[geos-commits] r2366 - in trunk/source: geomgraph headers/geos/geomgraph headers/geos/operation/overlay operation/overlay
svn_geos at osgeo.org svn_geos at osgeo.org
Wed Apr 15 05:25:28 EDT 2009
Author: strk
Date: 2009-04-15 05:25:28 -0400 (Wed, 15 Apr 2009)
New Revision: 2366
   trunk/source/geomgraph/EdgeRing.cpp
   trunk/source/headers/geos/geomgraph/EdgeRing.h
   trunk/source/headers/geos/operation/overlay/MaximalEdgeRing.h
   trunk/source/headers/geos/operation/overlay/PolygonBuilder.h
   trunk/source/operation/overlay/MaximalEdgeRing.cpp
   trunk/source/operation/overlay/PolygonBuilder.cpp
Fix leak in PolygonBuilder (overlay operation). The leak was exposed by the stmlf-cases-20061020.xml testcase. This commit also adds some doc-only throw specs related to the bug.
Modified: trunk/source/geomgraph/EdgeRing.cpp
--- trunk/source/geomgraph/EdgeRing.cpp	2009-04-15 07:52:11 UTC (rev 2365)
+++ trunk/source/geomgraph/EdgeRing.cpp	2009-04-15 09:25:28 UTC (rev 2366)
@@ -222,6 +222,7 @@
 /*protected*/
 void
 EdgeRing::computePoints(DirectedEdge *newStart)
+	// throw(const TopologyException &)
 	startDe=newStart;
 	DirectedEdge *de=newStart;
Modified: trunk/source/headers/geos/geomgraph/EdgeRing.h
--- trunk/source/headers/geos/geomgraph/EdgeRing.h	2009-04-15 07:52:11 UTC (rev 2365)
+++ trunk/source/headers/geos/geomgraph/EdgeRing.h	2009-04-15 09:25:28 UTC (rev 2366)
@@ -144,6 +144,7 @@
 	const geom::GeometryFactory *geometryFactory;
+	/// throw(const TopologyException &)
 	void computePoints(DirectedEdge *newStart);
 	void mergeLabel(Label& deLabel);
Modified: trunk/source/headers/geos/operation/overlay/MaximalEdgeRing.h
--- trunk/source/headers/geos/operation/overlay/MaximalEdgeRing.h	2009-04-15 07:52:11 UTC (rev 2365)
+++ trunk/source/headers/geos/operation/overlay/MaximalEdgeRing.h	2009-04-15 09:25:28 UTC (rev 2366)
@@ -62,9 +62,9 @@
 public:
-	// CGAlgorithms arg is obsoleted
 	MaximalEdgeRing(geomgraph::DirectedEdge *start,
 		const geom::GeometryFactory *geometryFactory);
 	virtual ~MaximalEdgeRing();
Modified: trunk/source/headers/geos/operation/overlay/PolygonBuilder.h
--- trunk/source/headers/geos/operation/overlay/PolygonBuilder.h	2009-04-15 07:52:11 UTC (rev 2365)
+++ trunk/source/headers/geos/operation/overlay/PolygonBuilder.h	2009-04-15 09:25:28 UTC (rev 2366)
@@ -61,7 +61,8 @@
 	 * The graph is assumed to contain one or more polygons,
 	 * possibly with holes.
-	void add(geomgraph::PlanarGraph *graph); // throw(TopologyException *);
+	void add(geomgraph::PlanarGraph *graph);
 	 * Add a set of edges and nodes, which form a graph.
@@ -70,7 +71,7 @@
 	void add(const std::vector<geomgraph::DirectedEdge*> *dirEdges,
 			const std::vector<geomgraph::Node*> *nodes);
-			// throw(TopologyException *);
   	std::vector<geom::Geometry*>* getPolygons();
@@ -87,10 +88,14 @@
 	std::vector<geomgraph::EdgeRing*> shellList;
-	 * for all DirectedEdges in result, form them into MaximalEdgeRings
+	 * For all DirectedEdges in result, form them into MaximalEdgeRings
+	 * Ownership of the returned vector *and* it's elements is
+	 * transferred to caller.
