[geos-commits] r2777 - trunk/source/headers/geos/noding/snapround
svn_geos at osgeo.org
Thu Dec 3 14:41:18 EST 2009
Author: mloskot
Date: 2009-12-03 14:41:15 -0500 (Thu, 03 Dec 2009)
New Revision: 2777
trunk/source/headers/geos/noding/snapround/HotPixel.h
trunk/source/headers/geos/noding/snapround/MCIndexPointSnapper.h
trunk/source/headers/geos/noding/snapround/MCIndexSnapRounder.h
trunk/source/headers/geos/noding/snapround/SimpleSnapRounder.h
Part 16 of larger changeset - source/headers/geos/noding/snapround:
* Declare noncopyable types as such explicitly (Ticket #304).
* Added Visual C++ pragmas.
* Tidy up.
* Unified EOL and style.
Modified: trunk/source/headers/geos/noding/snapround/HotPixel.h
--- trunk/source/headers/geos/noding/snapround/HotPixel.h 2009-12-03 19:39:19 UTC (rev 2776)
+++ trunk/source/headers/geos/noding/snapround/HotPixel.h 2009-12-03 19:41:15 UTC (rev 2777)
@@ -136,6 +136,10 @@
bool intersectsPixelClosure(const geom::Coordinate& p0,
const geom::Coordinate& p1);
+ // Declare type as noncopyable
+ HotPixel(const HotPixel& other);
+ HotPixel& operator=(const HotPixel& rhs);
public:
HotPixel(const geom::Coordinate& pt,
Modified: trunk/source/headers/geos/noding/snapround/MCIndexPointSnapper.h
--- trunk/source/headers/geos/noding/snapround/MCIndexPointSnapper.h 2009-12-03 19:39:19 UTC (rev 2776)
+++ trunk/source/headers/geos/noding/snapround/MCIndexPointSnapper.h 2009-12-03 19:41:15 UTC (rev 2777)
@@ -48,10 +48,6 @@
class GEOS_DLL MCIndexPointSnapper {
-private:
- index::SpatialIndex& index;
public:
@@ -60,7 +56,6 @@
index(nIndex)
* Snaps (nodes) all interacting segments to this hot pixel.
* The hot pixel may represent a vertex of an edge,
@@ -79,7 +74,15 @@
bool snap(HotPixel& hotPixel) {
return snap(hotPixel, 0, 0);
+private:
+ index::SpatialIndex& index;
+ MCIndexPointSnapper(const MCIndexPointSnapper& other);
+ MCIndexPointSnapper& operator=(const MCIndexPointSnapper& rhs);
Modified: trunk/source/headers/geos/noding/snapround/MCIndexSnapRounder.h
--- trunk/source/headers/geos/noding/snapround/MCIndexSnapRounder.h 2009-12-03 19:39:19 UTC (rev 2776)
+++ trunk/source/headers/geos/noding/snapround/MCIndexSnapRounder.h 2009-12-03 19:41:15 UTC (rev 2777)
@@ -76,6 +76,24 @@
class GEOS_DLL MCIndexSnapRounder: public Noder { // implments Noder
+public:
+ MCIndexSnapRounder(geom::PrecisionModel& nPm);
+ std::vector<SegmentString*>* getNodedSubstrings() const;
+ void computeNodes(std::vector<SegmentString*>* segStrings);
+ * Computes nodes introduced as a result of
+ * snapping segments to vertices of other segments
+ * @param segStrings the list of segment strings to snap together
+ * NOTE: they *must* be instances of NodedSegmentString, or
+ * an assertion will fail.
+ void computeVertexSnaps(std::vector<SegmentString*>& edges);
private:
/// externally owned
@@ -117,24 +135,9 @@
void checkCorrectness(std::vector<SegmentString*>& inputSegmentStrings);
-public:
- MCIndexSnapRounder(geom::PrecisionModel& nPm);
- std::vector<SegmentString*>* getNodedSubstrings() const;
- void computeNodes(std::vector<SegmentString*>* segStrings);
- * Computes nodes introduced as a result of
- * snapping segments to vertices of other segments
- * @param segStrings the list of segment strings to snap together
- * NOTE: they *must* be instances of NodedSegmentString, or
- * an assertion will fail.
- void computeVertexSnaps(std::vector<SegmentString*>& edges);
+ MCIndexSnapRounder(const MCIndexSnapRounder& other);
+ MCIndexSnapRounder& operator=(const MCIndexSnapRounder& rhs);
Modified: trunk/source/headers/geos/noding/snapround/SimpleSnapRounder.h
--- trunk/source/headers/geos/noding/snapround/SimpleSnapRounder.h 2009-12-03 19:39:19 UTC (rev 2776)
+++ trunk/source/headers/geos/noding/snapround/SimpleSnapRounder.h 2009-12-03 19:41:15 UTC (rev 2777)
@@ -72,7 +72,27 @@
class GEOS_DLL SimpleSnapRounder: public Noder { // implements NoderIface
+public:
+ SimpleSnapRounder(const geom::PrecisionModel& newPm);
+ void computeNodes(std::vector<SegmentString*>* inputSegmentStrings);
+ void add(const SegmentString* segStr);
+ * @param segStrings the list of segment strings to snap together.
+ * Must be NodedSegmentString or an assertion will fail.
+ void computeVertexSnaps(const std::vector<SegmentString*>& edges);
private:
const geom::PrecisionModel& pm;
algorithm::LineIntersector li;
double scaleFactor;
@@ -114,24 +134,9 @@
void computeVertexSnaps(NodedSegmentString* e0, NodedSegmentString* e1);
-public:
- SimpleSnapRounder(const geom::PrecisionModel& newPm);
- void computeNodes(std::vector<SegmentString*>* inputSegmentStrings);
- void add(const SegmentString* segStr);
- * @param segStrings the list of segment strings to snap together.
- * Must be NodedSegmentString or an assertion will fail.
- void computeVertexSnaps(const std::vector<SegmentString*>& edges);
+ SimpleSnapRounder(const SimpleSnapRounder& other);
+ SimpleSnapRounder& operator=(const SimpleSnapRounder& rhs);
} // namespace geos::noding::snapround
More information about the geos-commits
