[geos-commits] r2391 - trunk/tests/xmltester/tests
svn_geos at osgeo.org svn_geos at osgeo.org
Sat Apr 18 03:49:38 EDT 2009
Author: strk
Date: 2009-04-18 03:49:38 -0400 (Sat, 18 Apr 2009)
New Revision: 2391
Added:
   trunk/tests/xmltester/tests/TestBigNastyBuffer.xml
Imported cleaned-up version of fme.xml -- this one fails (the one we have is actually expecting a wrong result)
Added: trunk/tests/xmltester/tests/TestBigNastyBuffer.xml
--- trunk/tests/xmltester/tests/TestBigNastyBuffer.xml	                        (rev 0)
+++ trunk/tests/xmltester/tests/TestBigNastyBuffer.xml	2009-04-18 07:49:38 UTC (rev 2391)
@@ -0,0 +1,27 @@
+<run>
+  <desc>
+ Test case provided by Dale Lutz (dale dot lutz at safe dot com).
+ Written permission to use the data for tests has been given
+ by email on the 22 Dec 2006.
+  </desc>
+  <precisionModel type='FLOATING'/>
+  <resultMatcher>com.vividsolutions.jtstest.testrunner.BufferResultMatcher</resultMatcher>
+<case>
+  <desc>
+  	Big Bad Nasty buffer
+  	Note: the expected result has been cleaned up manually from what is returned by JTS 1.10,
+  	since there are visually determined problems with the actual computed value (i.e a small hole).
+  </desc>
+  <a>
+ POLYGON((377888.21875 5686717.5,377888.09375 5686717.5,377886.46875 5686721,377885.25 5686725,377884.40625 5686730.5,377883.59375 5686735,377883.5625 5686737,377883.5 5686743.5,377883.09375 5686747,377883.03125 5686752.5,377883 5686758,377883.75 5686762,377884.46875 5686767.5,377885.25 5686771.5,377885.21875 5686775,377887.53125 5686781,377891.8125 5686788,377895.4375 5686792,377896.5 5686793,377900.03125 5686797,377905.5 5686802.5,377908.65625 5686804.5,377911.40625 5686807.5,377915.34375 5686809,377918.6875 5686810.5,377920.90625 5686806.5,377923.3125 5686801,377926.09375 5686797.5,377928.21875 5686794.5,377928.90625 5686793.5,377932.09375 5686790.5,377935.6875 5686786,377939.28125 5686782,377944.46875 5686776,377948.0625 5686773,377953.625 5686769,377958.8125 5686765.5,377962.75 5686763.5,377964.0625 5686763,377964.59375 5686762,377965.0625 5686761,377965.5625 5686760,377965.625 5686759,377965.65625 5686759,377966.125 5686758,377967.03125 5686757,377967.46875 5686756.5,377968.46875 5686754.5,377969.71875 5686753.5,377970.625 5686752.5,377971.125 5686751.5,377971.53125 5686751.5,377971.5625 5686751,377973.125 5686751,377975.6875 5686749.5,377978.15625 5686748.5,377978.9375 5686748.5,377979.75 5686748.5,377980.15625 5686748.5,377980.96875 5686748,377981.75 5686748,377982.96875 5686748,377984.15625 5686748,377986.625 5686747,377989 5686747,377990.1875 5686747,377990.96875 5686747,377991.84375 5686746.5,377992.25 5686746,377993.03125 5686746,377993.84375 5686746,377994.65625 5686746,377995.4375 5686746,377996.625 5686746,377997.40625 5686746,377998.59375 5686746.5,377999.375 5686746.5,378000.9375 5686746.5,378001.71875 5686746.5,378002.90625 5686746.5,378003.6875 5686747,378004.46875 5686747,378004.875 5686747,378005.71875 5686746,378006.125 5686746,378007.40625 5686745,378008.21875 5686745,378009.03125 5686745,378009.09375 5686744,378010.375 5686743,378012.40625 5686742.5,378013.6875 5686742,378014.53125 5686741,378015.3125 5686741,378015.34375 5686741,378016.1875 5686740.5,378017.59375 5686738.5,378018.0625 5686737.5,378018.125 5686736.5,378018.59375 5686736,378018.78125 5686734,378018.90625 5686733,378019.03125 5686731,378019.1875 5686729.5,378019.28125 5686729,378019.34375 5686728,378019.40625 5686727.5,378019.5 5686726.5,378019.6875 5686724.5,378020.9375 5686724,378021.40625 5686723,378021.5 5686722,378021.5625 5686721.5,378021.6875 5686720,378021.78125 5686719,378022.5625 5686719.5,378022.625 5686718.5,378022.71875 5686717.5,378022.84375 5686716,378023.3125 5686715.5,378023.4375 5686714,378023.5 5686713.5,378023.65625 5686712,378024.53125 5686711,378025.4375 5686710,378025.46875 5686709.5,378025.96875 5686708.5,378026.78125 5686708,378027.71875 5686706.5,378028.9375 5686706.5,378029.40625 5686705.5,378030.28125 5686705,378031.09375 5686704.5,378031.5625 5686704,378032.84375 5686703,378034.0625 5686702.5,378034.96875 5686701.5,378035.8125 5686701,378036.25 5686700.5,378036.6875 5686700,378037.53125 5686699.5,378037.9375 5686699.5,378038.78125 5686698.5,378039.1875 5686698.5,378040.0625 5686698,378040.875 5686697.5,378042.125 5686697,378042.5625 5686696.5,378043.78125 5686696.5,378044.5625 5686696.5,378045.34375 5686696.5,378046.125 5686696.5,378047.40625 5686695.5,378049.03125 5686695.5,378049.84375 5686695,378050.65625 5686694.5,378051.5 5686694.5,378052.3125 5686694,378053.59375 5686693,378054.8125 5686692.5,378055.59375 5686693,378055.6875 5686692,378056.15625 5686691.5,378057.78125 5686690.5,378059 5686690.5,378059.84375 5686690,378060.25 5686689.5,378060.65625 5686690,378061.4375 5686690,378061.84375 5686690,378062.6875 5686689,378063.46875 5686689.5,378064.65625 5686689.5,378065.0625 5686689.5,378066.28125 5686689,378067.0625 5686689,378067.84375 5686689.5,378069.40625 5686689.5,378070.96875 5686689.5,378071.375 5686689.5,378071.78125 5686689.5,378072.5625 5686690,378073.34375 5686690,378074.40625 5686691,378075.5 5686692,378076.25 5686692.5,378076.96875 5686693.5,378077.6875 5686694.5,378078.4375 5686694.5,378079.15625 5686695,378079.125 5686695.5,378079.53125 5686695.5,378079.4375 5686696.5,378080.4375 5686698.5,378080.71875 5686699.5,378080.5625 5686701.5,378081.21875 5686703,378081.0625 5686704.5,378080.9375 5686705.5,378080.84375 5686707,378081.5 5686708,378082.1875 5686709.5,378082.90625 5686710.5,378083.21875 5686711,378083.125 5686712,378083.5 5686712.5,378083.40625 5686713,378084.59375 5686713,378085.6875 5686714,378086.4375 5686714.5,378088.8125 5686715,378091.46875 5686716,378093.78125 5686716.5,378094.59375 5686716.5,378095.28125 5686717.5,378095.6875 5686717.5,378096.0625 5686717.5,378096.875 5686717.5,378097.65625 5686717.5,378098.8125 5686718,378100.1875 5686716,378102.3125 5686714.5,378102.78125 5686714,378102.84375 5686713,378104.03125 5686713,378105.34375 5686712,378107.4375 5686711,378108.65625 5686710.5,378109.0625 5686710,378109.875 5686710,378110.65625 5686710.5,378111.90625 5686709.5,378113.0625 5686710,378115.125 5686709,378116.6875 5686709.5,378117.53125 5686708.5,378117.96875 5686708.5,378118.8125 5686708,378119.28125 5686707,378120.1875 5686705.5,378121.46875 5686705,378122.34375 5686704,378122.84375 5686703,378123.71875 5686702,378124.15625 5686701.5,378125.09375 5686700,378125.5 5686700,378127.28125 5686698,378128.96875 5686697,378129.8125 5686696.5,378130.6875 5686695.5,378131.46875 5686695.5,378132.28125 5686695.5,378133.0625 5686695.5,378134.625 5686695.5,378135.8125 5686696,378137.78125 5686696,378139.34375 5686696,378140.1875 5686696,378140.96875 5686696,378141.0625 5686694.5,378142.3125 5686694,378142.84375 5686693,378144.09375 5686692,378144.9375 5686691.5,378145.84375 5686690.5,378146.28125 5686690,378147.125 5686689.5,378147.96875 5686689,378149.1875 5686689,378150.8125 5686688,378152.4375 5686688,378153.59375 5686688,378154 5686688,378155.1875 5686688,378155.96875 5686688.5,378156.34375 5686688.5,378156.75 5686688.5,378156.84375 5686687,378156.15625 5686686.5,378155.90625 5686684.5,378155.1875 5686684,378155.28125 5686683,378154.46875 5686683,378153.5 5686681,378152.0625 5686679,378151.71875 5686678.5,378151.75 5686678.5,378150.96875 5686678,378150.625 5686678,378149.5 5686677,378148.375 5686676.5,378148.09375 5686675,378146.9375 5686674.5,378146.5625 5686674.5,378146.625 5686674,378146.65625 5686673.5,378145.875 5686673.5,378146.0625 5686671.5,378145.4375 5686669.5,378145.125 5686669,378145.1875 5686668,378145.28125 5686667.5,378145.34375 5686666.5,378145.375 5686666,378145.53125 5686664.5,378146.375 5686664,378146.9375 5686662.5,378147.03125 5686661,378147.90625 5686660.5,378147.96875 5686659.5,378148.46875 5686658.5,378149.34375 5686658,378149.8125 5686657,378149.84375 5686656.5,378149.875 5686656.5,378150.65625 5686656.5,378151.53125 5686655.5,378152.3125 5686655.5,378153.09375 5686656,378154 5686654.5,378155.65625 5686654,378156.46875 5686654,378157.34375 5686653,378158.15625 5686652.5,378158.59375 5686652.5,378159.84375 5686651.5,378161.0625 5686651.5,378161.875 5686651,378162.75 5686650.5,378163.5625 5686650,378164.40625 5686649.5,378165.65625 5686648.5,378167.28125 5686648.5,378168.53125 5686648,378169.40625 5686647,378169.78125 5686647,378169.875 5686646.5,378170.65625 5686646.5,378171.0625 5686646,378171.15625 5686645.5,378171.96875 5686645,378172.15625 5686643,378172.28125 5686642,378172.375 5686640.5,378172.84375 5686640,378172.96875 5686638.5,378173.4375 5686638,378173.9375 5686637,378174 5686636,378174.9375 5686634.5,378175.03125 5686634,378175.0625 5686633.5,378175.09375 5686633,378176 5686632,378176.03125 5686631.5,378176.1875 5686630,378176.25 5686629,378176.34375 5686628.5,378176.375 5686628,378176.59375 5686628,378182.875 5686630.5,378186.8125 5686632,378193.09375 5686633.5,378194.34375 5686630,378194.78125 5686625.5,378194.46875 5686618,378193.6875 5686614,378192.96875 5686607.5,378192.21875 5686604,378191.0625 5686599.5,378189.9375 5686593.5,378188.78125 5686588,378187.6875 5686580,378187.71875 5686575.5,378187.71875 5686574,378187.75 5686571,378186.59375 5686567.5,378186.65625 5686563,378187.5 5686557,378188.3125 5686553.5,378189.90625 5686550.5,378192.3125 5686546.5,378195.125 5686543,378196.5 5686541.5,378196.6875 5686539.5,378197.625 5686538,378198.09375 5686537,378198.21875 5686536,378198.25 5686535.5,378198.71875 5686535,378198.8125 5686533.5,378198.90625 5686533,378199.6875 5686533,378199.84375 5686531.5,378201.5625 5686530,378202.8125 5686529.5,378203.3125 5686528,378203.6875 5686528,378203.78125 5686527.5,378204.15625 5686527.5,378205.03125 5686526.5,378206.21875 5686527,378206.71875 5686525.5,378207.5625 5686525,378208 5686524.5,378208.46875 5686524,378209.4375 5686522,378211.09375 5686521.5,378212.40625 5686520,378213.71875 5686519,378214.5625 5686518,378215.03125 5686517.5,378215.875 5686517,378216.28125 5686517,378217.15625 5686516,378217.59375 5686515.5,378218.4375 5686515,378219.65625 5686514.5,378220.46875 5686514.5,378220.5625 5686513.5,378221.375 5686513.5,378221.78125 5686513.5,378222.59375 5686513,378223.09375 5686512,378223.90625 5686511.5,378225.28125 5686509.5,378226.96875 5686508.5,378227.84375 5686508,378228.25 5686507.5,378228.71875 5686507,378228.75 5686506.5,378229.21875 5686505.5,378230.09375 5686505,378230.125 5686504.5,378231.0625 5686503,378231.9375 5686502.5,378232.4375 5686501.5,378233.34375 5686500,378234.21875 5686499,378235.09375 5686498.5,378235.9375 5686497.5,378236.40625 5686497,378237.3125 5686496,378237.8125 5686494.5,378238.71875 5686493.5,378239.21875 5686492.5,378240.125 5686491.5,378241.0625 5686490,378241.5625 5686488.5,378242.46875 5686487.5,378242.875 5686487.5,378243.34375 5686486.5,378243.8125 5686486,378244.65625 5686485.5,378245.53125 5686484.5,378246.78125 5686483.5,378247.3125 5686482.5,378247.84375 5686481,378248.3125 5686480.5,378248.4375 5686479,378248.5 5686478.5,378248.96875 5686477.5,378249.8125 5686477,378249.90625 5686476,378250.09375 5686474,378251 5686473,378251.53125 5686471.5,378251.65625 5686470.5,378251.75 5686469,378252.21875 5686468.5,378252.71875 5686467,378252.75 5686467,378252.84375 5686466,378253.09375 5686463.5,378254.4375 5686462,378255.3125 5686460.5,378255.4375 5686459.5,378255.5 5686458.5,378255.90625 5686459,378257 5686455.5,378258.40625 5686453.5,378258.5 5686452.5,378259.0625 5686450.5,378259.125 5686450,378260.78125 5686447,378262.78125 5686443.5,378265.59375 5686439,378266.9375 5686437,378269.1875 5686434,378270.28125 5686433,378270.625 5686432.5,378271.15625 5686432,378271.34375 5686429.5,378272.28125 5686428,378272.75 5686427.5,378272.84375 5686426.5,378272.875 5686426.5,378273.25 5686426.5,378274.15625 5686425.5,378274.25 5686424.5,378274.375 5686423,378275.71875 5686421.5,378276.625 5686420.5,378276.71875 5686419,378277.15625 5686419,378277.21875 5686418,378278 5686418,378278.5625 5686416.5,378279.5 5686415,378279.5625 5686414.5,378279.65625 5686413.5,378280.15625 5686412.5,378280.5625 5686412,378281.5 5686410.5,378282.375 5686410,378282.40625 5686409.5,378282.4375 5686409,378282.96875 5686408,378284.21875 5686407,378284.75 5686405.5,378284.78125 5686405.5,378284.8125 5686405,378285.25 5686404.5,378286.0625 5686404,378286.46875 5686404,378287 5686402.5,378288.6875 5686401.5,378289.125 5686401.5,378290 5686400.5,378290.375 5686400.5,378291.1875 5686400.5,378292 5686400.5,378293.15625 5686400.5,378293.9375 5686400.5,378295.53125 5686401,378295.90625 5686401,378296.6875 5686401,378297.09375 5686401,378298.15625 5686402.5,378299.3125 5686403,378299.96875 5686404,378301.03125 5686405.5,378302.09375 5686406.5,378302.78125 5686408,378303.53125 5686408.5,378303.84375 5686409,378304.15625 5686410,378304.09375 5686411,378304.84375 5686411.5,378305.625 5686411.5,378306.6875 5686412.5,378307.03125 5686413,378308.15625 5686414,378309.28125 5686414.5,378309.96875 5686416,378310.65625 5686416.5,378311.375 5686417.5,378312.09375 5686418.5,378313.21875 5686419,378313.1875 5686419.5,378313.9375 5686419.5,378314.34375 5686420,378315.40625 5686421,378316.9375 5686421.5,378319.9375 5686423.5,378322.21875 5686424.5,378323.3125 5686425.5,378324.03125 5686426.5,378325.15625 5686427,378325.53125 5686427.5,378326.3125 5686427.5,378326.625 5686428,378327.75 5686428.5,378328.15625 5686428.5,378329.25 5686429.5,378330.03125 5686429.5,378331.09375 5686431,378332.65625 5686431.5,378333.71875 5686433,378334.375 5686434,378335.4375 5686435.5,378336.15625 5686436.5,378337.25 5686437,378337.9375 5686438.5,378338.65625 5686439.5,378339.34375 5686440,378340.09375 5686440.5,378340.46875 5686441,378341.15625 5686442,378342.3125 5686442.5,378343.8125 5686443.5,378344.90625 5686444.5,378345.25 5686445,378345.21875 5686445,378345.96875 5686445.5,378346.75 5686445.5,378348.1875 5686447.5,378350.09375 5686448,378350.8125 5686449,378351.5625 5686449.5,378352.34375 5686449.5,378353.0625 5686450.5,378353.46875 5686450.5,378354.5625 5686451.5,378354.90625 5686451.5,378355.625 5686452.5,378356.375 5686453,378357.84375 5686454.5,378359.375 5686455,378360.46875 5686456,378361.1875 5686456.5,378362.28125 5686457.5,378363 5686458.5,378364.125 5686459,378364.5 5686459.5,378365.5625 5686460.5,378366.3125 5686461,378367.09375 5686461.5,378367 5686462,378368.59375 5686462,378370.46875 5686463,378372.4375 5686463.5,378373.21875 5686463.5,378374.375 5686464,378375.9375 5686464,378378.6875 5686464.5,378379.84375 5686464.5,378380.65625 5686464.5,378381.4375 5686464.5,378381.8125 5686465,378382.25 5686464.5,378384.25 5686464,378385.5 5686463.5,378386.6875 5686463.5,378387.875 5686464,378387.90625 5686463.5,378388.71875 5686463,378389.5 5686463,378391.15625 5686462.5,378393.125 5686462.5,378394.375 5686462,378395.1875 5686461.5,378395.625 5686461.5,378395.65625 5686461,378396.4375 5686461,378396.59375 5686459.5,378397.40625 5686459,378398.3125 5686458,378398.40625 5686457.5,378399.28125 5686456,378399.75 5686455.5,378399.90625 5686454,378400.03125 5686452.5,378400.09375 5686452,378400.21875 5686450.5,378400.34375 5686449,378400.46875 5686448,378400.59375 5686447,378400.71875 5686445,378401.1875 5686444.5,378401.3125 5686443.5,378401.4375 5686442,378401.5 5686441.5,378401.625 5686440,378401.6875 5686439.5,378401.75 5686438.5,378401.5625 5686436.5,378401.71875 5686435,378401.8125 5686434,378402.09375 5686431,378402.21875 5686429.5,378402.40625 5686427.5,378402.65625 5686425,378402.78125 5686423.5,378402.9375 5686422,378403.0625 5686421,378403.15625 5686419.5,378402.84375 5686419,378402.65625 5686417,378402.78125 5686415,378402.9375 5686413.5,378403.03125 5686413,378402.6875 5686412,378402.78125 5686411,378402.84375 5686410.5,378402.96875 5686409.5,378403.03125 5686408.5,378402 5686407,378402.125 5686405.5,378402.1875 5686405,378401.875 5686404,378401.5625 5686403,378400.875 5686402,378401.0625 5686400,378400.03125 5686398.5,378399.4375 5686396,378398.84375 5686394,378398.5625 5686393,378398.6875 5686392,378397.96875 5686391,378398.09375 5686389.5,378398.15625 5686389,378397.84375 5686388,378397.59375 5686386.5,378396.9375 5686385,378397.125 5686383.5,378397.34375 5686381,378397.0625 5686379.5,378396.8125 5686378,378396.5 5686377,378396.53125 5686377,378396.65625 5686375.5,378396.71875 5686375,378396.9375 5686372.5,378396.6875 5686371,378396.96875 5686368,378398.3125 5686366.5,378398.75 5686366,378398.84375 5686365,378398.90625 5686364.5,378400.90625 5686364,378401.8125 5686363,378402.625 5686363,378403.4375 5686362.5,378403.5 5686362,378403.59375 5686361,378404.8125 5686360.5,378405.59375 5686360.5,378406.46875 5686360,378408.09375 5686359.5,378409.03125 5686358,378410.3125 5686357,378411.09375 5686357,378411.15625 5686356.5,378411.96875 5686356,378412.78125 5686356,378414.0625 5686355,378415.6875 5686354.5,378416.53125 5686354,378416.5625 5686354,378416.96875 5686354,378417.75 5686354,378419 5686353.5,378420.21875 5686353,378420.59375 5686353,378421.375 5686353,378422.5625 5686353,378424.59375 5686352.5,378425.8125 5686352.5,378426.59375 5686352.5,378426.65625 5686352,378429 5686352.5,378430.40625 5686351.5,378430.6875 5686351.5,378432.28125 5686351,378433.0625 5686351,378433.46875 5686351,378434.25 5686351,378434.65625 5686351.5,378436.21875 5686351.5,378437.40625 5686351.5,378438.1875 5686351.5,378438.5625 5686351.5,378440.15625 5686352,378441.3125 5686352,378442.0625 5686352.5,378442.46875 5686352.5,378443.65625 5686352.5,378444.8125 5686352.5,378446 5686353,378446.40625 5686353,378447.1875 5686353,378447.96875 5686353,378448.8125 5686352.5,378451.21875 5686352,378452.5 5686351,378453.375 5686350.5,378453.75 5686350.5,378453.84375 5686349.5,378454.625 5686349.5,378454.71875 5686348.5,378455.59375 5686348,378456.5 5686346.5,378456.96875 5686346,378457.0625 5686345,378457.15625 5686344,378457.25 5686343,378457.34375 5686342,378457.59375 5686339.5,378458.125 5686338,378458.3125 5686336,378458.5625 5686333.5,378458.625 5686332.5,378458.75 5686331.5,378458.84375 5686330.5,378458.875 5686330,378459.03125 5686328.5,378458.6875 5686328,378457.625 5686326.5,378457.65625 5686326,378457.25 5686326,378456.6875 5686323.5,378452.53125 5686321.5,378451.09375 5686320,378450.4375 5686318.5,378449.65625 5686318.5,378448.9375 5686318,378448.59375 5686317.5,378447.90625 5686316,378446.8125 5686315,378446.15625 5686313.5,378445.53125 5686312,378445.28125 5686310,378445.4375 5686308.5,378445.5625 5686307.5,378445.25 5686306.5,378445.3125 5686306,378445.375 5686305,378445.625 5686302.5,378445.71875 5686301.5,378445.875 5686300,378446.03125 5686298.5,378446.09375 5686297.5,378446.1875 5686297,378446.28125 5686295.5,378446.3125 5686295,378447.1875 5686294.5,378447.21875 5686294,378447.625 5686294,378448 5686294,378448.09375 5686293.5,378448.125 5686293,378448.15625 5686292.5,378450.5 5686293,378451.8125 5686292,378452.28125 5686291,378452.6875 5686290.5,378452.75 5686290.5,378453.53125 5686290.5,378454.09375 5686288.5,378456.1875 5686287.5,378456.71875 5686286,378457.65625 5686284.5,378457.6875 5686284,378458.125 5686283.5,378458.53125 5686284,378459.3125 5686284,378460.59375 5686283,378462.28125 5686282,378463.0625 5686282,378463.125 5686281,378464.03125 5686280,378464.84375 5686279.5,378466.625 5686278,378467.875 5686277,378468.71875 5686276.5,378469.1875 5686275.5,378469.625 5686275.5,378470.0625 5686275,378470.90625 