[geos-commits] r2373 - in trunk/source: algorithm/distance
headers/geos/algorithm/distance
svn_geos at osgeo.org
Wed Apr 15 11:58:09 EDT 2009
Author: strk
Date: 2009-04-15 11:58:09 -0400 (Wed, 15 Apr 2009)
New Revision: 2373
Added:
trunk/source/algorithm/distance/DistanceToPoint.cpp
trunk/source/headers/geos/algorithm/distance/DistanceToPoint.h
Removed:
trunk/source/algorithm/distance/EuclideanDistanceToPoint.cpp
trunk/source/headers/geos/algorithm/distance/EuclideanDistanceToPoint.h
trunk/source/algorithm/distance/DiscreteHausdorffDistance.cpp
trunk/source/algorithm/distance/Makefile.am
trunk/source/headers/geos/algorithm/distance/DiscreteHausdorffDistance.h
trunk/source/headers/geos/algorithm/distance/Makefile.am
New class rename, following JTS
Modified: trunk/source/algorithm/distance/DiscreteHausdorffDistance.cpp
--- trunk/source/algorithm/distance/DiscreteHausdorffDistance.cpp 2009-04-15 12:56:08 UTC (rev 2372)
+++ trunk/source/algorithm/distance/DiscreteHausdorffDistance.cpp 2009-04-15 15:58:09 UTC (rev 2373)
@@ -13,7 +13,7 @@
- * Last port: algorithm/distance/DiscreteHausdorffDistance.java 1.4 (JTS-1.9)
+ * Last port: algorithm/distance/DiscreteHausdorffDistance.java 1.5 (JTS-1.9)
@@ -57,7 +57,7 @@
double y = p0.y + i*dely;
Coordinate pt(x, y);
minPtDist.initialize();
- EuclideanDistanceToPoint::computeDistance(geom, pt, minPtDist);
+ DistanceToPoint::computeDistance(geom, pt, minPtDist);
maxPtDist.setMaximum(minPtDist);
Copied: trunk/source/algorithm/distance/DistanceToPoint.cpp (from rev 2361, trunk/source/algorithm/distance/EuclideanDistanceToPoint.cpp)
--- trunk/source/algorithm/distance/DistanceToPoint.cpp (rev 0)
+++ trunk/source/algorithm/distance/DistanceToPoint.cpp 2009-04-15 15:58:09 UTC (rev 2373)
@@ -0,0 +1,119 @@
+ * $Id$
+ * GEOS - Geometry Engine Open Source
+ * http://geos.refractions.net
+ * Copyright (C) 2009 Sandro Santilli <strk at keybit.net>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+ * Last port: algorithm/distance/DistanceToPoint.java 1.1 (JTS-1.9)
+#include <geos/algorithm/distance/DistanceToPoint.h>
+#include <geos/algorithm/distance/PointPairDistance.h>
+#include <geos/geom/Coordinate.h>
+#include <geos/geom/CoordinateSequence.h>
+#include <geos/geom/LineSegment.h>
+#include <geos/geom/LineString.h>
+#include <geos/geom/Polygon.h>
+#include <geos/geom/GeometryCollection.h>
+#include <typeinfo> // for dynamic_cast
+#include <cassert>
+using namespace geos::geom;
+namespace geos {
+namespace algorithm { // geos.algorithm
+namespace distance { // geos.algorithm.distance
+/* static */
+LineSegment DistanceToPoint::tempSegment;
+/* public static */
+void
+DistanceToPoint::computeDistance(const geom::Geometry& geom,
+ const geom::Coordinate& pt,
+ PointPairDistance& ptDist)
+ if ( const LineString* ls = dynamic_cast<const LineString*>(&geom) )
+ computeDistance(*ls, pt, ptDist);
+ else if ( const Polygon* pl = dynamic_cast<const Polygon*>(&geom) )
+ computeDistance(*pl, pt, ptDist);
+ else if ( const GeometryCollection* gc = dynamic_cast<const GeometryCollection*>(&geom) )
+ for (size_t i = 0; i < gc->getNumGeometries(); i++)
+ const Geometry* g = gc->getGeometryN(i);
+ computeDistance(*g, pt, ptDist);
+ else
+ // assume geom is Point
+ ptDist.setMinimum(*(geom.getCoordinate()), pt);
+void
+DistanceToPoint::computeDistance(const geom::LineString& line,
+ const CoordinateSequence* coordsRO = line.getCoordinatesRO();
+ const CoordinateSequence& coords = *coordsRO;
+ for (size_t i=0, n=coords.size()-1; i<n; ++i)
+ // NOT THREAD SAFE
+ tempSegment.setCoordinates(coords[i], coords[i + 1]);
+ // this is somewhat inefficient - could do better
+ Coordinate closestPt;
+ tempSegment.closestPoint(pt, closestPt);
+ ptDist.setMinimum(closestPt, pt);
+void
+DistanceToPoint::computeDistance(const geom::LineSegment& segment,
+ segment.closestPoint(pt, closestPt);
+void
+DistanceToPoint::computeDistance(const geom::Polygon& poly,
+ computeDistance(*(poly.getExteriorRing()), pt, ptDist);
+ for (size_t i=0, n=poly.getNumInteriorRing(); i<n; ++i)
