[geos-commits] r2803 - in trunk/build/msvc80: . geos_xmltester
svn_geos at osgeo.org
Sat Dec 5 16:28:58 EST 2009
Author: mloskot
Date: 2009-12-05 16:28:58 -0500 (Sat, 05 Dec 2009)
New Revision: 2803
Added:
trunk/build/msvc80/geos_xmltester/
trunk/build/msvc80/geos_xmltester/Makefile.am
trunk/build/msvc80/geos_xmltester/geos_xmltester.vcproj
trunk/build/msvc80/Makefile.am
trunk/build/msvc80/geos.sln
Added geos_xmltester.vcproj project to build/msvc80
Modified: trunk/build/msvc80/Makefile.am
--- trunk/build/msvc80/Makefile.am 2009-12-05 21:20:16 UTC (rev 2802)
+++ trunk/build/msvc80/Makefile.am 2009-12-05 21:28:58 UTC (rev 2803)
@@ -10,7 +10,8 @@
geos_lib \
geos_python \
geos_ruby \
- geos_unit
+ geos_unit \
+ geos_xmltester
EXTRA_DIST = \
README \
Modified: trunk/build/msvc80/geos.sln
--- trunk/build/msvc80/geos.sln 2009-12-05 21:20:16 UTC (rev 2802)
+++ trunk/build/msvc80/geos.sln 2009-12-05 21:28:58 UTC (rev 2803)
@@ -27,6 +27,12 @@
..\..\TODO = ..\..\TODO
EndProjectSection
EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "geos_xmltester", "geos_xmltester\geos_xmltester.vcproj", "{304618A3-CCA4-4A2F-3BEE-1AB57060F5C2}"
+ ProjectSection(ProjectDependencies) = postProject
+ {108E75A3-0A92-489A-B1A9-8F071D40A108} = {108E75A3-0A92-489A-B1A9-8F071D40A108}
+ {CDBC2FB8-2995-49DE-B80B-B7BE0E4C1115} = {CDBC2FB8-2995-49DE-B80B-B7BE0E4C1115}
+ EndProjectSection
+EndProject
Global
GlobalSection(SolutionConfigurationPlatforms) = preSolution
Debug|Win32 = Debug|Win32
@@ -45,6 +51,10 @@
{CDBC2FB8-2995-49DE-B80B-B7BE0E4C1115}.Debug|Win32.Build.0 = Debug|Win32
{CDBC2FB8-2995-49DE-B80B-B7BE0E4C1115}.Release|Win32.ActiveCfg = Release|Win32
{CDBC2FB8-2995-49DE-B80B-B7BE0E4C1115}.Release|Win32.Build.0 = Release|Win32
+ {304618A3-CCA4-4A2F-3BEE-1AB57060F5C2}.Debug|Win32.ActiveCfg = Debug|Win32
+ {304618A3-CCA4-4A2F-3BEE-1AB57060F5C2}.Debug|Win32.Build.0 = Debug|Win32
+ {304618A3-CCA4-4A2F-3BEE-1AB57060F5C2}.Release|Win32.ActiveCfg = Release|Win32
+ {304618A3-CCA4-4A2F-3BEE-1AB57060F5C2}.Release|Win32.Build.0 = Release|Win32
EndGlobalSection
GlobalSection(SolutionProperties) = preSolution
HideSolutionNode = FALSE
Added: trunk/build/msvc80/geos_xmltester/Makefile.am
--- trunk/build/msvc80/geos_xmltester/Makefile.am (rev 0)
+++ trunk/build/msvc80/geos_xmltester/Makefile.am 2009-12-05 21:28:58 UTC (rev 2803)
@@ -0,0 +1,9 @@
+# NOTE: Make sure that 'source' appears first.
+# 'capi' and 'doc' surely rely on availability of libgeos
+# which is built under 'source' and it seems that automake
+# is not able to detect required build order but blindly
+# relies on the order items in SUBDIRS appear.
+EXTRA_DIST = \
+ geos_xmltester.vcproj
Added: trunk/build/msvc80/geos_xmltester/geos_xmltester.vcproj
--- trunk/build/msvc80/geos_xmltester/geos_xmltester.vcproj (rev 0)
+++ trunk/build/msvc80/geos_xmltester/geos_xmltester.vcproj 2009-12-05 21:28:58 UTC (rev 2803)
@@ -0,0 +1,505 @@
+<?xml version="1.0" encoding="windows-1250"?>
+<VisualStudioProject
+ ProjectType="Visual C++"
+ Version="8.00"
+ Name="geos_xmltester"
+ ProjectGUID="{304618A3-CCA4-4A2F-3BEE-1AB57060F5C2}"
+ RootNamespace="geos_xmltester"
+ Keyword="Win32Proj"
+ <Platforms>
+ <Platform
+ Name="Win32"
+ </Platforms>
+ <ToolFiles>
+ </ToolFiles>
+ <Configurations>
+ <Configuration
+ Name="Debug|Win32"
+ OutputDirectory="$(SolutionDir)$(ConfigurationName)"
+ IntermediateDirectory="$(ConfigurationName)"
+ ConfigurationType="1"
+ CharacterSet="1"
+ <Tool
+ Name="VCPreBuildEventTool"
+ <Tool
+ Name="VCCustomBuildTool"
+ <Tool
+ Name="VCXMLDataGeneratorTool"
+ <Tool
+ Name="VCWebServiceProxyGeneratorTool"
+ <Tool
+ Name="VCMIDLTool"
+ <Tool
+ Name="VCCLCompilerTool"
+ Optimization="0"
+ AdditionalIncludeDirectories=".\;..\..\..\tests\unit;..\..\..\tests\unit\tut;..\..\..\capi;..\..\..\source\headers"
+ PreprocessorDefinitions="_CRT_SECURE_NO_DEPRECATE;_SCL_SECURE_NO_DEPRECATE;WIN32_LEAN_AND_MEAN;NOMINMAX;NOGDI"
+ MinimalRebuild="true"
+ BasicRuntimeChecks="3"
+ RuntimeLibrary="3"
+ UsePrecompiledHeader="0"
+ WarningLevel="4"
+ Detect64BitPortabilityProblems="false"
+ DebugInformationFormat="4"
+ <Tool
+ Name="VCManagedResourceCompilerTool"
+ <Tool
+ Name="VCResourceCompilerTool"
+ <Tool
+ Name="VCPreLinkEventTool"
+ <Tool
+ Name="VCLinkerTool"
+ OutputFile="$(OutDir)\$(ProjectName)d.exe"
+ LinkIncremental="2"
+ AdditionalLibraryDirectories=""
+ GenerateDebugInformation="true"
+ SubSystem="1"
+ TargetMachine="1"
+ <Tool
+ Name="VCALinkTool"
+ <Tool
+ Name="VCManifestTool"
+ <Tool
+ Name="VCXDCMakeTool"
+ <Tool
+ Name="VCBscMakeTool"
+ <Tool
+ Name="VCFxCopTool"
+ <Tool
+ Name="VCAppVerifierTool"
+ <Tool
+ Name="VCWebDeploymentTool"
+ <Tool
+ Name="VCPostBuildEventTool"
+ CommandLine=""
+ </Configuration>
+ <Configuration
+ Name="Release|Win32"
+ CharacterSet="1"
+ WholeProgramOptimization="1"
+ <Tool
+ <Tool
+ <Tool
+ <Tool
+ <Tool
+ Name="VCMIDLTool"
+ <Tool
+ RuntimeLibrary="2"
+ WarningLevel="3"
+ DebugInformationFormat="3"
+ <Tool
+ <Tool
+ <Tool
+ <Tool
+ LinkIncremental="1"
+ SubSystem="1"
+ OptimizeReferences="2"
+ EnableCOMDATFolding="2"
+ TargetMachine="1"
+ <Tool
+ <Tool
+ <Tool
+ <Tool
+ <Tool
+ <Tool
+ <Tool
+ <Tool
+ CommandLine=""
+ </Configuration>
+ </Configurations>
+ <References>
+ </References>
+ <Files>
+ <Filter
+ Name="tinyxml"
+ <File
+ RelativePath="..\..\..\tests\xmltester\tinyxml\tinystr.cpp"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tinyxml\tinystr.h"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tinyxml\tinyxml.cpp"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tinyxml\tinyxml.h"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tinyxml\tinyxmlerror.cpp"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tinyxml\tinyxmlparser.cpp"