5686274.5,378471.75 5686274,378473.0625 5686272.5,378474.3125 5686272,378474.78125 5686271,378475.65625 5686270.5,378476.5 5686269.5,378477.40625 5686268.5,378477.84375 5686268,378478.6875 5686267.5,378480 5686266.5,378481.25 5686266,378481.75 5686265.5,378482.0625 5686265.5,378482.5 5686265,378483.4375 5686263.5,378485.875 5686263,378487.59375 5686261.5,378489.34375 5686260,378490.1875 5686259,378491.09375 5686258,378491.96875 5686257.5,378492.375 5686257,378493.25 5686256.5,378493.6875 5686256,378494.5625 5686255,378496.21875 5686254,378497.5625 5686252.5,378498.875 5686251.5,378499.75 5686250.5,378500.625 5686249.5,378501.0625 5686249,378501.9375 5686248.5,378502.78125 5686247.5,378503.21875 5686247.5,378504.0625 5686246.5,378504.90625 5686246.5,378505.8125 5686245,378506.625 5686245,378507.46875 5686244,378507.9375 5686243.5,378508.5 5686242,378510.125 5686241.5,378511.4375 5686240,378511.9375 5686239,378512.78125 5686238.5,378513.65625 5686237.5,378514.90625 5686237,378515.8125 5686236,378516.65625 5686235,378517.90625 5686234.5,378518.75 5686234,378519.59375 5686233.5,378520 5686233.5,378520.78125 5686233.5,378521.625 5686233,378522.5 5686232,378524.15625 5686231.5,378525.75 5686231.5,378526.65625 5686230.5,378527.90625 5686229.5,378528.71875 5686229.5,378529.59375 5686228.5,378530.8125 5686228.5,378531.625 5686228,378532.875 5686227.5,378534.09375 5686227,378534.875 5686227,378535.75 5686226.5,378536.5625 5686226,378537.46875 5686225,378539.0625 5686225,378539.9375 5686224,378539.96875 5686223.5,378540.78125 5686223.5,378541.6875 5686222,378542.5625 5686221.5,378543.84375 5686220.5,378545.0625 5686220,378546.34375 5686219,378547.21875 5686218.5,378548.0625 5686217.5,378548.9375 5686217,378549.78125 5686216.5,378550.21875 5686216,378551.0625 5686215,378551.90625 5686215,378552.71875 5686214.5,378553.59375 5686214,378554.4375 5686213,378556.0625 5686213,378557.3125 5686212.5,378558.15625 5686211.5,378559.375 5686211.5,378559.8125 5686211,378560.59375 5686211,378560.6875 5686210.5,378561.46875 5686210.5,378561.5 5686210,378561.6875 5686208,378563.84375 5686206,378564.90625 5686203,378566 5686200,378566.5 5686199,378567 5686198,378567.46875 5686197,378567.5625 5686196.5,378567.59375 5686196,378567.65625 5686195,378568.0625 5686195,378569.0625 5686193,378570.03125 5686191,378570.9375 5686190,378571.40625 5686189,378571.875 5686188.5,378572.3125 5686188,378572.8125 5686187,378573.6875 5686186,378575.40625 5686184.5,378577.0625 5686183.5,378578.375 5686182.5,378578.875 5686181.5,378579.6875 5686181,378579.78125 5686180.5,378580.25 5686179.5,378580.375 5686178,378581.21875 5686178,378582.53125 5686176.5,378583.4375 5686175,378583.90625 5686174.5,378584.8125 5686173.5,378585.28125 5686172.5,378585.34375 5686172,378586.3125 5686170,378587.21875 5686169,378588.0625 5686168,378588.59375 5686167,378589.03125 5686166,378589.5 5686165.5,378590.40625 5686164.5,378591.65625 5686163.5,378592.09375 5686163.5,378592.15625 5686162.5,378593 5686162.5,378593.0625 5686161.5,378593.09375 5686161,378593.53125 5686160.5,378593.96875 5686160,378598.0625 5686158,378601.25 5686156.5,378604.40625 5686156.5,378609.15625 5686154,378615.125 5686151.5,378618.28125 5686151.5,378622.65625 5686149.5,378625.84375 5686146,378628.21875 5686143.5,378628.25 5686140,378628.25 5686139.5,378629.46875 5686136,378630.3125 5686132,378631.90625 5686129,378635.53125 5686123.5,378640.65625 5686123,378645 5686122.5,378649.5 5686122,378649.5625 5686122,378650.40625 5686121.5,378651.3125 5686120,378651.84375 5686119,378651.875 5686118.5,378652.6875 5686118,378653.1875 5686117,378654.84375 5686116.5,378655.75 5686115.5,378656.25 5686114,378657.09375 5686113.5,378657.5625 5686113,378658.4375 5686112,378658.90625 5686111.5,378659.8125 5686110,378659.84375 5686110,378660.8125 5686108,378661.65625 5686107,378662.1875 5686106,378662.25 5686105.5,378663.0625 5686105,378663.15625 5686104,378663.25 5686103,378664.5625 5686102,378665.4375 5686101,378665.53125 5686100,378665.59375 5686099.5,378666.0625 5686098.5,378666.65625 5686096.5,378666.71875 5686096,378666.78125 5686095,378666.84375 5686094.5,378666.90625 5686094,378667.15625 5686091,378667.28125 5686090,378667.34375 5686089,378667.40625 5686088.5,378667.46875 5686088,378667.65625 5686086,378666.59375 5686084.5,378665.96875 5686083,378665.28125 5686082,378664.96875 5686081,378665.03125 5686080,378663.875 5686080,378662.59375 5686076.5,378660.5 5686073.5,378659.78125 5686073,378659.46875 5686072,378659.0625 5686072,378659.15625 5686071,378658.375 5686071,378658.4375 5686070.5,378656.9375 5686069.5,378656.21875 5686068.5,378654.84375 5686066.5,378654.1875 5686065,378653.90625 5686064,378653.53125 5686063.5,378653.5625 5686063,378652.90625 5686062,378652.96875 5686061,378652.34375 5686059.5,378651.625 5686058.5,378651.375 5686057,378651.53125 5686055.5,378651.5625 5686055,378651.625 5686054.5,378651.71875 5686053.5,378651.75 5686053,378651.84375 5686052,378651.90625 5686051.5,378651.9375 5686051,378652.84375 5686050,378652.9375 5686049,378653 5686048.5,378653.03125 5686048,378653.4375 5686048,378654.375 5686046.5,378654.84375 5686045.5,378654.875 5686045.5,378654.90625 5686045,378655.3125 5686045,378656.1875 5686044,378657.0625 5686043,378657.4375 5686043,378657.84375 5686043.5,378658.625 5686043.5,378659.40625 5686043.5,378660.625 5686043,378661.03125 5686043,378662.1875 5686043.5,378662.59375 5686043.5,378663.78125 5686043.5,378664.15625 5686043.5,378665.34375 5686043.5,378666.125 5686043.5,378666.90625 5686044,378668.09375 5686044,378668.875 5686044,378669.65625 5686044,378670.4375 5686044,378671.21875 5686044,378672.40625 5686044.5,378673.1875 5686044.5,378674.4375 5686043.5,378675.25 5686044,378676.8125 5686044,378677.1875 5686044,378678 5686044,378679.15625 5686044,378679.5625 5686044.5,378680.78125 5686044,378681.5625 5686044,378681.9375 5686044,378682.75 5686044,378683.90625 5686044.5,378686.34375 5686044,378687.90625 5686044,378688.75 5686043.5,378689.53125 5686043.5,378690.84375 5686042,378691.71875 5686041.5,378692.15625 5686041,378693.40625 5686040.5,378693.78125 5686040.5,378695.03125 5686040,378695.90625 5686039,378696.84375 5686037.5,378697.28125 5686037.5,378698.1875 5686036,378699.0625 5686035,378699.96875 5686034,378700.03125 5686033,378700.9375 5686032,378701.40625 5686031.5,378701.90625 5686030,378702.03125 5686029,378702.875 5686028.5,378703 5686027,378703.125 5686025.5,378704 5686025,378704.53125 5686023.5,378704.65625 5686022,378704.78125 5686021,378704.875 5686020,378705 5686018.5,378705.0625 5686018,378705.1875 5686016.5,378705.21875 5686016.5,378705.375 5686014.5,378704.6875 5686013.5,378703.28125 5686011.5,378702.40625 5686008.5,378701.71875 5686007,378701.84375 5686006,378702.03125 5686004,378702.21875 5686002,378702.28125 5686001.5,378702.3125 5686001,378703.09375 5686001,378703.15625 5686000.5,378703.71875 5685994.5,378704.15625 5685990,378704.21875 5685989,378704.3125 5685988.5,378704.40625 5685987,378705.3125 5685986,378705.5625 5685983.5,378705.6875 5685982,378705.75 5685981.5,378705.8125 5685981,378706.1875 5685981,378706.3125 5685980,378707.5625 5685979,378708.5625 5685977,378709.5 5685975.5,378709.53125 5685975,378709.59375 5685974.5,378709.96875 5685974.5,378710.125 5685973,378712.21875 5685971.5,378713.0625 5685971.5,378713.09375 5685971,378713.21875 5685970,378714.03125 5685969.5,378715.4375 5685967,378716.75 5685966,378717.1875 5685965.5,378717.25 5685964.5,378718.0625 5685964.5,378718.59375 5685963,378720.65625 5685962,378722.03125 5685960.5,378723.28125 5685959.5,378723.75 5685959,378724.21875 5685958,378724.625 5685958,378724.65625 5685958,378725.46875 5685957.5,378726.375 5685956.5,378727.1875 5685956,378728.5625 5685954.5,378730.25 5685953,378731.09375 5685952.5,378731.625 5685951.5,378732.46875 5685950.5,378733.375 5685949.5,378733.8125 5685949,378733.875 5685948.5,378735.09375 5685948,378736 5685947,378736.8125 5685946.5,378738.09375 5685945.5,378739.34375 5685945,378740.1875 5685944.5,378740.59375 5685944.5,378741.46875 5685943.5,378741.875 5685943.5,378743.15625 5685942.5,378744.375 5685942.5,378745.15625 5685942.5,378746 5685941.5,378746.84375 5685941.5,378748.09375 5685940.5,378748.46875 5685941,378749.6875 5685940.5,378750.09375 5685940.5,378751.75 5685940,378752.53125 5685940,378753.8125 5685939,378755.53125 5685939,378758.5 5685935.5,378761.6875 5685932.5,378766.875 5685927.5,378770.46875 5685924,378774.84375 5685920,378778.8125 5685917,378783.21875 5685913,378787.96875 5685909.5,378793.53125 5685906.5,378796.71875 5685904.5,378799.5 5685903.5,378802.65625 5685903,378806.25 5685899.5,378808.09375 5685898,378808.65625 5685896,378809.9375 5685895,378810.4375 5685894,378810.59375 5685892,378811.40625 5685892,378811.5 5685891,378812.4375 5685889.5,378813.28125 5685889,378813.75 5685888,378813.875 5685887,378813.9375 5685886,378814.4375 5685885,378815.40625 5685883,378816.28125 5685882.5,378816.78125 5685881.5,378816.90625 5685880,378816.96875 5685879.5,378817 5685879,378817.125 5685878,378817.96875 5685877,378819.09375 5685873.5,378819.25 5685872,378819.40625 5685870.5,378819.5625 5685869,378819.625 5685868,378819.75 5685867,378819.84375 5685865.5,378819.96875 5685864.5,378820.1875 5685862,378820.3125 5685861,378820.5 5685859,378820.53125 5685858.5,378820.6875 5685857,378820.8125 5685855.5,378820.9375 5685854.5,378821 5685853.5,378821.0625 5685853,378821.46875 5685849,378821.0625 5685845,378821.1875 5685843,378821.3125 5685842,378821.375 5685841.5,378821.46875 5685840.5,378821.5 5685840,378820.78125 5685839,378820.59375 5685837,378820.3125 5685836,378820.375 5685835,378820.5 5685834,378820.21875 5685833,378817.96875 5685831.5,378817.3125 5685825.5,378814.8125 5685822.5,378813.875 5685820,378813.28125 5685818,378812.5625 5685817.5,378812.28125 5685816,378811.9375 5685815.5,378812 5685815,378809.25 5685814.5,378806.71875 5685812,378803.8125 5685809.5,378801.96875 5685808,378801.25 5685807,378800.0625 5685807,378799.75 5685806,378799.375 5685806,378798.625 5685805.5,378797.84375 5685805.5,378794.28125 5685805,378792.71875 5685805,378790.75 5685805,378789.59375 5685804.5,378789.1875 5685804.5,378788.40625 5685804.5,378787.625 5685804.5,378786.84375 5685804.5,378785.65625 5685804.5,378784.09375 5685804,378782.03125 5685804.5,378780.875 5685804.5,378780.09375 5685804.5,378779.28125 5685804.5,378778.90625 5685804.5,378777.6875 5685804.5,378775.34375 5685804.5,378773.65625 5685805.5,378772.4375 5685805.5,378771.21875 5685806,378770.40625 5685806.5,378769.59375 5685806,378768.8125 5685806,378767.65625 5685806,378767.25 5685806,378766.0625 5685806,378765.6875 5685806,378764.53125 5685805.5,378763.75 5685805,378762.6875 5685804,378761.1875 5685803,378760 5685803,378759.28125 5685802.5,378758.09375 5685802.5,378757.3125 5685802,378756.125 5685802,378755.90625 5685802,378754.9375 5685802,378752.1875 5685801.5,378750.625 5685801.5,378749.84375 5685801.5,378748.65625 5685801.5,378747.875 5685801,378746.65625 5685801.5,378745.46875 5685801.5,378745.0625 5685801.5,378744.1875 5685802.5,378743.375 5685803,378742.125 5685803.5,378740.875 5685804,378740 5685805,378739.15625 5685805.5,378738.28125 5685806,378737.8125 5685807,378737.03125 5685807,378737 5685807.5,378736.21875 5685807,378734.8125 5685809.5,378731.875 5685811,378730.625 5685812,378730.53125 5685812.5,378729.375 5685812.5,378727.59375 5685814.5,378723.90625 5685815.5,378723.0625 5685816,378722.625 5685816.5,378721.84375 5685816.5,378721.03125 5685817,378720.59375 5685817,378719.65625 5685818.5,378717.65625 5685819,378716.375 5685820,378715.46875 5685821,378714.65625 5685821.5,378714.59375 5685821.5,378713.75 5685822.5,378713.3125 5685823,378712.375 5685824.5,378711.90625 5685825,378711.84375 5685826,378711.75 5685826.5,378711.6875 5685827.5,378710.8125 5685828,378710.25 5685830,378709.75 5685831,378709.59375 5685832.5,378709.46875 5685834,378709.375 5685835,378708.46875 5685836,378707.96875 5685837.5,378707.875 5685838,378707 5685839,378706.90625 5685840,378705.90625 5685842.5,378705.03125 5685843,378704.5 5685844.5,378704.34375 5685846,378703.53125 5685846.5,378703.46875 5685847,378702.5625 5685848.5,378702.09375 5685849,378700.75 5685850.5,378699.90625 5685851,378699.03125 5685852,378698.1875 5685852.5,378697.3125 5685853.5,378696.84375 5685854,378696 5685855,378695.53125 5685855.5,378694.65625 5685856.5,378694.1875 5685857,378692.90625 5685858,378691.21875 5685859,378690.375 5685860,378689.875 5685861,378689.03125 5685861,378688.59375 5685861.5,378687.75 5685862.5,378686.9375 5685862.5,378686.125 5685862.5,378685.75 5685862.5,378684.84375 5685863.5,378683.625 5685864,378681.9375 5685865,378680.34375 5685865,378679.5625 5685865,378678.78125 5685865,378677.90625 5685865.5,378676.71875 5685865.5,378674.3125 5685866,378672.34375 5685866,378671.15625 5685866,378670.375 5685865.5,378669.125 5685866.5,378668.34375 5685866.5,378667.09375 5685867,378665.90625 5685867,378665.03125 5685867.5,378664.1875 5685868.5,378663.34375 5685868.5,378662.90625 5685869.5,378662.46875 5685869.5,378661.6875 5685869.5,378660.375 5685870.5,378658.78125 5685871,378657.96875 5685871,378657.125 5685871.5,378656.6875 5685872,378655.875 5685872,378654.125 5685874,378652.46875 5685874.5,378651.1875 5685875.5,378650.3125 5685876.5,378649.46875 5685877,378648.625 5685877.5,378648.1875 5685878,378647.75 5685878.5,378646.90625 5685879,378646.4375 5685879.5,378645.59375 5685880.5,378643.9375 5685881,378643.46875 5685881.5,378642.65625 5685882,378641.78125 5685882.5,378640.9375 5685883.5,378639.71875 5685883.5,378638.84375 5685884.5,378638.375 5685885,378637.5625 5685885.5,378636.75 5685886,378636.3125 5685886,378635.46875 5685887,378635.0625 5685887,378633.6875 5685888.5,378632.0625 5685889.5,378630.8125 5685890,378630.28125 5685891,378629.4375 5685892,378629 5685892,378628.5625 5685892.5,378628.5 5685893.5,378627.625 5685894,378627.21875 5685894.5,378626.28125 5685896,378625.03125 5685896.5,378624.5 5685897.5,378624.03125 5685898.5,378623.15625 5685899.5,378622.65625 5685900.5,378622.34375 5685901,378623.25 5685903,378626.75 5685907.5,378629.09375 5685910.5,378631.03125 5685914.5,378633.375 5685918.5,378636.125 5685922.5,378637.65625 5685928,378638.40625 5685931.5,378638.34375 5685938,378636.34375 5685941.5,378634.3125 5685945.5,378628.34375 5685951.5,378627.09375 5685951.5,378627.4375 5685954.5,378629.5625 5685957,378630.5625 5685959,378631.125 5685961.5,378631.4375 5685962.5,378631.375 5685963,378632.125 5685963.5,378632.09375 5685964,378632.40625 5685965,378632.65625 5685966.5,378633.34375 5685967.5,378634.3125 5685970,378634.96875 5685971,378634.9375 5685971.5,378634.875 5685972,378635.53125 5685973.5,378635.90625 5685974,378636.53125 5685975.5,378637.25 5685976.5,378637.15625 5685977,378637.09375 5685978,378637.0625 5685978.5,378638.9375 5685979.5,378639.375 5685983,378640.375 5685985,378640.65625 5685986.5,378640.5 5685988,378640.46875 5685988.5,378641.65625 5685988.5,378642.53125 5685991.5,378643.875 5685994,378644.15625 5685995.5,378644.09375 5685996,378644.46875 5685996,378644.59375 5685999,378644.8125 5686001,378644.75 5686002,378644.65625 5686002.5,378644.5625 5686004,378644.46875 5686004.5,378644.375 5686005.5,378644.25 5686007,378643.65625 5686009,378642.78125 5686010,378640.71875 5686015,378640.25 5686015.5,378639.78125 5686016.5,378638.8125 5686018.5,378637.53125 5686019.5,378637 5686020.5,378636.875 5686022,378636.03125 5686022.5,378636 5686023,378635.875 5686024,378634.28125 5686024,378633.125 5686028,378632.15625 5686030,378632.0625 5686030.5,378631.5625 5686032,378631.53125 5686032.5,378631.09375 5686032.5,378630.25 5686033.5,378629.78125 5686034,378628.40625 5686036,378626.71875 5686037,378625.78125 5686038.5,378624.84375 5686040,378624.8125 5686040.5,378624.78125 5686040.5,378623.90625 5686041.5,378623.4375 5686042,378623.0625 5686042,378622.15625 5686043,378620.90625 5686044,378620 5686045,378618.75 5686045.5,378617.90625 5686046.5,378617 5686047.5,378616.1875 5686048,378615.71875 5686048.5,378614.875 5686049,378614.0625 5686049,378612.8125 5686050,378611.15625 5686050.5,378609.90625 5686051,378609.0625 5686052,378608.1875 5686052.5,378608.15625 5686053,378607.34375 5686053,378606.875 5686054,378605.59375 5686054.5,378604.78125 5686055,378604.40625 5686055,378603.21875 5686055,378601.65625 5686054.5,378599.28125 5686054.5,378598.5 5686054.5,378598.1875 5686053.5,378597.40625 5686053.5,378597 5686053.5,378595.9375 5686052,378594.40625 5686051.5,378593.3125 5686050.5,378592.1875 5686049.5,378591.09375 5686049,378590 5686048,378588.9375 5686046.5,378587.8125 5686045.5,378586.71875 5686045,378586 5686044,378584.90625 5686043,378584.1875 5686042,378583.4375 5686041.5,378582.75 5686041,378582.375 5686040.5,378581.625 5686040,378580.96875 5686038.5,378579.8125 5686038,378579.46875 5686037.5,378579.125 5686037.5,378578.4375 5686036,378577.28125 5686035.5,378576.625 5686034,378575.90625 5686033.5,378575.65625 5686032,378575 5686030.5,378574.40625 5686028.5,378573 5686026.5,378572.46875 5686024,378571.84375 5686022,378571.21875 5686020,378570.625 5686018,378570 5686016.5,378569.3125 5686015,378568.625 5686014,378568.3125 5686013,378567.625 5686012.5,378567.65625 5686012,378566.9375 5686011,378566.96875 5686010.5,378565.875 5686009.5,378565.53125 5686009.5,378564.40625 5686008.5,378563.3125 5686007.5,378562.5625 5686007,378562.21875 5686006.5,378561.5 5686005.5,378560.75 5686005,378559.28125 5686004,378557.78125 5686003,378556.71875 5686001.5,378556.0625 5686000.5,378555 5685999,378554.3125 5685998,378553.21875 5685997,378552.53125 5685995.5,378551.84375 5685995,378551.65625 5685994.5,378551.5 5685994,378551.15625 5685993.5,378551.1875 5685993,378550 5685993,378549.46875 5685990.5,378546.90625 5685988.5,378546.21875 5685987,378545.96875 5685985.5,378545.625 5685985,378545.65625 5685984.5,378544.9375 5685984,378544.59375 5685983.5,378543.96875 5685981.5,378543.59375 5685981,378542.5625 5685979.5,378541.8125 5685979,378541.5 5685978,378541.1875 5685977.5,378540.5625 5685976,378539.0625 5685975,378538.375 5685973.5,378537.3125 5685972.5,378536.59375 5685971.5,378535.875 5685971,378535.15625 5685970,378534.78125 5685969.5,378534.03125 5685969,378532.875 5685969,378531.875 5685967,378530.46875 5685965,378529.75 5685964.5,378529.78125 5685964,378529.375 5685964,378528.6875 5685963,378527.90625 5685963,378525.96875 5685962.5,378524.40625 5685962,378523.625 5685962,378522.8125 5685962,378522.03125 5685962,378521.65625 5685962,378520.46875 5685962,378519.6875 5685961.5,378518.5 5685961.5,378517.71875 5685961.5,378516.53125 5685961.5,378515.75 5685961.5,378514.25 5685960.5,378512.34375 5685960,378511.21875 5685959,378510.53125 5685958,378509.78125 5685957.5,378509.8125 5685957,378508.65625 5685956.5,378508.28125 5685956.5,378507.21875 5685955.5,378506.90625 5685954.5,378506.09375 5685954.5,378506.21875 5685953,378505.46875 5685952.5,378503.71875 5685950,378502.65625 5685949,378502.0625 5685947,378502.21875 5685945.5,378501.53125 5685944,378501.65625 5685943,378501.78125 5685941.5,378501.5 5685940.5,378501.125 5685940,378501.21875 5685939,378500.4375 5685939,378499.40625 5685937.5,378498.34375 5685936,378497.53125 5685936,378497.59375 5685935.5,378496.0625 5685935,378495.21875 5685935,378494.46875 5685935,378493.78125 5685934,378492.96875 5685934,378492.1875 5685934,378491.40625 5685934,378490.21875 5685933.5,378488.65625 