[geos-commits] r2813 - trunk/source/algorithm
svn_geos at osgeo.org svn_geos at osgeo.org
Tue Dec 8 12:50:03 EST 2009
Author: strk
Date: 2009-12-08 12:50:03 -0500 (Tue, 08 Dec 2009)
New Revision: 2813
Removed:
   trunk/source/algorithm/NonRobustLineIntersector.cpp
   trunk/source/algorithm/RobustLineIntersector.cpp
Remove deprecated/unused files
Deleted: trunk/source/algorithm/NonRobustLineIntersector.cpp
--- trunk/source/algorithm/NonRobustLineIntersector.cpp	2009-12-08 17:42:59 UTC (rev 2812)
+++ trunk/source/algorithm/NonRobustLineIntersector.cpp	2009-12-08 17:50:03 UTC (rev 2813)
@@ -1,282 +0,0 @@
- * $Id$
- * GEOS - Geometry Engine Open Source
- * http://geos.refractions.net
- * Copyright (C) 2001-2002 Vivid Solutions Inc.
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
- * $Log$
- * Revision 1.12  2006/03/21 11:12:23  strk
- * Cleanups: headers inclusion and Log section
- * Revision 1.11  2006/02/19 19:46:49  strk
- * Packages <-> namespaces mapping for most GEOS internal code (uncomplete, but working). Dir-level libs for index/ subdirs.
- * Revision 1.10  2005/04/06 11:09:41  strk
- * Applied patch from Jon Schlueter (math.h => cmath; ieeefp.h in "C" block)
- * Revision 1.9  2004/07/02 13:28:26  strk
- * Fixed all #include lines to reflect headers layout change.
- * Added client application build tips in README.
- * Revision 1.8  2003/11/07 01:23:42  pramsey
- * Add standard CVS headers licence notices and copyrights to all cpp and h
- * files.
-#include <geos/geosAlgorithm.h>
-#include <geos/util.h>
-//#include <stdio.h>
-#include <cmath>
-namespace geos {
-namespace algorithm { // geos.algorithm
-NonRobustLineIntersector::NonRobustLineIntersector(){}
-void NonRobustLineIntersector::computeIntersection(const Coordinate& p,const Coordinate& p1,const Coordinate& p2) {
-	double a1;
-	double b1;
-	double c1;
-	*  Coefficients of line eqns.
-	double r;
-	*  'Sign' values
-	isProperVar=false;
-	*  Compute a1,b1,c1,where line joining points 1 and 2
-	*  is "a1 x + b1 y + c1 = 0".
-	a1=p2.y-p1.y;
-	b1=p1.x-p2.x;
-	c1=p2.x*p1.y-p1.x*p2.y;
-	*  Compute r3 and r4.
-	r=a1*p.x+b1*p.y+c1;
-	// if r !=0 the point does not lie on the line
-	if (r!=0) {
-		result=DONT_INTERSECT;
-		return;
-	// Point lies on line-check to see whether it lies in line segment.
-	double dist=rParameter(p1,p2,p);
-	if (dist<0.0 || dist>1.0) {
-		return;
-	isProperVar=true;
-	if (p==p1 || p==p2) {
-	result=DO_INTERSECT;
-int NonRobustLineIntersector::computeIntersect(const Coordinate& p1,const Coordinate& p2,const Coordinate& p3,const Coordinate& p4){
-	double a1;
-	double b1;
-	double c1;
-	double a2;
-	double b2;
-	double c2;
-	double r1;
-	double r2;
-	double r3;
-	double r4;
-	*  'Sign' values
-	//double denom,offset,num;    /* Intermediate values */
-	a1=p2.y-p1.y;
-	b1=p1.x-p2.x;
-	r3=a1*p3.x+b1*p3.y+c1;
-	r4=a1*p4.x+b1*p4.y+c1;
-	*  Check signs of r3 and r4.  If both point 3 and point 4 lie on
-	*  same side of line 1,the line segments do not intersect.
-	if (r3!=0 && r4!=0 && isSameSignAndNonZero(r3,r4)) {
-		return DONT_INTERSECT;
-	*  Compute a2,b2,c2
-	a2=p4.y-p3.y;
-	b2=p3.x-p4.x;
-	c2=p4.x*p3.y-p3.x*p4.y;
-	*  Compute r1 and r2
-	r1=a2*p1.x+b2*p1.y+c2;
-	r2=a2*p2.x+b2*p2.y+c2;
-	*  Check signs of r1 and r2.  If both point 1 and point 2 lie
-	*  on same side of second line segment,the line segments do
-	*  not intersect.