+ </File>
+ </Filter>
+ <Filter
+ Name="tests"
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\badguy3.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\buffer.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\buffer_snapround.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\bug176.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\bug188.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\bug244.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\bug275.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\fme.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\heisenbugs.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\hexwkb.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\hole_from_shell.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\hole_red.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\linemerge.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\robustness.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\singlesidedbuffer.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\split.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\test.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\TestBigNastyBuffer.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\TestBufferExternal.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\TestBufferExternal2.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\TestIsValid.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\testLeaksBig.xml"
+ </File>
+ <Filter
+ Name="general"
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\general\MISSING"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\general\TestBoundary.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\general\TestBuffer.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\general\TestBufferMitredJoin.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\general\TestCentroid.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\general\TestConvexHull-big.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\general\TestConvexHull.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\general\TestFunctionAA.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\general\TestFunctionAAPrec.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\general\TestFunctionLA.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\general\TestFunctionLAPrec.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\general\TestFunctionLL.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\general\TestFunctionLLPrec.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\general\TestFunctionPA.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\general\TestFunctionPL.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\general\TestFunctionPLPrec.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\general\TestFunctionPP.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\general\TestInteriorPoint.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\general\TestRectanglePredicate.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\general\TestRelateAA.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\general\TestRelateAC.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\general\TestRelateLA.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\general\TestRelateLC.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\general\TestRelateLL.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\general\TestRelatePA.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\general\TestRelatePL.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\general\TestRelatePP.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\general\TestSimple.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\general\TestValid.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\general\TestValid2-big.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\general\TestValid2.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\general\TestWithinDistance.xml"
+ </File>
+ </Filter>
+ <Filter
+ Name="robust"
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\stmlf\stmlf-cases-20061020.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\stmlf\stmlf-cases-20070119.xml"
+ </File>
+ </Filter>
+ <Filter
+ Name="safe"
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\safe\16595.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\safe\16596.xml"
+ </File>
+ </Filter>
+ <Filter
+ Name="stmlf"
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\robust\TestRobustOverlayFixed.xml"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\tests\robust\TestRobustRelate.xml"
+ </File>
+ </Filter>
+ </Filter>
+ <File
+ RelativePath="..\..\..\tests\xmltester\BufferResultMatcher.cpp"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\BufferResultMatcher.h"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\Makefile.am"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\makefile.vc"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\safe_to_xml.sh"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\SingleSidedBufferResultMatcher.cpp"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\SingleSidedBufferResultMatcher.h"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\XMLTester.cpp"
+ </File>
+ <File
+ RelativePath="..\..\..\tests\xmltester\XMLTester.h"
+ </File>
+ </Files>
+ <Globals>
+ </Globals>
+</VisualStudioProject>
More information about the geos-commits
