[geos-commits] r2371 - in trunk/source: headers/geos/index/quadtree index/quadtree
svn_geos at osgeo.org svn_geos at osgeo.org
Wed Apr 15 07:17:29 EDT 2009
Author: strk
Date: 2009-04-15 07:17:29 -0400 (Wed, 15 Apr 2009)
New Revision: 2371
   trunk/source/headers/geos/index/quadtree/Key.h
   trunk/source/headers/geos/index/quadtree/Node.h
   trunk/source/index/quadtree/Key.cpp
Few more docs about memory management in quadtree indexing; fix a potential leak in quadtree::Key
Modified: trunk/source/headers/geos/index/quadtree/Key.h
--- trunk/source/headers/geos/index/quadtree/Key.h	2009-04-15 10:43:48 UTC (rev 2370)
+++ trunk/source/headers/geos/index/quadtree/Key.h	2009-04-15 11:17:29 UTC (rev 2371)
@@ -37,20 +37,37 @@
 class Key {
 public:
+	// Doesn't touch the Envelope, might as well be const
 	static int computeQuadLevel(geom::Envelope *env);
 	Key(geom::Envelope *itemEnv);
 	virtual ~Key();
+	/// Returned object ownership retained by this class
 	geom::Coordinate* getPoint();
 	int getLevel();
 	geom::Envelope* getEnvelope();
+	/// Returns newly allocated object (ownership transferred)
 	geom::Coordinate* getCentre();
 	void computeKey(geom::Envelope *itemEnv);
 private:
 	// the fields which make up the key
+	// Owned by this class
 	geom::Coordinate *pt;
 	int level;
 	// auxiliary data which is derived from the key for use in computation
 	geom::Envelope *env;
 	void computeKey(int level,geom::Envelope *itemEnv);
Modified: trunk/source/headers/geos/index/quadtree/Node.h
--- trunk/source/headers/geos/index/quadtree/Node.h	2009-04-15 10:43:48 UTC (rev 2370)
+++ trunk/source/headers/geos/index/quadtree/Node.h	2009-04-15 11:17:29 UTC (rev 2371)
@@ -46,6 +46,7 @@
 private:
+	/// Owned by this class
 	geom::Coordinate centre;
@@ -81,6 +82,8 @@
 	virtual ~Node() { delete env; }
+	/// Return Envelope associated with this node
+	/// ownership retained by this object
 	geom::Envelope* getEnvelope() { return env; }
 	/** \brief
Modified: trunk/source/index/quadtree/Key.cpp
--- trunk/source/index/quadtree/Key.cpp	2009-04-15 10:43:48 UTC (rev 2370)
+++ trunk/source/index/quadtree/Key.cpp	2009-04-15 11:17:29 UTC (rev 2371)
@@ -84,7 +84,8 @@
 void Key::computeKey(Envelope *itemEnv) {
 	level=computeQuadLevel(itemEnv);
-	env=new Envelope();
+	delete env;
+	env=new Envelope();
 	computeKey(level,itemEnv);
 	// MD - would be nice to have a non-iterative form of this algorithm
 	while (!env->contains(itemEnv)) {
More information about the geos-commits mailing list