-	if (r1!=0 && r2 !=0 && isSameSignAndNonZero(r1,r2)) {
-	*  Line segments intersect: compute intersection point.
-	double denom=a1*b2-a2*b1;
-	if (denom==0) {
-		return computeCollinearIntersection(p1,p2,p3,p4);
-	double numX=b1*c2-b2*c1;
-	pa.x=numX/denom;
-	*  TESTING ONLY
-	*  double valX=(( num<0 ? num-offset : num+offset ) / denom);
-	*  double valXInt=(int) (( num<0 ? num-offset : num+offset ) / denom);
-	*  if (valXInt !=pa.x)     // TESTING ONLY
-	*  System.out.println(val+"-int: "+valInt+",floor: "+pa.x);
-	double numY=a2*c1-a1*c2;
-	pa.y=numY/denom;
-	// check if this is a proper intersection BEFORE truncating values,
-	// to avoid spurious equality comparisons with endpoints
-	isProperVar=true;
-	if (pa==p1 || pa==p2 || pa==p3 || pa==p4) {
-	// truncate computed point to precision grid
-	// TESTING-don't force coord to be precise
-	if (precisionModel!=NULL) {
-		precisionModel->makePrecise(&pa);
-	return DO_INTERSECT;
-*  p1-p2  and p3-p4 are assumed to be collinear (although
-*  not necessarily intersecting). Returns:
-*  DONT_INTERSECT	: the two segments do not intersect
-*  COLLINEAR		: the segments intersect,in the
-*  line segment pa-pb.  pa-pb is in
-*  the same direction as p1-p2
-*  DO_INTERSECT		: the inputLines intersect in a single point
-*  only,pa
-int NonRobustLineIntersector::computeCollinearIntersection(const Coordinate& p1,const Coordinate& p2,const Coordinate& p3,const Coordinate& p4){
-	double r1;
-	double r2;
-	double r3;
-	double r4;
-	Coordinate q3;
-	Coordinate q4;
-	double t3;
-	double t4;
-	r1=0;
-	r2=1;
-	r3=rParameter(p1,p2,p3);
-	r4=rParameter(p1,p2,p4);
-	// make sure p3-p4 is in same direction as p1-p2
-	if (r3<r4) {
-		q3=p3;
-		t3=r3;
-		q4=p4;
-		t4=r4;
-	} else {
-		q3=p4;
-		t3=r4;
-		q4=p3;
-		t4=r3;
-	// check for no intersection
-	if (t3>r2 || t4<r1) {
-	// check for single point intersection
-	if (q4==p1) {
-		pa.setCoordinate(p1);
-	if (q3==p2) {
-		pa.setCoordinate(p2);
-	// intersection MUST be a segment-compute endpoints
-	if (t3>r1) {
-		pa.setCoordinate(q3);
-	pb.setCoordinate(p2);
-	if (t4<r2) {
-		pb.setCoordinate(q4);
-	return COLLINEAR;
-*  RParameter computes the parameter for the point p
-*  in the parameterized equation
-*  of the line from p1 to p2.  The 'distance' of p along p1-p2
-double NonRobustLineIntersector::rParameter(const Coordinate& p1,const Coordinate& p2,const Coordinate& p) const {
-	double r;
-	// compute maximum delta,for numerical stability
-	// also handle case of p1-p2 being vertical or horizontal
-	double dx=fabs(p2.x-p1.x);
-	double dy=fabs(p2.y-p1.y);
-	if (dx>dy) {
-		r=(p.x-p1.x)/(p2.x-p1.x);
-	} else {
-		r=(p.y-p1.y)/(p2.y-p1.y);
-	return r;
-} // namespace geos.algorithm
Deleted: trunk/source/algorithm/RobustLineIntersector.cpp
