[geos-commits] r2408 - in trunk/source: headers/geos/index/quadtree index/quadtree
svn_geos at osgeo.org svn_geos at osgeo.org
Mon Apr 27 10:58:14 EDT 2009
Author: strk
Date: 2009-04-27 10:58:14 -0400 (Mon, 27 Apr 2009)
New Revision: 2408
   trunk/source/headers/geos/index/quadtree/Node.h
   trunk/source/headers/geos/index/quadtree/NodeBase.h
   trunk/source/headers/geos/index/quadtree/Root.h
   trunk/source/index/quadtree/NodeBase.cpp
   trunk/source/index/quadtree/Quadtree.cpp
Quadtree's NodeBase: check port sync, add port info, drop unneeded pointers and virtuals, document objects ownership.
Modified: trunk/source/headers/geos/index/quadtree/Node.h
--- trunk/source/headers/geos/index/quadtree/Node.h	2009-04-25 00:23:06 UTC (rev 2407)
+++ trunk/source/headers/geos/index/quadtree/Node.h	2009-04-27 14:58:14 UTC (rev 2408)
@@ -60,7 +60,7 @@
 protected:
-	bool isSearchMatch(const geom::Envelope *searchEnv) {
+	bool isSearchMatch(const geom::Envelope& searchEnv) const {
 		return env->intersects(searchEnv);
Modified: trunk/source/headers/geos/index/quadtree/NodeBase.h
--- trunk/source/headers/geos/index/quadtree/NodeBase.h	2009-04-25 00:23:06 UTC (rev 2407)
+++ trunk/source/headers/geos/index/quadtree/NodeBase.h	2009-04-27 14:58:14 UTC (rev 2408)
@@ -11,6 +11,10 @@
  * by the Free Software Foundation.
  * See the COPYING file for more information.
+ * Last port: index/quadtree/NodeBase.java rev 1.9 (JTS-1.10)
 #ifndef GEOS_IDX_QUADTREE_NODEBASE_H
@@ -58,20 +62,23 @@
 	virtual ~NodeBase();
-	virtual std::vector<void*>* getItems();
+	std::vector<void*>& getItems();
-	virtual void add(void* item);
+	/// Add an item to this node.
+	/// Ownership of the item is left to caller.
+	void add(void* item);
-	virtual std::vector<void*>* addAllItems(std::vector<void*> *resultItems);
+	/// Push all node items to the given vector, return the argument
+	std::vector<void*>& addAllItems(std::vector<void*>& resultItems) const;
-	virtual void addAllItemsFromOverlapping(const geom::Envelope *searchEnv,
-			std::vector<void*> *resultItems);
+	virtual void addAllItemsFromOverlapping(const geom::Envelope& searchEnv,
+			std::vector<void*>& resultItems) const;
-	virtual int depth();
+	unsigned int depth() const;
-	virtual int size();
+	unsigned int size() const;
-	virtual int nodeCount();
+	unsigned int getNodeCount() const;
 	virtual std::string toString() const;
@@ -94,7 +101,8 @@
 protected:
-	std::vector<void*> *items;
+	/// Actual items are NOT owned by this class
+	std::vector<void*> items;
 	 * subquads are numbered as follows:
@@ -108,7 +116,7 @@
 	Node* subnode[4];
-	virtual bool isSearchMatch(const geom::Envelope *searchEnv)=0;
+	virtual bool isSearchMatch(const geom::Envelope& searchEnv) const=0;
@@ -131,7 +139,7 @@
 inline bool
 NodeBase::hasItems() const
-	return ! items->empty();
+	return ! items.empty();
 } // namespace geos::index::quadtree
Modified: trunk/source/headers/geos/index/quadtree/Root.h
--- trunk/source/headers/geos/index/quadtree/Root.h	2009-04-25 00:23:06 UTC (rev 2407)
