[geos-commits] r2442 - in trunk/source: geom headers/geos/geom
svn_geos at osgeo.org svn_geos at osgeo.org
Thu Apr 30 08:17:23 EDT 2009
Author: strk
Date: 2009-04-30 08:17:23 -0400 (Thu, 30 Apr 2009)
New Revision: 2442
   trunk/source/geom/Point.cpp
   trunk/source/headers/geos/geom/Point.h
Point full up to JTS-1.0 (rev 1.37) : adds reverse()
Modified: trunk/source/geom/Point.cpp
--- trunk/source/geom/Point.cpp	2009-04-30 12:07:26 UTC (rev 2441)
+++ trunk/source/geom/Point.cpp	2009-04-30 12:17:23 UTC (rev 2442)
@@ -12,6 +12,10 @@
  * by the Free Software Foundation.
  * See the COPYING file for more information.
+ * Last port: geom/Point.java rev. 1.37 (JTS-1.10)
 #include <geos/util/UnsupportedOperationException.h>
@@ -253,94 +257,3 @@
 } // namespace geos::geom
 } // namesapce geos
- * $Log$
- * Revision 1.46  2006/05/04 15:49:39  strk
- * updated all Geometry::getDimension() methods to return Dimension::DimensionType (closes bug#93)
- * Revision 1.45  2006/04/28 10:55:39  strk
- * Geometry constructors made protected, to ensure all constructions use GeometryFactory,
- * which has been made friend of all Geometry derivates. getNumPoints() changed to return
- * size_t.
- * Revision 1.44  2006/04/10 18:15:09  strk
- * Changed Geometry::envelope member to be of type auto_ptr<Envelope>.
- * Changed computeEnvelopeInternal() signater to return auto_ptr<Envelope>
- * Revision 1.43  2006/04/10 17:35:44  strk
- * Changed LineString::points and Point::coordinates to be wrapped
- * in an auto_ptr<>. This should close bugs #86 and #89
- * Revision 1.42  2006/03/22 16:58:34  strk
- * Removed (almost) all inclusions of geom.h.
- * Removed obsoleted .cpp files.
- * Fixed a bug in WKTReader not using the provided CoordinateSequence
- * implementation, optimized out some memory allocations.
- * Revision 1.41  2006/03/09 16:46:47  strk
- * geos::geom namespace definition, first pass at headers split
- * Revision 1.40  2006/03/06 19:40:46  strk
- * geos::util namespace. New GeometryCollection::iterator interface, many cleanups.
- * Revision 1.39  2006/03/03 10:46:21  strk
- * Removed 'using namespace' from headers, added missing headers in .cpp files, removed useless includes in headers (bug#46)
- * Revision 1.38  2006/02/09 15:52:47  strk
- * GEOSException derived from std::exception; always thrown and cought by const ref.
- * Revision 1.37  2006/01/31 19:07:33  strk
- * - Renamed DefaultCoordinateSequence to CoordinateArraySequence.
- * - Moved GetNumGeometries() and GetGeometryN() interfaces
- *   from GeometryCollection to Geometry class.
- * - Added getAt(int pos, Coordinate &to) funtion to CoordinateSequence class.
- * - Reworked automake scripts to produce a static lib for each subdir and
- *   then link all subsystem's libs togheter
- * - Moved C-API in it's own top-level dir capi/
- * - Moved source/bigtest and source/test to tests/bigtest and test/xmltester
- * - Fixed PointLocator handling of LinearRings
- * - Changed CoordinateArrayFilter to reduce memory copies
- * - Changed UniqueCoordinateArrayFilter to reduce memory copies
- * - Added CGAlgorithms::isPointInRing() version working with
- *   Coordinate::ConstVect type (faster!)
- * - Ported JTS-1.7 version of ConvexHull with big attention to
- *   memory usage optimizations.