+ computeDistance(*(poly.getInteriorRingN(i)), pt, ptDist);
+} // namespace geos.algorithm.distance
Property changes on: trunk/source/algorithm/distance/DistanceToPoint.cpp
___________________________________________________________________
Deleted: trunk/source/algorithm/distance/EuclideanDistanceToPoint.cpp
--- trunk/source/algorithm/distance/EuclideanDistanceToPoint.cpp 2009-04-15 12:56:08 UTC (rev 2372)
+++ trunk/source/algorithm/distance/EuclideanDistanceToPoint.cpp 2009-04-15 15:58:09 UTC (rev 2373)
@@ -1,119 +0,0 @@
- * $Id$
- * GEOS - Geometry Engine Open Source
- * http://geos.refractions.net
- * Copyright (C) 2009 Sandro Santilli <strk at keybit.net>
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
- * Last port: algorithm/distance/EuclideanDistanceToPoint.java 1.1 (JTS-1.9)
-#include <geos/algorithm/distance/EuclideanDistanceToPoint.h>
-#include <geos/algorithm/distance/PointPairDistance.h>
-#include <geos/geom/Coordinate.h>
-#include <geos/geom/CoordinateSequence.h>
-#include <geos/geom/LineSegment.h>
-#include <geos/geom/LineString.h>
-#include <geos/geom/Polygon.h>
-#include <geos/geom/GeometryCollection.h>
-#include <typeinfo> // for dynamic_cast
-#include <cassert>
-using namespace geos::geom;
-namespace geos {
-namespace algorithm { // geos.algorithm
-namespace distance { // geos.algorithm.distance
-/* static */
-LineSegment EuclideanDistanceToPoint::tempSegment;
-/* public static */
-void
-EuclideanDistanceToPoint::computeDistance(const geom::Geometry& geom,
- const geom::Coordinate& pt,
- PointPairDistance& ptDist)
- if ( const LineString* ls = dynamic_cast<const LineString*>(&geom) )
- computeDistance(*ls, pt, ptDist);
- else if ( const Polygon* pl = dynamic_cast<const Polygon*>(&geom) )
- computeDistance(*pl, pt, ptDist);
- else if ( const GeometryCollection* gc = dynamic_cast<const GeometryCollection*>(&geom) )
- for (size_t i = 0; i < gc->getNumGeometries(); i++)
- const Geometry* g = gc->getGeometryN(i);
- computeDistance(*g, pt, ptDist);
- else
- // assume geom is Point
- ptDist.setMinimum(*(geom.getCoordinate()), pt);
-void
-EuclideanDistanceToPoint::computeDistance(const geom::LineString& line,
- const CoordinateSequence* coordsRO = line.getCoordinatesRO();
- const CoordinateSequence& coords = *coordsRO;
- for (size_t i=0, n=coords.size()-1; i<n; ++i)
- // NOT THREAD SAFE
- tempSegment.setCoordinates(coords[i], coords[i + 1]);
- // this is somewhat inefficient - could do better
- Coordinate closestPt;
- tempSegment.closestPoint(pt, closestPt);
- ptDist.setMinimum(closestPt, pt);
-void
-EuclideanDistanceToPoint::computeDistance(const geom::LineSegment& segment,
- segment.closestPoint(pt, closestPt);
-void
-EuclideanDistanceToPoint::computeDistance(const geom::Polygon& poly,
- computeDistance(*(poly.getExteriorRing()), pt, ptDist);
- for (size_t i=0, n=poly.getNumInteriorRing(); i<n; ++i)
- computeDistance(*(poly.getInteriorRingN(i)), pt, ptDist);
-} // namespace geos.algorithm.distance
Modified: trunk/source/algorithm/distance/Makefile.am
--- trunk/source/algorithm/distance/Makefile.am 2009-04-15 12:56:08 UTC (rev 2372)
+++ trunk/source/algorithm/distance/Makefile.am 2009-04-15 15:58:09 UTC (rev 2373)
@@ -6,7 +6,7 @@
libdistance_la_SOURCES = \
DiscreteHausdorffDistance.cpp \
- EuclideanDistanceToPoint.cpp
+ DistanceToPoint.cpp
libdistance_la_LIBADD =
Modified: trunk/source/headers/geos/algorithm/distance/DiscreteHausdorffDistance.h
--- trunk/source/headers/geos/algorithm/distance/DiscreteHausdorffDistance.h 2009-04-15 12:56:08 UTC (rev 2372)
+++ trunk/source/headers/geos/algorithm/distance/DiscreteHausdorffDistance.h 2009-04-15 15:58:09 UTC (rev 2373)
@@ -13,7 +13,7 @@
@@ -21,7 +21,7 @@
#define GEOS_ALGORITHM_DISTANCE_DISCRETEHAUSDORFFDISTANCE_H
#include <geos/algorithm/distance/PointPairDistance.h> // for composition
-#include <geos/algorithm/distance/EuclideanDistanceToPoint.h> // for composition
+#include <geos/algorithm/distance/DistanceToPoint.h> // for composition
#include <geos/util/IllegalArgumentException.h> // for inlines
