[geos-commits] r2394 - in trunk/source: geomgraph headers/geos/geomgraph
svn_geos at osgeo.org svn_geos at osgeo.org
Mon Apr 20 05:37:55 EDT 2009
Author: strk
Date: 2009-04-20 05:37:55 -0400 (Mon, 20 Apr 2009)
New Revision: 2394
   trunk/source/geomgraph/Quadrant.cpp
   trunk/source/headers/geos/geomgraph/Quadrant.h
Add named constants, sync to JTS-1.10
Modified: trunk/source/geomgraph/Quadrant.cpp
--- trunk/source/geomgraph/Quadrant.cpp	2009-04-20 09:24:55 UTC (rev 2393)
+++ trunk/source/geomgraph/Quadrant.cpp	2009-04-20 09:37:55 UTC (rev 2394)
@@ -11,6 +11,10 @@
  * by the Free Software Foundation.
  * See the COPYING file for more information.
+ * Last port: geomgraph/Quadrant.java rev. 1.8 (JTS-1.10)
 #include <sstream>
@@ -26,11 +30,10 @@
 namespace geos {
 namespace geomgraph { // geos.geomgraph
-* Returns the quadrant of a directed line segment (specified as x and y
-* displacements, which cannot both be 0).
-int Quadrant::quadrant(double dx, double dy) {
+/* public static */
+int
+Quadrant::quadrant(double dx, double dy)
 	if (dx == 0.0 && dy == 0.0) {
 		ostringstream s;
 		s<<"Cannot compute the quadrant for point ";
@@ -39,34 +42,44 @@
 	if (dx >= 0) {
 		if (dy >= 0)
-			return 0;
+			return NE;
 		else
-			return 3;
+			return SE;
 	} else {
 		if (dy >= 0)
-			return 1;
+			return NW;
 		else
-		return 2;
+			return SW;
-* Returns the quadrant of a directed line segment from p0 to p1.
-int Quadrant::quadrant(const Coordinate& p0, const Coordinate& p1) {
-	double dx=p1.x-p0.x;
-	double dy=p1.y-p0.y;
-	if (dx==0.0 && dy==0.0)
+int
+Quadrant::quadrant(const Coordinate& p0, const Coordinate& p1)
+	if (p1.x == p0.x && p1.y == p0.y)
 		throw util::IllegalArgumentException("Cannot compute the quadrant for two identical points " + p0.toString());
-	return quadrant(dx, dy);
+	if (p1.x >= p0.x) {
+		if (p1.y >= p0.y)
+			return NE;
+		else
+			return SE;
+	else {
+		if (p1.y >= p0.y)
+			return NW;
+		else
+			return SW;
-* Returns true if the quadrants are 1 and 3, or 2 and 4
-bool Quadrant::isOpposite(int quad1, int quad2){
+bool
+Quadrant::isOpposite(int quad1, int quad2)
 	if (quad1==quad2) return false;
 	int diff=(quad1-quad2+4)%4;
 	// if quadrants are not adjacent, they are opposite
@@ -74,12 +87,12 @@
 	return false;
-* Returns the right-hand quadrant of the halfplane defined by the two quadrants,
-* or -1 if the quadrants are opposite, or the quadrant if they are identical.
-int Quadrant::commonHalfPlane(int quad1, int quad2){
-	// if quadrants are the same they do not determine a unique common halfplane.
+int
+Quadrant::commonHalfPlane(int quad1, int quad2)
+	// if quadrants are the same they do not determine a unique
+	// common halfplane.
 	// Simply return one of the two possibilities
 	if (quad1==quad2) return quad1;
@@ -90,26 +103,26 @@
 	int max=(quad1>quad2)? quad1:quad2;
 	// for this one case, the righthand plane is NOT the minimum index;
 	if (min==0 && max==3) return 3;
-	// in general, the halfplane index is the minimum of the two adjacent quadrants
+	// in general, the halfplane index is the minimum of the two
+	// adjacent quadrants
 	return min;
-* Returns whether the given quadrant lies within the given halfplane (specified
-* by its right-hand quadrant).
-bool Quadrant::isInHalfPlane(int quad, int halfPlane){
-	if (halfPlane==3) {
-		return quad==3 || quad==0;
+bool
+Quadrant::isInHalfPlane(int quad, int halfPlane)
+	if (halfPlane==SE) {
+		return quad==SE || quad==SW;
 	return quad==halfPlane || quad==halfPlane+1;
-* Returns true if the given quadrant is 0 or 1.
-bool Quadrant::isNorthern(int quad) {
-	return quad==0 || quad==1;
+bool
+Quadrant::isNorthern(int quad)
+	return quad==NE || quad==NW;
 } // namespace geos.geomgraph
Modified: trunk/source/headers/geos/geomgraph/Quadrant.h
--- trunk/source/headers/geos/geomgraph/Quadrant.h	2009-04-20 09:24:55 UTC (rev 2393)
+++ trunk/source/headers/geos/geomgraph/Quadrant.h	2009-04-20 09:37:55 UTC (rev 2394)
@@ -12,6 +12,10 @@
@@ -42,17 +46,29 @@
 class Quadrant {
 public:
+        static const int NE = 0;
+        static const int NW = 1;
+        static const int SW = 2;
+        static const int SE = 3;
 	 * (specified as x and y displacements, which cannot both be 0).
+	 * @throws IllegalArgumentException if the displacements are both 0
 	static int quadrant(double dx, double dy);
+	 * @throws IllegalArgumentException if the points are equal
-	static int quadrant(const geom::Coordinate& p0, const geom::Coordinate& p1);
+	static int quadrant(const geom::Coordinate& p0,
+	                    const geom::Coordinate& p1);
More information about the geos-commits mailing list