--- trunk/source/algorithm/RobustLineIntersector.cpp	2009-12-08 17:42:59 UTC (rev 2812)
+++ trunk/source/algorithm/RobustLineIntersector.cpp	2009-12-08 17:50:03 UTC (rev 2813)
@@ -1,582 +0,0 @@
- * $Id$
-//#define DEBUG 1
-#ifndef COMPUTE_Z
-#define COMPUTE_Z 1
-#endif // COMPUTE_Z
-namespace geos {
-RobustLineIntersector::RobustLineIntersector(){}
-RobustLineIntersector::~RobustLineIntersector(){}
-void
-RobustLineIntersector::computeIntersection(const Coordinate& p,const Coordinate& p1,const Coordinate& p2)
-	// do between check first, since it is faster than the orientation test
-	if(Envelope::intersects(p1,p2,p)) {
-		if ((CGAlgorithms::orientationIndex(p1,p2,p)==0)&&
-			(CGAlgorithms::orientationIndex(p2,p1,p)==0)) {
-			isProperVar=true;
-			if ((p==p1)||(p==p2)) // 2d only test
-#if COMPUTE_Z
-			intPt[0].setCoordinate(p);
-#if DEBUG
-			cerr<<"RobustIntersector::computeIntersection(Coordinate,Coordinate,Coordinate) calling interpolateZ"<<endl;
-#endif
-			double z = interpolateZ(p, p1, p2);
-			if ( !ISNAN(z) )
-				if ( ISNAN(intPt[0].z) )
-					intPt[0].z = z;
-				else
-					intPt[0].z = (intPt[0].z+z)/2;
-			return;
-	result = DONT_INTERSECT;
-int
-RobustLineIntersector::computeIntersect(const Coordinate& p1,const Coordinate& p2,const Coordinate& q1,const Coordinate& q2)
-#if DEBUG
-	cerr<<"RobustLineIntersector::computeIntersect called"<<endl;
-	cerr<<" p1:"<<p1.toString()<<" p2:"<<p2.toString()<<" q1:"<<q1.toString()<<" q2:"<<q2.toString()<<endl;
-#endif // DEBUG
-	// first try a fast test to see if the envelopes of the lines intersect
-	if (!Envelope::intersects(p1,p2,q1,q2))
-#if DEBUG
-		cerr<<" DONT_INTERSECT"<<endl;
-#endif
-	// for each endpoint, compute which side of the other segment it lies
-	// if both endpoints lie on the same side of the other segment,
-	// the segments do not intersect
-	int Pq1=CGAlgorithms::orientationIndex(p1,p2,q1);
-	int Pq2=CGAlgorithms::orientationIndex(p1,p2,q2);
-	if ((Pq1>0 && Pq2>0) || (Pq1<0 && Pq2<0))
-#if DEBUG
-#endif
-	int Qp1=CGAlgorithms::orientationIndex(q1,q2,p1);
-	int Qp2=CGAlgorithms::orientationIndex(q1,q2,p2);
-	if ((Qp1>0 && Qp2>0)||(Qp1<0 && Qp2<0)) {
-#if DEBUG
-#endif
-	bool collinear=Pq1==0 && Pq2==0 && Qp1==0 && Qp2==0;
-	if (collinear) {
-#if DEBUG
-		cerr<<" computingCollinearIntersection"<<endl;
-#endif
-		return computeCollinearIntersection(p1,p2,q1,q2);
-	 * Check if the intersection is an endpoint.
-	 * If it is, copy the endpoint as
-	 * the intersection point. Copying the point rather than
-	 * computing it ensures the point has the exact value,
-	 * which is important for robustness. It is sufficient to
-	 * simply check for an endpoint which is on the other line,
-	 * since at this point we know that the inputLines must
-	 *  intersect.
