[geos-commits] r2822 - trunk/source/geom/prep
svn_geos at osgeo.org svn_geos at osgeo.org
Fri Dec 11 08:10:32 EST 2009
Author: strk
Date: 2009-12-11 08:10:32 -0500 (Fri, 11 Dec 2009)
New Revision: 2822
   trunk/source/geom/prep/BasicPreparedGeometry.cpp
Fix memory leak in BasicPreparedGeometry::isAnyTargetComponentInTest (issue #308) and drop Coordinate copies from it.
Modified: trunk/source/geom/prep/BasicPreparedGeometry.cpp
--- trunk/source/geom/prep/BasicPreparedGeometry.cpp	2009-12-09 11:10:54 UTC (rev 2821)
+++ trunk/source/geom/prep/BasicPreparedGeometry.cpp	2009-12-11 13:10:32 UTC (rev 2822)
@@ -66,12 +66,12 @@
 bool
 BasicPreparedGeometry::isAnyTargetComponentInTest( const geom::Geometry * testGeom) const
-	algorithm::PointLocator *locator = new algorithm::PointLocator();
+	algorithm::PointLocator locator;
 	for (size_t i=0, n=representativePts.size(); i<n; i++)
-		geom::Coordinate c = *(representativePts[i]);
-		if ( locator->intersects( c, testGeom) )
+		const geom::Coordinate& c = *(representativePts[i]);
+		if ( locator.intersects( c, testGeom) )
 		return true;
 	return false;
More information about the geos-commits mailing list
