[geos-commits] r2411 - in trunk/source: headers/geos/index/quadtree
index/quadtree
svn_geos at osgeo.org
Mon Apr 27 11:39:42 EDT 2009
Author: strk
Date: 2009-04-27 11:39:42 -0400 (Mon, 27 Apr 2009)
New Revision: 2411
trunk/source/headers/geos/index/quadtree/IntervalSize.h
trunk/source/index/quadtree/IntervalSize.cpp
Port info and check, doxygen.
Modified: trunk/source/headers/geos/index/quadtree/IntervalSize.h
--- trunk/source/headers/geos/index/quadtree/IntervalSize.h 2009-04-27 15:30:52 UTC (rev 2410)
+++ trunk/source/headers/geos/index/quadtree/IntervalSize.h 2009-04-27 15:39:42 UTC (rev 2411)
@@ -11,6 +11,10 @@
* by the Free Software Foundation.
* See the COPYING file for more information.
+ * Last port: index/quadtree/IntervalSize.java rev 1.7 (JTS-1.10)
#ifndef GEOS_IDX_QUADTREE_INTERVALSIZE_H
@@ -39,10 +43,16 @@
* This value is chosen to be a few powers of 2 less than the
* number of bits available in the double representation (i.e. 53).
* This should allow enough extra precision for simple computations
- * to be correct,
- * at least for comparison purposes.
+ * to be correct, at least for comparison purposes.
- static const int MIN_BINARY_EXPONENT=-50;
+ static const int MIN_BINARY_EXPONENT = -50;
+ * Computes whether the interval [min, max] is effectively zero width.
+ * I.e. the width of the interval is so much less than the
+ * location of the interval that the midpoint of the interval
+ * cannot be represented precisely.
static bool isZeroWidth(double min, double max);
Modified: trunk/source/index/quadtree/IntervalSize.cpp
--- trunk/source/index/quadtree/IntervalSize.cpp 2009-04-27 15:30:52 UTC (rev 2410)
+++ trunk/source/index/quadtree/IntervalSize.cpp 2009-04-27 15:39:42 UTC (rev 2411)
@@ -12,6 +12,10 @@
#include <geos/index/quadtree/IntervalSize.h>
@@ -26,13 +30,17 @@
namespace index { // geos.index
namespace quadtree { // geos.index.quadtree
-bool IntervalSize::isZeroWidth(double mn,double mx){
- double width=mx-mn;
- if (width==0.0) return true;
- double maxAbs=max(fabs(mn),fabs(mx));
- double scaledInterval=width/maxAbs;
- int level=DoubleBits::exponent(scaledInterval);
- return level<=MIN_BINARY_EXPONENT;
+/* public static */
+bool
+IntervalSize::isZeroWidth(double mn, double mx)
+ double width = mx - mn;
+ if (width == 0.0) return true;
+ double maxAbs = max(fabs(mn), fabs(mx));
+ double scaledInterval = width / maxAbs;
+ int level = DoubleBits::exponent(scaledInterval);
+ return level <= MIN_BINARY_EXPONENT;
} // namespace geos.index.quadtree
More information about the geos-commits