-	if (Pq1==0 || Pq2==0 || Qp1==0 || Qp2==0) {
-#if COMPUTE_Z
-		int hits=0;
-		double z=0.0;
-#endif
-		if (Pq1==0) {
-			intPt[0].setCoordinate(q1);
-#if COMPUTE_Z
-			if ( !ISNAN(q1.z) )
-				z += q1.z;
-				hits++;
-#endif
-		if (Pq2==0) {
-			intPt[0].setCoordinate(q2);
-#if COMPUTE_Z
-			if ( !ISNAN(q2.z) )
-				z += q2.z;
-				hits++;
-#endif
-		if (Qp1==0) {
-			intPt[0].setCoordinate(p1);
-#if COMPUTE_Z
-			if ( !ISNAN(p1.z) )
-				z += p1.z;
-				hits++;
-#endif
-		if (Qp2==0) {
-			intPt[0].setCoordinate(p2);
-#if COMPUTE_Z
-			if ( !ISNAN(p2.z) )
-				z += p2.z;
-				hits++;
-#endif
-#if COMPUTE_Z
-#if DEBUG
-		cerr<<"RobustLineIntersector::computeIntersect: z:"<<z<<" hits:"<<hits<<endl;
-#endif // DEBUG
-		if ( hits ) intPt[0].z = z/hits;
-	} else {
-		isProperVar=true;
-		Coordinate *c=intersection(p1, p2, q1, q2);
-		intPt[0].setCoordinate(*c);
-		delete c;
-#if DEBUG
-	cerr<<" DO_INTERSECT; intPt[0]:"<<intPt[0].toString()<<endl;
-#endif // DEBUG
-//bool RobustLineIntersector::intersectsEnvelope(Coordinate& p1,Coordinate& p2,Coordinate& q) {
-//	if (((q.x>=min(p1.x,p2.x)) && (q.x<=max(p1.x,p2.x))) &&
-//		((q.y>=min(p1.y,p2.y)) && (q.y<=max(p1.y,p2.y)))) {
-//			return true;
-//	} else {
-//		return false;
-int
-RobustLineIntersector::computeCollinearIntersection(const Coordinate& p1,const Coordinate& p2,const Coordinate& q1,const Coordinate& q2)
-#if COMPUTE_Z
-	double ztot;
-	int hits;
-	double p2z;
-	double p1z;
-	double q1z;
-	double q2z;
-#if DEBUG
-	cerr<<"RobustLineIntersector::computeCollinearIntersection called"<<endl;
-#endif // DEBUG
-	bool p1q1p2=Envelope::intersects(p1,p2,q1);
-	bool p1q2p2=Envelope::intersects(p1,p2,q2);
-	bool q1p1q2=Envelope::intersects(q1,q2,p1);
-	bool q1p2q2=Envelope::intersects(q1,q2,p2);
-	if (p1q1p2 && p1q2p2) {
-#if DEBUG
-		cerr<<" p1q1p2 && p1q2p2"<<endl;
-#endif
-#if COMPUTE_Z
-		ztot=0;
-		hits=0;
-		q1z = interpolateZ(q1, p1, p2);
-		if (!ISNAN(q1z)) { ztot+=q1z; hits++; }
-		if (!ISNAN(q1.z)) { ztot+=q1.z; hits++; }
-		if ( hits ) intPt[0].z = ztot/hits;
-#endif
-		intPt[1].setCoordinate(q2);
-#if COMPUTE_Z
-		ztot=0;
-		hits=0;
-		q2z = interpolateZ(q2, p1, p2);
-		if (!ISNAN(q2z)) { ztot+=q2z; hits++; }
-		if (!ISNAN(q2.z)) { ztot+=q2.z; hits++; }
-		if ( hits ) intPt[1].z = ztot/hits;
-#endif
-#if DEBUG
-		cerr<<" intPt[0]: "<<intPt[0].toString()<<endl;
-		cerr<<" intPt[1]: "<<intPt[1].toString()<<endl;
-#endif
-		return COLLINEAR;
-	if (q1p1q2 && q1p2q2) {
-#if DEBUG
-		cerr<<" q1p1q2 && q1p2q2"<<endl;
-#endif
-#if COMPUTE_Z
-		ztot=0;
-		hits=0;
-		p1z = interpolateZ(p1, q1, q2);
-		if (!ISNAN(p1z)) { ztot+=p1z; hits++; }
-		if (!ISNAN(p1.z)) { ztot+=p1.z; hits++; }
-#endif
-		intPt[1].setCoordinate(p2);
-#if COMPUTE_Z
-		ztot=0;
-		hits=0;
-		p2z = interpolateZ(p2, q1, q2);
-		if (!ISNAN(p2z)) { ztot+=p2z; hits++; }
-		if (!ISNAN(p2.z)) { ztot+=p2.z; hits++; }
-#endif
-		return COLLINEAR;
-	if (p1q1p2 && q1p1q2) {
-#if DEBUG
-		cerr<<" p1q1p2 && q1p1q2"<<endl;
-#endif
-#if COMPUTE_Z
-		ztot=0;
-		hits=0;
-#endif
-		intPt[1].setCoordinate(p1);
-#if COMPUTE_Z
-		ztot=0;
-		hits=0;
-#endif
-#if DEBUG
-#endif
-		return (q1==p1) && !p1q2p2 && !q1p2q2 ? DO_INTERSECT : COLLINEAR;
-	if (p1q1p2 && q1p2q2) {
-#if DEBUG
-		cerr<<" p1q1p2 && q1p2q2"<<endl;
-#endif
-#if COMPUTE_Z
-		ztot=0;
-		hits=0;
-#endif
-#if COMPUTE_Z
-		ztot=0;
-		hits=0;
-#endif
-#if DEBUG
-#endif
