[geos-commits] r2238 - trunk/capi
svn_geos at osgeo.org
Wed Jan 14 15:25:04 EST 2009
Author: pramsey
Date: 2009-01-14 15:25:04 -0500 (Wed, 14 Jan 2009)
New Revision: 2238
trunk/capi/geos_ts_c.cpp
Remove strdup use from code for compilation in mingw
Modified: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp 2009-01-13 20:59:17 UTC (rev 2237)
+++ trunk/capi/geos_ts_c.cpp 2009-01-14 20:25:04 UTC (rev 2238)
@@ -570,6 +570,8 @@
IsValidOp ivo(g1);
try {
char *result = NULL;
+ char *validstr = "Valid Geometry";
+ int validstrlen = std::strlen(validstr) + 1;
bool isvalid = ivo.isValid();
if ( ! isvalid )
@@ -584,7 +586,8 @@
sprintf(result, "%s [%s]", errmsg.c_str(), errloc.c_str());
else {
- result = strdup( "Valid Geometry" );
+ result = (char*)std::malloc(validstrlen);
+ std::memcpy(result, validstr, validstrlen);
return result;
More information about the geos-commits