5685933.5,378487.46875 5685933.5,378486.3125 5685933.5,378485.15625 5685933,378484.78125 5685933,378484.03125 5685932.5,378483.25 5685932,378482.53125 5685931.5,378481.375 5685931,378479.84375 5685930.5,378478.6875 5685930,378477.9375 5685929.5,378477.53125 5685929.5,378477.21875 5685929,378476.875 5685928.5,378476.21875 5685926.5,378475.125 5685926,378474.4375 5685924.5,378473.78125 5685923.5,378473.40625 5685923,378473.46875 5685922.5,378473.6875 5685920,378473.125 5685917.5,378473.3125 5685915.5,378473.53125 5685913.5,378473.65625 5685912,378473.75 5685911,378473.875 5685910,378473.9375 5685909,378474.0625 5685908,378474.15625 5685906.5,378474.34375 5685904.5,378474.53125 5685902.5,378474.6875 5685901,378474.84375 5685899.5,378475 5685898,378475.15625 5685896.5,378475.25 5685895.5,378474.53125 5685894.5,378473.84375 5685893.5,378473.875 5685893,378473.15625 5685892.5,378472.09375 5685891,378471.4375 5685889.5,378470.75 5685888.5,378470.875 5685887.5,378469.75 5685886.5,378469.46875 5685885,378468.84375 5685883.5,378467.8125 5685882,378467.1875 5685880,378466.5 5685879,378466.65625 5685877.5,378465.9375 5685876.5,378466.03125 5685875.5,378465.28125 5685875,378465.3125 5685875,378464.53125 5685874.5,378463.84375 5685873.5,378461.96875 5685872.5,378461.21875 5685872,378461 5685872,378460.46875 5685871.5,378459.6875 5685871.5,378458.53125 5685871,378457.4375 5685870,378454.6875 5685869.5,378453.1875 5685869,378451.6875 5685868,378450.53125 5685867.5,378449.71875 5685867.5,378448.625 5685866.5,378448.28125 5685866.5,378447.09375 5685866,378446.3125 5685866,378445.125 5685866,378444.75 5685866,378443.5625 5685866,378442.78125 5685865.5,378442 5685865.5,378441.59375 5685865.5,378440.40625 5685865.5,378439.625 5685865.5,378438.46875 5685865.5,378438.25 5685865.5,378437.28125 5685865,378435.25 5685866,378432.4375 5685866,378430.875 5685865.5,378429.28125 5685866,378428.09375 5685866,378426.84375 5685866.5,378425.28125 5685866.5,378424.09375 5685866,378422.84375 5685867,378422 5685867,378421.21875 5685867,378420.84375 5685867,378419.96875 5685868,378419.125 5685868.5,378417.46875 5685869,378415.46875 5685869.5,378414.21875 5685870,378413.71875 5685871,378412.875 5685871.5,378412.46875 5685872,378411.5625 5685873,378410.125 5685873,378410.09375 5685873.5,378408.8125 5685882.5,378405.96875 5685892.5,378403.53125 5685899.5,378401.53125 5685904,378399.28125 5685908,378399.46875 5685908,378399.875 5685912.5,378400.34375 5685916,378400.15625 5685918,378399.96875 5685920,378399.875 5685920.5,378399.8125 5685921.5,378399.75 5685922,378399.625 5685923.5,378399.5 5685924.5,378398.0625 5685927,378397.0625 5685929.5,378395.625 5685932,378395.15625 5685933,378395.03125 5685934,378394.90625 5685935.5,378390.84375 5685936.5,378389.15625 5685937.5,378387.90625 5685938,378387.09375 5685938.5,378386.21875 5685939,378385.8125 5685939.5,378384.96875 5685940,378384.15625 5685940,378382.9375 5685940.5,378381.25 5685941.5,378378.875 5685941.5,378377.25 5685942,378376 5685942.5,378374.78125 5685942.5,378373.53125 5685943.5,378371.9375 5685943.5,378371.09375 5685944,378369.9375 5685944,378369.53125 5685944,378368.71875 5685944,378367.9375 5685944,378366.34375 5685944,378365.5625 5685944,378364.3125 5685944.5,378363.125 5685944.5,378362.75 5685944.5,378361.875 5685945,378361.09375 5685945,378359.90625 5685945,378359.125 5685944.5,378357.84375 5685946,378357.0625 5685945.5,378355.40625 5685946.5,378353.84375 5685946,378352.96875 5685947,378352.15625 5685947,378351.34375 5685947.5,378350.90625 5685948,378349.625 5685949,378348 5685949,378346.75 5685950,378345.5 5685950.5,378344.28125 5685950.5,378343.0625 5685951,378341.84375 5685951.5,378341.03125 5685951.5,378340.25 5685951.5,378339.84375 5685951.5,378339.1875 5685950,378339.28125 5685949,378339.3125 5685948.5,378338.6875 5685947,378338.71875 5685946.5,378338.0625 5685945.5,378337.5 5685943,378337.59375 5685941.5,378337.71875 5685940.5,378337.78125 5685940,378337.84375 5685939.5,378337.5625 5685938,378337.28125 5685937,378336.09375 5685937,378335.3125 5685936.5,378334.15625 5685936,378333.375 5685936,378333 5685936,378331.8125 5685936,378331.40625 5685936,378329.84375 5685936,378329.0625 5685935.5,378328.28125 5685935.5,378327.5 5685935.5,378326.3125 5685935.5,378325.53125 5685935.5,378323.96875 5685935,378323.15625 5685935,378321.59375 5685935,378320.03125 5685935,378319.25 5685934.5,378318.0625 5685934.5,378316.84375 5685935,378316.03125 5685935,378315.15625 5685936,378313.9375 5685936,378313.15625 5685936,378312.375 5685936,378311.53125 5685936.5,378311.0625 5685937.5,378309.75 5685938.5,378308.9375 5685939,378308.4375 5685940,378307.9375 5685941,378307.46875 5685942,378306.5625 5685943,378306.09375 5685943.5,378306.03125 5685944.5,378305.53125 5685945.5,378305.09375 5685946,378304.1875 5685947,378303.375 5685947.5,378302.5 5685948,378302.03125 5685949,378301.5625 5685949.5,378301.53125 5685950,378301.46875 5685951,378300.65625 5685950.5,378300.3125 5685950.5,378299.53125 5685950,378299.125 5685950,378299.09375 5685950.5,378298.28125 5685951,378297.5 5685951,378296.59375 5685952,378294.53125 5685953,378293.6875 5685953,378293.28125 5685953.5,378292.875 5685953.5,378292.8125 5685954.5,378291.59375 5685954.5,378291.1875 5685954.5,378291.125 5685955.5,378289.53125 5685955,378288.59375 5685956.5,378287.34375 5685957.5,378286.5 5685958,378285.625 5685958.5,378285.21875 5685959,378284.75 5685960,378283.90625 5685960,378283.125 5685960,378282.21875 5685961,378280.59375 5685962,378279.34375 5685962.5,378278.46875 5685963,378277.625 5685964,378277.1875 5685964,378276.3125 5685965,378275.9375 5685965,378274.6875 5685965.5,378274.28125 5685965.5,378273.03125 5685966,378272.625 5685966,378271 5685967,378270.59375 5685966.5,378269.3125 5685968,378268.5 5685968,378267.21875 5685969,378265.96875 5685969.5,378265.1875 5685969.5,378264.40625 5685969.5,378263.15625 5685970,378262.375 5685970,378260.8125 5685969.5,378260 5685969.5,378259.15625 5685970.5,378258.375 5685970.5,378257.59375 5685970,378256.375 5685970.5,378255.1875 5685970.5,378253.21875 5685970,378251.65625 5685970,378250.875 5685970,378250.46875 5685970,378249.6875 5685970,378248.90625 5685969.5,378247.71875 5685969.5,378246.90625 5685970,378245.25 5685970.5,378244.46875 5685970.5,378243.6875 5685970.5,378243.28125 5685970.5,378242.03125 5685971,378241.21875 5685971.5,378239.5625 5685972,378239.15625 5685972.5,378238.75 5685972.5,378237.84375 5685973.5,378237.03125 5685973.5,378235.78125 5685974.5,378235.28125 5685975.5,378235.1875 5685976.5,378235.15625 5685976.5,378234.8125 5685980,378233.375 5685983,378233.3125 5685983.5,378233.28125 5685984,378233.1875 5685985,378233.15625 5685985,378233.03125 5685986.5,378232.5625 5685987,378231.53125 5685990,378231.375 5685991.5,378231.21875 5685993,378231.09375 5685994.5,378231.03125 5685995,378231 5685995.5,378230.90625 5685996.5,378230.8125 5685997.5,378230.71875 5685998.5,378230.625 5685999.5,378230.46875 5686001,378230.4375 5686001,378230.28125 5686003,378230.1875 5686004,378230.0625 5686005,378230 5686006,378229.34375 5686008.5,378228.40625 5686010,378228.25 5686011.5,378228.15625 5686013,378227.6875 5686013.5,378227.59375 5686014.5,378227.21875 5686014.5,378226.40625 5686014.5,378225.8125 5686016.5,378225.625 5686018.5,378224.84375 5686018.5,378223.90625 5686020,378222.5625 5686021.5,378222.1875 5686021.5,378220.96875 5686021.5,378220.0625 5686023,378219.25 5686023,378218.78125 5686024,378218.34375 5686024,378217.5625 5686024,378216.78125 5686024,378215.96875 5686024,378215.1875 5686024,378214.03125 5686024,378213.25 5686023.5,378212.0625 5686023.5,378212.125 5686023,378211.34375 5686022.5,378211.03125 5686022,378210.3125 5686021,378210.40625 5686020.5,378209.65625 5686020,378209.71875 5686019,378209.375 5686018.5,378209.09375 5686017.5,378209.125 5686017,378208.03125 5686016,378208.0625 5686015.5,378208.15625 5686014.5,378205.9375 5686013,378204.96875 5686010.5,378203.90625 5686009.5,378203.59375 5686008.5,378203.65625 5686007.5,378202.875 5686007.5,378201.6875 5686007.5,378200.53125 5686007.5,378199.71875 5686007.5,378198.9375 5686007,378197.78125 5686007,378196.59375 5686007,378195.03125 5686007,378193.84375 5686006.5,378193.0625 5686006.5,378192.96875 5686007.5,378191.8125 5686007,378191.40625 5686007,378190.625 5686007,378190.5625 5686008,378189.34375 5686008,378188.40625 5686009.5,378187.5 5686011,378187.4375 5686011.5,378186.59375 5686012,378186.125 5686012.5,378184.84375 5686013.5,378184.375 5686014.5,378183.46875 5686015.5,378183 5686016.5,378182.59375 5686016.5,378182.53125 5686017,378181.28125 5686017.5,378180.8125 5686018.5,378180.71875 5686019.5,378179.46875 5686020.5,378179.03125 5686020.5,378179 5686021,378178.96875 5686021.5,378178.5625 5686021.5,378177.6875 5686022,378176.375 5686023.5,378175.9375 5686024,378175.09375 5686024.5,378173.78125 5686025.5,378173.375 5686026,378172.5 5686027,378171.59375 5686028,378170.34375 5686028.5,378169.0625 5686029.5,378167.40625 5686030,378165.78125 5686031,378164.875 5686032,378163.65625 5686032,378162.84375 5686032.5,378162.4375 5686032.5,378162.5 5686031.5,378162.5625 5686031.5,378162.59375 5686030.5,378152.25 5686035.5,378151.90625 5686039,378153.625 5686042,378154.40625 5686042,378154.3125 5686043,378154.03125 5686046,378158.40625 5686046,378163.125 5686048,378164.6875 5686052,378166.59375 5686059.5,378167.71875 5686064.5,378168.09375 5686067.5,378169.625 5686072.5,378174.53125 5686078,378175.5625 5686078,378176.75 5686078,378177.53125 5686078,378178.3125 5686078,378179.09375 5686078.5,378179.875 5686078.5,378181.46875 5686078.5,378182.25 5686078.5,378183.40625 5686078.5,378184.21875 5686079,378185.78125 5686079,378186.5625 5686079,378186.96875 5686079,378188.0625 5686080,378188.84375 5686080,378190.34375 5686081,378191.90625 5686081,378192.6875 5686081,378193.46875 5686081.5,378194.53125 5686082.5,378195.6875 5686083,378197.5625 5686084,378199.0625 5686085,378200.21875 5686085.5,378200.96875 5686086,378202.09375 5686086.5,378203.25 5686087,378204 5686087.5,378205.125 5686088,378206.28125 5686088.5,378207.375 5686089.5,378208.5 5686090,378209.25 5686090.5,378210.40625 5686091,378211.53125 5686091.5,378212.34375 5686091.5,378213.125 5686091.5,378214.21875 5686092.5,378215 5686092.5,378216.1875 5686093,378216.9375 5686093,378218.375 5686094.5,378220.3125 5686095,378221.375 5686096.5,378222.5 5686097.5,378223.9375 5686098.5,378225.03125 5686099.5,378226.15625 5686100.5,378227.25 5686101.5,378228.34375 5686102.5,378229.0625 5686103,378229.78125 5686104,378230.53125 5686104.5,378231.15625 5686106,378232.65625 5686107,378233.375 5686108,378234.09375 5686109,378234.78125 5686109.5,378235.5 5686110.5,378235.78125 5686112,378236.5 5686112.5,378237.1875 5686113.5,378237.125 5686114.5,378237.875 5686115,378238.5625 5686116,378239.28125 5686116.5,378240.3125 5686118,378241.375 5686119.5,378242.5 5686120.5,378243.15625 5686121.5,378243.90625 5686122,378244.28125 5686122.5,378245.34375 5686124,378245.6875 5686124.5,378246.84375 5686125,378247.625 5686125,378248 5686125,378248.71875 5686126,378249.46875 5686126.5,378250.9375 5686127.5,378252.4375 5686128.5,378253.46875 5686129.5,378253.53125 5686129.5,378254.25 5686130.5,378255.375 5686131,378256.125 5686131.5,378257.3125 5686131.5,378258 5686132.5,378259.125 5686133.5,378261.03125 5686134,378261.78125 5686134.5,378262.53125 5686135,378263.3125 5686135,378264.125 5686135,378264.8125 5686136,378267.125 5686136.5,378268.3125 5686136.5,378269.0625 5686137,378269.84375 5686137,378270.25 5686137,378271.03125 5686137,378271.875 5686136.5,378272.3125 5686136,378273.5625 5686135.5,378274.40625 5686135,378275.6875 5686134,378276.9375 5686133.5,378278.1875 5686133,378278.65625 5686132,378279.53125 5686131.5,378280 5686130.5,378280.9375 5686129,378282.1875 5686128.5,378282.71875 5686127,378282.875 5686125.5,378283.71875 5686124.5,378283.78125 5686124,378283.90625 5686122.5,378284.0625 5686121,378284.5625 5686116,378283.21875 5686113.5,378283.03125 5686111,378283.21875 5686109,378283.34375 5686108,378283.03125 5686107,378282.34375 5686106,378282.46875 5686104.5,378281.78125 5686103.5,378281.46875 5686102.5,378281.21875 5686101,378280.96875 5686099.5,378280.6875 5686098,378280.84375 5686096.5,378280.1875 5686095.5,378280.28125 5686094,378280.34375 5686093.5,378280.375 5686093.5,378280.625 5686090.5,378279.6875 5686088,378279.5 5686085.5,378279.71875 5686083.5,378279.84375 5686082,378279.96875 5686081,378280.03125 5686080,378279.3125 5686079.5,378278.9375 5686079,378278.71875 5686077,378276.53125 5686075.5,378276.03125 5686075,378272.375 5686073.5,378267.28125 5686070,378262.5625 5686067,378258.25 5686062.5,378255.53125 5686058,378255.5625 5686054.5,378256.78125 5686050.5,378260 5686041.5,378260.84375 5686037.5,378263.25 5686032,378265.28125 5686027.5,378267.6875 5686021.5,378270.53125 5686014.5,378273.34375 5686008.5,378277.75 5686000.5,378282.40625 5685992.5,378282.96875 5685992,378285.3125 5685987.5,378286.03125 5685988,378287.28125 5685987,378288.875 5685987.5,378289.71875 5685986.5,378290.96875 5685986,378292.1875 5685985.5,378292.625 5685985.5,378293.40625 5685985.5,378294.28125 5685984.5,378294.6875 5685984.5,378295.5 5685984.5,378295.875 5685984.5,378296.75 5685983.5,378297.15625 5685983.5,378298 5685983,378298.84375 5685982.5,378299.25 5685982.5,378300.15625 5685981,378300.53125 5685981.5,378301.78125 5685980.5,378302.5625 5685980.5,378303 5685980.5,378304.25 5685979.5,378304.6875 5685979.5,378305.90625 5685979,378307.15625 5685978.5,378307.5625 5685978.5,378308.8125 5685978,378310.375 5685978,378311.625 5685977,378312.0625 5685977,378312.4375 5685977,378313.25 5685977,378314.5 5685976.5,378314.875 5685976.5,378316.09375 5685976,378316.875 5685976,378317.75 5685975.5,378318.53125 5685975.5,378319.3125 5685975.5,378320.96875 5685975,378322.1875 5685974.5,378322.5625 5685975,378323.4375 5685974,378324.21875 5685974,378324.59375 5685974,378325.46875 5685973.5,378326.6875 5685973,378327.0625 5685973,378327.9375 5685972.5,378328.75 5685972,378330.8125 5685971.5,378331.96875 5685972,378333.15625 5685972,378333.59375 5685971.5,378333.96875 5685971.5,378334.75 5685971.5,378335.9375 5685972,378336.34375 5685972,378337.9375 5685971.5,378338.71875 5685971.5,378339.5 5685971.5,378340.28125 5685971.5,378340.78125 5685971,378342.375 5685971,378342.78125 5685971,378343.9375 5685971,378344.34375 5685971,378345.59375 5685970.5,378346.375 5685970.5,378347.15625 5685970.5,378347.9375 5685970.5,378349.15625 5685970.5,378349.9375 5685970.5,378351.1875 5685969.5,378352 5685970,378353.28125 5685968.5,378354.5 5685968.5,378355.28125 5685968.5,378355.65625 5685968.5,378356.53125 5685968,378356.96875 5685967.5,378357.75 5685967.5,378358.125 5685967.5,378358.96875 5685967.5,378359.75 5685967.5,378361.03125 5685966.5,378361.875 5685966,378362.65625 5685966,378363.46875 5685966,378363.875 5685966,378365.125 5685965,378365.90625 5685965.5,378367.59375 5685964,378369.1875 5685964,378370.40625 5685963.5,378371.21875 5685963.5,378372.03125 5685963.5,378373.21875 5685963,378374.03125 5685963.5,378374.125 5685962,378375.3125 5685962,378376.53125 5685962,378377.6875 5685962,378378.59375 5685961,378379 5685961,378380.625 5685960.5,378381.4375 5685960.5,378382.75 5685959,378384 5685958.5,378384.40625 5685958.5,378385.25 5685957.5,378386.09375 5685957.5,378386.90625 5685957,378388.09375 5685957,378389.75 5685956,378391.03125 5685955.5,378391.8125 5685955.5,378392.1875 5685955.5,378393.03125 5685955.5,378393.40625 5685955.5,378394.1875 5685955.5,378394.96875 5685955.5,378396.625 5685955,378397.40625 5685955,378398.625 5685954.5,378399.8125 5685955,378401.5 5685954,378402.34375 5685953,378402.75 5685953,378403.59375 5685952.5,378405.65625 5685952,378406.90625 5685951,378408.125 5685951,378408.90625 5685951,378409.28125 5685951,378410.53125 5685950.5,378410.96875 5685950,378412.625 5685949.5,378413.40625 5685949.5,378413.84375 5685949,378414.71875 5685948,378415.15625 5685947.5,378416.40625 5685947,378417.28125 5685946,378418.53125 5685945.5,378419.4375 5685944.5,378420.25 5685944,378421.125 5685943.5,378421.53125 5685943,378422.84375 5685942,378424.03125 5685941.5,378425.3125 5685941,378425.78125 5685940.5,378426.1875 5685940,378427.03125 5685939.5,378427.96875 5685938,378429.59375 5685937.5,378430.4375 5685937,378430.46875 5685937,378430.53125 5685936,378432.15625 5685936,378432.96875 5685935.5,378433.375 5685935.5,378434.6875 5685934,378436.3125 5685934,378437.125 5685933.5,378437.9375 5685933,378437.96875 5685933,378438.75 5685933,378439.5625 5685933,378441.5 5685933,378442.59375 5685934.5,378443.375 5685934.5,378443.71875 5685935,378443.5625 5685936.5,378445.8125 5685938,378447.125 5685941,378448.53125 5685942.5,378449.28125 5685943,378449.21875 5685944,378449.15625 5685944.5,378449.84375 5685945.5,378451.625 5685947.5,378453.125 5685948.5,378453.84375 5685949.5,378454.5625 5685950.5,378454.90625 5685951,378455.25 5685951,378455.96875 5685952,378456.71875 5685952.5,378457.375 5685954,378458.125 5685954.5,378458.5 5685954.5,378459.625 5685955.5,378460 5685955.5,378460.375 5685955.5,378460.3125 5685956.5,378461.0625 5685957,378461.84375 5685957,378462.46875 5685958.5,378463.625 5685959,378464 5685959.5,378463.9375 5685960,378465.8125 5685961,378466.5 5685962.5,378467.96875 5685963.5,378469.09375 5685964,378469.03125 5685965,378468.90625 5685966,378470.8125 5685967,378471.4375 5685969,378472.15625 5685969.5,378472.46875 5685970.5,378472.4375 5685971,378472.34375 5685971.5,378473.4375 5685972.5,378474.09375 5685974,378474.75 5685975.5,378475.125 5685976,378475.4375 5685976.5,378475.78125 5685977,378476.96875 5685977.5,378478.53125 5685977.5,378479.71875 5685977.5,378480.46875 5685978,378481.25 5685978,378482.40625 5685978.5,378484.34375 5685979,378485.15625 5685979,378486.71875 5685979,378487.4375 5685980,378487.375 5685980.5,378488.5625 5685980.5,378489.25 5685981.5,378490.3125 5685983,378490.96875 5685984.5,378490.8125 5685986,378490.75 5685986.5,378490.71875 5685987,378491.09375 5685987,378491.34375 5685988.5,378491.25 5685990,378491.15625 5685990.5,378491.09375 5685991.5,378491.46875 5685991.5,378492.0625 5685993.5,378493.5 5685995,378494.125 5685997,378494.71875 5685999,378495.4375 5686000,378495.71875 5686001,378496.4375 5686002,378496.34375 5686002.5,378497.0625 5686003.5,378498.125 5686005,378498.8125 5686006,378499.53125 5686007,378499.5625 5686007,378500.1875 5686008,378500.90625 5686009,378501.25 5686009.5,378501.1875 5686010.5,378501.5625 5686010.5,378501.78125 5686012.5,378502.8125 5686014,378503.40625 5686016,378503.25 5686017.5,378503.21875 5686018,378503.1875 5686018.5,378502.96875 5686021,378503.9375 5686023,378504.5625 5686025,378505.1875 5686026.5,378505.46875 5686028,378505.375 5686028.5,378506.1875 5686028.5,378506.625 5686032.5,378507.53125 5686035,378507.75 5686037,378507.5625 5686039,378507.53125 5686039.5,378507.84375 5686040.5,378508.1875 5686041,378508.15625 5686041,378509.34375 5686041.5,378510.75 5686043,378512.21875 5686044.5,378512.96875 5686045,378513.28125 5686045.5,378513.6875 5686046,378514.40625 5686046,378514.8125 5686046.5,378515.5625 5686046.5,378516.6875 5686047.5,378517.5 5686047.5,378519.4375 5686047.5,378520.25 5686047.5,378520.625 5686047.5,378521.8125 5686048,378522.5625 5686048.5,378523.71875 5686048.5,378524.53125 5686048.5,378525.65625 5686049,378527.21875 