-		return (q1==p2) && !p1q2p2 && !q1p1q2 ? DO_INTERSECT : COLLINEAR;
-	if (p1q2p2 && q1p1q2) {
-#if DEBUG
-		cerr<<" p1q2p2 && q1p1q2"<<endl;
-#endif
-#if COMPUTE_Z
-		ztot=0;
-		hits=0;
-#endif
-#if COMPUTE_Z
-		ztot=0;
-		hits=0;
-#endif
-#if DEBUG
-#endif
-		return (q2==p1) && !p1q1p2 && !q1p2q2 ? DO_INTERSECT : COLLINEAR;
-	if (p1q2p2 && q1p2q2) {
-#if DEBUG
-		cerr<<" p1q2p2 && q1p2q2"<<endl;
-#endif
-#if COMPUTE_Z
-		ztot=0;
-		hits=0;
-#endif
-#if COMPUTE_Z
-		ztot=0;
-		hits=0;
-#endif
-#if DEBUG
-#endif
-		return (q2==p2) && !p1q1p2 && !q1p1q2 ? DO_INTERSECT : COLLINEAR;
-Coordinate*
-RobustLineIntersector::intersection(const Coordinate& p1,const Coordinate& p2,const Coordinate& q1,const Coordinate& q2) const
-	Coordinate n1=p1;
-	Coordinate n2=p2;
-	Coordinate n3=q1;
-	Coordinate n4=q2;
-	Coordinate normPt;
-	//normalize(&n1, &n2, &n3, &n4, &normPt);
-	normalizeToEnvCentre(n1, n2, n3, n4, normPt);
-	Coordinate *intPt=NULL;
-#if DEBUG
-	cerr<<"RobustIntersector::intersection(p1,p2,q1,q2) called:"<<endl;
-	cerr<<" p1"<<p1.toString()<<endl;
-	cerr<<" p2"<<p2.toString()<<endl;
-	cerr<<" q1"<<q1.toString()<<endl;
-	cerr<<" q2"<<q2.toString()<<endl;
-	cerr<<" n1"<<n1.toString()<<endl;
-	cerr<<" n2"<<n2.toString()<<endl;
-	cerr<<" n3"<<n3.toString()<<endl;
-	cerr<<" n4"<<n4.toString()<<endl;
-#endif
-	try {
-		intPt=HCoordinate::intersection(n1,n2,n3,n4);
-#if DEBUG
-		cerr<<" HCoordinate found intersection h:"<<h->toString()<<endl;
-#endif
-	} catch (const NotRepresentableException& e) {
-		delete intPt;
-		Assert::shouldNeverReachHere("Coordinate for intersection is not calculable"+e.toString());
-	intPt->x+=normPt.x;
-	intPt->y+=normPt.y;
- * MD - May 4 2005 - This is still a problem.  Here is a failure case:
- * LINESTRING (2089426.5233462777 1180182.3877339689,
- *             2085646.6891757075 1195618.7333999649)
- * LINESTRING (1889281.8148903656 1997547.0560044837,
- *             2259977.3672235999 483675.17050843034)
- * int point = (2097408.2633752143,1144595.8008114607)
-#if DEBUG
-	if (! isInSegmentEnvelopes(intPt))
-		cerr<<"Intersection outside segment envelopes: "<<
-			intPt->toString();
-#endif
-	if (precisionModel!=NULL) precisionModel->makePrecise(intPt);
-#if COMPUTE_Z
-	double ztot = 0;
-	double zvals = 0;
-	double zp = interpolateZ(*intPt, p1, p2);
-	double zq = interpolateZ(*intPt, q1, q2);
-	if ( !ISNAN(zp)) { ztot += zp; zvals++; }
-	if ( !ISNAN(zq)) { ztot += zq; zvals++; }
-	if ( zvals ) intPt->z = ztot/zvals;
-	return intPt;
-void
-RobustLineIntersector::normalize(Coordinate *n1,Coordinate *n2,Coordinate *n3,Coordinate *n4,Coordinate *normPt) const
-	normPt->x=smallestInAbsValue(n1->x,n2->x,n3->x,n4->x);
-	normPt->y=smallestInAbsValue(n1->y,n2->y,n3->y,n4->y);
-	n1->x-=normPt->x;
-	n1->y-=normPt->y;
-	n2->x-=normPt->x;
-	n2->y-=normPt->y;
-	n3->x-=normPt->x;
-	n3->y-=normPt->y;
-	n4->x-=normPt->x;
-	n4->y-=normPt->y;
-#if COMPUTE_Z
-	normPt->z=smallestInAbsValue(n1->z,n2->z,n3->z,n4->z);
-	n1->z-=normPt->z;
-	n2->z-=normPt->z;
-	n3->z-=normPt->z;
-	n4->z-=normPt->z;
-#endif
-double
-RobustLineIntersector::smallestInAbsValue(double x1,double x2,double x3,double x4) const
-	double x=x1;
-	double xabs=fabs(x);
-	if(fabs(x2)<xabs) {
-		x=x2;
-		xabs=fabs(x2);
-	if(fabs(x3)<xabs) {
-		x=x3;
-		xabs=fabs(x3);
-	if(fabs(x4)<xabs) {
-		x=x4;
-	return x;
- * Test whether a point lies in the envelopes of both input segments.
