[geos-commits] r2404 - in trunk/tests/unit: . operation/valid
svn_geos at osgeo.org svn_geos at osgeo.org
Tue Apr 21 12:11:49 EDT 2009
Author: strk
Date: 2009-04-21 12:11:49 -0400 (Tue, 21 Apr 2009)
New Revision: 2404
Added:
   trunk/tests/unit/operation/valid/ValidSelfTouchingRingFormingHoleTest.cpp
   trunk/tests/unit/Makefile.am
Port ValidSelfTouchingRingFormingHoleTest
Modified: trunk/tests/unit/Makefile.am
--- trunk/tests/unit/Makefile.am	2009-04-21 15:30:16 UTC (rev 2403)
+++ trunk/tests/unit/Makefile.am	2009-04-21 16:11:49 UTC (rev 2404)
@@ -73,6 +73,7 @@
 	operation/union/CascadedPolygonUnionTest.cpp \
 	operation/valid/IsValidTest.cpp \
 	operation/valid/ValidClosedRingTest.cpp \
+	operation/valid/ValidSelfTouchingRingFormingHoleTest.cpp \
 	precision/GeometrySnapperTest.cpp \
 	precision/LineStringSnapperTest.cpp \
 	precision/SimpleGeometryPrecisionReducerTest.cpp \
Added: trunk/tests/unit/operation/valid/ValidSelfTouchingRingFormingHoleTest.cpp
--- trunk/tests/unit/operation/valid/ValidSelfTouchingRingFormingHoleTest.cpp	                        (rev 0)
+++ trunk/tests/unit/operation/valid/ValidSelfTouchingRingFormingHoleTest.cpp	2009-04-21 16:11:49 UTC (rev 2404)
@@ -0,0 +1,188 @@
+// $Id$
+// Test Suite for geos::operation::valid::IsValidOp class
+// Ported from JTS junit/operation/valid/ValidSelfTouchingRingFormingHoleTest.java rev. 1.4
+#include <tut.hpp>
+// geos
+#include <geos/operation/valid/IsValidOp.h>
+#include <geos/geom/Coordinate.h>
+#include <geos/geom/CoordinateArraySequence.h>
+#include <geos/geom/Dimension.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/LineString.h>
+#include <geos/geom/LinearRing.h>
+#include <geos/geom/Polygon.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/PrecisionModel.h>
+#include <geos/util/GEOSException.h>
+#include <geos/io/WKTReader.h>
+#include <geos/operation/valid/TopologyValidationError.h>
+#include <geos/platform.h> // for ISNAN
+// std
+#include <string>
+#include <memory>
+#include <iostream>
+using namespace geos::geom;
+//using namespace geos::operation;
+using namespace geos::operation::valid;
+using namespace geos::util;
+using namespace std;
+namespace tut
+    // Test Group
+    struct test_ValidSelfTouchingRingFormingHole_data
+	typedef std::auto_ptr<Geometry> GeomPtr;
+        geos::geom::PrecisionModel pm_;
+        geos::geom::GeometryFactory factory_;
+        geos::io::WKTReader rdr;
+        test_ValidSelfTouchingRingFormingHole_data()
+			: pm_(1), factory_(&pm_, 0), rdr(&factory_)
+	GeomPtr fromWKT(const std::string& wkt)
+		GeomPtr geom;
+		try {
+			geom.reset( rdr.read(wkt) );
+		catch (const GEOSException& ex) {
+			cerr << ex.what() << endl;
+		return geom;
+	void checkIsValidDefault(const std::string& wkt, bool expected)
+		GeomPtr geom = fromWKT(wkt);
+		IsValidOp validator(geom.get());
+		bool isValid = validator.isValid();
+		ensure(isValid == expected);
+	void checkIsValidSTR(const std::string& wkt, bool expected)
+		validator.setSelfTouchingRingFormingHoleValid(true);
+    typedef test_group<test_ValidSelfTouchingRingFormingHole_data> group;
+    typedef group::object object;
+    group test_ValidSelfTouchingRingFormingHole_group("geos::operation::valid::ValidSelfTouchingRingFormingHole");
+    // Test Cases
+    // 1 - testShellAndHoleSelfTouch
+    //  Tests a geometry with both a shell self-touch and a hole self=touch.
+    //  This is valid if STR is allowed, but invalid in OGC
+    template<>
+    template<>
+    void object::test<1>()
+    string wkt = "POLYGON ((0 0, 0 340, 320 340, 320 0, 120 0, 180 100, 60 100, 120 0, 0 0),   (80 300, 80 180, 200 180, 200 240, 280 200, 280 280, 200 240, 200 300, 80 300))";
+    checkIsValidSTR(wkt, true);
+    checkIsValidDefault(wkt, false);
+   * 2 - testShellHoleAndHoleHoleTouch
+   * Tests a geometry representing the same area as in
+   * {@link #testShellAndHoleSelfTouch}
+   * but using a shell-hole touch and a hole-hole touch.
+   * This is valid in OGC.
+    template<>
+    template<>
+    void object::test<2>()
+    string wkt = "POLYGON ((0 0, 0 340, 320 340, 320 0, 120 0, 0 0),   (120 0, 180 100, 60 100, 120 0),   (80 300, 80 180, 200 180, 200 240, 200 300, 80 300),  (200 240, 280 200, 280 280, 200 240))";
+    checkIsValidDefault(wkt, true);
+   * 3 - testShellSelfTouchHoleOverlappingHole
+   * Tests an overlapping hole condition, where one of the holes is
+   * created by a shell self-touch.
+   * This is never valid.
+    template<>
+    template<>
+    void object::test<3>()
+    string wkt = "POLYGON ((0 0, 220 0, 220 200, 120 200, 140 100, 80 100, 120 200, 0 200, 0 0),   (200 80, 20 80, 120 200, 200 80))";
+    checkIsValidSTR(wkt, false);
+   * 4 - testDisconnectedInteriorShellSelfTouchAtNonVertex
+   * Ensure that the Disconnected Interior condition is not validated
+    template<>
+    template<>
+    void object::test<4>()
+    string wkt = "POLYGON ((40 180, 40 60, 240 60, 240 180, 140 60, 40 180))";
+   * 5 - testDisconnectedInteriorShellSelfTouchAtVertex
+    template<>
+    template<>
+    void object::test<5>()
+    string wkt = "POLYGON ((20 20, 20 100, 140 100, 140 180, 260 180, 260 100, 140 100, 140 20, 20 20))";
+    /// 6 - testShellCross()
+    template<>
+    template<>
+    void object::test<6>()
+    string wkt = "POLYGON ((20 20, 120 20, 120 220, 240 220, 240 120, 20 120, 20 20))";
+    /// 7 - testShellCrossAndSTR
+    template<>
+    template<>
+    void object::test<7>()
+    string wkt = "POLYGON ((20 20, 120 20, 120 220, 180 220, 140 160, 200 160, 180 220, 240 220, 240 120, 20 120,  20 20))";
+} // namespace tut
More information about the geos-commits mailing list