- * - Improved XMLTester output and user interface
- * - geos::geom::util namespace used for geom/util stuff
- * - Improved memory use in geos::geom::util::PolygonExtractor
- * - New ShortCircuitedGeometryVisitor class
- * - New operation/predicate package
- * Revision 1.36  2005/12/08 14:14:07  strk
- * ElevationMatrixFilter used for both elevation and Matrix fill,
- * thus removing CoordinateSequence copy in ElevetaionMatrix::add(Geometry *).
- * Changed CoordinateFilter::filter_rw to be a const method: updated
- * all apply_rw() methods to take a const CoordinateFilter.
- * Revision 1.35  2005/06/23 14:22:33  strk
- * Inlined and added missing ::clone() for Geometry subclasses
- * Revision 1.34  2005/05/23 16:42:43  strk
- * Added Refractions copyright
- * Revision 1.33  2005/05/13 17:15:34  strk
- * cleanups and indentations
- * Revision 1.32  2005/04/19 11:49:26  strk
- * Fixed segfault in ::isEmpty
- * Revision 1.31  2004/11/23 16:22:49  strk
- * Added ElevationMatrix class and components to do post-processing draping of overlayed geometries.
- * Revision 1.30  2004/09/13 12:39:14  strk
- * Made Point and MultiPoint subject to Validity tests.
- * Revision 1.29  2004/07/08 19:34:49  strk
- * Mirrored JTS interface of CoordinateSequence, factory and
- * default implementations.
- * Added CoordinateArraySequenceFactory::instance() function.
Modified: trunk/source/headers/geos/geom/Point.h
--- trunk/source/headers/geos/geom/Point.h	2009-04-30 12:07:26 UTC (rev 2441)
+++ trunk/source/headers/geos/geom/Point.h	2009-04-30 12:17:23 UTC (rev 2442)
@@ -12,6 +12,10 @@
 #ifndef GEOS_GEOS_POINT_H
@@ -48,7 +52,9 @@
  * \class Point geom.h geos.h
  * \brief Basic implementation of Point.
-class Point : public Geometry {
+class Point : public Geometry
+	// NOTE: in JTS Point implements Puntual
 public:
@@ -59,6 +65,12 @@
 	virtual ~Point();
+	 * Creates and returns a full copy of this {@link Point} object.
+	 * (including all coordinates contained by it).
+	 * @return a clone of this instance
 	Geometry *clone() const { return new Point(*this); }
 	CoordinateSequence* getCoordinates(void) const;
@@ -76,7 +88,14 @@
 	/// Returns Dimension::False (Point has no boundary)
 	int getBoundaryDimension() const;
-	/// Returns an EMPTY Geometry.
+	 * Gets the boundary of this geometry.
+	 * Zero-dimensional geometries have no boundary by definition,
+	 * so an empty GeometryCollection is returned.
+	 * @return an empty GeometryCollection
+	 * @see Geometry::getBoundary
 	Geometry* getBoundary() const;
 	double getX() const;
@@ -94,8 +113,17 @@
 	void apply_ro(CoordinateSequenceFilter& filter) const;
 	bool equalsExact(const Geometry *other, double tolerance=0) const;
-	void normalize(void) { };
+	void normalize(void)
+		// a Point is always in normalized form
+  	Geometry* reverse() const
+		return clone();
 protected:
@@ -135,28 +163,3 @@
 #endif // ndef GEOS_GEOS_POINT_H
- * $Log$
- * Revision 1.6  2006/05/04 15:49:39  strk
- * Revision 1.5  2006/04/28 10:55:39  strk
- * size_t.
- * Revision 1.4  2006/04/10 18:15:09  strk
- * Revision 1.3  2006/04/10 17:35:44  strk
- * Revision 1.2  2006/03/24 09:52:41  strk
- * USE_INLINE => GEOS_INLINE
- * Revision 1.1  2006/03/09 16:46:49  strk
More information about the geos-commits mailing list