+++ trunk/source/headers/geos/index/quadtree/Root.h	2009-04-27 14:58:14 UTC (rev 2408)
@@ -69,7 +69,9 @@
 protected:
-	bool isSearchMatch(const geom::Envelope* /* searchEnv */) { return true; }
+	bool isSearchMatch(const geom::Envelope& /* searchEnv */) const {
+		return true;
Modified: trunk/source/index/quadtree/NodeBase.cpp
--- trunk/source/index/quadtree/NodeBase.cpp	2009-04-25 00:23:06 UTC (rev 2407)
+++ trunk/source/index/quadtree/NodeBase.cpp	2009-04-27 14:58:14 UTC (rev 2408)
@@ -12,6 +12,10 @@
 #include <geos/index/quadtree/NodeBase.h>
@@ -58,15 +62,16 @@
 	return subnodeIndex;
-NodeBase::NodeBase() {
-	items=new vector<void*>();
-	subnode[0]=NULL;
-	subnode[1]=NULL;
-	subnode[2]=NULL;
-	subnode[3]=NULL;
+NodeBase::NodeBase()
+	subnode[0]=0;
+	subnode[1]=0;
+	subnode[2]=0;
+	subnode[3]=0;
-NodeBase::~NodeBase() {
+NodeBase::~NodeBase()
 	delete subnode[0];
 	delete subnode[1];
 	delete subnode[2];
@@ -75,27 +80,33 @@
 	subnode[1]=NULL;
 	subnode[2]=NULL;
 	subnode[3]=NULL;
-	delete items;
-vector<void*>* NodeBase::getItems() {
+vector<void*>&
+NodeBase::getItems()
 	return items;
-void NodeBase::add(void* item) {
-	items->push_back(item);
+void
+NodeBase::add(void* item)
+	items.push_back(item);
 	//GEOS_DEBUG itemCount++;
 	//GEOS_DEBUG System.out.print(itemCount);
-vector<void*>*
-NodeBase::addAllItems(vector<void*> *resultItems)
+vector<void*>&
+NodeBase::addAllItems(vector<void*>& resultItems) const
-	//<<TODO:ASSERT?>> Can we assert that this node cannot have both items
-	//and subnodes? [Jon Aquino]
-	resultItems->insert(resultItems->end(),items->begin(),items->end());
-	for(int i=0;i<4;i++) {
-		if (subnode[i]!=NULL) {
+	// this node may have items as well as subnodes (since items may not
+	// be wholely contained in any single subnode
+	resultItems.insert(resultItems.end(), items.begin(), items.end());
+	for(int i=0; i<4; ++i)
+		if ( subnode[i] )
 			subnode[i]->addAllItems(resultItems);
@@ -103,65 +114,78 @@
 void
-NodeBase::addAllItemsFromOverlapping(const Envelope *searchEnv, vector<void*> *resultItems)
+NodeBase::addAllItemsFromOverlapping(const Envelope& searchEnv,
+                                     vector<void*>& resultItems) const
 	if (!isSearchMatch(searchEnv))
 		return;
-			subnode[i]->addAllItemsFromOverlapping(searchEnv,resultItems);
+		if ( subnode[i] )
+			subnode[i]->addAllItemsFromOverlapping(searchEnv,
+			                                       resultItems);
 //<<TODO:RENAME?>> In Samet's terminology, I think what we're returning here is
 //actually level+1 rather than depth. (See p. 4 of his book) [Jon Aquino]
-int NodeBase::depth() {
-	int maxSubDepth=0;
-			int sqd=subnode[i]->depth();
-			if (sqd>maxSubDepth)
+unsigned int
+NodeBase::depth() const
+	unsigned int maxSubDepth=0;
+	for (int i=0; i<4; ++i)
+		if (subnode[i] != NULL)
+			unsigned int sqd=subnode[i]->depth();
+			if ( sqd > maxSubDepth )
 				maxSubDepth=sqd;
-	return maxSubDepth+1;
+	return maxSubDepth + 1;
-//<<TODO:RENAME?>> "size" is a bit generic. How about "itemCount"? [Jon Aquino]
-int NodeBase::size() {
