[geos-commits] r2338 - trunk/source/operation/buffer
svn_geos at osgeo.org
Thu Apr 9 04:54:00 EDT 2009
Author: strk
Date: 2009-04-09 04:54:00 -0400 (Thu, 09 Apr 2009)
New Revision: 2338
trunk/source/operation/buffer/OffsetCurveBuilder.cpp
trunk/source/operation/buffer/OffsetCurveVertexList.h
Sync port of OffsetCurveVertexList to JTS-1.9, improve memory management documentation (would need some refactoring/love)
Modified: trunk/source/operation/buffer/OffsetCurveBuilder.cpp
--- trunk/source/operation/buffer/OffsetCurveBuilder.cpp 2009-04-08 16:52:28 UTC (rev 2337)
+++ trunk/source/operation/buffer/OffsetCurveBuilder.cpp 2009-04-09 08:54:00 UTC (rev 2338)
@@ -106,6 +106,7 @@
} else {
computeLineBufferCurve(*inputPts);
+ // NOTE: we take ownership of lineCoord here
CoordinateSequence *lineCoord=vertexList->getCoordinates();
lineList.push_back(lineCoord);
@@ -130,7 +131,10 @@
return;
computeRingBufferCurve(*inputPts, side);
- lineList.push_back(vertexList->getCoordinates()); // this will be vertexList
+ // this will be vertexList
+ // NOTE: getCoordinates() take ownership of the CoordinateSequence
+ lineList.push_back(vertexList->getCoordinates());
/*private*/
Modified: trunk/source/operation/buffer/OffsetCurveVertexList.h
--- trunk/source/operation/buffer/OffsetCurveVertexList.h 2009-04-08 16:52:28 UTC (rev 2337)
+++ trunk/source/operation/buffer/OffsetCurveVertexList.h 2009-04-09 08:54:00 UTC (rev 2338)
@@ -13,7 +13,7 @@
- * Last port: operation/buffer/OffsetCurveVertexList.java rev. 1.1
+ * Last port: operation/buffer/OffsetCurveVertexList.java rev. 1.2 (JTS-1.9)
@@ -54,7 +54,6 @@
private:
geom::CoordinateSequence* ptList;
- bool ptListConsumed;
const geom::PrecisionModel* precisionModel;
@@ -87,10 +86,11 @@
public:
+ friend std::ostream& operator<< (std::ostream& os, const OffsetCurveVertexList& node);
OffsetCurveVertexList()
ptList(new geom::CoordinateArraySequence()),
- ptListConsumed(false),
precisionModel(NULL),
minimumVertexDistance (0.0)
@@ -98,7 +98,6 @@
~OffsetCurveVertexList()
- if (!ptListConsumed)
delete ptList;
@@ -127,10 +126,11 @@
// (JTS uses a vector for ptList, not a CoordinateSequence,
// we should do the same)
ptList->add(bufPt, true);
- //ptList.push_back(bufPt);
- // check that points are a ring - add the startpoint again if they are not
+ /// Check that points are a ring
+ /// add the startpoint again if they are not
void closeRing()
if (ptList->size() < 1) return;
@@ -141,23 +141,37 @@
ptList->add(startPt, true);
+ /// Get coordinates by taking ownership of them
+ /// After this call, the coordinates reference in
+ /// this object are dropped. Calling twice will
+ /// segfault...
+ /// FIXME: refactor memory management of this
geom::CoordinateSequence* getCoordinates()
closeRing();
- ptListConsumed = true;
- return ptList;
+ geom::CoordinateSequence* ret = ptList;
+ ptList = 0;
+ return ret;
- // Added getCoordinatesRO(), which returns the coordinates without
- // passing ownership to the caller.
- const geom::CoordinateSequence* getCoordinatesRO()
+std::ostream& operator<< (std::ostream& os, const OffsetCurveVertexList& lst)
+ if ( lst.ptList )
- closeRing();
- return ptList;
+ os << *(lst.ptList);
+ else
+ os << "empty (consumed?)";
+ return os;
} // namespace geos.operation.buffer
} // namespace geos
More information about the geos-commits
