[geos-commits] r2384 - trunk/tests/xmltester
    svn_geos at osgeo.org
    Fri Apr 17 11:47:07 EDT 2009
Author: strk
Date: 2009-04-17 11:47:07 -0400 (Fri, 17 Apr 2009)
New Revision: 2384
Added:
   trunk/tests/xmltester/BufferResultMatcher.cpp
   trunk/tests/xmltester/BufferResultMatcher.h
   trunk/tests/xmltester/XMLTester.cpp
Port BufferResultMatcher. Gives 31 new failures !!
Added: trunk/tests/xmltester/BufferResultMatcher.cpp
--- trunk/tests/xmltester/BufferResultMatcher.cpp	                        (rev 0)
+++ trunk/tests/xmltester/BufferResultMatcher.cpp	2009-04-17 15:47:07 UTC (rev 2384)
@@ -0,0 +1,125 @@
+ * $Id$
+ * GEOS - Geometry Engine Open Source
+ * http://geos.refractions.net
+ * Copyright (C) 2009  Sandro Santilli <strk at keybit.net>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+ * Last port: jtstest/testrunner/BufferResultMatcher.java rev rev 1.5 (JTS-1.10)
+#include "BufferResultMatcher.h"
+#include <geos/geom/Geometry.h>
+#include <geos/geom/BinaryOp.h>
+#include <geos/operation/overlay/OverlayOp.h>
+#include <geos/algorithm/distance/DiscreteHausdorffDistance.h>
+#include <cmath>
+namespace geos {
+namespace xmltester {
+double BufferResultMatcher::MAX_RELATIVE_AREA_DIFFERENCE = 1.0E-3;
+double BufferResultMatcher::MAX_HAUSDORFF_DISTANCE_FACTOR = 100;
+bool
+BufferResultMatcher::isBufferResultMatch(const geom::Geometry& actualBuffer,
+	                         const geom::Geometry& expectedBuffer,
+	                         double distance)
+	if (actualBuffer.isEmpty() && expectedBuffer.isEmpty())
+		return true;
+	 * MD - need some more checks here - symDiffArea won't catch
+	 * very small holes ("tears")
+	 * near the edge of computed buffers (which can happen
+	 * in current version of JTS (1.8)).
+	 * This can probably be handled by testing
+	 * that every point of the actual buffer is at least a certain
+	 * distance away from the geometry boundary.
+	if (! isSymDiffAreaInTolerance(actualBuffer, expectedBuffer))
+std::cerr << "isSymDiffAreaInTolerance failed" << std::endl;
+		return false;
+	if (! isBoundaryHausdorffDistanceInTolerance(actualBuffer,
+	           expectedBuffer, distance))
+std::cerr << "isBoundaryHasudorffDistanceInTolerance failed" << std::endl;
+		return false;
+	return true;
+bool
+BufferResultMatcher::isSymDiffAreaInTolerance(
+	const geom::Geometry& actualBuffer,
+	const geom::Geometry& expectedBuffer)
+	typedef std::auto_ptr<geom::Geometry> GeomPtr;
+	using namespace operation::overlay;
+	using geos::geom::BinaryOp;
+	double area = expectedBuffer.getArea();
+	GeomPtr diff = BinaryOp(&actualBuffer, &expectedBuffer,
+	                   overlayOp(OverlayOp::opSYMDIFFERENCE));
+	double areaDiff = diff->getArea();
+	// can't get closer than difference area = 0 !
+	// This also handles case when symDiff is empty
+	if (areaDiff <= 0.0) return true;
+	if (area <= 0) return false;
+	double frac = areaDiff / area;
+	bool ret = frac < MAX_RELATIVE_AREA_DIFFERENCE;
+	if ( ! ret )
+std::cerr << "symDiffArea frac: " << frac << " tolerated " << MAX_RELATIVE_AREA_DIFFERENCE << std::endl;
+	return ret;
+bool
+BufferResultMatcher::isBoundaryHausdorffDistanceInTolerance(
+	const geom::Geometry& expectedBuffer, double distance)
+	using geos::algorithm::distance::DiscreteHausdorffDistance;
+	GeomPtr actualBdy ( actualBuffer.getBoundary() );
+	GeomPtr expectedBdy ( expectedBuffer.getBoundary() );
+	DiscreteHausdorffDistance haus(*actualBdy, *expectedBdy);
+	haus.setDensifyFraction(0.25);
+	double maxDistanceFound = haus.orientedDistance();
+	double expectedDistanceTol = fabs(distance) / MAX_HAUSDORFF_DISTANCE_FACTOR;
+	if (maxDistanceFound > expectedDistanceTol)
+std::cerr << "maxDistanceFound: " << maxDistanceFound << " tolerated " << expectedDistanceTol << std::endl;
+		return false;
+	return true;
+} // namespace geos::xmltester
Added: trunk/tests/xmltester/BufferResultMatcher.h
--- trunk/tests/xmltester/BufferResultMatcher.h	                        (rev 0)
+++ trunk/tests/xmltester/BufferResultMatcher.h	2009-04-17 15:47:07 UTC (rev 2384)
@@ -0,0 +1,58 @@
+ * $Id$
+#ifndef XMLTESTER_BUFFERRESULTMATCHER_H
+#define XMLTESTER_BUFFERRESULTMATCHER_H
+// Forward declarations
+namespace geos {
+	namespace geom {
+		class Geometry;
+namespace geos {
+class BufferResultMatcher
+public:
+	bool isBufferResultMatch(const geom::Geometry& actualBuffer,
+	                         double distance);
+private:
+	static double MAX_RELATIVE_AREA_DIFFERENCE;
+	static double MAX_HAUSDORFF_DISTANCE_FACTOR;
+	bool isSymDiffAreaInTolerance(const geom::Geometry& actualBuffer,
+	                              const geom::Geometry& expectedBuffer);
+	bool isBoundaryHausdorffDistanceInTolerance(
+	                double distance);
+#endif // XMLTESTER_BUFFERRESULTMATCHER_H
Modified: trunk/tests/xmltester/XMLTester.cpp
--- trunk/tests/xmltester/XMLTester.cpp	2009-04-17 15:37:32 UTC (rev 2383)
+++ trunk/tests/xmltester/XMLTester.cpp	2009-04-17 15:47:07 UTC (rev 2384)
@@ -46,6 +46,7 @@
 #include <geos/unload.h>
 #include <geos/opValid.h>
 #include "XMLTester.h"
 #include <cassert>
 #include <cctype>
@@ -724,6 +725,17 @@
 			success=1;
 			do
+#if USE_BUFFER_RESULT_MATCHER
+				geos::xmltester::BufferResultMatcher matcher;
+				if ( ! matcher.isBufferResultMatch(*gRealRes,
+				                                   *gRes,
+					                           dist) )
+					success=0;
+					break;
+#endif
 				// TODO: Is a buffer always an area ?
 				// 	 we might check geometry type..
More information about the geos-commits