5686049,378527.625 5686049,378528.75 5686049.5,378530.25 5686050.5,378532.21875 5686051,378533.375 5686051.5,378534.15625 5686051.5,378534.9375 5686051.5,378534.875 5686052.5,378536.03125 5686052.5,378537.1875 5686053,378539.09375 5686053.5,378539.78125 5686055,378540.875 5686055.5,378541.625 5686056,378542 5686056.5,378542.78125 5686056.5,378543.5625 5686056.5,378544.34375 5686057,378545.4375 5686057.5,378546.1875 5686058,378546.59375 5686058,378547.375 5686058.5,378548.15625 5686058.5,378549.34375 5686058.5,378550.125 5686058.5,378550.90625 5686058.5,378552.09375 5686059,378552.46875 5686059,378552.875 5686059,378553.25 5686059,378554.125 5686058,378554.9375 5686058,378555.34375 5686058,378556.125 5686058,378556.96875 5686057.5,378558.59375 5686057,378559 5686057,378559.78125 5686057,378560.5625 5686057.5,378561.40625 5686056.5,378561.8125 5686056.5,378562.59375 5686056.5,378563.375 5686057,378564.15625 5686057,378564.5625 5686057,378564.9375 5686057,378566.125 5686057,378566.90625 5686057,378567.3125 5686057,378568.09375 5686057,378568.8125 5686058,378569.96875 5686058,378569.84375 5686060,378570.5 5686061,378570.75 5686062.5,378570.59375 5686064,378570.4375 5686066,378571.15625 5686066.5,378571.40625 5686068.5,378571.25 5686070,378571.1875 5686070.5,378571.09375 5686071.5,378570.75 5686075,378570.53125 5686077.5,378570.34375 5686079.5,378570.21875 5686081,378570.125 5686081.5,378570.03125 5686083,378569.6875 5686086.5,378568.59375 5686089.5,378568.4375 5686091,378568.34375 5686092,378568.25 5686093,378568.21875 5686093.5,378568.15625 5686094,378567.96875 5686096,378566.59375 5686098,378566 5686100,378565.0625 5686101.5,378564.5625 5686102.5,378564.0625 5686103.5,378563.15625 5686105,378562.65625 5686106,378561.71875 5686107.5,378560.84375 5686108.5,378560.28125 5686110,378559.40625 5686111,378558.84375 5686112.5,378558.3125 5686114.5,378557.40625 5686115.5,378556.90625 5686116.5,378556.40625 5686117.5,378555.90625 5686119,378555.375 5686120,378555.3125 5686120.5,378554.46875 5686121.5,378554.375 5686122,378553.40625 5686124,378552.53125 5686125,378551.65625 5686126,378551.5 5686127.5,378551.03125 5686128,378550.96875 5686129,378550.84375 5686130,378550.8125 5686130.5,378550.03125 5686130.5,378549.78125 5686133,378548.40625 5686135,378547.8125 5686137,378547.625 5686139,378547.5 5686140,378547 5686141.5,378546.125 5686142.5,378546.0625 5686143,378545.6875 5686143,378545.03125 5686145.5,378544.0625 5686147.5,378543.875 5686149.5,378543.28125 5686151.5,378543.1875 5686152.5,378543.03125 5686154,378542.09375 5686155.5,378541.9375 5686157,378541.875 5686158,378541.75 5686159,378541.625 5686160.5,378541.59375 5686160.5,378541.40625 5686162.5,378540.46875 5686164,378540.375 5686165.5,378540.25 5686166.5,378539.90625 5686170,378538.875 5686172.5,378538.78125 5686173.5,378538.75 5686174,378538.5625 5686176,378537.28125 5686177,378536.78125 5686178,378536.6875 5686179,378536.5 5686181,378534.75 5686182.5,378533.84375 5686183.5,378533.75 5686185,378533.71875 5686185.5,378533.625 5686186,378532.84375 5686186,378531.84375 5686188.5,378530.4375 5686190.5,378530.34375 5686191.5,378530.28125 5686192,378529.8125 5686193,378529.75 5686193.5,378528.84375 5686194.5,378528.78125 5686195.5,378527.90625 5686196,378527.875 5686196.5,378527 5686197.5,378525.78125 5686197.5,378524.90625 5686198.5,378524.03125 5686199.5,378523.1875 5686200,378522.75 5686200.5,378522.28125 5686201,378522.25 5686201.5,378521.46875 5686201.5,378520.5625 5686202.5,378519.3125 5686203.5,378518.53125 5686203,378518.125 5686203,378516.84375 5686204,378515.15625 5686205.5,378514.28125 5686206,378513.46875 5686206.5,378513.0625 5686206,378512.625 5686207,378511.8125 5686207,378511.03125 5686207,378509.875 5686206.5,378509.46875 5686206.5,378508.6875 5686206.5,378507.90625 5686206.5,378506.71875 5686206.5,378505.9375 5686206.5,378504.375 5686206,378503.5625 5686206,378502.40625 5686206,378501.625 5686206,378500.03125 5686205.5,378499.65625 5686205.5,378498.46875 5686205.5,378497.6875 5686205.5,378496.90625 5686205.5,378495.71875 5686205.5,378495.34375 5686205,378494.15625 5686205,378493.375 5686205,378491.40625 5686205,378490.625 5686205,378489.84375 5686204.5,378489.4375 5686204.5,378488.65625 5686204.5,378487.875 5686204.5,378487.78125 5686205.5,378487.75 5686205.5,378486.46875 5686206.5,378486.4375 5686207,378486.15625 5686210,378487.1875 5686211.5,378487.40625 5686213.5,378487.59375 5686215.5,378487.5625 5686216,378487.5 5686217,378487.8125 5686217.5,378488.15625 5686218,378488.84375 5686219.5,378488.75 5686220,378489.46875 5686221,378489.4375 5686221.5,378489.28125 5686223,378489.1875 5686224,378489.09375 5686225,378489.0625 5686225.5,378489 5686226,378488.9375 5686226.5,378488.84375 5686227.5,378488.75 5686228.5,378487.90625 5686229,378487.875 5686229.5,378487.46875 5686229.5,378486.625 5686230,378484.625 5686230.5,378483.75 5686231,378482.53125 5686231.5,378481.75 5686231.5,378480.875 5686232,378480.5 5686232,378480.09375 5686232,378479.21875 5686233,378478.375 5686233.5,378476.75 5686234,378475.125 5686234,378473.875 5686235,378473.0625 5686235,378472.28125 5686235,378471.875 5686235,378471 5686236,378470.21875 5686235.5,378468.59375 5686236.5,378467 5686236,378465.78125 5686236.5,378465 5686236.5,378464.1875 5686236.5,378463.40625 5686236.5,378462.21875 5686236.5,378461.4375 5686236.5,378459.875 5686236,378457.90625 5686236,378457.125 5686236,378455.9375 5686236,378454.6875 5686236.5,378453.875 5686237,378452.6875 5686236.5,378451.90625 5686236.5,378450.71875 5686236.5,378449.9375 5686236.5,378448.75 5686236.5,378447.59375 5686236,378445.53125 5686237,378443.9375 5686237,378442.375 5686237,378441.5625 5686237,378440.78125 5686236.5,378440.40625 5686236.5,378439.625 5686236.5,378439.21875 5686236.5,378438.03125 5686236.5,378437.65625 5686236.5,378436.59375 5686235,378436.21875 5686234.5,378435.0625 5686234.5,378434.65625 5686234.5,378433.46875 5686234.5,378433.09375 5686234.5,378432 5686233.5,378431.59375 5686233.5,378430.5 5686232.5,378429.3125 5686232.5,378429 5686231.5,378428.59375 5686231.5,378427.9375 5686230,378427.1875 5686229.5,378425.65625 5686229,378424.59375 5686228,378423.84375 5686227.5,378423.875 5686227,378423.5625 5686226,378423.59375 5686226,378422.53125 5686224.5,378421.40625 5686223.5,378421.125 5686222.5,378420.4375 5686221.5,378420.15625 5686220.5,378419.46875 5686219,378418.75 5686218,378418.4375 5686217.5,378418.09375 5686217,378418.125 5686216.5,378416.9375 5686216.5,378415.90625 5686214.5,378414.5 5686213,378414.09375 5686213,378413.3125 5686213,378412.53125 5686213,378410.96875 5686212.5,378410.1875 5686212.5,378408.625 5686212.5,378407.8125 5686212.5,378407.03125 5686212,378405.875 5686212,378404.6875 5686212,378402.71875 5686212,378400.75 5686211.5,378399.5625 5686211.5,378398.78125 5686211.5,378398 5686211.5,378397.21875 5686211,378396.03125 5686211,378395.1875 5686212,378393.09375 5686213,378391.875 5686213,378391 5686214,378390.09375 5686215.5,378389.625 5686216,378389.15625 5686216.5,378388.6875 5686217.5,378388.65625 5686218,378388.59375 5686218.5,378387.28125 5686219.5,378386.8125 5686220.5,378386.34375 5686221,378386.25 5686222.5,378385.34375 5686223.5,378385.28125 5686224.5,378384.40625 5686225,378384.03125 5686225,378382.4375 5686225,378381.65625 5686224.5,378380.875 5686224.5,378380.09375 5686224.5,378378.53125 5686224.5,378376.15625 5686224,378374.96875 5686224,378373.40625 5686224,378372.625 5686224,378371.84375 5686223.5,378370.96875 5686224.5,378370.59375 5686224.5,378369.71875 5686225,378368.5 5686225.5,378366.84375 5686226.5,378365.5625 5686227,378364.71875 5686228,378363.84375 5686228.5,378363.4375 5686229,378363.375 5686229,378362.78125 5686230,378362.5 5686230.5,378361.65625 5686230.5,378360.6875 5686232.5,378359.40625 5686233.5,378358.90625 5686234.5,378358.34375 5686236.5,378357.53125 5686236.5,378357.5 5686237,378357 5686238,378356.96875 5686238.5,378356.875 5686239.5,378356.84375 5686239.5,378356.65625 5686241.5,378355.78125 5686242.5,378355.6875 5686243.5,378355.5625 5686244.5,378355.40625 5686246.5,378354.9375 5686247,378354.5625 5686247,378354.46875 5686248,378354.375 5686249,378353.90625 5686249.5,378352.9375 5686251.5,378352.4375 5686253,378352.34375 5686253.5,378352.28125 5686254.5,378351.875 5686254.5,378350.84375 5686257,378350.25 5686259,378350.15625 5686260,378350.0625 5686261,378349.6875 5686261,378349.0625 5686263,378347.6875 5686265,378347.125 5686267,378346.9375 5686269,378346.46875 5686269.5,378346.40625 5686270,378346.34375 5686271,378346.3125 5686271,378346.28125 5686271.5,378346.09375 5686273.5,378345.96875 5686275,378345.875 5686276,378345.75 5686277,378345.625 5686278.5,378345.5625 5686279,378345.5 5686280,378345.4375 5686280.5,378345.34375 5686281.5,378345.25 5686282,378345.15625 5686283.5,378345.46875 5686284.5,378345.78125 5686285,378345.65625 5686286.5,378346.46875 5686286.5,378347.125 5686287.5,378347.4375 5686288.5,378348.21875 5686288.5,378348.9375 5686289.5,378349.34375 5686289.5,378350.5 5686289.5,378350.90625 5686289.5,378352.0625 5686290,378352.84375 5686290,378354.75 5686291,378355.53125 5686291,378357.5 5686291,378358.28125 5686291,378359.09375 5686291,378359.875 5686291.5,378361.03125 5686291.5,378362.625 5686291.5,378363.40625 5686291.5,378364.1875 5686291.5,378365.25 5686293,378366.03125 5686293,378366.8125 5686293,378367.59375 5686293,378368.75 5686294,378369.53125 5686294,378370.71875 5686294,378371.5 5686294,378371.875 5686294,378373.0625 5686294,378373.84375 5686294.5,378375.03125 5686294.5,378375.4375 5686294.5,378376.65625 5686294,378377.03125 5686294,378378.21875 5686294.5,378378.59375 5686294.5,378379.78125 5686294.5,378380.5625 5686294.5,378381.34375 5686294.5,378382.53125 5686295,378383.28125 5686295,378384.03125 5686295.5,378385.90625 5686296.5,378386.6875 5686297,378387.5 5686297,378388.1875 5686297.5,378388.96875 5686298,378389.375 5686298,378390.0625 5686299,378390.8125 5686299.5,378391.0625 5686301,378391.03125 5686301,378391.625 5686303,378391.53125 5686304.5,378391.40625 5686305.5,378391.34375 5686306.5,378391.25 5686307,378390.40625 5686308,378389.15625 5686308.5,378388.71875 5686309,378387.9375 5686309,378386.75 5686308.5,378386.25 5686310,378384.21875 5686310.5,378383.3125 5686311.5,378382 5686313,378381.125 5686313.5,378380.28125 5686314.5,378379.8125 5686315,378379.71875 5686316,378378.875 5686316.5,378378.4375 5686317,378377.5625 5686317.5,378377.15625 5686318,378376.28125 5686319,378375.8125 5686319.5,378374.5 5686321,378372.8125 5686322,378371.875 5686323.5,378370.9375 5686325,378370.0625 5686325.5,378369.59375 5686326.5,378369.125 5686327,378369.09375 5686327.5,378368.28125 5686328,378367.40625 5686328.5,378366.1875 5686329,378365.40625 5686329,378363.0625 5686328.5,378361.5 5686328.5,378360.3125 5686328.5,378359.875 5686328.5,378359.09375 5686328.5,378358.3125 5686328.5,378357.53125 5686328.5,378356.75 5686328.5,378355.5625 5686328,378355.15625 5686328,378354.375 5686328,378353.59375 5686328,378353.21875 5686328,378352.40625 5686328,378351.625 5686328,378350.46875 5686327.5,378349.65625 5686327.5,378347.71875 5686327.5,378345.75 5686327,378344.875 5686328,378344.03125 5686328.5,378343.25 5686328.5,378342.84375 5686328.5,378341.65625 5686328.5,378340.875 5686328.5,378339.6875 5686328,378338.53125 5686328,378336.5625 5686328,378335 5686327.5,378334.21875 5686327.5,378333.40625 5686327.5,378332.625 5686327.5,378331.84375 5686327.5,378330.65625 5686327.5,378329.875 5686327,378328.28125 5686327.5,378327.5 5686327.5,378325.90625 5686327,378325.53125 5686327,378323.96875 5686327,378323.5625 5686327,378322 5686327,378321.21875 5686326.5,378319.625 5686326.5,378319.25 5686326.5,378318.40625 5686327,378317.625 5686326.5,378316.8125 5686327,378316.03125 5686327,378315.25 5686327,378314.46875 5686327,378312.875 5686326.5,378312.09375 5686326.5,378310.03125 5686327.5,378309.25 5686327.5,378308.4375 5686327.5,378307.625 5686327.5,378307.25 5686327.5,378306.40625 5686328,378304.84375 5686328,378304.0625 5686327.5,378303.65625 5686327.5,378302.375 5686329,378301.59375 5686328.5,378300.8125 5686328.5,378300.03125 5686328.5,378298.75 5686329,378297.15625 5686329.5,378296.375 5686329.5,378295.59375 5686329.5,378294.71875 5686330,378294.28125 5686330.5,378293.5 5686330.5,378292.71875 5686330,378291.53125 5686330,378290.375 5686330,378288.78125 5686330,378288 5686329.5,378287.1875 5686330,378285.96875 5686330.5,378284.40625 5686330,378283.625 5686330,378282.78125 5686330.5,378282.375 5686330.5,378281.96875 5686330.5,378281.5625 5686330.5,378280.71875 5686331.5,378280.3125 5686331.5,378279.5 5686331.5,378278.71875 5686331.5,378277.0625 5686332,378275.84375 5686332.5,378275.0625 5686332.5,378274.25 5686332.5,378274.15625 5686333.5,378273.375 5686333.5,378272.5625 5686333.5,378271 5686333.5,378270.96875 5686333.5,378270.46875 5686335.5,378268.40625 5686344,378266.78125 5686349.5,378264.75 5686356.5,378262.71875 5686362.5,378258.6875 5686369,378256.6875 5686372,378254.625 5686373,378254.53125 5686373,378254.46875 5686374,378254.40625 5686374.5,378253.0625 5686376,378252.1875 5686377,378251.65625 5686378.5,378251.15625 5686379.5,378250.25 5686380.5,378250.1875 5686381.5,378249.3125 5686382,378249.25 5686383,378249.15625 5686384,378249 5686385.5,378246.15625 5686386.5,378244.4375 5686387.5,378242.75 5686388.5,378241.875 5686389.5,378241.84375 5686390,378241.46875 5686390,378240.28125 5686389.5,378239.5 5686389.5,378238.3125 5686389.5,378237.8125 5686390.5,378237.40625 5686390.5,378236.15625 5686391,378235.375 5686391,378233.71875 5686392,378231.375 5686391.5,378230.1875 5686391.5,378229.40625 5686391.5,378228.25 5686391,378227.84375 5686391,378227.0625 5686391,378226.65625 5686391,378225.875 5686391,378225.8125 5686392,378225.40625 5686391.5,378223.75 5686392.5,378223.375 5686392.5,378221.65625 5686393.5,378220 5686394.5,378218.71875 5686395.5,378217.8125 5686396.5,378216.96875 5686397,378216.09375 5686398,378215.25 5686398.5,378215.1875 5686399,378215.0625 5686400.5,378212.1875 5686401.5,378210.8125 5686403.5,378208.75 5686404.5,378208.34375 5686404.5,378207.9375 5686404.5,378207.5 5686405,378206.71875 5686405,378206.3125 5686405,378205.9375 5686405,378205.53125 5686405,378204.8125 5686404,378204.46875 5686403.5,378203.75 5686402.5,378202.96875 5686402.5,378202.25 5686401.5,378201.46875 5686401.5,378200.0625 5686400,378199.3125 5686399.5,378198.90625 5686399.5,378198.125 5686399.5,378197.34375 5686399,378196.5625 5686399,378195.78125 5686399,378194.09375 5686400,378191.65625 5686400.5,378190.46875 5686400.5,378189.65625 5686401,378188.875 5686400.5,378188.46875 5686400.5,378187.6875 5686400.5,378186.90625 5686400.5,378185.71875 5686400.5,378184.53125 5686400.5,378182.59375 5686400,378181 5686400,378180.21875 5686400,378179.84375 5686400,378179.0625 5686399.5,378177.875 5686399.5,378177.71875 5686401,378174.90625 5686401.5,378173.21875 5686402.5,378171.59375 5686403,378170.4375 5686403,378169.5625 5686403.5,378169.1875 5686403.5,378168.375 5686403.5,378168.28125 5686404.5,378166.625 5686405,378165.71875 5686406.5,378165.65625 5686407,378165.59375 5686408,378165.5 5686408.5,378164.53125 5686410.5,378164.46875 5686411.5,378164.3125 5686413,378164.15625 5686414.5,378164.09375 5686415.5,378164 5686416,378164.6875 5686417.5,378164.59375 5686418,378165.40625 5686418,378166.09375 5686423.5,378168.46875 5686427.5,378169.03125 5686430,378169.1875 5686432.5,378169.5 5686433.5,378169.46875 5686433.5,378169.40625 5686434.5,378170.15625 5686435,378170.46875 5686436,378170.4375 5686436,378171.09375 5686437.5,378171.40625 5686438.5,378171.65625 5686440,378171.59375 5686440.5,378171.5 5686441.5,378172.625 5686442.5,378172.625 5686446.5,378172.4375 5686448.5,378172.375 5686449,378172.28125 5686450,378172.6875 5686450,378173.15625 5686453,378173.3125 5686456,378173.125 5686458,378172.96875 5686459.5,378172.84375 5686460.5,378172.78125 5686461.5,378172.65625 5686462.5,378172.59375 5686463.5,378172.40625 5686465.5,378172.28125 5686466.5,378172.15625 5686468,378172 5686470,378171.8125 5686471.5,378171.65625 5686473.5,378171.46875 5686475.5,378171.25 5686477.5,378171.15625 5686478.5,378171.09375 5686479,378170.6875 5686479,378169.8125 5686480.5,378169.34375 5686481,378169.21875 5686482,378168.75 5686483,378167.78125 5686485,378167.71875 5686485.5,378167.3125 5686485.5,378166.40625 5686486.5,378165.9375 5686487.5,378165.84375 5686488.5,378165 5686489,378164.21875 5686489,378163.28125 5686490.5,378161.625 5686491.5,378160.71875 5686492.5,378160.59375 5686493.5,378159.8125 5686493.5,378159.375 5686494,378156.9375 5686494.5,378155.65625 5686495.5,378154.40625 5686496,378154.03125 5686496,378153.625 5686496,378153.5625 5686497,378152.75 5686497,378152.71875 5686497,378152.28125 5686497.5,378151.09375 5686498,378150.28125 5686498,378149.03125 5686498.5,378148.25 5686498.5,378146.6875 5686498,378144.25 5686498.5,378140.3125 5686498.5,378138.75 5686498,378137.1875 5686498,378136.40625 5686498,378135.5625 5686498.5,378134.78125 5686498,378133.625 5686498,378132.4375 5686498,378130.09375 5686497.5,378128.90625 5686497.5,378127.71875 5686497.5,378126.53125 5686497.5,378125.375 5686497,378124.1875 5686497,378122.625 5686497,378121.4375 5686497,378119.78125 5686497.5,378118.625 5686497.5,378117.84375 5686497.5,378116.65625 5686497,378115.875 5686497,378115.09375 5686497,378114.28125 5686497,378112.34375 5686496.5,378111.53125 5686496.5,378110.75 5686496.5,378108.78125 5686496.5,378107.625 5686496,378106.0625 5686496,378104.875 5686496,378104.46875 5686496,378103.6875 5686496,378103.3125 5686496,378102.5 5686495.5,378101.71875 5686495.5,378100.125 5686496,378098.9375 5686495.5,378098.15625 5686495.5,378097.375 5686495.5,378096.15625 5686496,378094.96875 5686495.5,378092.625 5686495.5,378090.25 5686495.5,378089.09375 5686495,378087.90625 5686495,378087.125 5686495,378086.34375 5686495,378085.1875 5686494.5,378083.625 5686494,378082.84375 5686494,378082.0625 5686494,378081.3125 5686493.5,378080.53125 5686493.5,378078.15625 5686493,378077 5686493,378075.40625 5686493,378074.25 5686493,378073.4375 5686493,378072.65625 5686492.5,378072.28125 5686492.5,378071.09375 5686492.5,378070.3125 5686492.5,378068.3125 5686492.5,378066.75 5686492.5,378065.5625 5686492.5,378064.78125 5686492.5,378064 5686492,378063.25 5686491.5,378062.46875 5686491.5,378061.65625 5686491.5,378060.5625 5686490.5,378059.78125 5686490.5,378058.21875 5686490.5,378057.4375 5686490.5,378055.46875 5686490,378054.28125 5686490,378053.15625 5686489.5,378052.75 5686489.5,378051.59375 5686489,378051.21875 5686489,378049.65625 5686489,378048.9375 5686488,378048.625 5686487,378047.875 5686486.5,378047.1875 5686485.5,378046.125 5686484,378045.78125 5686483.5,378045.03125 5686483,378044.625 5686483,378043.53125 5686482,378042.03125 5686481,378041.28125 5686481,378041.3125 5686480.5,378040.53125 5686480.5,378039.75 5686480,378038.96875 5686480,378038.5625 5686480,378037 5686480,378036.21875 5686480,378034.65625 5686479.5,378033.4375 5686480,378032.59375 5686480.5,378032.1875 5686480.5,378031.3125 5686481.5,378030.9375 5686481.5,378029.65625 5686482,378028.875 5686482,378028.03125 5686482.5,378026.46875 5686482.5,378025.59375 5686483,378024.40625 5686483,378023.5625 5686483.5,378023.125 5686484,378022.3125 5686484.5,378021.90625 5686484.5,378021.0625 5686485,378019.84375 5686485.5,378019.4375 5686485.5,378018.53125 