[geos-commits] r2342 - in trunk/source: algorithm
headers/geos/algorithm
svn_geos at osgeo.org
Thu Apr 9 12:22:27 EDT 2009
Author: strk
Date: 2009-04-09 12:22:26 -0400 (Thu, 09 Apr 2009)
New Revision: 2342
Added:
trunk/source/algorithm/Angle.cpp
trunk/source/headers/geos/algorithm/Angle.h
trunk/source/algorithm/Makefile.am
trunk/source/headers/geos/algorithm/Makefile.am
Port algorithm.Angle from JTS-1.9
Added: trunk/source/algorithm/Angle.cpp
--- trunk/source/algorithm/Angle.cpp (rev 0)
+++ trunk/source/algorithm/Angle.cpp 2009-04-09 16:22:26 UTC (rev 2342)
@@ -0,0 +1,206 @@
+ * $Id$
+ * GEOS - Geometry Engine Open Source
+ * http://geos.refractions.net
+ * Copyright (C) 2009 Sandro Santilli <strk at keybit.net>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+ * Last port: algorithm/Angle.java rev. 1.6 (JTS-1.9)
+#include <cmath>
+#include <geos/algorithm/Angle.h>
+#include <geos/algorithm/CGAlgorithms.h>
+#include <geos/geom/Coordinate.h>
+namespace geos {
+namespace algorithm { // geos.algorithm
+namespace {
+ const double PI = 3.14159265358979;
+const double Angle::PI_TIMES_2 = 2.0 * PI;
+const double Angle::PI_OVER_2 = PI / 2.0;
+const double Angle::PI_OVER_4 = PI / 4.0;
+/* public static */
+double
+Angle::toDegrees(double radians)
+ return (radians * 180) / (PI);
+double
+Angle::toRadians(double angleDegrees)
+ return (angleDegrees * PI) / 180.0;
+double
+Angle::angle(const geom::Coordinate& p0,
+ const geom::Coordinate& p1)
+ double dx = p1.x - p0.x;
+ double dy = p1.y - p0.y;
+ return atan2(dy, dx);
+double
+Angle::angle(const geom::Coordinate& p)
+ return atan2(p.y, p.x);
+bool
+Angle::isAcute(const geom::Coordinate& p0,
+ const geom::Coordinate& p1,
+ const geom::Coordinate& p2)
+ // relies on fact that A dot B is positive iff A ang B is acute
+ double dx0 = p0.x - p1.x;
+ double dy0 = p0.y - p1.y;
+ double dx1 = p2.x - p1.x;
+ double dy1 = p2.y - p1.y;
+ double dotprod = dx0 * dx1 + dy0 * dy1;
+ return dotprod > 0;
+bool
+Angle::isObtuse(const geom::Coordinate& p0,
+ // relies on fact that A dot B is negative iff A ang B is obtuse
+ return dotprod < 0;
+double
+Angle::angleBetween(const geom::Coordinate& tip1,
+ const geom::Coordinate& tail,
+ const geom::Coordinate& tip2)
+ double a1 = angle(tail, tip1);
+ double a2 = angle(tail, tip2);
+ return diff(a1, a2);
+double
+Angle::angleBetweenOriented(const geom::Coordinate& tip1,
+ double angDel = a2 - a1;
+ // normalize, maintaining orientation
+ if (angDel <= -PI)
+ return angDel + PI_TIMES_2;
+ if (angDel > PI)
+ return angDel - PI_TIMES_2;
+ return angDel;
+double
+Angle::interiorAngle(const geom::Coordinate& p0, const geom::Coordinate& p1,
+ double anglePrev = angle(p1, p0);
+ double angleNext = angle(p1, p2);
+ return fabs(angleNext - anglePrev);
+int
+Angle::getTurn(double ang1, double ang2)
+ double crossproduct = sin(ang2 - ang1);
+ if (crossproduct > 0) {
+ return COUNTERCLOCKWISE;
+ if (crossproduct < 0) {
+ return CLOCKWISE;
+ return NONE;
+double
+Angle::normalize(double angle)
+ while (angle > PI)
+ angle -= PI_TIMES_2;
+ while (angle <= -PI)
+ angle += PI_TIMES_2;
+ return angle;
+double
+Angle::normalizePositive(double angle)
+ if (angle < 0.0) {
+ while (angle < 0.0)
+ // in case round-off error bumps the value over
+ if (angle >= PI_TIMES_2)
