaxy = MIN(p0.y, p1.y);
 	bool isOutsidePixelEnv =  maxx < segMinx
                          || minx > segMaxx
                          || maxy < segMiny
@@ -166,7 +168,22 @@
     return false;
+bool
+HotPixel::addSnappedNode(NodedSegmentString& segStr, size_t segIndex)
+	const Coordinate& p0 = segStr.getCoordinate(segIndex);
+	const Coordinate& p1 = segStr.getCoordinate(segIndex + 1);
+	if (intersects(p0, p1))
+		//cout << "snapped: " <<  snapPt << endl;
+		segStr.addIntersection(getCoordinate(), segIndex);
+		return true;
+	return false;
 } // namespace geos.noding.snapround
 } // namespace geos
More information about the geos-commits mailing list