 	std::vector<MaximalEdgeRing*>* buildMaximalEdgeRings(
 		const std::vector<geomgraph::DirectedEdge*> *dirEdges);
 	std::vector<MaximalEdgeRing*>* buildMinimalEdgeRings(
 		std::vector<MaximalEdgeRing*> *maxEdgeRings,
@@ -148,6 +153,7 @@
 	void placeFreeHoles(std::vector<geomgraph::EdgeRing*>& newShellList,
 		std::vector<geomgraph::EdgeRing*>& freeHoleList);
+		// throw(const TopologyException&)
 	/** \brief
 	 * Find the innermost enclosing shell geomgraph::EdgeRing containing the
Modified: trunk/source/operation/overlay/MaximalEdgeRing.cpp
--- trunk/source/operation/overlay/MaximalEdgeRing.cpp	2009-04-15 07:52:11 UTC (rev 2365)
+++ trunk/source/operation/overlay/MaximalEdgeRing.cpp	2009-04-15 09:25:28 UTC (rev 2366)
@@ -49,6 +49,7 @@
 // CGAlgorithms obsoleted
 MaximalEdgeRing::MaximalEdgeRing(DirectedEdge *start,
 		const GeometryFactory *geometryFactory)
 	EdgeRing(start, geometryFactory)
Modified: trunk/source/operation/overlay/PolygonBuilder.cpp
--- trunk/source/operation/overlay/PolygonBuilder.cpp	2009-04-15 07:52:11 UTC (rev 2365)
+++ trunk/source/operation/overlay/PolygonBuilder.cpp	2009-04-15 09:25:28 UTC (rev 2366)
@@ -30,6 +30,7 @@
 #include <geos/geom/Polygon.h>
 #include <geos/algorithm/CGAlgorithms.h>
 #include <geos/util/TopologyException.h>
+#include <geos/util/GEOSException.h>
 #include <vector>
 #include <cassert>
@@ -144,10 +145,11 @@
 #endif
 	vector<EdgeRing*> freeHoleList;
-	vector<MaximalEdgeRing*> *edgeRings=
-		buildMinimalEdgeRings(maxEdgeRings,&shellList,&freeHoleList);
+	vector<MaximalEdgeRing*> *edgeRings;
+	edgeRings= buildMinimalEdgeRings(maxEdgeRings,&shellList,&freeHoleList);
 	sortShellsAndHoles(edgeRings,&shellList,&freeHoleList);
 	placeFreeHoles(shellList, freeHoleList);
 	delete maxEdgeRings;
 	delete edgeRings;
@@ -166,6 +168,7 @@
 /*private*/
 PolygonBuilder::buildMaximalEdgeRings(const vector<DirectedEdge*> *dirEdges)
 #if GEOS_DEBUG
 	cerr<<"PolygonBuilder::buildMaximalEdgeRings got "<<dirEdges->size()<<" dirEdges"<<endl;
@@ -180,10 +183,24 @@
 	     << " inResult:" << de->isInResult() << endl
 	     << " isArea:" << de->getLabel()->isArea() << endl;
 #endif
-		if (de->isInResult() && de->getLabel()->isArea()) {
+		if (de->isInResult() && de->getLabel()->isArea())
 			// if this edge has not yet been processed
-			if (de->getEdgeRing()==NULL) {
-				MaximalEdgeRing *er=new MaximalEdgeRing(de,geometryFactory);
+			if (de->getEdgeRing() == NULL)
+				MaximalEdgeRing *er;
+	try
+	{ // MaximalEdgeRing constructor may throw
+				er=new MaximalEdgeRing(de,geometryFactory);
+	catch (util::GEOSException& e)
+	{ // cleanup if that happens (see stmlf-cases-20061020.xml)
+		for(size_t i=0, n=maxEdgeRings->size(); i<n; i++)
+			delete (*maxEdgeRings)[i];
+		delete maxEdgeRings;
+		//cerr << "Exception! " << e.what() << endl;
+		throw;
 				maxEdgeRings->push_back(er);
 				er->setInResult();
 				//System.out.println("max node degree=" + er.getMaxDegree());
More information about the geos-commits mailing list