+ angle = 0.0;
+ else {
+ while (angle >= PI_TIMES_2)
+ // in case round-off error bumps the value under
+ if (angle < 0.0)
+ angle = 0.0;
+ return angle;
+double
+Angle::diff(double ang1, double ang2)
+ double delAngle;
+ if (ang1 < ang2) {
+ delAngle = ang2 - ang1;
+ } else {
+ delAngle = ang1 - ang2;
+ if (delAngle > PI) {
+ delAngle = (2 * PI) - delAngle;
+ return delAngle;
+} // namespace geos.algorithm
+} //namespace geos
Modified: trunk/source/algorithm/Makefile.am
--- trunk/source/algorithm/Makefile.am 2009-04-09 11:45:57 UTC (rev 2341)
+++ trunk/source/algorithm/Makefile.am 2009-04-09 16:22:26 UTC (rev 2342)
@@ -6,6 +6,7 @@
INCLUDES = -I$(top_srcdir)/source/headers
libalgorithm_la_SOURCES = \
+ Angle.cpp \
CentroidArea.cpp \
CentroidLine.cpp \
CentroidPoint.cpp \
Added: trunk/source/headers/geos/algorithm/Angle.h
--- trunk/source/headers/geos/algorithm/Angle.h (rev 0)
+++ trunk/source/headers/geos/algorithm/Angle.h 2009-04-09 16:22:26 UTC (rev 2342)
@@ -0,0 +1,228 @@
+ * $Id$
+#ifndef GEOS_ALGORITHM_ANGLE_H
+#define GEOS_ALGORITHM_ANGLE_H
+#include <geos/algorithm/CGAlgorithms.h> // for constants
+// Forward declarations
+namespace geos {
+ namespace geom {
+ class Coordinate;
+namespace geos {
+namespace algorithm { // geos::algorithm
+/// Utility functions for working with angles.
+/// Unless otherwise noted, methods in this class express angles in radians.
+class Angle
+public:
+ static const double PI_TIMES_2; // 2.0 * PI;
+ static const double PI_OVER_2; // PI / 2.0;
+ static const double PI_OVER_4; // PI / 4.0;
+ /// Constant representing counterclockwise orientation
+ static const int COUNTERCLOCKWISE = CGAlgorithms::COUNTERCLOCKWISE;
+ /// Constant representing clockwise orientation
+ static const int CLOCKWISE = CGAlgorithms::CLOCKWISE;
+ /// Constant representing no orientation
+ static const int NONE = CGAlgorithms::COLLINEAR;
+ /// Converts from radians to degrees.
+ /// @param radians an angle in radians
+ /// @return the angle in degrees
+ static double toDegrees(double radians);
+ /// Converts from degrees to radians.
+ /// @param angleDegrees an angle in degrees
+ /// @return the angle in radians
+ static double toRadians(double angleDegrees);
+ /// \brief
+ /// Returns the angle of the vector from p0 to p1,
+ /// relative to the positive X-axis.
+ /// The angle is normalized to be in the range [ -Pi, Pi ].
+ /// @return the normalized angle (in radians) that p0-p1 makes
+ /// with the positive x-axis.
+ static double angle(const geom::Coordinate& p0,
+ const geom::Coordinate& p1);
+ /// \brief
+ /// Returns the angle that the vector from (0,0) to p,
+ /// The angle is normalized to be in the range ( -Pi, Pi ].
+ /// @return the normalized angle (in radians) that p makes
+ static double angle(const geom::Coordinate& p);
+ /// Tests whether the angle between p0-p1-p2 is acute.
+ /// An angle is acute if it is less than 90 degrees.
+ /// Note: this implementation is not precise (determistic) for
+ /// angles very close to 90 degrees.
+ /// @param p0 an endpoint of the angle
+ /// @param p1 the base of the angle
+ /// @param p2 the other endpoint of the angle
+ static bool isAcute(const geom::Coordinate& p0,
+ const geom::Coordinate& p2);
+ /// Tests whether the angle between p0-p1-p2 is obtuse.