5686486.5,378017.3125 5686486.5,378016.5 5686487,378016.03125 5686488,378015.5625 5686488.5,378015.125 5686489,378013.8125 5686490.5,378013.34375 5686491,378013.28125 5686492,378013.1875 5686492.5,378012.8125 5686492.5,378012.03125 5686492.5,378011.125 5686493.5,378009.4375 5686494.5,378008.96875 5686495.5,378008.53125 5686495.5,378008.15625 5686495.5,378008.0625 5686496.5,378007.25 5686497,378006.46875 5686496.5,378005.3125 5686496,378004.9375 5686496,378004.53125 5686496,378003.34375 5686496,378002.5625 5686496,378001 5686496,378000.21875 5686495.5,377998.25 5686495.5,377996.6875 5686495.5,377995.53125 5686495,377994.78125 5686494.5,377994 5686494.5,377993.21875 5686494,377992.09375 5686493.5,377991.28125 5686493.5,377989.71875 5686493.5,377989.34375 5686493.5,377987.75 5686493,377987.375 5686493,377986.1875 5686493,377985.78125 5686493,377984.6875 5686492,377984.3125 5686492,377983.125 5686492,377982.34375 5686492,377981.5625 5686492,377980.78125 5686491.5,377979.96875 5686491.5,377980.0625 5686491,377979.3125 5686490.5,377978.90625 5686490.5,377979 5686489.5,377978.21875 5686489.5,377977.5625 5686488,377976.53125 5686486,377975.875 5686485,377975.625 5686483.5,377975.65625 5686483,377974.9375 5686482,377974.65625 5686481,377974.75 5686480,377974 5686479.5,377974.03125 5686479,377973.75 5686478,377973.9375 5686476,377972.84375 5686475,377972.59375 5686473.5,377972.75 5686472,377972.46875 5686470.5,377972.5625 5686469.5,377971.90625 5686468,377971.625 5686467,377971.3125 5686466,377971.40625 5686465,377971.5 5686464,377971.1875 5686463.5,377970.46875 5686462.5,377970.5 5686462,377969.71875 5686462,377969.15625 5686459.5,377967.34375 5686458,377966.71875 5686456,377966.03125 5686455,377965.71875 5686454,377965.40625 5686453,377965.03125 5686453,377964.6875 5686452.5,377963.96875 5686451.5,377963.625 5686451,377962.84375 5686451,377962.4375 5686451,377962.0625 5686451,377960.875 5686451,377960.15625 5686450,377959.78125 5686450,377958.96875 5686450,377958.625 5686449.5,377957.5 5686449,377957.09375 5686449,377955.90625 5686448.5,377955.125 5686448.5,377955.25 5686447.5,377954.46875 5686447.5,377953.78125 5686446,377953.0625 5686445,377952.75 5686444.5,377952.46875 5686443,377952.125 5686442.5,377952.1875 5686442,377951.53125 5686440.5,377951.5625 5686440.5,377950.53125 5686438.5,377949.8125 5686437.5,377949.5 5686437,377949.1875 5686436,377948.875 5686435.5,377948.9375 5686434.5,377948.3125 5686433,377947.1875 5686432,377946.59375 5686430,377946.375 5686428.5,377946.09375 5686427,377945.8125 5686426,377945.46875 5686425,377945.59375 5686424,377944.875 5686423,377944.96875 5686422,377945.03125 5686421.5,377945.0625 5686421,377944.28125 5686421,377944.375 5686420,377944.4375 5686419.5,377944.03125 5686419.5,377943.84375 5686417.5,377941.625 5686415.5,377940.96875 5686414,377941.0625 5686413,377940.75 5686412,377939.96875 5686412,377940 5686411.5,377939.4375 5686409.5,377939.1875 5686407.5,377939.34375 5686406,377938.28125 5686405,377937.90625 5686405,377937.96875 5686404,377936.0625 5686403,377935.40625 5686401.5,377933.875 5686401,377933.1875 5686400,377932.875 5686399,377932.15625 5686398,377932.21875 5686398,377931.15625 5686396.5,377930.40625 5686396,377929.3125 5686394.5,377928.3125 5686393,377927.625 5686392,377927.375 5686390,377926.6875 5686389.5,377926.75 5686388.5,377925.96875 5686388.5,377926 5686388,377926.03125 5686387.5,377925.3125 5686387,377924.96875 5686386.5,377925 5686386,377924.625 5686386,377923.90625 5686385,377923.28125 5686383.5,377922.5625 5686382.5,377921.9375 5686381,377921.6875 5686379.5,377920.96875 5686378.5,377920.6875 5686377,377920.40625 5686376,377920.15625 5686374.5,377919.53125 5686372.5,377919.28125 5686371,377919.03125 5686369.5,377919.1875 5686368,377919.375 5686366,377919.53125 5686364.5,377919.6875 5686363,377919.84375 5686361,377919.9375 5686360,377919.625 5686359,377919.40625 5686357,377919.5 5686356.5,377919.6875 5686354.5,377919.78125 5686353.5,377919.9375 5686351.5,377920.0625 5686350.5,377920.15625 5686349.5,377920.25 5686348.5,377920.28125 5686348,377920.125 5686345.5,377919.09375 5686344,377918.375 5686343,377918.4375 5686342.5,377918.0625 5686342.5,377917.53125 5686339.5,377916.96875 5686337,377917.15625 5686335,377913.75 5686333.5,377912.25 5686332.5,377911.1875 5686331.5,377910.46875 5686330.5,377910.09375 5686330,377909.71875 5686330,377908.9375 5686330,377909.03125 5686328.5,377907.5 5686328,377906.8125 5686327.5,377906.40625 5686327.5,377905.71875 5686326,377903.875 5686324.5,377902.8125 5686323.5,377902.09375 5686322.5,377901 5686321.5,377900.28125 5686320.5,377899.59375 5686320,377899.25 5686319,377898.5 5686318.5,377898.5625 5686318,377898.15625 5686318,377896.96875 5686318,377896.1875 5686318,377894.21875 5686317.5,377893.4375 5686317.5,377892.28125 5686317.5,377891.4375 5686318,377891.03125 5686318,377890.15625 5686319,377889.375 5686319,377887.8125 5686318.5,377887.375 5686319,377886.15625 5686319.5,377885.375 5686319,377885.25 5686320.5,377884.40625 5686321,377882.75 5686321.5,377881.5 5686322.5,377880.6875 5686322.5,377880.25 5686323,377879.375 5686323.5,377879 5686323.5,377877.65625 5686325,377876.40625 5686326,377875.5625 5686326.5,377875.46875 5686327.5,377875.09375 5686327.5,377874.96875 5686328.5,377874.15625 5686329,377872.65625 5686332,377871.71875 5686333.5,377871.21875 5686334.5,377871.125 5686335.5,377871.09375 5686336,377871 5686337,377870.09375 5686338,377870 5686339,377869.03125 5686341,377868.15625 5686341.5,377868.0625 5686343,377867.53125 5686344,377867.4375 5686345,377866.9375 5686346.5,377865.9375 5686348,377865.4375 5686349.5,377865.375 5686350,377865.34375 5686350.5,377865.3125 5686351,377864.5 5686351,377863.53125 5686352.5,377863.03125 5686354,377862.9375 5686355,377862.375 5686356.5,377862.21875 5686358,377861.71875 5686359.5,377860.8125 5686360.5,377860.75 5686361,377860.375 5686361,377859.65625 5686364.5,377858.625 5686367,377858.5 5686368,377858.40625 5686369.5,377858.34375 5686369.5,377858.3125 5686370,377858.25 5686371,377858.21875 5686371.5,377857.75 5686372,377857.6875 5686372.5,377856.8125 5686373.5,377856.53125 5686376.5,377856.5 5686376.5,377856.46875 5686377,377856.3125 5686378.5,377856.25 5686379.5,377856.09375 5686381,377856.03125 5686382,377855.875 5686383.5,377855.78125 5686384,377855.46875 5686387.5,377855.3125 5686389,377855.125 5686391,377854.9375 5686393,377854.8125 5686394.5,377854.34375 5686395,377853.46875 5686396,377853.03125 5686396.5,377852.125 5686397.5,377851.6875 5686398,377850.71875 5686400,377849.875 5686400.5,377849.34375 5686402,377849.25 5686403,377849.1875 5686403.5,377849.09375 5686404.5,377848.1875 5686405.5,377848.125 5686406.5,377847.90625 5686409,377847.75 5686410.5,377847.5625 5686412.5,377847.375 5686414.5,377847.3125 5686415,377847.21875 5686416,377847.15625 5686416.5,377847 5686418,377846.8125 5686420,377846.6875 5686421.5,377846.5625 5686423,377847.15625 5686425,377847.4375 5686426,377847.3125 5686427.5,377847.21875 5686428.5,377847.09375 5686429.5,377847.03125 5686430.5,377846.96875 5686431,377847.375 5686431,377847.15625 5686433.5,377847.78125 5686435,377847.71875 5686436,377847.625 5686436.5,377848.40625 5686436.5,377848.65625 5686438,377850.875 5686440,377851.96875 5686441,377852.28125 5686442,377853.0625 5686442,377853.40625 5686442.5,377854.53125 5686443,377856.03125 5686444,377857.21875 5686444.5,377857.96875 5686444.5,377858.625 5686446,377859.40625 5686446,377860.53125 5686447,377862.0625 5686447.5,377863.15625 5686448.5,377863.5 5686449,377864.3125 5686449,377864.6875 5686449,377865 5686450,377865.78125 5686450,377866.9375 5686450.5,377867.71875 5686450.5,377869.28125 5686450.5,377870.0625 5686450.5,377871.65625 5686451,377872.4375 5686451,377874.03125 5686450.5,377875.21875 5686451,377876 5686451,377876.875 5686450,377877.65625 5686450.5,377879.25 5686450,377880.84375 5686450,377881.625 5686450.5,377882.90625 5686449.5,377883.3125 5686449.5,377884.15625 5686448.5,377884.9375 5686448.5,377886.21875 5686447.5,377887.03125 5686447.5,377888.25 5686447.5,377888.625 5686447.5,377889.4375 5686447,377890.25 5686447,377891.09375 5686446.5,377892.28125 5686446.5,377894.25 5686447,377896.1875 5686447,377897.375 5686447,377898.15625 5686447,377899.34375 5686447.5,377900.125 5686447.5,377901.21875 5686448.5,377903.5625 5686449,377905.0625 5686450,377905.75 5686451,377906.53125 5686451,377907.34375 5686451,377908.03125 5686452,377908.78125 5686452.5,377909.90625 5686453,377910.6875 5686453.5,377912.5 5686455,377913.59375 5686456,377914.34375 5686456.5,377915.0625 5686457.5,377915.40625 5686457.5,377915.71875 5686458.5,377916.3125 5686460.5,377918.5625 5686462,377919.625 5686463.5,377920.3125 5686464.5,377921.03125 5686465.5,377921.375 5686466,377921.71875 5686466.5,377922.4375 5686467,377922.78125 5686467.5,377923.125 5686468.5,377924.59375 5686469.5,377925.71875 5686470.5,377926.03125 5686471,377926.75 5686472,377927.09375 5686472.5,377927.5 5686472.5,377928.1875 5686473.5,377928.5625 5686473.5,377929.21875 5686475,377930.75 5686475.5,377931.46875 5686476.5,377932.21875 5686477,377932.9375 5686478,377933.625 5686478.5,377934.34375 5686479.5,377934.65625 5686480.5,377935.375 5686481,377935.6875 5686482,377936.4375 5686482.5,377936.40625 5686483,377937.125 5686483.5,377937.46875 5686484,377938.1875 5686485,377938.09375 5686486,377938.46875 5686486.5,377939.53125 5686487.5,377940.28125 5686488,377940.25 5686488.5,377940.5625 5686489.5,377941.28125 5686490,377941.59375 5686491,377941.875 5686492,377942.96875 5686493,377943.6875 5686494,377944.34375 5686495,377945.09375 5686495.5,377945.03125 5686496.5,377945.40625 5686496.5,377946.09375 5686498,377947.59375 5686498.5,377948.21875 5686500.5,377949.71875 5686501.5,377950.03125 5686502,377950.75 5686503,377951.0625 5686504,377951.4375 5686504.5,377952.21875 5686504.5,377952.125 5686505,377952.53125 5686505,377953.71875 5686505.5,377954.6875 5686507.5,377956.53125 5686509,377957.25 5686509.5,377957.5625 5686510.5,377957.96875 5686510.5,377957.90625 5686511.5,377958.625 5686512,377959.75 5686512.5,377960.125 5686512.5,377960.8125 5686514,377961.15625 5686514.5,377960.9375 5686517,377960.78125 5686518.5,377960.59375 5686520.5,377960.4375 5686522,377960.3125 5686523.5,377960.1875 5686524.5,377960.09375 5686526,377959.96875 5686527,377959 5686529,377958.90625 5686529.5,377958.8125 5686531,377958.71875 5686531.5,377958.625 5686533,377958.59375 5686533,377957.5625 5686535.5,377957 5686537.5,377956.90625 5686538,377956.4375 5686539,377956.34375 5686540,377955.5 5686540.5,377954.21875 5686541.5,377953.40625 5686542,377952.53125 5686542.5,377952.125 5686543,377951.21875 5686544,377950 5686544.5,377949.125 5686545,377948.71875 5686545.5,377948.3125 5686545.5,377947.90625 5686545,377947.0625 5686546,377946.625 5686546.5,377945.40625 5686546.5,377944.25 5686546.5,377943.0625 5686546.5,377941.875 5686546,377941.40625 5686547,377940.59375 5686547.5,377939.40625 5686547,377938.625 5686547,377937.4375 5686547,377936.65625 5686547,377935.09375 5686546.5,377933.90625 5686546.5,377933.125 5686546.5,377932.34375 5686546.5,377931.5625 5686546.5,377930.375 5686546,377929.59375 5686546,377928.0625 5686545.5,377926.90625 5686545,377926.125 5686545,377925.34375 5686545,377924.53125 5686545.5,377922.09375 5686546,377921.28125 5686546,377920.40625 5686547,377919.625 5686546.5,377919.21875 5686546.5,377918.40625 5686547,377917.5 5686548,377917.40625 5686549.5,377916.4375 5686550,377916.40625 5686552.5,377915.59375 5686558,377914.71875 5686565.5,377914.6875 5686571,377914.65625 5686574,377914.625 5686576.5,377914.1875 5686581.5,377914.15625 5686585.5,377914.125 5686589.5,377914.09375 5686593,377914.8125 5686600.5,377915.53125 5686607,377916.6875 5686610.5,377917.84375 5686614,377920.15625 5686616,377920.09375 5686616.5,377920.375 5686618,377920.3125 5686618.5,377920.125 5686620.5,377920 5686622,377919.875 5686623.5,377919.71875 5686625,377919.6875 5686625.5,377919.59375 5686626,377918.75 5686627,377918.6875 5686627.5,377918.625 5686628,377918.1875 5686628.5,377918.15625 5686629,377918.125 5686629,377917.9375 5686631,377917.78125 5686633,377917.625 5686634.5,377918.28125 5686636,377918.59375 5686637,377918.5 5686637.5,377918.46875 5686638,377920.4375 5686638,377921.125 5686639.5,377921.90625 5686639.5,377922.6875 5686639.5,377923.0625 5686639.5,377923.40625 5686640.5,377924.15625 5686641,377925.3125 5686641,377926.09375 5686641,377927.28125 5686641.5,377928.0625 5686641.5,377929.625 5686641.5,377930.4375 5686641.5,377931.125 5686642.5,377931.5 5686643,377931.84375 5686643.5,377932.625 5686643.5,377934.09375 5686645,377935.21875 5686645.5,377936.375 5686646,377936.6875 5686646.5,377937 5686647.5,377937.75 5686648,377938.4375 5686649,377939.125 5686650,377939.84375 5686651,377940.15625 5686651.5,377940.5 5686652.5,377941.15625 5686654,377941.46875 5686654.5,377941.75 5686656,377942.03125 5686657,377942.71875 5686658.5,377943.03125 5686659,377942.90625 5686660.5,377943.59375 5686661.5,377943.90625 5686662.5,377944.1875 5686663.5,377944.4375 5686665.5,377944.71875 5686666.5,377945.03125 5686667.5,377945.28125 5686669,377945.5625 5686670,377945.84375 5686671.5,377945.71875 5686672.5,377945.65625 5686673.5,377946.3125 5686674.5,377947 5686676,377946.90625 5686676.5,377946.8125 5686678,377946.71875 5686678.5,377946.53125 5686680.5,377946.4375 5686682,377946.3125 5686683,377946.21875 5686684,377946.09375 5686685.5,377946.0625 5686685.5,377945.9375 5686687,377945.875 5686687.5,377945.71875 5686689.5,377945.65625 5686690,377944.84375 5686690,377944.46875 5686690,377943.59375 5686690.5,377942.375 5686691,377941.59375 5686691,377940.8125 5686691,377940.03125 5686690.5,377938.84375 5686690.5,377938.46875 5686690.5,377937.28125 5686690.5,377936.5 5686690.5,377934.9375 5686690,377933.75 5686690,377932.96875 5686690,377932.5625 5686690,377931.78125 5686690,377931.46875 5686689,377930.3125 5686688.5,377929.53125 5686688.5,377929.15625 5686688.5,377927.96875 5686688.5,377927.5625 5686688,377926.78125 5686688,377926 5686688,377923.9375 5686689,377922.6875 5686689.5,377921.46875 5686690,377921 5686690.5,377920.59375 5686690.5,377919.4375 5686690.5,377918.21875 5686691,377916.625 5686690.5,377916.25 5686690.5,377915.84375 5686690.5,377915.46875 5686690.5,377914.28125 5686690.5,377913.875 5686690.5,377913.09375 5686690.5,377912.71875 5686690.5,377911.96875 5686690,377911.5625 5686690,377910.40625 5686689.5,377910 5686689.5,377909.25 5686689,377908.84375 5686689,377908.0625 5686689,377907.28125 5686689,377906.09375 5686689,377905.71875 5686689,377904.8125 5686690,377903.21875 5686690,377901.96875 5686691,377901.5625 5686691,377900.28125 5686692,377898.25 5686692.5,377897.375 5686693,377896.5 5686694,377896.125 5686694,377895.96875 5686695.5,377893.5 5686696.5,377892.1875 5686698,377891.3125 5686698.5,377890.875 5686699,377890.8125 5686699.5,377890.75 5686700.5,377890.6875 5686701,377889.90625 5686700.5,377889.84375 5686701.5,377889.375 5686702,377889.09375 5686705,377888.21875 5686706,377888.125 5686707,377888.03125 5686708,377887.9375 5686709,377887.875 5686709.5,377887.75 5686711,377887.6875 5686711.5,377887.5625 5686713,377887.5 5686713.5,377887.4375 5686714.5,377887.96875 5686717,377888.21875 5686717.5),(378145.21875 5686513.5,378145.125 5686514.5,378145.4375 5686515.5,378146.34375 5686518.5,378147.03125 5686519.5,378147.6875 5686521,378147.59375 5686522,378147.90625 5686523,378147.875 5686523.5,378147.75 5686524.5,378148.5 5686525,378149.125 5686526.5,378149.84375 5686527.5,378150.15625 5686528.5,378150.90625 5686529,378151.21875 5686529.5,378151.53125 5686530.5,378151.75 5686532.5,378152.8125 5686534,378153.5 5686535,378154.125 5686536.5,378154.4375 5686537.5,378154.375 5686538.5,378155.0625 5686539,378154.9375 5686540.5,378155.625 5686541.5,378155.5 5686543,378155.40625 5686544,378155.8125 5686544,378156 5686546,378156.65625 5686547.5,378156.5625 5686548.5,378156.53125 5686549,378156.3125 5686551,378156.9375 5686553,378156.90625 5686553.5,378156.84375 5686554,378157.625 5686554,378157.8125 5686556,378157.71875 5686557.5,378158.4375 5686558,378158.375 5686558.5,378159.15625 5686558.5,378159.8125 5686560.5,378160.09375 5686561.5,378160 5686562.5,378161.15625 5686563,378160.96875 5686565,378160.8125 5686566.5,378160.71875 5686567.5,378160.59375 5686568.5,378159.59375 5686571,378159.40625 5686573,378159.25 5686574.5,378157.96875 5686575.5,378157.4375 5686577,378157.375 5686577.5,378157.3125 5686578.5,378157.21875 5686579,378156.84375 5686579,378156.375 5686580,378156.28125 5686580.5,378156.21875 5686581.5,378156.1875 5686582,378155.3125 5686582.5,378155.28125 5686583,378155.21875 5686583.5,378155.125 5686584.5,378155.03125 5686585.5,378154.9375 5686586.5,378154.84375 5686587.5,378154.75 5686588.5,378154.6875 5686589,378154.65625 5686589.5,378154.53125 5686591,378154.5 5686591,378154.40625 5686592,378153.59375 5686592.5,378153.40625 5686594,378152.125 5686595.5,378152 5686596.5,378151.9375 5686597.5,378151.84375 5686598,378151.375 5686599,378151.28125 5686600,378151.1875 5686601,378150.59375 5686603,378150.09375 5686604,378150 5686605,378149.9375 5686606,378149.84375 5686606.5,378149.03125 5686607,378148.09375 5686608.5,378147.625 5686609,378147.5625 5686610,378147.46875 5686610.5,378147.46875 5686611,378147.40625 5686611.5,378146.9375 5686612.5,378146.15625 5686612,378146.125 5686612.5,378145.25 5686613.5,378144.6875 5686615,378144.5625 5686616.5,378143.78125 5686616.5,378142.40625 5686618,378141.875 5686619.5,378141.84375 5686620,378139.84375 5686620.5,378139.3125 5686621.5,378139.25 5686622,378139.1875 5686623,378136.78125 5686623,378135.90625 5686624,378135.875 5686624.5,378135.09375 5686624,378133.8125 5686625,378132.96875 5686625.5,378132.5625 5686626,378132.5 5686626.5,378132.28125 5686628.5,378131.34375 5686630,378131.28125 5686631,378131.15625 5686632,378131.09375 5686633,378131.0625 5686633.5,378130.90625 5686635,378129.96875 5686636.5,378129.9375 5686637,378129.84375 5686637.5,378129.78125 5686638.5,378129.75 5686638.5,378129.65625 5686639.5,378129.5625 5686640.5,378129.46875 5686641.5,378129.40625 5686642.5,378130.125 5686643,378130.09375 5686643.5,378130 5686644.5,378130.78125 5686644.5,378130.96875 5686647,378130.8125 5686648.5,378130.6875 5686649.5,378130.59375 5686650.5,378130.4375 5686652.5,378130.3125 5686653.5,378130.25 5686654.5,378130.03125 5686656.5,378130 5686657,378129.90625 5686658,378129.875 5686658,378129.75 5686659.5,378128.15625 5686659.5,378127.25 5686660.5,378126.78125 5686661.5,378126.75 5686662,378126.3125 5686662,378125.5 5686662.5,378125.09375 5686662.5,378124.3125 5686662.5,378123.46875 5686663,378123.375 5686664,378122.59375 5686664,378120.53125 5686665,378119.65625 5686665.5,378118.875 5686665.5,378118.40625 5686666,378116.75 5686667,378116.34375 5686667,378115.15625 5686667,378114.375 5686667,378113.46875 5686668,378112.28125 5686668,378111.5 5686668,378109.875 5686668.5,378108.65625 5686669,378107.46875 5686668.5,378107.0625 5686668.5,378106.6875 5686668.5,378105.90625 5686668.5,378105.03125 5686669,378103.875 5686669,378101.90625 5686669,378100.71875 5686669,378099.9375 5686668.5,378099.15625 5686668.5,378098.75 5686668.5,378097.96875 5686668.5,378096.40625 5686668.5,378094.5 5686667.5,378093.34375 5686667,378092.9375 5686667,378092.15625 5686667,378091.375 5686667,378090.65625 5686666,378089.90625 5686665.5,378088.34375 