-	int subSize=0;
-			subSize+=subnode[i]->size();
+unsigned int
+NodeBase::size() const
+	unsigned int subSize=0;
+	for(int i=0; i<4; i++)
+			subSize += subnode[i]->size();
-	return subSize+(int)items->size();
+	return subSize + items.size();
-//<<TODO:RENAME?>> The Java Language Specification recommends that "Methods to
-//get and set an attribute that might be thought of as a variable V should be
-//named getV and setV" (6.8.3). Perhaps this and other methods should be
-//renamed to "get..."? [Jon Aquino]
-int NodeBase::nodeCount() {
-	int subSize=0;
+unsigned int
+NodeBase::getNodeCount() const
-	return subSize+1;
+	return subSize + 1;
 string
 NodeBase::toString() const
 	ostringstream s;
-	s<<"ITEMS:"<<items->size()<<endl;
+	s<<"ITEMS:"<<items.size()<<endl;
 	for (int i=0; i<4; i++)
 		s<<"subnode["<<i<<"] ";
@@ -176,7 +200,7 @@
 void
 NodeBase::visit(const Envelope* searchEnv, ItemVisitor& visitor)
-	if (! isSearchMatch(searchEnv)) return;
+	if (! isSearchMatch(*searchEnv)) return;
@@ -197,7 +221,7 @@
 	// would be nice to filter items based on search envelope, but can't
 	// until they contain an envelope
-	for (vector<void*>::iterator i=items->begin(), e=items->end();
+	for (vector<void*>::iterator i=items.begin(), e=items.end();
 			i!=e; i++)
 		visitor.visitItem(*i);
@@ -209,16 +233,22 @@
 NodeBase::remove(const Envelope* itemEnv, void* item)
 	// use envelope to restrict nodes scanned
-	if (! isSearchMatch(itemEnv)) return false;
+	if (! isSearchMatch(*itemEnv)) return false;
 	bool found = false;
-	for (int i = 0; i < 4; i++) {
-		if (subnode[i] != NULL) {
+	for (int i = 0; i < 4; ++i)
+		if ( subnode[i] )
 			found = subnode[i]->remove(itemEnv, item);
-			if (found) {
+			if (found)
 				// trim subtree if empty
 				if (subnode[i]->isPrunable())
-				subnode[i] = NULL;
+					// delete subnode[i]
+					subnode[i] = NULL;
 				break;
@@ -229,9 +259,9 @@
 	// otherwise, try and remove the item from the list of items
 	// in this node
 	vector<void*>::iterator foundIter =
-		find(items->begin(), items->end(), item);
-	if ( foundIter != items->end() ) {
-		items->erase(foundIter);
+		find(items.begin(), items.end(), item);
+	if ( foundIter != items.end() ) {
+		items.erase(foundIter);
 		return true;
 	} else {
 		return false;
Modified: trunk/source/index/quadtree/Quadtree.cpp
--- trunk/source/index/quadtree/Quadtree.cpp	2009-04-25 00:23:06 UTC (rev 2407)
+++ trunk/source/index/quadtree/Quadtree.cpp	2009-04-27 14:58:14 UTC (rev 2408)
@@ -119,7 +119,7 @@
 	 * the items that are matched are the items in quads which
 	 * overlap the search envelope
-	root->addAllItemsFromOverlapping(searchEnv, &foundItems);
+	root->addAllItemsFromOverlapping(*searchEnv, foundItems);
 #if GEOS_DEBUG
 	cerr<<"Quadtree::query returning "<<foundItems.size()
 		<<" items over "<<size()
@@ -133,7 +133,7 @@
 Quadtree::queryAll()
 	vector<void*> *foundItems=new vector<void*>();
-	root->addAllItems(foundItems);
+	root->addAllItems(*foundItems);
 	return foundItems;
More information about the geos-commits mailing list
