[geos-commits] r2790 - trunk/source/headers/geos
svn_geos at osgeo.org
Thu Dec 3 15:29:06 EST 2009
Author: mloskot
Date: 2009-12-03 15:29:05 -0500 (Thu, 03 Dec 2009)
New Revision: 2790
trunk/source/headers/geos/export.h
Removed mysterious extra tokens (blanks) from geos/export.h
Modified: trunk/source/headers/geos/export.h
--- trunk/source/headers/geos/export.h 2009-12-03 20:16:02 UTC (rev 2789)
+++ trunk/source/headers/geos/export.h 2009-12-03 20:29:05 UTC (rev 2790)
@@ -1,17 +1,17 @@
- * $Id: export.h 2045 2008-03-17 20:18:24Z Ragi Burhum $
- * GEOS - Geometry Engine Open Source
- * http://geos.refractions.net
- * Copyright (C) 2009 Ragi Y. Burhum <ragi at burhum.com>
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
+* $Id: export.h 2045 2008-03-17 20:18:24Z Ragi Burhum $
+* GEOS - Geometry Engine Open Source
+* http://geos.refractions.net
+* Copyright (C) 2009 Ragi Y. Burhum <ragi at burhum.com>
+* This is free software; you can redistribute and/or modify it under
+* the terms of the GNU Lesser General Public Licence as published
+* by the Free Software Foundation.
+* See the COPYING file for more information.
#ifndef GEOS_EXPORT_H
#define GEOS_EXPORT_H
@@ -19,15 +19,16 @@
#if defined(_MSC_VER) || defined(__CYGWIN__) || defined(__MINGW32__) || \
defined( __BCPLUSPLUS__) || defined( __MWERKS__)
- #if defined(GEOS_DLL_EXPORT)
- #define GEOS_DLL __declspec(dllexport)
- #elif defined(GEOS_DLL_IMPORT)
- #define GEOS_DLL __declspec(dllimport)
- #else
- #define GEOS_DLL
- #endif
+# if defined(GEOS_DLL_EXPORT)
+# define GEOS_DLL __declspec(dllexport)
+# elif defined(GEOS_DLL_IMPORT)
+# define GEOS_DLL __declspec(dllimport)
+# else
+# define GEOS_DLL
+# endif
#else
- #define GEOS_DLL
+# define GEOS_DLL
#endif
#endif // GEOS_EXPORT_H
More information about the geos-commits