5686665.5,378087.5625 5686665.5,378087.15625 5686665.5,378086.375 5686665.5,378085.1875 5686665,378084.40625 5686665,378083.21875 5686665,378082.84375 5686665,378082.0625 5686665,378081.28125 5686665,378080.46875 5686664.5,378079.3125 5686664.5,378077.34375 5686664.5,378075.78125 5686664.5,378074.59375 5686664,378074.1875 5686664,378073.8125 5686664,378073.03125 5686664,378071.84375 5686664,378069.875 5686663.5,378069.09375 5686663.5,378067.125 5686663.5,378065.90625 5686663.5,378065.125 5686663.5,378064.34375 5686663.5,378075.375 5686660.5,378075.40625 5686660,378076.1875 5686660,378076.6875 5686659,378077.15625 5686658,378077.28125 5686657,378078.125 5686656,378078.90625 5686656,378079.03125 5686655,378080.71875 5686654,378081.5 5686654,378081.59375 5686653,378081.65625 5686652.5,378082.15625 5686651.5,378082.1875 5686651,378083.4375 5686650.5,378083.875 5686650,378084.34375 5686649,378085.5625 5686649,378085.96875 5686648.5,378086.40625 5686648.5,378087.3125 5686647,378088.5625 5686646.5,378089.4375 5686646,378089.9375 5686644.5,378091.1875 5686644,378091.65625 5686643,378092.125 5686642.5,378092.15625 5686642,378092.21875 5686641.5,378092.625 5686641.5,378093.59375 5686639.5,378093.71875 5686638.5,378093.78125 5686637.5,378093.90625 5686636.5,378093.96875 5686635.5,378094 5686635,378094.09375 5686634.5,378094.15625 5686633.5,378093.5625 5686631.5,378093.25 5686630.5,378093.3125 5686630,378093.34375 5686629.5,378093.5 5686628,378092.75 5686627.5,378092.5 5686626,378092.5625 5686625.5,378092.65625 5686624.5,378092.6875 5686624,378092.84375 5686622.5,378092.9375 5686621.5,378093.4375 5686620.5,378093.5 5686619.5,378094.78125 5686618.5,378094.875 5686617.5,378094.96875 5686616.5,378095.0625 5686616,378095.90625 5686615,378095.96875 5686614.5,378096.4375 5686614,378098.0625 5686613.5,378098.96875 5686612,378099.4375 5686611.5,378099.46875 5686611,378099.53125 5686610,378099.65625 5686609,378100.125 5686608.5,378100.28125 5686606.5,378100.34375 5686606,378100.53125 5686604,378100.625 5686603,378100.6875 5686602.5,378100.8125 5686601,378100.90625 5686600,378101.40625 5686599,378102.34375 5686597.5,378102.46875 5686596,378102.53125 5686595.5,378103 5686594.5,378103.40625 5686594.5,378103.5 5686593.5,378104.75 5686593,378105.6875 5686591.5,378106.96875 5686590.5,378107.40625 5686590,378107.84375 5686589.5,378108.75 5686588.5,378109.40625 5686588.5,378109.96875 5686588.5,378110.78125 5686588,378110.875 5686587,378111.65625 5686587,378111.6875 5686587,378111.71875 5686586.5,378112.59375 5686585.5,378112.71875 5686584,378112.8125 5686583.5,378113.75 5686582,378113.84375 5686580.5,378114 5686579,378114.09375 5686578.5,378114.1875 5686577,378114.28125 5686576.5,378114.34375 5686575.5,378114.03125 5686575,378114.125 5686573.5,378114.21875 5686573,378114.28125 5686572,378113.5625 5686571,378113.28125 5686570,378113.34375 5686569.5,378113.5625 5686567,378113.65625 5686566,378113.84375 5686564,378113.25 5686562,378112.96875 5686560.5,378113.125 5686559,378113.21875 5686558.5,378113.28125 5686557.5,378113.3125 5686557,378112.96875 5686557,378113.03125 5686556,378113.0625 5686555.5,378111.90625 5686555.5,378110.3125 5686555.5,378108.3125 5686555.5,378107.53125 5686555.5,378107.15625 5686555.5,378106.71875 5686555.5,378105.90625 5686556,378105.09375 5686556,378104.3125 5686556,378103.53125 5686556,378102.75 5686555.5,378101.5625 5686555.5,378100.40625 5686555.5,378100.03125 5686555,378099.3125 5686554,378098.59375 5686553.5,378096.625 5686553.5,378095.125 5686552.5,378094.34375 5686552.5,378093.15625 5686552.5,378092.8125 5686552,378091.65625 5686551.5,378091.28125 5686551.5,378089.6875 5686551,378088.53125 5686551,378086.5625 5686551,378084.625 5686550.5,378083.4375 5686550,378083.0625 5686550,378082.65625 5686550,378082.28125 5686550,378081.5 5686550,378081.09375 5686550,378080 5686549,378078.8125 5686549,378078.21875 5686547,378077.125 5686546,378076 5686545,378075.65625 5686544.5,378074.875 5686544.5,378074.15625 5686543.5,378073.375 5686543.5,378071.53125 5686542,378069.71875 5686540.5,378068.6875 5686539,378067.65625 5686537,378066.96875 5686536,378066.3125 5686534.5,378066 5686533.5,378065.3125 5686532.5,378065 5686531.5,378065.0625 5686531,378064.34375 5686530,378064.4375 5686529,378063.71875 5686528.5,378063.75 5686528,378063.90625 5686526.5,378063.96875 5686525.5,378063.3125 5686524.5,378063.375 5686523.5,378063.46875 5686523,378063.5 5686522.5,378063.65625 5686521,378063.75 5686519.5,378063.84375 5686519,378064.625 5686519,378065.90625 5686518,378067.90625 5686517.5,378069.125 5686517.5,378070 5686516.5,378070.8125 5686516.5,378072.0625 5686515.5,378072.9375 5686515,378073.78125 5686514.5,378074.6875 5686513,378075.53125 5686512.5,378076.34375 5686512.5,378076.40625 5686511.5,378076.4375 5686511.5,378077.625 5686511.5,378078.875 5686511,378080.875 5686510.5,378081.65625 5686510.5,378082.4375 5686511,378083.21875 5686511,378083.625 5686511,378084.8125 5686511,378085.59375 5686511,378087.21875 5686510.5,378089.1875 5686510.5,378090.0625 5686510,378090.84375 5686510,378092.0625 5686510,378092.21875 5686510,378095.40625 5686512,378099.71875 5686514.5,378103.28125 5686515.5,378108 5686517.5,378113.125 5686518,378117.46875 5686519,378121.8125 5686519,378126.5625 5686519,378131.3125 5686519,378135.25 5686518.5,378138.4375 5686517.5,378143.1875 5686515,378145.21875 5686513.5),(378774.4375 5685824.5,378776.46875 5685827,378781.53125 5685834,378783.875 5685837.5,378787 5685842,378790.90625 5685846.5,378796.40625 5685850,378798.6875 5685851,378798.625 5685851.5,378798.5625 5685852,378798.4375 5685853,378798.34375 5685854.5,378799.34375 5685856,378799.28125 5685857,378798.875 5685861,378798.65625 5685863.5,378798.375 5685866.5,378798.125 5685869,378798 5685870.5,378797.46875 5685872,378797 5685872.5,378796.875 5685873.5,378796.8125 5685874.5,378796.78125 5685875,378796 5685875,378794.9375 5685877.5,378790.625 5685881,378789.15625 5685884,378787.6875 5685887,378786.40625 5685888,378785.09375 5685889,378783.8125 5685890.5,378782.53125 5685891.5,378780.875 5685892,378780.03125 5685892.5,378778.75 5685893.5,378777.90625 5685894,378776.65625 5685894.5,378775.4375 5685895,378774.1875 5685895.5,378773.34375 5685896,378772.53125 5685896.5,378771.3125 5685896.5,378770.53125 5685896.5,378769.75 5685896.5,378768.53125 5685896.5,378766.875 5685897.5,378765.65625 5685897.5,378764.46875 5685898,378763.625 5685898,378762.375 5685899,378761.5625 5685899,378760.6875 5685900,378759.84375 5685900.5,378758.625 5685901,378757.71875 5685902,378756.4375 5685903,378755.09375 5685904.5,378753.375 5685906,378752.4375 5685907.5,378751.5625 5685908.5,378750.65625 5685909.5,378749.78125 5685910.5,378748.96875 5685910.5,378748.15625 5685911,378747.28125 5685911.5,378746.0625 5685912,378744.78125 5685913,378742.78125 5685913,378741.5 5685914,378740.1875 5685915.5,378739.375 5685915.5,378739.3125 5685916.5,378738.46875 5685916.5,378738.4375 5685917,378737.625 5685917.5,378736.6875 5685919,378735.4375 5685919.5,378734.53125 5685920.5,378732.8125 5685922,378731.90625 5685923,378731 5685924.5,378730.15625 5685925,378729.28125 5685925.5,378728.4375 5685926.5,378727.5625 5685927,378726.71875 5685928,378725.84375 5685928.5,378724.59375 5685929,378723.75 5685930,378722.90625 5685930,378722.0625 5685931,378721.1875 5685931.5,378720.34375 5685932.5,378719.46875 5685933,378718.21875 5685933.5,378717.375 5685934.5,378716.90625 5685935,378716.03125 5685936,378715.21875 5685936,378714.78125 5685936.5,378713.90625 5685937.5,378713.4375 5685938,378712.9375 5685939,378712.125 5685939.5,378711.65625 5685940,378711.53125 5685941.5,378710.65625 5685942.5,378709.34375 5685943.5,378708.875 5685944.5,378708.40625 5685945,378707.5625 5685946,378707.09375 5685946.5,378705.78125 5685948,378704.5625 5685948,378703.65625 5685949.5,378703.15625 5685950.5,378702.25 5685951.5,378701.34375 5685952.5,378700.84375 5685954,378699.90625 5685955.5,378698.96875 5685957,378698.4375 5685958.5,378697.53125 5685959.5,378697 5685961,378696.5 5685962,378696.03125 5685963,378695.5625 5685963.5,378695.53125 5685964,378695.125 5685964,378694.125 5685966.5,378692.75 5685968,378692.21875 5685969.5,378692.0625 5685971,378692.03125 5685971.5,378691.96875 5685972,378691.875 5685973,378690.96875 5685974.5,378690.71875 5685977,378689.375 5685978.5,378688.53125 5685979,378688 5685980.5,378687.625 5685980.5,378687.5 5685981.5,378686.6875 5685982,378684.53125 5685983.5,378682.875 5685984,378681.5625 5685985.5,378680.65625 5685987,378680.1875 5685987.5,378680.15625 5685988,378659.96875 5685975,378660 5685974.5,378660.0625 5685974,378660.15625 5685973,378660.25 5685972,378660.3125 5685971.5,378659.65625 5685970,378659.34375 5685969,378659.40625 5685968.5,378659.5 5685967.5,378659.5625 5685966.5,378659.1875 5685966.5,378658.875 5685966,378658.90625 5685965.5,378658.21875 5685964,378658.3125 5685963.5,378657.28125 5685961.5,378656.96875 5685961,378657.0625 5685959.5,378657.15625 5685959,378656.875 5685957.5,378656.53125 5685957,378655.90625 5685955,378655.1875 5685954.5,378655.28125 5685953.5,378655.3125 5685953,378655.03125 5685952,378654.6875 5685951.5,378654.03125 5685950,378653.71875 5685949,378653.78125 5685948.5,378653.90625 5685947,378653.9375 5685946.5,378653.96875 5685946.5,378653.6875 5685945,378653.75 5685944.5,378653.09375 5685943,378653.1875 5685942.5,378652.65625 5685939.5,378652.03125 5685938,378652.125 5685936.5,378652.25 5685935.5,378652.3125 5685934.5,378652.40625 5685934,378652.4375 5685933.5,378652.125 5685932.5,378652.25 5685931,378651.9375 5685930,378651.65625 5685929,378651.75 5685928,378651.875 5685926.5,378651.1875 5685926,378651.3125 5685924,378651.4375 5685923,378651.5625 5685922,378651.28125 5685920.5,378651.4375 5685919,378651.5 5685918,378651.53125 5685918,378651.59375 5685917,378650.9375 5685916,378650.96875 5685915.5,378651.0625 5685914.5,378651.09375 5685914,378651.15625 5685913.5,378651.1875 5685913,378651.375 5685911,378652.25 5685910.5,378652.40625 5685909,378653.28125 5685907.5,378653.8125 5685906.5,378654.65625 5685906,378655.09375 5685905.5,378655.5625 5685904.5,378656.375 5685904.5,378657.15625 5685904.5,378658.84375 5685903.5,378660.46875 5685903.5,378661.34375 5685902,378662.21875 5685901.5,378663.46875 5685901,378664.71875 5685900,378665.96875 5685899.5,378666.84375 5685898.5,378668.0625 5685898.5,378668.90625 5685898,378669.8125 5685896.5,378671.0625 5685896,378671.96875 5685895,378673.21875 5685894,378674.46875 5685893.5,378675.3125 5685893,378676.53125 5685892.5,378677.375 5685892,378678.21875 5685891.5,378679.0625 5685891,378679.875 5685891,378680.6875 5685890.5,378681.96875 5685889.5,378683.625 5685889,378684.5 5685888,378685.34375 5685887.5,378686.59375 5685887,378687.46875 5685886,378688.71875 5685885.5,378689.96875 5685885,378690.78125 5685884.5,378692 5685884,378693.3125 5685883,378694.9375 5685882.5,378696.625 5685881.5,378697.875 5685881,378699.5625 5685880,378701.25 5685879,378702.5 5685878,378703.78125 5685877,378705.4375 5685876.5,378706.28125 5685875.5,378707.1875 5685874.5,378708.0625 5685874,378708.90625 5685873,378709.375 5685872.5,378710.21875 5685872,378710.625 5685872,378711.53125 5685870.5,378712.34375 5685870.5,378713.65625 5685869.5,378714.90625 5685868.5,378715.34375 5685868.5,378715.8125 5685867.5,378717.09375 5685866.5,378717.9375 5685866,378720.0625 5685864.5,378722.53125 5685863.5,378723.40625 5685862.5,378724.25 5685862,378724.6875 5685861.5,378725.53125 5685861,378726 5685860,378727.25 5685859.5,378729.03125 5685857.5,378731.0625 5685857,378732.34375 5685856,378733.25 5685855,378734.09375 5685854.5,378734.5625 5685853.5,378735 5685853,378735.84375 5685853,378736.71875 5685852,378738.34375 5685851.5,378739.1875 5685851,378740.5 5685850,378741.34375 5685849,378742.21875 5685848.5,378743.46875 5685847.5,378744.3125 5685847,378744.78125 5685846,378745.65625 5685845.5,378746.5 5685845,378746.96875 5685844,378747.4375 5685843.5,378747.53125 5685842.5,378748.40625 5685841.5,378748.5 5685840.5,378748.625 5685839,378749.15625 5685838,378749.28125 5685836.5,378749.40625 5685835,378749.5625 5685833.5,378749.71875 5685832,378750.21875 5685831,378750.375 5685829.5,378751.21875 5685828.5,378751.34375 5685827.5,378751.375 5685827,378751.40625 5685826.5,378752.59375 5685826.5,378753.90625 5685825.5,378756.34375 5685824.5,378757.5625 5685824.5,378758.78125 5685824,378759.96875 5685824.5,378760.75 5685824.5,378762.78125 5685824,378765.5625 5685823.5,378767.125 5685824,378768.71875 5685824,378770.28125 5685824,378771.46875 5685824.5,378772.25 5685824.5,378773.03125 5685824.5,378774.21875 5685824.5,378774.4375 5685824.5))
+</a>
+<test>
+  <op name="buffer" arg1="a" arg3="60">
+ POLYGON((377787.21236766 5686430.83570257,377787.091569461 5686434.83708883,377787.737693002 5686438.88795447,377787.864087559 5686442.68909533,377788.459649403 5686444.80578393,377788.880197144 5686448.70852724,377792.362122552 5686459.86695051,377797.94149236 5686470.13850574,377798.930849234 5686471.33060785,377799.58710372 5686472.52852275,377804.899910503 5686478.52288668,377805.406547456 5686479.13334686,377805.529915074 5686479.23371183,377805.644567469 5686479.36307249,377807.392061045 5686481.81156509,377816.741061307 5686490.34144172,377819.268024607 5686491.8162556,377819.445913559 5686491.96408342,377821.252932048 5686492.97470892,377821.845793585 5686493.32072123,377822.749238227 5686493.92301766,377822.749238226 5686493.92301766,377823.285211318 5686494.21114939,377825.784078899 5686496.21427985,377828.942060624 5686497.86905437,377829.459811307 5686498.34144172,377829.814097052 5686498.54821383,377830.563106926 5686499.15138158,377833.445420292 5686500.66756629,377840.389980754 5686504.72062639,377852.415040396 5686508.66531166,377853.163293988 5686508.74466712,377854.777839837 5686509.25493736,377860.602216238 5686509.85131204,377862.571299679 5686510.30820919,377870.722679781 5686510.92891152,377865.18357042 5686518.6232882,377864.473453212 5686520.3059776,377860.565589664 5686528.1292516,377857.549254266 5686538.50328245,377856.91908596 5686544.62059585,377856.237925827 5686549.23152597,377855.997961655 5686551.04715803,377855.122961655 5686558.54715803,377854.719718468 5686565.15909641,377854.689275479 5686570.51706246,377854.660155864 5686573.31254549,377854.65773972 5686573.50583704,377854.41587695 5686576.26998298,377854.189330971 5686581.0312643,377854.127092524 5686588.99778552,377854.096141439 5686592.46430707,377854.367387449 5686598.72377641,377855.086137449 5686606.22377641,377855.17598771 5686607.09442203,377855.89473771 5686613.59442203,377858.280137917 5686624.53884835,377858.199446436 5686625.39955748,377858.119771519 5686626.32673996,377858.023869995 5686627.55427948,377857.947895467 5686628.28363494,377857.764790992 5686638.5933333,377859.05375186 5686646.88004093,377856.001223071 5686649.83265362,377854.203654971 5686651.45270116,377853.326280308 5686652.05597871,377846.157898318 5686658.98972353,377845.720398318 5686659.48972353,377842.727400395 5686663.68434142,377841.391454247 5686665.19681894,377840.139069476 5686667.31182779,377838.825885171 5686669.15222545,377838.128428148 5686670.70736908,377835.625770583 5686674.93382011,377833.502392192 5686680.82867703,377832.29696122 5686683.50412238,377831.973057845 5686685.07436739,377831.790848094 5686685.58021243,377831.644992471 5686686.50242365,377830.932850338 5686688.15831566,377828.480696436 5686700.39955748,377828.206798474 5686703.32113575,377828.082254505 5686704.51727121,377827.999100384 5686705.51512066,377827.894754505 5686706.51727121,377827.786916907 5686707.81132239,377825.943807975 5686715.901891,377825.220199407 5686720.61874685,377824.548478334 5686724.33904817,377823.601072878 5686734.06261442,377823.569822878 5686736.06261442,377823.565273476 5686736.42310359,377823.533360075 5686739.74209727,377823.493888631 5686740.08215895,377823.097623592 5686746.31822584,377823.035123592 5686751.81822584,377823.032218468 5686752.15909641,377823.000968468 5686757.65909641,377823.000968468 5686757.65909641,377824.027668784 5686769.0573121,377824.471288948 5686771.42328631,377824.974612037 5686775.27480212,377825.581424615 5686779.00143074,377825.630407432 5686779.25222276,377826.18246145 5686785.71058515,377829.233057786 5686796.57781887,377831.545557786 5686802.57781887,377831.545557786 5686802.57781887,377836.345640303 5686812.3054845,377840.626890303 5686819.3054845,377840.626890303 5686819.3054845,377847.353282914 5686828.29116548,377850.978282914 5686832.29116548,377852.700599818 5686834.04625263,377855.051235229 5686836.70891929,377857.484142848 5686839.30536223,377862.952892848 5686844.80536223,377862.952892848 5686844.80536223,377869.686775859 5686850.21221063,377877.705497875 5686857.14130645,377890.046530344 5686863.5692641,377892.365742884 5686864.45277363,377894.129456389 5686865.24397222,377894.129456389 5686865.24397222,377904.662578639 5686868.8378229,377915.678245555 5686870.42448905,377926.797449571 5686869.94937946,377937.637620798 5686867.42884086,377947.825789816 5686862.94959549,377957.011420141 5686856.66575728,377964.878468864 5686848.79352942,377971.156260501 5686839.60376559,377971.156260501 5686839.60376559,377973.375010501 5686835.60376559,377975.066906348 5686832.18392847,377978.977625886 5686827.94198421,377981.484173001 5686824.80335131,377983.913558476 5686822.09933965,377984.669362103 5686821.24180526,377986.185425879 5686819.48828571,377987.926419053 5686818.23633556,377989.293706174 5686817.31382859,377989.921927409 5686816.99473209,377989.873018893 5686816.89844345,377995.095714589 5686814.35114013,378003.770653794 5686807.98069055,378004.698589966 5686807,378004.875 5686807,378017.82150131 5686805.58658638,378030.158043911 5686801.41293679,378031.59311331 5686800.54545313,378041.188704049 5686795.65469523,378043.084469103 5686794.18364035,378044.434002771 5686793.52332062,378045.233912908 5686792.95104325,378045.931893418 5686792.61749202,378045.931893418 5686792.61749202,378046.775643418 5686792.11749202,378046.775643418 5686792.11749202,378056.930405571 5686784.5456087,378065.269249503 5686775.01060512,378066.675499503 5686773.01060512,378066.675499503 5686773.01060512,378067.710879139 5686771.22544555,378068.621616828 5686771.50978914,378070.328964472 5686772.15255531,378070.328964472 5686772.15255531,378071.629707797 5686772.53575925,378072.614108282 5686773.05358392,378083.73168367 5686776.37790347,378086.021479365 5686776.60036826,378086.217855703 5686776.66323325,378097.923439188 5686777.99341273,378109.663298452 5686777.01067847,378120.984829107 5686773.75291761,378131.451554502 5686768.34572595,378132.83400169 5686767.24255441,378133.275728824 5686767.16134463,378144.21991248 5686762.81009532,378147.862764532 5686760.44920264,378148.556893418 5686760.11749202,378148.556893418 5686760.11749202,378149.400643418 5686759.61749202,378149.400643418 5686759.61749202,378151.27530229 5686758.23757414,378154.103268256 5686756.40480024,378155.154383617 5686755.38222069,378158.072315767 5686753.23435965,378163.061983609 5686751.78430809,378173.126204049 5686746.65469523,378174.586891142 5686745.52124735,378178.843233609 5686744.28430809,378188.907454049 5686739.15469523,378197.831858343 5686732.22963429,378205.300122319 5686723.754583,378211.047534476 5686714.0299383,378214.870378653 5686703.40038876,378216.633154709 