+ /// An angle is obtuse if it is greater than 90 degrees.
+ static bool isObtuse(const geom::Coordinate& p0,
+ /// Returns the unoriented smallest angle between two vectors.
+ /// The computed angle will be in the range [0, Pi).
+ /// @param tip1 the tip of one vector
+ /// @param tail the tail of each vector
+ /// @param tip2 the tip of the other vector
+ /// @return the angle between tail-tip1 and tail-tip2
+ static double angleBetween(const geom::Coordinate& tip1,
+ const geom::Coordinate& tip2);
+ /// Returns the oriented smallest angle between two vectors.
+ /// The computed angle will be in the range (-Pi, Pi].
+ /// A positive result corresponds to a counterclockwise rotation
+ /// from v1 to v2;
+ /// a negative result corresponds to a clockwise rotation.
+ /// @param tip1 the tip of v1
+ /// @param tip2 the tip of v2
+ /// @return the angle between v1 and v2, relative to v1
+ static double angleBetweenOriented(const geom::Coordinate& tip1,
+ /// Computes the interior angle between two segments of a ring.
+ /// The ring is assumed to be oriented in a clockwise direction.
+ /// The computed angle will be in the range [0, 2Pi]
+ /// @param p0
+ /// a point of the ring
+ /// @param p1
+ /// the next point of the ring
+ /// @param p2
+ /// @return the interior angle based at <code>p1</code>
+ static double interiorAngle(const geom::Coordinate& p0,
+ /// \brief
+ /// Returns whether an angle must turn clockwise or counterclockwise
+ /// to overlap another angle.
+ /// @param ang1 an angle (in radians)
+ /// @param ang2 an angle (in radians)
+ /// @return whether a1 must turn CLOCKWISE, COUNTERCLOCKWISE or
+ /// NONE to overlap a2.
+ static int getTurn(double ang1, double ang2);
+ /// \brief
+ /// Computes the normalized value of an angle, which is the
+ /// equivalent angle in the range ( -Pi, Pi ].
+ /// @param angle the angle to normalize
+ /// @return an equivalent angle in the range (-Pi, Pi]
+ static double normalize(double angle);
+ /// \brief
+ /// Computes the normalized positive value of an angle,
+ /// which is the equivalent angle in the range [ 0, 2*Pi ).
+ /// E.g.:
+ /// - normalizePositive(0.0) = 0.0
+ /// - normalizePositive(-PI) = PI
+ /// - normalizePositive(-2PI) = 0.0
+ /// - normalizePositive(-3PI) = PI
+ /// - normalizePositive(-4PI) = 0
+ /// - normalizePositive(PI) = PI
+ /// - normalizePositive(2PI) = 0.0
+ /// - normalizePositive(3PI) = PI
+ /// - normalizePositive(4PI) = 0.0
+ /// @param angle the angle to normalize, in radians
+ /// @return an equivalent positive angle
+ static double normalizePositive(double angle);
+ /// Computes the unoriented smallest difference between two angles.
+ /// The angles are assumed to be normalized to the range [-Pi, Pi].
+ /// The result will be in the range [0, Pi].
+ /// @param ang1 the angle of one vector (in [-Pi, Pi] )
+ /// @param ang2 the angle of the other vector (in range [-Pi, Pi] )
+ /// @return the angle (in radians) between the two vectors
+ /// (in range [0, Pi] )
+ static double diff(double ang1, double ang2);
+} // namespace geos::algorithm
+#endif // GEOS_ALGORITHM_ANGLE_H
Modified: trunk/source/headers/geos/algorithm/Makefile.am
--- trunk/source/headers/geos/algorithm/Makefile.am 2009-04-09 11:45:57 UTC (rev 2341)
+++ trunk/source/headers/geos/algorithm/Makefile.am 2009-04-09 16:22:26 UTC (rev 2342)
@@ -19,6 +19,7 @@
PointLocator.h
noinst_HEADERS = \
+ Angle.h \
CGAlgorithms.h \
CentralEndpointIntersector.h \
CentroidArea.h \
More information about the geos-commits
