[geos-commits] r2779 - trunk/source/headers/geos/operation/buffer
svn_geos at osgeo.org
Thu Dec 3 14:45:54 EST 2009
Author: mloskot
Date: 2009-12-03 14:45:53 -0500 (Thu, 03 Dec 2009)
New Revision: 2779
trunk/source/headers/geos/operation/buffer/BufferBuilder.h
trunk/source/headers/geos/operation/buffer/OffsetCurveBuilder.h
trunk/source/headers/geos/operation/buffer/OffsetCurveSetBuilder.h
Part 18of larger changeset - source/headers/geos/operation/buffer:
* Declare noncopyable types as such explicitly (Ticket #304).
* Tidy up.
* Unified EOL and style.
Modified: trunk/source/headers/geos/operation/buffer/BufferBuilder.h
--- trunk/source/headers/geos/operation/buffer/BufferBuilder.h 2009-12-03 19:44:00 UTC (rev 2778)
+++ trunk/source/headers/geos/operation/buffer/BufferBuilder.h 2009-12-03 19:45:53 UTC (rev 2779)
@@ -83,6 +83,61 @@
class GEOS_DLL BufferBuilder {
+public:
+ * Creates a new BufferBuilder
+ * @param nBufParams buffer parameters, this object will
+ * keep a reference to the passed parameters
+ * so caller must make sure the object is
+ * kept alive for the whole lifetime of
+ * the buffer builder.
+ BufferBuilder(const BufferParameters& nBufParams)
+ bufParams(nBufParams),
+ workingPrecisionModel(NULL),
+ li(NULL),
+ intersectionAdder(NULL),
+ workingNoder(NULL),
+ geomFact(NULL),
+ edgeList()
+ ~BufferBuilder();
+ * Sets the precision model to use during the curve computation
+ * and noding,
+ * if it is different to the precision model of the Geometry.
+ * If the precision model is less than the precision of the
+ * Geometry precision model,
+ * the Geometry must have previously been rounded to that precision.
+ * @param pm the precision model to use
+ void setWorkingPrecisionModel(const geom::PrecisionModel *pm) {
+ workingPrecisionModel=pm;
+ * Sets the {@link noding::Noder} to use during noding.
+ * This allows choosing fast but non-robust noding, or slower
+ * but robust noding.
+ * @param noder the noder to use
+ void setNoder(noding::Noder* newNoder) { workingNoder = newNoder; }
+ geom::Geometry* buffer(const geom::Geometry *g, double distance);
+ // throw (GEOSException);
+ /// Not in JTS: this is a GEOS extension
+ geom::Geometry* bufferLineSingleSided( const geom::Geometry* g,
+ double distance, bool leftSide ) ;
private:
* Compute the change in depth as an edge is crossed from R to L
@@ -155,62 +210,10 @@
* @return the empty result geometry, transferring ownership to caller.
geom::Geometry* createEmptyResultGeometry() const;
-public:
- * Creates a new BufferBuilder
- * @param nBufParams buffer parameters, this object will
- * keep a reference to the passed parameters
- * so caller must make sure the object is
- * kept alive for the whole lifetime of
- * the buffer builder.
- BufferBuilder(const BufferParameters& nBufParams)
- bufParams(nBufParams),
- workingPrecisionModel(NULL),
- li(NULL),
- intersectionAdder(NULL),
- workingNoder(NULL),
- geomFact(NULL),
- edgeList()
- ~BufferBuilder();
- * Sets the precision model to use during the curve computation
- * and noding,
- * if it is different to the precision model of the Geometry.
- * If the precision model is less than the precision of the
- * Geometry precision model,
- * the Geometry must have previously been rounded to that precision.
- * @param pm the precision model to use
- void setWorkingPrecisionModel(const geom::PrecisionModel *pm) {
- workingPrecisionModel=pm;
- * Sets the {@link noding::Noder} to use during noding.
- * This allows choosing fast but non-robust noding, or slower
- * but robust noding.
- * @param noder the noder to use
- void setNoder(noding::Noder* newNoder) { workingNoder = newNoder; }
- geom::Geometry* buffer(const geom::Geometry *g, double distance);
- // throw (GEOSException);
- /// Not in JTS: this is a GEOS extension
- geom::Geometry* bufferLineSingleSided( const geom::Geometry* g,
- double distance, bool leftSide ) ;
+ // Declare type as noncopyable
+ BufferBuilder(const BufferBuilder& other);
+ BufferBuilder& operator=(const BufferBuilder& rhs);
} // namespace geos::operation::buffer
Modified: trunk/source/headers/geos/operation/buffer/OffsetCurveBuilder.h
--- trunk/source/headers/geos/operation/buffer/OffsetCurveBuilder.h 2009-12-03 19:44:00 UTC (rev 2778)
+++ trunk/source/headers/geos/operation/buffer/OffsetCurveBuilder.h 2009-12-03 19:45:53 UTC (rev 2779)
@@ -357,7 +357,11 @@
/// Adds a CW square around a point
void addSquare(const geom::Coordinate &p, double distance);
- std::vector<OffsetCurveVertexList*> vertexLists;
+ std::vector<OffsetCurveVertexList*> vertexLists;
+ OffsetCurveBuilder(const OffsetCurveBuilder& other);
+ OffsetCurveBuilder& operator=(const OffsetCurveBuilder& rhs);
Modified: trunk/source/headers/geos/operation/buffer/OffsetCurveSetBuilder.h
--- trunk/source/headers/geos/operation/buffer/OffsetCurveSetBuilder.h 2009-12-03 19:44:00 UTC (rev 2778)
+++ trunk/source/headers/geos/operation/buffer/OffsetCurveSetBuilder.h 2009-12-03 19:45:53 UTC (rev 2779)
@@ -163,6 +163,10 @@
bool isTriangleErodedCompletely(geom::CoordinateSequence *triangleCoord,
double bufferDistance);
+ OffsetCurveSetBuilder(const OffsetCurveSetBuilder& other);
+ OffsetCurveSetBuilder& operator=(const OffsetCurveSetBuilder& rhs);
public:
/// Constructor
More information about the geos-commits