5686692.24269717,378216.633154709 5686692.24269717,378216.726904709 5686690.74269717,378216.726904709 5686690.74269717,378216.645742475 5686688.60917386,378227.027757499 5686682.98214966,378236.551161192 5686674.86971613,378244.185292614 5686664.95877101,378249.598264696 5686653.68018382,378249.598264696 5686653.68018382,378250.848264696 5686650.18018382,378250.848264696 5686650.18018382,378254.062179706 5686635.80595844,378254.499679706 5686631.30595844,378254.499679706 5686631.30595844,378254.729234386 5686623.00216732,378254.416734386 5686615.50216732,378253.356075385 5686606.49856926,378253.050996439 5686604.93656506,378252.60526229 5686600.90557797,378251.636894845 5686594.92825468,378250.886894845 5686591.42825468,378250.331105977 5686589.06835298,378249.668944511 5686586.49129214,378248.909831216 5686582.4426879,378248.654024391 5686581.15618521,378247.938225112 5686577.75130216,378247.715857559 5686576.12484234,378247.717303293 5686575.91665662,378247.71875 5686575.5,378247.71875 5686574.31249152,378247.737534969 5686572.50913452,378248.39564958 5686571.61381003,378250.086972119 5686567.80307527,378250.783169124 5686567.17477502,378251.960406524 5686565.56243201,378252.034074363 5686565.52578072,378253.415790902 5686564.48337878,378254.03959554 5686564.099499,378262.909901064 5686557.43656111,378264.933487426 5686555.226561,378265.24510196 5686554.98677176,378265.763339467 5686554.37955416,378266.671507815 5686553.74281608,378271.889194546 5686548.41174489,378272.022232248 5686548.53646773,378272.490982248 5686548.03646773,378273.453968001 5686546.81296766,378274.410590007 5686545.8355575,378274.816840007 5686545.33555751,378274.694827002 5686545.23642194,378277.147059306 5686542.12079289,378277.641602136 5686541.59510565,378277.947947396 5686541.10324239,378278.891109616 5686539.90492867,378279.078203741 5686539.55762228,378279.349962447 5686539.27034681,378280.020015725 5686538.20549869,378280.178482248 5686538.03646773,378280.865467086 5686537.29116548,378281.771717086 5686536.29116548,378281.771717086 5686536.29116548,378289.111109473 5686526.28042366,378289.588184921 5686525.2273648,378289.810851682 5686525.01027647,378290.497979114 5686524.22498798,378292.972080264 5686521.7936966,378299.768193168 5686511.64931356,378300.299443167 5686510.64931356,378300.299443167 5686510.64931356,378302.780656154 5686505.00791412,378303.295109949 5686504.19577969,378305.408136913 5686498.84630532,378305.516626195 5686498.60215308,378305.528653296 5686498.54119833,378307.443388493 5686493.6937321,378307.582809068 5686492.9597446,378307.950301597 5686491.92211864,378308.385479485 5686492.16072969,378314.207170076 5686496.95035064,378317.15747356 5686498.62266775,378317.530488227 5686498.92301766,378318.280488227 5686499.42301766,378318.280488226 5686499.42301766,378319.277926173 5686499.95504202,378321.075314038 5686501.4022915,378321.182831792 5686501.52701992,378324.324605925 5686504.08281167,378324.324779073 5686504.08297463,378324.781547456 5686504.63334686,378333.848959523 5686512.01008414,378344.174584471 5686517.48874125,378353.459109908 5686520.28659093,378355.699519231 5686521.15384615,378357.668269231 5686521.65384615,378359.426962812 5686521.87368285,378362.215339837 5686522.75493736,378365.566960279 5686523.09811944,378367.954373708 5686523.53219461,378370.998826888 5686523.80671278,378373.647177666 5686524.44179936,378385.481215174 5686524.88773271,378394.988365155 5686523.35316882,378398.235660894 5686523.09870308,378404.265772984 5686521.43700791,378404.471451269 5686521.4173832,378406.550548316 5686520.80740102,378409.249217489 5686520.06373896,378409.487854801 5686519.94563045,378415.408440581 5686518.20860145,378416.658440581 5686517.70860145,378416.658440581 5686517.70860145,378417.205932556 5686517.43318833,378417.718233609 5686517.28430809,378420.19869325 5686516.02004746,378420.856221764 5686515.80625902,378422.637998175 5686514.7767629,378427.782454049 5686512.15469523,378429.550356832 5686510.7828575,378431.723905632 5686509.52699844,378435.162318673 5686506.42814917,378436.706858343 5686505.22963429,378437.535289576 5686504.28952328,378441.047459662 5686501.12420091,378448.418885996 5686490.96557208,378448.624675583 5686490.50245318,378449.381599944 5686489.4951906,378450.392909613 5686487.45810343,378450.536892713 5686487.21127526,378451.314091539 5686486.1780779,378456.699493191 5686474.38796509,378459.427104533 5686461.71636506,378459.583354533 5686460.21636506,378459.698995495 5686458.98272879,378459.782149616 5686457.98487934,378459.886495495 5686456.98272879,378460.033802457 5686455.21504524,378460.118158214 5686454.54019919,378460.724172603 5686451.94208407,378460.849172603 5686450.94208408,378461.105245495 5686448.48272879,378461.188399616 5686447.48487934,378461.292745495 5686446.48272879,378461.417745495 5686444.98272879,378461.407762427 5686444.98189687,378461.570654709 5686443.24269717,378461.633154709 5686442.24269717,378461.633154709 5686442.24269717,378461.586212728 5686439.2200781,378461.831803564 5686436.60044252,378461.886495495 5686435.98272879,378461.985745646 5686434.79172697,378462.126964899 5686433.28538828,378462.358481413 5686430.97022314,378462.448995495 5686429.98272879,378462.52254423 5686429.10014397,378462.550689799 5686428.8299465,378462.599172603 5686428.44208407,378462.945654709 5686424.74269717,378463.039404709 5686423.24269717,378463.039404709 5686423.24269717,378462.760497768 5686416.45785223,378463.026022923 5686413.79197347,378462.913720164 5686412.2536499,378462.914404709 5686412.24269717,378462.848800117 5686410.88732273,378463.185646724 5686410.79501182,378463.425537409 5686410.74516441,378463.706274599 5686410.65233669,378468.916223591 5686409.22457959,378470.919633681 5686408.26718909,378476.4382307 5686406.44242641,378480.856071903 5686403.74435199,378482.244813679 5686403.05342394,378482.268336301 5686403.09458853,378482.983655565 5686402.68583466,378485.315324363 5686401.52578072,378494.147855443 5686394.86229565,378501.606683948 5686386.69029983,378501.686676282 5686386.56132124,378502.481683948 5686385.69029983,378504.660033884 5686382.17795703,378506.948682517 5686379.0269384,378507.797555292 5686377.62190759,378508.638023677 5686376.50059274,378514.04678878 5686364.49587762,378516.706803564 5686351.60044252,378517.064464899 5686347.78538828,378517.167259982 5686346.75743745,378517.863053564 5686343.60044252,378518.033214899 5686341.78538828,378518.264731413 5686339.47022314,378518.368139354 5686338.19706551,378518.488053564 5686337.10044252,378518.581803564 5686336.10044252,378518.634623593 5686335.42418208,378518.708354533 5686334.71636506,378518.712933798 5686334.42156822,378518.726904709 5686334.24269717,378518.758154709 5686333.74269717,378518.723512761 5686333.74053205,378518.872640897 5686324.14019089,378517.245233236 5686314.11876861,378525.327054795 5686308.20547945,378526.844298538 5686306.88133946,378528.391232407 5686305.55539614,378528.391232408 5686305.55539614,378530.433059692 5686303.49763807,378530.534230962 5686303.42670452,378531.236219692 5686302.94402129,378532.885980675 5686301.34826067,378534.491385764 5686300.20828228,378539.198661458 5686295.6800569,378539.59190745 5686295.45819816,378542.138030614 5686293.22902237,378543.05340656 5686292.67568768,378546.266262528 5686289.61468242,378548.850854898 5686287.35182616,378549.385775754 5686286.6426082,378549.497957834 5686286.53572824,378550.065942003 5686286.35193674,378555.043688699 5686283.49137127,378555.228753112 5686283.44222475,378562.484597062 5686280.09149011,378563.855476946 5686279.63797484,378574.844866515 5686273.16245682,378578.195086568 5686270.06962916,378579.925374024 5686268.55473194,378580.485185386 5686268.16609236,378581.978751324 5686267.29894701,378582.828406369 5686266.63580161,378583.728884702 5686266.36032462,378584.098168333 5686266.16106896,378584.167976946 5686266.13797484,378584.461319104 5686265.96512243,378589.118933177 5686263.45199732,378593.626204049 5686261.15469523,378602.550608343 5686254.22963429,378610.018872319 5686245.754583,378615.766284476 5686236.0299383,378616.636689569 5686233.60974705,378620.40138351 5686226.03082854,378620.919053422 5686224.56917231,378621.027280372 5686224.48588919,378622.44197345 5686222.82818932,378624.585394632 5686220.77008529,378625.836940187 5686218.85005723,378629.13146682 5686214.9896182,378630.965230287 5686211.61708631,378632.504951879 5686209.64043998,378643.226835616 5686206.06846854,378647.601835616 5686204.06846854,378658.026050605 5686197.9662481,378667.016792889 5686189.89978013,378669.778875653 5686186.86690494,378671.718716016 5686184.82496771,378671.718716016 5686184.82496771,378678.666192883 5686175.98161798,378679.80628052 5686173.78205631,378680.150643418 5686173.61749202,378680.150643418 5686173.61749202,378680.994393418 5686173.11749202,378680.994393418 5686173.11749202,378689.016905355 5686167.42621575,378696.001741737 5686160.50065555,378697.445240391 5686158.50218896,378699.302967086 5686156.79116549,378699.302967086 5686156.79116549,378700.209217086 5686155.79116548,378700.209217086 5686155.79116548,378702.179269768 5686153.10406446,378702.717101682 5686152.51027647,378703.592101682 5686151.51027647,378703.510176204 5686151.43859168,378706.697738223 5686147.23085638,378708.05211086 5686145.72049752,378708.888508611 5686144.33893402,378710.261182517 5686142.5269384,378711.167432517 5686141.0269384,378711.054203941 5686140.95852946,378716.72558217 5686131.8379137,378716.741039557 5686131.79819963,378717.791067693 5686130.31047509,378722.723399662 5686118.84168434,378723.150942352 5686116.70737561,378723.581311977 5686115.57589731,378724.175061977 5686113.57589731,378724.175061977 5686113.57589731,378726.192922603 5686103.94208407,378726.255422603 5686103.44208407,378726.442199357 5686101.44787004,378726.442922603 5686101.44208407,378726.698995495 5686098.98272879,378726.903726676 5686096.52595461,378727.004699357 5686095.44787004,378727.005422603 5686095.44208407,378727.206803564 5686093.60044252,378727.394303564 5686091.60044252,378727.400868624 5686090.21980753,378729.70932404 5686088.96356994,378740.185851682 5686079.51027647,378741.060851682 5686078.51027647,378741.090535847 5686078.47030038,378741.225854898 5686078.35182616,378743.537483929 5686075.28698248,378743.8728117 5686074.90375074,378744.427967086 5686074.29116548,378744.427967086 5686074.29116548,378747.349409706 5686070.23298961,378748.636182517 5686068.52693839,378748.942132528 5686068.02053838,378752.28517958 5686063.3767118,378752.554464219 5686062.73861656,378752.947238098 5686062.21687722,378754.892621556 5686057.97059332,378756.525230487 5686055.3635956,378760.318371987 5686045.5535046,378760.55763351 5686045.03082853,378761.08888351 5686043.53082853,378764.119716025 5686029.43293325,378764.192922603 5686029.44208407,378764.297348442 5686028.60667736,378764.323995495 5686028.48272879,378764.357685096 5686028.07845357,378764.519303564 5686026.60044252,378764.613053564 5686025.60044252,378764.667745495 5686024.98272879,378764.750899616 5686023.98487934,378764.855245495 5686022.98272879,378764.97772926 5686021.5129236,378765.036478481 5686021.17326004,378765.192728481 5686019.17326004,378764.712117656 5686005.60581829,378764.087602098 5686003.27845524,378764.760311183 5686002.65652859,378764.885498412 5686002.54347771,378764.901640586 5686002.52586807,378767.053482248 5686000.53646773,378767.522232248 5686000.03646773,378767.794136784 5685999.6963826,378768.368058548 5685999.28125337,378768.42433033 5685999.34455912,378769.052518591 5685998.78616956,378770.542014955 5685997.70878667,378771.700012641 5685996.49550307,378780.743480126 5685993.44578452,378791.8665466 5685986.74668806,378801.287904958 5685977.8114484,378802.076355126 5685976.88190715,378802.80938194 5685976.19199956,378803.326001028 5685975.69994482,378808.513501028 5685970.69994482,378808.737049828 5685970.48335473,378811.653086552 5685967.64338853,378813.260840081 5685966.17344245,378814.993147565 5685964.86398167,378819.141493108 5685961.42490647,378820.680900257 5685960.02743048,378820.901908995 5685959.90823475,378823.912518014 5685959.10856503,378834.890522105 5685953.60584652,378844.518299828 5685945.98335473,378848.112049828 5685942.48335473,378848.066158661 5685942.43623434,378854.623970899 5685935.88058267,378861.348710525 5685925.63890699,378861.678801755 5685924.8038634,378863.60313146 5685921.83281573,378864.10313146 5685920.83281573,378864.555712231 5685919.6562937,378865.094427308 5685918.78767659,378865.213754785 5685918.48045524,378867.608786158 5685914.46603257,378868.077536158 5685913.46603257,378869.165152867 5685910.57513817,378869.94688146 5685909.33281573,378870.44688146 5685908.33281573,378874.552846828 5685897.70008024,378874.891592625 5685895.82004503,378875.090463677 5685895.36055082,378876.215463677 5685891.86055082,378876.215463677 5685891.86055082,378878.770854533 5685879.71636506,378879.239604533 5685875.21636506,378879.444196981 5685872.76019745,378879.633154709 5685870.74269717,378879.633643026 5685870.7348841,378879.74037305 5685869.73001702,378879.868664309 5685868.26383119,378880.050553564 5685866.60044252,378880.238053564 5685864.60044252,378880.290873593 5685863.92418208,378880.364604533 5685863.21636506,378880.480245495 5685861.98272879,378880.559976677 5685861.02595461,378880.68865159 5685859.6520935,378880.755425319 5685859.06256273,378881.161675319 5685855.06256273,378881.161675319 5685855.06256273,378881.161675319 5685846.58181046,378881.206803564 5685846.10044252,378881.351904709 5685844.24269717,378881.383154709 5685843.74269717,378881.383154709 5685843.74269717,378880.67402079 5685830.07854529,378880.049842602 5685827.91108609,378878.259056409 5685817.75526539,378877.977806409 5685816.75526538,378874.658656173 5685808.01009282,378874.557579977 5685807.52777648,378869.982610536 5685796.76222945,378867.906156209 5685793.70815317,378867.688303869 5685792.9770032,378867.265578075 5685792.19961426,378866.185489212 5685789.23310731,378860.364952091 5685779.49181208,378852.81440755 5685771.02063966,378843.803937489 5685764.12260266,378842.564372905 5685763.5023179,378842.501604784 5685763.43045671,378836.333689154 5685758.61063122,378835.290188693 5685757.65855828,378834.599378598 5685757.25538016,378833.555058031 5685756.43931146,378832.01932966 5685755.65186093,378831.907011773 5685755.57698234,378831.907011774 5685755.57698234,378829.776251417 5685754.44045408,378824.360019246 5685751.27937361,378823.034923463 5685750.84469087,378821.54734454 5685750.05122976,378810.309900209 5685746.64880539,378806.160818512 5685746.24088685,378806.183067702 5685746.08236137,378802.620567702 5685745.58236137,378802.620567702 5685745.58236137,378794.896531841 5685745.04296711,378793.640025358 5685744.91430979,378791.704589973 5685744.48466488,378780.776064765 5685744.09179551,378778.011169716 5685744.5,378775.34375 5685744.5,378774.331260387 5685744.59051271,378772.872400209 5685744.14880539,378772.619267546 5685744.12391856,378771.354298877 5685743.7272045,378770.584865243 5685743.64899291,378768.630544417 5685743.07715324,378763.681500867 5685742.60614623,378762.920626292 5685742.46780539,378759.351818049 5685742.14600616,378758.962579723 5685742.033352,378747.523116618 5685741.00103186,378736.096548767 5685742.16745725,378734.606338054 5685742.61776609,378732.379410671 5685742.85582514,378720.269523054 5685746.86202516,378709.280133485 5685753.33754318,378709.22462373 5685753.38878821,378706.19692596 5685755.03643006,378704.970337347 5685756.14321874,378699.837063399 5685759.28865041,378697.176956001 5685761.78279137,378696.959308011 5685761.85099138,378691.870814747 5685764.67127677,378690.39790446 5685765.400501,378690.39790446 5685765.400501,378689.58540446 5685765.900501,378689.602593435 5685765.92843308,378686.353713423 5685767.72911717,378684.3497119 5685769.4465256,378680.739998676 5685771.70105299,378679.458748676 5685772.70105299,378679.458748676 5685772.70105299,378678.406830535 5685773.67833603,378678.16534344 5685773.82431232,378674.856619359 5685776.97665463,378671.915782914 5685779.70883452,378671.4535599 5685780.2188737,378668.73626099 5685782.80774365,378668.24027845 5685783.39557481,378668.157898318 5685783.48972353,378662.43260176 5685791.2000636,378662.410519235 5685791.23539564,378661.733890384 5685792.09507133,378656.826161565 5685801.20538174,378654.845604472 5685807.15314028,378654.661405339 5685807.62614885,378650.207672737 5685809.3215261,378645.552496888 5685810.55777525,378636.137913699 5685814.90541147,378635.262913699 5685815.40541147,378634.290907651 5685816.08021024,378632.793219186 5685816.79592627,378631.082023054 5685817.36202516,378628.822481722 5685818.69346405,378627.380606582 5685819.38250798,378626.536856582 5685819.88250798,378626.536856582 5685819.88250798,378625.176215335 5685820.84203323,378620.092633485 5685823.83754318,378618.490948039 5685825.31617353,378615.552498676 5685827.20105299,378614.271248676 5685828.20105299,378612.868489354 5685829.52724449,378610.272855003 5685831.35768781,378609.739921226 5685831.87727007,378608.446346597 5685832.68003912,378603.936383485 5685835.33754318,378602.250679396 5685836.89373715,378599.88409344 5685838.32431232,378599.099956155 5685839.07138856,378590.733998846 5685845.34897823,378585.414353045 5685851.04130925,378583.845398318 5685852.48972353,378583.407898318 5685852.98972353,378581.994432069 5685855.01454958,378577.772697069 5685859.53205206,378572.044306833 5685868.35068644,378571.838173476 5685868.73870217,378571.77635176 5685868.7000636,378571.46385176 5685869.2000636,378571.46385176 5685869.2000636,378570.463716367 5685871.21772283,378569.49061854 5685872.66718427,378568.99061854 5685873.66718427,378569.198113776 5685873.77093189,378566.227854681 5685879.76309127,378563.15844897 5685891.14605957,378562.374142008 5685902.90948091,378563.905215283 5685914.59917866,378563.945426146 5685914.71771567,378561.624393074 5685912.84861842,378552.559120642 5685908.08000872,378545.581045653 5685898.60214456,378542.900060347 5685896.21194793,378539.835311923 5685892.65890761,378537.429913119 5685890.76045454,378536.693251013 5685889.9892428,378534.718242295 5685888.60525161,378533.157729507 5685879.79347704,378529.431659302 5685869.72505489,378526.596792458 5685864.92656496,378524.937543479 5685861.49418064,378524.856349961 5685861.388558,378524.724425222 5685861.03796298,378523.58377914 5685859.19247,378523.298992842 5685858.4136909,378522.655679579 5685855.65878091,378521.089873527 5685852.37261397,378520.9041998 5685851.86486898,378520.609791466 5685851.36506275,378517.110911015 5685844.02194049,378509.208525032 5685833.83799188,378507.405171181 5685832.33247121,378506.959014286 5685831.80778024,378505.473906323 5685830.6354288,378503.821630274 5685828.75886581,378499.559475357 5685825.78253248,378499.313261773 5685825.57698234,378498.563261773 5685825.07698234,378498.558768469 5685825.0837223,378495.161282336 5685822.7112015,378495.250761773 5685822.57698234,378494.500761773 5685822.07698234,378494.500761774 5685822.07698234,378493.597004531 5685821.59492642,378492.660982755 5685820.86740032,378492.140510344 5685820.60174641,378492.079044118 5685820.55882353,378490.204044118 5685819.55882353,378490.181183176 5685819.6016878,378489.101008897 5685819.0503569,378488.988754928 5685818.9655184,378487.108124264 