- * A correctly computed intersection point should return <code>true</code>
- * for this test.
- * Since this test is for debugging purposes only, no attempt is
- * made to optimize the envelope test.
- * @return <code>true</code> if the input point lies within both input
- *	segment envelopes
-bool
-RobustLineIntersector::isInSegmentEnvelopes(const Coordinate& intPt)
-	Envelope *env0=new Envelope(*inputLines[0][0], *inputLines[0][1]);
-	Envelope *env1=new Envelope(*inputLines[1][0], *inputLines[1][1]);
-	return env0->contains(intPt) && env1->contains(intPt);
-void
-RobustLineIntersector::normalizeToEnvCentre(Coordinate &n00, Coordinate &n01,
-		Coordinate &n10, Coordinate &n11, Coordinate &normPt) const
-	double minX0 = n00.x < n01.x ? n00.x : n01.x;
-	double minY0 = n00.y < n01.y ? n00.y : n01.y;
-	double maxX0 = n00.x > n01.x ? n00.x : n01.x;
-	double maxY0 = n00.y > n01.y ? n00.y : n01.y;
-	double minX1 = n10.x < n11.x ? n10.x : n11.x;
-	double minY1 = n10.y < n11.y ? n10.y : n11.y;
-	double maxX1 = n10.x > n11.x ? n10.x : n11.x;
-	double maxY1 = n10.y > n11.y ? n10.y : n11.y;
-	double intMinX = minX0 > minX1 ? minX0 : minX1;
-	double intMaxX = maxX0 < maxX1 ? maxX0 : maxX1;
-	double intMinY = minY0 > minY1 ? minY0 : minY1;
-	double intMaxY = maxY0 < maxY1 ? maxY0 : maxY1;
-	double intMidX = (intMinX + intMaxX) / 2.0;
-	double intMidY = (intMinY + intMaxY) / 2.0;
-	normPt.x = intMidX;
-	normPt.y = intMidY;
-	n00.x -= normPt.x;    n00.y -= normPt.y;
-	n01.x -= normPt.x;    n01.y -= normPt.y;
-	n10.x -= normPt.x;    n10.y -= normPt.y;
-	n11.x -= normPt.x;    n11.y -= normPt.y;
-#if COMPUTE_Z
-	double minZ0 = n00.z < n01.z ? n00.z : n01.z;
-	double minZ1 = n10.z < n11.z ? n10.z : n11.z;
-	double maxZ0 = n00.z > n01.z ? n00.z : n01.z;
-	double maxZ1 = n10.z > n11.z ? n10.z : n11.z;
-	double intMinZ = minZ0 > minZ1 ? minZ0 : minZ1;
-	double intMaxZ = maxZ0 < maxZ1 ? maxZ0 : maxZ1;
-	double intMidZ = (intMinZ + intMaxZ) / 2.0;
-	normPt.z = intMidZ;
-	n00.z -= normPt.z;
-	n01.z -= normPt.z;
-	n10.z -= normPt.z;
-	n11.z -= normPt.z;
-#endif
- * $Log$
- * Revision 1.36  2006/03/21 11:12:23  strk
- * Revision 1.35  2006/02/19 19:46:49  strk
More information about the geos-commits mailing list
