[geos-commits] r2425 - in trunk/source: headers/geos/operation
operation
svn_geos at osgeo.org
Thu Apr 30 04:33:46 EDT 2009
Author: strk
Date: 2009-04-30 04:33:46 -0400 (Thu, 30 Apr 2009)
New Revision: 2425
trunk/source/headers/geos/operation/IsSimpleOp.h
trunk/source/operation/IsSimpleOp.cpp
Port info, and sync from 1.14 to 1.17 (more to do, need more classes)
Modified: trunk/source/headers/geos/operation/IsSimpleOp.h
--- trunk/source/headers/geos/operation/IsSimpleOp.h 2009-04-29 23:52:36 UTC (rev 2424)
+++ trunk/source/headers/geos/operation/IsSimpleOp.h 2009-04-30 08:33:46 UTC (rev 2425)
@@ -12,6 +12,10 @@
* by the Free Software Foundation.
* See the COPYING file for more information.
+ * Last port: operation/IsSimpleOp.java rev. 1.17
#ifndef GEOS_OPERATION_ISSIMPLEOP_H
@@ -44,22 +48,62 @@
/** \brief
* Tests whether a Geometry is simple.
- * Only Geometry whose definition allows them
- * to be simple or non-simple are tested. (E.g. Polygons must be simple
- * by definition, so no test is provided. To test whether a given Polygon is valid,
- * use <code>Geometry#isValid</code>)
+ * In general, the SFS specification of simplicity follows the rule:
+ * - A Geometry is simple iff the only self-intersections are at
+ * boundary points.
+ * Simplicity is defined for each {@link Geometry} subclass as follows:
+ * - Valid polygonal geometries are simple by definition, so
+ * <code>isSimple</code> trivially returns true.
+ * - Linear geometries are simple iff they do not self-intersect at points
+ * other than boundary points.
+ * - Zero-dimensional geometries (points) are simple iff they have no
+ * repeated points.
+ * - Empty <code>Geometry</code>s are always simple
class IsSimpleOp {
public:
IsSimpleOp();
bool isSimple(const geom::LineString *geom);
bool isSimple(const geom::MultiLineString *geom);
+ * A MultiPoint is simple iff it has no repeated points
bool isSimple(const geom::MultiPoint *mp);
bool isSimpleLinearGeometry(const geom::Geometry *geom);
private:
+ * For all edges, check if there are any intersections which are
+ * NOT at an endpoint.
+ * The Geometry is not simple if there are intersections not at
+ * endpoints.
bool hasNonEndpointIntersection(geomgraph::GeometryGraph &graph);
+ * Tests that no edge intersection is the endpoint of a closed line.
+ * This ensures that closed lines are not touched at their endpoint,
+ * which is an interior point according to the Mod-2 rule
+ * To check this we compute the degree of each endpoint.
+ * The degree of endpoints of closed lines
+ * must be exactly 2.
bool hasClosedEndpointIntersection(geomgraph::GeometryGraph &graph);
+ * Add an endpoint to the map, creating an entry for it if none exists
void addEndpoint(std::map<const geom::Coordinate*, EndpointInfo*,
geom::CoordinateLessThen>&endPoints,
const geom::Coordinate *p, bool isClosed);
Modified: trunk/source/operation/IsSimpleOp.cpp
--- trunk/source/operation/IsSimpleOp.cpp 2009-04-29 23:52:36 UTC (rev 2424)
+++ trunk/source/operation/IsSimpleOp.cpp 2009-04-30 08:33:46 UTC (rev 2425)
@@ -14,6 +14,8 @@
#include <geos/operation/IsSimpleOp.h>
@@ -41,24 +43,25 @@
namespace geos {
namespace operation { // geos.operation
+/*public*/
IsSimpleOp::IsSimpleOp()
+/*public*/
bool
IsSimpleOp::isSimple(const LineString *geom)
return isSimpleLinearGeometry(geom);
+/*public*/
bool
IsSimpleOp::isSimple(const MultiLineString *geom)
- * A MultiPoint is simple iff it has no repeated points
+/*public*/
bool
IsSimpleOp::isSimple(const MultiPoint *mp)
@@ -106,10 +109,7 @@
return true;
- * For all edges, check if there are any intersections which are NOT at an endpoint.