5685818.03317025,378482.587520607 5685815.72581254,378482.264212419 5685815.63173527,378478.954541551 5685813.99092107,378475.860918869 5685813.12366841,378475.502169041 5685812.92857784,378474.345919041 5685812.42857784,378473.591766921 5685812.19023132,378470.340159184 5685810.56743469,378464.992636409 5685809.04278175,378458.97046355 5685807.18721504,378454.738472604 5685806.76417854,378454.099294417 5685806.57715324,378445.814130912 5685805.78864328,378443.443794055 5685805.31731364,378432.253276928 5685805.2110421,378428.922780543 5685805.80777847,378424.918847315 5685805.79636322,378423.364853639 5685806.11415208,378422.247067112 5685806.02842538,378409.515017138 5685807.79810529,378406.578009806 5685808.87939861,378396.050773054 5685812.36202516,378394.159768006 5685813.47630337,378393.185309419 5685813.79139855,378391.935309419 5685814.29139855,378382.237494848 5685819.23387627,378378.574174462 5685822.03611347,378377.967545951 5685822.34530477,378369.043141657 5685829.27036571,378361.574877681 5685837.745417,378355.827465523 5685847.4700617,378352.004621347 5685858.09961124,378350.902831554 5685865.07351508,378350.692662324 5685865.04359516,378349.985849542 5685870.00852397,378348.7331974 5685874.41345457,378347.758789978 5685877.21175281,378347.525090354 5685877.62721881,378346.315910163 5685877.24506264,378340.696880242 5685876.66971397,378340.380544417 5685876.57715324,378334.481835622 5685876.01576533,378333.222751029 5685875.71793302,378326.862945037 5685875.22453404,378319.25 5685874.5,378318.0625 5685874.5,378306.456618434 5685875.63317137,378304.441117635 5685876.23898779,378303.348160671 5685876.35582514,378300.656668531 5685877.24622613,378291.427526409 5685879.77542041,378281.786856582 5685884.38250798,378280.943106582 5685884.88250798,378280.943106582 5685884.88250798,378271.335057685 5685891.95489787,378269.708212699 5685893.74704021,378268.621348936 5685894.56343889,378261.889680078 5685901.91523231,378253.885533457 5685906.73631912,378250.616477734 5685909.66276463,378248.90625 5685909.5,378247.71875 5685909.5,378236.747723614 5685910.51155554,378233.486806621 5685911.43453263,378231.934798731 5685911.5826168,378220.997809419 5685914.79139855,378219.747809419 5685915.29139855,378219.747809419 5685915.29139855,378216.462115851 5685916.94425043,378215.935284758 5685917.1622879,378214.434057997 5685917.64806326,378213.591226335 5685918.13241397,378211.239334504 5685919.10578201,378207.30359047 5685921.74573444,378203.600182905 5685923.87397448,378202.765108728 5685924.62163022,378199.549547146 5685926.64787143,378199.549547147 5685926.64787143,378198.299547147 5685927.64787143,378198.299547147 5685927.64787143,378189.121284722 5685936.7793473,378182.220677787 5685947.50390673,378182.045468976 5685947.52013032,378180.511377027 5685947.95628226,378179.379078188 5685948.06334551,378168.531766391 5685951.21569191,378158.467545951 5685956.34530477,378156.124893031 5685958.16313078,378155.103713423 5685958.72911717,378152.309148623 5685961.12403009,378149.543141657 5685963.27036571,378148.736489089 5685964.1857621,378145.8965485 5685966.6195616,378140.581371466 5685973.47065024,378140.495828194 5685973.55530235,378140.099170374 5685973.86473539,378139.544653626 5685974.49656784,378138.151918961 5685975.87479337,378136.481425453 5685976.48012859,378126.137675453 5685981.48012859,378126.137675453 5685981.48012859,378115.710327539 5685987.90953524,378106.806144543 5685996.32276169,378099.796299445 5686006.36910063,378094.972999303 5686017.62976802,378092.537304526 5686029.63536027,378092.193554526 5686033.13536027,378092.256836574 5686045.47668727,378094.84382494 5686057.54399219,378096.089521947 5686060.35426616,378097.126227984 5686065.02152647,378102.28181264 5686076.36438264,378109.668954347 5686086.39785544,378111.679556709 5686088.19038111,378112.255051206 5686090.06954682,378112.255051206 5686090.06954682,378117.342309051 5686101.93671563,378124.850689549 5686112.44072012,378129.756939549 5686117.94072012,378129.756939548 5686117.94072012,378139.095593642 5686126.41811911,378150.000078066 5686132.75601888,378161.988545602 5686136.67436038,378167.043594189 5686137.20862895,378167.775705583 5686137.42284676,378170.929305485 5686137.72297903,378173.283312044 5686139.00310359,378174.426402972 5686139.63220604,378174.521767939 5686139.70622614,378183.006692037 5686144.32869292,378183.791506063 5686144.67749915,378185.435330959 5686145.57142216,378186.059145529 5686145.84117981,378186.440328447 5686146.61018638,378192.281965243 5686153.99530037,378192.413531134 5686154.18104045,378192.413531134 5686154.18104045,378192.54531074 5686154.32822701,378194.207343764 5686156.42940237,378195.017328168 5686157.10135574,378196.019271166 5686158.30926235,378196.264128741 5686158.51465843,378197.974316826 5686160.56295615,378200.576405756 5686163.77241257,378200.824297808 5686163.97638744,378203.417330742 5686167.08207124,378212.060168336 5686174.19107128,378215.707534879 5686176.19094762,378220.635283202 5686180.19960578,378226.919114586 5686183.68531783,378230.803864518 5686186.39530494,378235.369022803 5686188.18725527,378239.60890546 5686190.44877024,378240.315725558 5686190.66277814,378241.346250518 5686191.22078536,378252.132532448 5686194.64484993,378254.445032448 5686195.14484993,378254.445032448 5686195.14484993,378255.371847678 5686195.24390174,378257.377599791 5686195.85119461,378269.0625 5686197,378271.03125 5686197,378281.673740887 5686196.04860191,378291.978723591 5686193.22457959,378301.619393418 5686188.61749202,378301.619393418 5686188.61749202,378302.463143418 5686188.11749202,378302.463143418 5686188.11749202,378303.256718141 5686187.55786252,378304.150643418 5686187.11749202,378304.994393418 5686186.61749202,378304.994393418 5686186.61749202,378306.37071544 5686185.67823676,378310.4893487 5686183.56273895,378319.369579626 5686176.63526461,378324.226593568 5686171.10104222,378325.456479778 5686170.06675822,378327.023086172 5686168.04444268,378327.557397254 5686167.46511059,378327.851602177 5686166.97492018,378333.249102472 5686160.00734443,378338.74513351 5686148.53082853,378339.27638351 5686147.03082853,378339.516861003 5686145.96588274,378340.73818421 5686143.17576297,378343.255422603 5686131.94208407,378343.255422603 5686131.94208407,378343.317922603 5686131.44208407,378343.573995495 5686128.98272879,378343.64754423 5686128.10014397,378343.739604533 5686127.21636505,378343.764731413 5686126.97022314,378344.264731413 5686121.97022314,378344.264731413 5686121.97022314,378344.274887638 5686110.13222678,378343.078871214 5686104.13242761,378343.104861821 5686102.65121379,378341.852922473 5686096.34824333,378341.836197064 5686095.81056796,378341.478852803 5686094.46496512,378340.612548682 5686090.10350041,378340.383396199 5686089.37021247,378340.380157902 5686089.05579863,378340.224503146 5686088.41552969,378340.05611435 5686082.25726701,378339.816894469 5686081.31368851,378339.421695955 5686071.46917769,378336.439833931 5686059.5531993,378334.745770587 5686056.04879669,378330.201857814 5686046.18621072,378325.142116805 5686039.48786053,378325.52683558 5686038.54086047,378326.841994115 5686035.73518893,378326.981378739 5686035.48212181,378327.744393418 5686035.11749202,378327.744393418 5686035.11749202,378327.858641822 5686035.04978926,378329.25738518 5686034.55913658,378330.792270128 5686034.15152573,378337.922332482 5686033.00065126,378341.687848842 5686031.59306344,378345.428700321 5686031.30820919,378347.788886508 5686030.76056234,378351.986669321 5686030.34711682,378352.353917565 5686030.23571329,378355.690201269 5686029.9173832,378356.061788788 5686029.80836387,378363.318831118 5686028.98880215,378365.086795369 5686028.36863378,378367.263978727 5686028.02595069,378372.420664412 5686026.0947433,378372.897046354 5686026.04190954,378380.282004811 5686023.50111123,378385.546481495 5686022.07919844,378390.171446883 5686021.28835561,378398.79742894 5686017.88935639,378402.003442003 5686016.85193674,378403.29756351 5686016.10824296,378406.230476946 5686015.13797484,378407.571203584 5686014.3479492,378409.464225985 5686014.21861351,378420.288242584 5686011.39808477,378425.098165519 5686009.12421498,378425.994984548 5686010.49172937,378426.338734548 5686010.99172937,378426.338734548 5686010.99172937,378426.716791326 5686011.44305532,378426.75 5686011.5,378427.125 5686012,378427.160818034 5686011.97313647,378433.647939148 5686019.71749193,378441.039453961 5686025.73782703,378441.305527045 5686026.18216112,378441.584439473 5686027.02382333,378444.129057211 5686031.44620916,378445.168506962 5686037.0975745,378446.976387614 5686041.88109574,378447.293701318 5686042.89649959,378447.42914556 5686043.26889358,378447.90983673 5686044.80935034,378447.964407252 5686046.69661345,378450.262451318 5686057.39649959,378450.574951318 5686058.39649959,378452.436126491 5686063.08708748,378452.628450515 5686063.73023283,378452.880132208 5686064.20608362,378453.884596499 5686066.73756379,378457.521229266 5686072.98093604,378458.116075298 5686074.10560248,378458.328754351 5686074.36729535,378458.401234548 5686074.49172937,378458.744984548 5686074.99172937,378458.803525845 5686074.95148223,378465.518603033 5686083.21410974,378468.894114969 5686086.01381834,378469.34812441 5686086.47748756,378469.34812441 5686086.47748756,378471.096722031 5686087.92644935,378474.541820716 5686091.47104346,378483.195790578 5686097.67451651,378485.806007041 5686098.91690257,378495.364666549 5686103.58330209,378496.165693331 5686103.80714234,378495.951161565 5686104.20538174,378495.641981302 5686105.1338728,378494.494401965 5686107.76478327,378494.17752199 5686109.27895625,378492.888120439 5686112.20621023,378492.656172009 5686113.32317709,378490.887438023 5686117.92410269,378490.293688023 5686119.92410269,378490.293688023 5686119.92410269,378490.038215987 5686121.24512057,378489.226145426 5686123.46585501,378489.218491316 5686123.48292164,378489.216171835 5686123.49312936,378488.217241206 5686126.22486199,378486.272775927 5686131.36470355,378485.457342653 5686135.77385019,378485.35449995 5686135.98955398,378483.381837077 5686144.91604782,378476.857968976 5686145.52013032,378466.215564864 5686148.54583242,378456.309675637 5686153.47421928,378447.477144557 5686160.13770435,378445.712019665 5686162.07159963,378438.351749789 5686157.94462758,378426.679442823 5686154.24916024,378422.976888441 5686153.86941514,378420.222751029 5686153.21793302,378418.089806525 5686153.05245743,378408.871753294 5686152.17516313,378408.536794417 5686152.07715324,378397.21875 5686151,378396.03125 5686151,378383.08474869 5686152.41341362,378370.748206089 5686156.5870632,378368.694212555 5686157.8286797,378367.082023054 5686158.36202516,378356.092633485 5686164.83754318,378354.502666276 5686166.30535559,378345.968279381 5686169.3662765,378341.472881069 5686172.1064123,378340.825413699 5686172.40541147,378340.076410342 5686172.83341339,378337.487854058 5686174.13613328,378337.197664211 5686174.31134225,378334.815997229 5686175.47667938,378326.726924277 5686181.26382112,378325.754150764 5686182.23964366,378325.015992185 5686182.75718392,378322.841023348 5686184.97941655,378320.912514265 5686186.45515923,378313.44788914 5686194.77950248,378313.067081186 5686195.40852183,378312.97366441 5686195.49980269,378310.004319798 5686200.08428963,378308.981127681 5686201.245417,378306.153864883 5686206.02915713,378305.74061854 5686206.66718427,378305.541955708 5686207.06450993,378303.233715524 5686210.9700617,378300.164721798 5686219.50350417,378299.063654724 5686222.39936232,378298.814694849 5686223.91576723,378298.495350338 5686224.65831566,378297.800841321 5686228.12533004,378297.668811462 5686228.46525504,378296.016502117 5686232.52633404,378295.93911819 5686232.75848582,378295.377433934 5686234.12014462,378295.377433934 5686234.12014462,378293.627932165 5686239.06730913,378293.357184263 5686239.53989804,378289.928443591 5686248.75526538,378289.365943591 5686250.75526538,378288.570517129 5686255.03356946,378288.561292023 5686255.07311949,378288.192121347 5686256.09961124,378287.919782994 5686257.82340782,378286.932077397 5686262.05791592,378286.869577397 5686262.55791593,378286.556484802 5686265.90080326,378286.543196436 5686265.89955748,378286.355696436 5686267.89955748,378286.301004505 5686268.51727121,378286.216197542 5686269.53495476,378286.213327397 5686269.55791593,378286.198533846 5686269.699995,378277.376371744 5686270.44800154,378276.790815717 5686270.61095001,378272.982509113 5686270.95139809,378270.038941888 5686271.75806607,378268.61599869 5686271.91341362,378264.965834824 5686273.14832241,378263.801031729 5686273.46753012,378263.232968976 5686273.52013032,378252.590564864 5686276.54583242,378252.127953088 5686276.77599144,378248.780120358 5686277.7535677,378238.681421946 5686282.92798751,378229.737518657 5686289.91117618,378222.26829995 5686298.45337156,378216.540911415 5686308.24905176,378212.760199991 5686318.9478625,378212.260199991 5686320.9478625,378212.160719698 5686321.35172794,378210.446585784 5686328.4160374,378209.240187516 5686332.49923154,378209.158255013 5686332.77904163,378208.881223643 5686333.73373435,378203.781766391 5686335.21569191,378196.357012929 5686339,378195.78125 5686339,378185.138759113 5686339.95139809,378184.795091371 5686340.04557829,378179.0625 5686339.5,378177.875 5686339.5,378165.392523102 5686340.81279722,378153.456278236 5686344.69374098,378150.35466243 5686346.48582972,378150.083746888 5686346.55777525,378149.912122419 5686346.6370311,378146.715564864 5686347.54583242,378136.809675637 5686352.47421928,378130.977557062 5686356.87411719,378129.826006776 5686357.60976791,378129.090400571 5686358.29783583,378127.977144557 5686359.13770435,378126.719995225 5686360.51505457,378121.795121559 5686365.12166003,378115.270067483 5686373.9730616,378114.363817483 5686375.4730616,378109.032787365 5686386.83526913,378108.041070634 5686391.08733387,378106.49793905 5686395.26402874,378104.883738308 5686405.29322795,378104.791645467 5686405.28363495,378104.479145467 5686408.28363494,378104.273095291 5686410.75730283,378104.210595291 5686411.75730283,378104.460625361 5686411.77292971,378104.011629082 5686417.18125126,378105.5086817 5686429.37032847,378106.483657896 5686432.242566,378107.648244037 5686435.97468073,378102.5 5686435.5,378101.71875 5686435.5,378100.140074503 5686435.62021125,378098.9375 5686435.5,378097.375 5686435.5,378096.532809999 5686435.58222948,378094.464048687 5686435.09287082,378092.997400209 5686434.64880539,378091.567748734 5686434.50824866,378090.516878863 5686434.2870129,378090.516878863 5686434.2870129,378084.126208825 5686433.62160381,378083.974294417 5686433.57715324,378080.775310503 5686433.27270171,378078.172012418 5686433.00164121,378077.613969466 5686432.70398616,378076.813261773 5686432.07698234,378075.313261773 5686431.07698234,378075.313261774 5686431.07698234,378073.300528278 5686430.00340854,378065.135687228 5686425.43226216,378062.813099321 5686424.69792192,378061.979713227 5686424.26993765,378055.001087444 5686422.22797248,378053.476704246 5686421.74600324,378053.287766154 5686421.72664994,378051.068044417 5686421.07715324,378044.546690613 5686420.45650738,378042.728578699 5686420.04550051,378032.268467407 5686419.54753137,378021.881091886 5686420.87581271,378016.891153862 5686422.42999057,378014.45719621 5686419.01966198,378014.473765452 5686419.00827063,378014.130015452 5686418.50827063,378013.408422281 5686417.48183711,378012.689672281 5686416.48183711,378012.660771406 5686416.50260961,378010.295438955 5686413.18843491,378008.407105479 5686411.46554999,378005.599698655 5686408.12664379,378002.807542065 5686405.87815699,378002.658281672 5686405.27813361,378002.537271275 5686404.51946003,378002.319601725 5686403.91664792,378001.509047328 5686400.65823767,378000.936226672 5686399.46620892,377997.463887609 5686390.57638875,377997.186543718 5686390.13234884,377993.425308938 5686380.01567813,377990.519433217 5686375.16625725,377990.256324968 5686374.57196058,377989.591228767 5686373.61723916,377987.761869038 5686370.56434354,377986.35695907 5686368.97456259,377983.692357771 5686365.1496243,377980.052548883 5686361.61563751,377979.648463586 5686360.77474379,377979.631521291 5686357.75671207,377979.661743092 5686357.36987301,377979.800553564 5686356.10044252,377979.988053564 5686354.10044252,377980.133154709 5686352.24269717,377980.164404709 5686351.74269717,377980.164404709 5686351.74269717,377980.164404709 5686344.25730283,377980.008154709 5686341.75730283,377980.008154709 5686341.75730283,377978.371241693 5686331.09946776,377975.701958091 5686323.36591394,377974.053316086 5686315.95468901,377968.886638814 5686304.60317659,377961.484757713 5686294.56507198,377952.167498583 5686286.27410881,377950.108550497 5686285.09814125,377947.319310436 5686282.30449775,377945.843331616 5686281.29914387,377943.115449585 5686278.20904762,377942.50961659 5686277.42349735,377942.1745247 5686277.14318464,377939.609879151 5686274.23799976,377930.690005005 5686267.32630444,377920.633748104 5686262.20698962,377909.796808551 5686259.06113073,377898.5625 5686258,377898.21875 5686258,377894.21875 5686257.5,377892.28125 5686257.5,377881.638759113 5686258.45139809,377876.556073103 5686259.84427949,377871.743182592 5686260.6918947,377871.697717158 5686260.70942128,377870.328885159 5686260.91717613,377858.782694968 5686265.21478537,377848.357695104 5686271.78009807,377847.02882866 5686273.06278234,377843.640842367 5686275.02598664,377840.180629417 5686278.15547427,377840.174547147 5686278.14787143,377838.924547147 5686279.14787143,377838.991214461 5686279.23120558,377838.955557203 5686279.26345473,377835.845022471 5686281.527542,377828.122362464 5686289.76536579,377824.383122888 5686295.66825783,377823.558077582 5686296.77420516,377823.217682564 5686297.50806196,377822.079890051 5686299.30422031,377821.747704321 5686300.14520297,377820.49061854 5686302.16718427,377819.781681905 5686303.58505754,377818.05311854 5686306.66718427,377817.55311854 5686307.66718427,377815.330365766 5686313.37922188,377814.342888867 5686314.96469967,377810.176942326 5686326.05979658,377810.167740165 5686326.11633596,377806.610252117 5686333.52633404,377806.110252117 5686335.02633404,377805.839142079 5686336.31335692,377805.064867551 5686337.7451242,377801.601488028 5686348.93043951,377800.882738028 5686352.43043951,377800.912196992 5686352.43648911,377799.526600338 5686355.65831566,377797.074446436 5686367.89955748,377796.80394407 5686370.78491605,377796.791645467 5686370.78363494,377796.635395467 5686372.28363494,377796.543730068 5686373.38409386,377793.31736649 5686380.46917147,377792.78611649 5686381.96917147,377792.11064063 5686385.03397965,377790.642193022 5686388.51360413,377788.304345291 5686401.75730283,377788.304345291 5686401.75730283,377788.28836736 5686402.01294973,377788.177813823 5686403.27641872,377788.072895467 5686404.28363494,377788.011946436 5686404.89955748,377787.68397999 5686408.39786624,377787.574446436 5686409.39955748,377787.547481292 5686409.68718568,377787.479145467 5686410.28363494,377787.322895467 5686411.78363494,377787.261946436 5686412.39955748,377787.074446436 5686414.39955748,377787.019754505 5686415.01727121,377786.769754505 5686418.01727121,377786.878782577 5686429.15255025,377787.21236766 5686430.83570257))
+  </op>
+</test>
+</case>
+</run>
More information about the geos-commits mailing list