#include <geos/geom/Geometry.h> // for inlines
#include <geos/util/math.h> // for inlines
@@ -157,7 +157,7 @@
void filter_ro(const geom::Coordinate* pt)
- EuclideanDistanceToPoint::computeDistance(geom, *pt,
+ DistanceToPoint::computeDistance(geom, *pt,
minPtDist);
@@ -170,7 +170,7 @@
private:
PointPairDistance maxPtDist;
PointPairDistance minPtDist;
- EuclideanDistanceToPoint euclideanDist;
+ DistanceToPoint euclideanDist;
const geom::Geometry& geom;
Copied: trunk/source/headers/geos/algorithm/distance/DistanceToPoint.h (from rev 2361, trunk/source/headers/geos/algorithm/distance/EuclideanDistanceToPoint.h)
--- trunk/source/headers/geos/algorithm/distance/DistanceToPoint.h (rev 0)
+++ trunk/source/headers/geos/algorithm/distance/DistanceToPoint.h 2009-04-15 15:58:09 UTC (rev 2373)
@@ -0,0 +1,86 @@
+ * $Id$
+#ifndef GEOS_ALGORITHM_DISTANCE_DISTANCETOPOINT_H
+#define GEOS_ALGORITHM_DISTANCE_DISTANCETOPOINT_H
+#include <geos/geom/LineSegment.h> // for composition
+namespace geos {
+ namespace algorithm {
+ namespace distance {
+ class PointPairDistance;
+ namespace geom {
+ class Geometry;
+ class Coordinate;
+ class LineString;
+ class Polygon;
+namespace geos {
+namespace algorithm { // geos::algorithm
+namespace distance { // geos::algorithm::distance
+ * Computes the Euclidean distance (L2 metric) from a Point to a Geometry.
+ * Also computes two points which are separated by the distance.
+class DistanceToPoint
+public:
+ DistanceToPoint() {}
+ static void computeDistance(const geom::Geometry& geom,
+ PointPairDistance& ptDist);
+ static void computeDistance(const geom::LineString& geom,
+ static void computeDistance(const geom::LineSegment& geom,
+ static void computeDistance(const geom::Polygon& geom,
+private:
+ // used for point-line distance calculation
+ // NOT THREAD SAFE !!
+ static geom::LineSegment tempSegment;
+} // geos::algorithm::distance
+} // geos
+#endif // GEOS_ALGORITHM_DISTANCE_DISTANCETOPOINT_H
+ * $Log$
Property changes on: trunk/source/headers/geos/algorithm/distance/DistanceToPoint.h
Deleted: trunk/source/headers/geos/algorithm/distance/EuclideanDistanceToPoint.h
--- trunk/source/headers/geos/algorithm/distance/EuclideanDistanceToPoint.h 2009-04-15 12:56:08 UTC (rev 2372)
+++ trunk/source/headers/geos/algorithm/distance/EuclideanDistanceToPoint.h 2009-04-15 15:58:09 UTC (rev 2373)
@@ -1,86 +0,0 @@
- * $Id$
-#ifndef GEOS_ALGORITHM_DISTANCE_EUCLIDEANDISTANCETOPOINT_H
-#define GEOS_ALGORITHM_DISTANCE_EUCLIDEANDISTANCETOPOINT_H
-#include <geos/geom/LineSegment.h> // for composition
-namespace geos {
- namespace algorithm {
- namespace distance {
- class PointPairDistance;
- namespace geom {
- class Geometry;
- class Coordinate;
- class LineString;
- class Polygon;
-namespace geos {
-namespace algorithm { // geos::algorithm
-namespace distance { // geos::algorithm::distance
- * Computes the Euclidean distance (L2 metric) from a Point to a Geometry.
- * Also computes two points which are separated by the distance.
-class EuclideanDistanceToPoint
-public:
- EuclideanDistanceToPoint() {}
- static void computeDistance(const geom::Geometry& geom,
- PointPairDistance& ptDist);
- static void computeDistance(const geom::LineString& geom,
- static void computeDistance(const geom::LineSegment& geom,
- static void computeDistance(const geom::Polygon& geom,
-private:
- // used for point-line distance calculation
- // NOT THREAD SAFE !!
- static geom::LineSegment tempSegment;
-} // geos::algorithm::distance
-} // geos
-#endif // GEOS_ALGORITHM_DISTANCE_EUCLIDEANDISTANCETOPOINT_H
- * $Log$
Modified: trunk/source/headers/geos/algorithm/distance/Makefile.am
--- trunk/source/headers/geos/algorithm/distance/Makefile.am 2009-04-15 12:56:08 UTC (rev 2372)
+++ trunk/source/headers/geos/algorithm/distance/Makefile.am 2009-04-15 15:58:09 UTC (rev 2373)
@@ -12,5 +12,5 @@
noinst_HEADERS = \
DiscreteHausdorffDistance.h \
- EuclideanDistanceToPoint.h \
+ DistanceToPoint.h \
PointPairDistance.h
More information about the geos-commits