- * The Geometry is not simple if there are intersections not at endpoints.
+/*private*/
bool
IsSimpleOp::hasNonEndpointIntersection(GeometryGraph &graph)
@@ -129,12 +129,7 @@
return false;
- * Test that no edge intersection is the
- * endpoint of a closed line. To check this we compute the
- * degree of each endpoint. The degree of endpoints of closed lines
- * must be exactly 2.
+/*private*/
bool
IsSimpleOp::hasClosedEndpointIntersection(GeometryGraph &graph)
@@ -171,9 +166,7 @@
return false;
-* Add an endpoint to the map, creating an entry for it if none exists
+/*private*/
void
IsSimpleOp::addEndpoint(
map<const Coordinate*,EndpointInfo*,CoordinateLessThen>&endPoints,
@@ -210,89 +203,3 @@
} // namespace geos::operation
} // namespace geos
- * $Log$
- * Revision 1.23 2006/03/21 21:42:54 strk
- * planargraph.h header split, planargraph:: classes renamed to match JTS symbols
- * Revision 1.22 2006/03/09 16:46:49 strk
- * geos::geom namespace definition, first pass at headers split
- * Revision 1.21 2006/02/19 19:46:49 strk
- * Packages <-> namespaces mapping for most GEOS internal code (uncomplete, but working). Dir-level libs for index/ subdirs.
- * Revision 1.20 2006/01/08 15:24:40 strk
- * Changed container-related typedef to class-scoped STL-like typedefs.
- * Fixed const correctness of EdgeIntersectionList::begin() and ::end() consts;
- * defined M_PI when undef as suggested by Charlie Savage.
- * Removed <stdio.h> include from GeometricShapeFactory.cpp.
- * Revision 1.19 2005/11/21 16:03:20 strk
- * Coordinate interface change:
- * Removed setCoordinate call, use assignment operator
- * instead. Provided a compile-time switch to
- * make copy ctor and assignment operators non-inline
- * to allow for more accurate profiling.
- * Coordinate copies removal:
- * NodeFactory::createNode() takes now a Coordinate reference
- * rather then real value. This brings coordinate copies
- * in the testLeaksBig.xml test from 654818 to 645991
- * (tested in 2.1 branch). In the head branch Coordinate
- * copies are 222198.
- * Removed useless coordinate copies in ConvexHull
- * operations
- * STL containers heap allocations reduction:
- * Converted many containers element from
- * pointers to real objects.
- * Made some use of .reserve() or size
- * initialization when final container size is known
- * in advance.
- * Stateless classes allocations reduction:
- * Provided ::instance() function for
- * NodeFactories, to avoid allocating
- * more then one (they are all
- * stateless).
- * HCoordinate improvements:
- * Changed HCoordinate constructor by HCoordinates
- * take reference rather then real objects.
- * Changed HCoordinate::intersection to avoid
- * a new allocation but rather return into a provided
- * storage. LineIntersector changed to reflect
- * the above change.
- * Revision 1.18 2005/11/16 15:49:54 strk
- * Reduced gratuitous heap allocations.
- * Revision 1.17 2005/11/07 12:31:24 strk
- * Changed EdgeIntersectionList to use a set<> rathern then a vector<>, and
- * to avoid dynamic allocation of initial header.
- * Inlined short SweepLineEvent methods.
- * Revision 1.16 2005/06/24 11:09:43 strk
- * Dropped RobustLineIntersector, made LineIntersector a concrete class.
- * Added LineIntersector::hasIntersection(Coordinate&,Coordinate&,Coordinate&)
- * to avoid computing intersection point (Z) when it's not necessary.
- * Revision 1.15 2005/02/05 05:44:47 strk
- * Changed geomgraph nodeMap to use Coordinate pointers as keys, reduces
- * lots of other Coordinate copies.
- * Revision 1.14 2004/12/08 13:54:43 strk
- * gcc warnings checked and fixed, general cleanups.
- * Revision 1.13 2004/07/02 13:28:27 strk
- * Fixed all #include lines to reflect headers layout change.
- * Added client application build tips in README.
- * Revision 1.12 2003/11/07 01:23:42 pramsey
- * Add standard CVS headers licence notices and copyrights to all cpp and h
- * files.
More information about the geos-commits
