[geos-commits] r2388 - in trunk/tests/unit: . algorithm algorithm/distance
svn_geos at osgeo.org svn_geos at osgeo.org
Fri Apr 17 12:49:25 EDT 2009
Author: strk
Date: 2009-04-17 12:49:25 -0400 (Fri, 17 Apr 2009)
New Revision: 2388
Added:
   trunk/tests/unit/algorithm/distance/
   trunk/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp
   trunk/tests/unit/Makefile.am
Port DiscreteHausdorffDistance unit test
Modified: trunk/tests/unit/Makefile.am
--- trunk/tests/unit/Makefile.am	2009-04-17 16:47:06 UTC (rev 2387)
+++ trunk/tests/unit/Makefile.am	2009-04-17 16:49:25 UTC (rev 2388)
@@ -33,6 +33,7 @@
 	algorithm/CGAlgorithms/isPointInRingTest.cpp \
 	algorithm/CGAlgorithms/computeOrientationTest.cpp \
 	algorithm/ConvexHullTest.cpp \
+	algorithm/distance/DiscreteHausdorffDistanceTest.cpp \
 	algorithm/PointLocatorTest.cpp \
 	algorithm/RobustLineIntersectionTest.cpp \
 	algorithm/RobustLineIntersectorTest.cpp \
Added: trunk/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp
--- trunk/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp	                        (rev 0)
+++ trunk/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp	2009-04-17 16:49:25 UTC (rev 2388)
@@ -0,0 +1,131 @@
+// $Id$
+// Test Suite for geos::algorithm::distance::DiscreteHausdorffDistance
+// Ported from JTS junit/algorithm/distance/DiscreteHausdorffDistanceTest.java rev. 1.2
+#include <tut.hpp>
+// geos
+#include <geos/io/WKTReader.h>
+#include <geos/algorithm/distance/DiscreteHausdorffDistance.h>
+#include <geos/geom/PrecisionModel.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/Geometry.h> // required for use in auto_ptr
+#include <geos/geom/Coordinate.h>
+// std
+#include <sstream>
+#include <string>
+#include <memory>
+namespace geos {
+	namespace geom {
+		class Geometry;
+using namespace geos::geom;
+using namespace geos::algorithm::distance; // for Location
+namespace tut
+	// Test Group
+	// Test data, not used
+	struct test_DiscreteHausdorffDistance_data {
+	typedef std::auto_ptr<Geometry> GeomPtr;
+	test_DiscreteHausdorffDistance_data()
+		pm(),
+		gf(&pm),
+		reader(&gf)
+	static const double TOLERANCE;
+	void runTest(const std::string& wkt1, const std::string& wkt2,
+	             double expectedDistance)
+		GeomPtr g1 ( reader.read(wkt1) );
+		GeomPtr g2 ( reader.read(wkt2) );
+		double distance = DiscreteHausdorffDistance::distance(*g1, *g2);
+		double diff = fabs(distance-expectedDistance);
+		std::cerr << "expectedDistance:" << expectedDistance << " actual distance:" << distance << std::endl;
+		ensure( diff <= TOLERANCE );
+	             double densifyFactor, double expectedDistance)
+			*g2, densifyFactor);
+	PrecisionModel pm;
+	GeometryFactory gf;
+        geos::io::WKTReader reader;
+	const double test_DiscreteHausdorffDistance_data::TOLERANCE = 0.00001;
+	typedef test_group<test_DiscreteHausdorffDistance_data> group;
+	typedef group::object object;
+	group test_DiscreteHausdorffDistance_group("geos::algorithm::distace::DiscreteHausdorffDistance");
+	// Test Cases
+	// 1 - testLineSegments
+	template<>
+	template<>
+	void object::test<1>()
+runTest("LINESTRING (0 0, 2 1)", "LINESTRING (0 0, 2 0)", 1.0);
+	// 2 - testLineSegments2
+	template<>
+	template<>
+	void object::test<2>()
+runTest("LINESTRING (0 0, 2 0)", "LINESTRING (0 1, 1 2, 2 1)", 2.0);
+	// 3 - testLinePoints
+	template<>
+	template<>
+	void object::test<3>()
+runTest("LINESTRING (0 0, 2 0)", "MULTIPOINT (0 1, 1 0, 2 1)", 1.0);
+	// 4 - testLinesShowingDiscretenessEffect
+	// Shows effects of limiting HD to vertices
+	// Answer is not true Hausdorff distance.
+	template<>
+	template<>
+	void object::test<4>()
+runTest("LINESTRING (130 0, 0 0, 0 150)", "LINESTRING (10 10, 10 150, 130 10)", 14.142135623730951);
+// densifying provides accurate HD
+runTest("LINESTRING (130 0, 0 0, 0 150)", "LINESTRING (10 10, 10 150, 130 10)", 0.5, 70.0);
+} // namespace tut
More information about the geos-commits mailing list
