[geos-commits] r2544 - in trunk/source: geomgraph
headers/geos/geomgraph
svn_geos at osgeo.org
Fri Jun 5 07:03:53 EDT 2009
Author: strk
Date: 2009-06-05 07:03:53 -0400 (Fri, 05 Jun 2009)
New Revision: 2544
trunk/source/geomgraph/Depth.cpp
trunk/source/geomgraph/GeometryGraph.cpp
trunk/source/geomgraph/GraphComponent.cpp
trunk/source/geomgraph/NodeMap.cpp
trunk/source/geomgraph/PlanarGraph.cpp
trunk/source/headers/geos/geomgraph/Depth.h
trunk/source/headers/geos/geomgraph/EdgeEnd.h
trunk/source/headers/geos/geomgraph/EdgeEndStar.h
trunk/source/headers/geos/geomgraph/EdgeList.h
trunk/source/headers/geos/geomgraph/GeometryGraph.h
trunk/source/headers/geos/geomgraph/GeometryGraph.inl
trunk/source/headers/geos/geomgraph/GraphComponent.h
trunk/source/headers/geos/geomgraph/Node.h
trunk/source/headers/geos/geomgraph/NodeMap.h
trunk/source/headers/geos/geomgraph/PlanarGraph.h
Port info in the geomgraph package (unfinished); fix compiler warning in GeometryGraph and make code more readable;
Modified: trunk/source/geomgraph/Depth.cpp
--- trunk/source/geomgraph/Depth.cpp 2009-06-05 10:23:23 UTC (rev 2543)
+++ trunk/source/geomgraph/Depth.cpp 2009-06-05 11:03:53 UTC (rev 2544)
@@ -12,6 +12,10 @@
* by the Free Software Foundation.
* See the COPYING file for more information.
+ * Last port: geomgraph/Depth.java rev. 1.4 (JTS-1.10)
#include <sstream>
@@ -22,7 +26,7 @@
#include <geos/geomgraph/Position.h>
#include <geos/geom/Location.h>
-#define DEPTHNULL -1
+#define NULL_VALUE -1
using namespace std;
using namespace geos::geom;
@@ -35,7 +39,7 @@
if (location == Location::EXTERIOR) return 0;
if (location == Location::INTERIOR) return 1;
- return DEPTHNULL;
+ return NULL_VALUE;
Depth::Depth()
@@ -43,7 +47,7 @@
// initialize depth array to a sentinel value
for (int i=0; i<2; i++) {
for (int j=0; j<3;j++) {
- depth[i][j]=DEPTHNULL;
+ depth[i][j]=NULL_VALUE;
@@ -87,7 +91,7 @@
for (int j=0; j<3; j++) {
- if (depth[i][j] != DEPTHNULL)
+ if (depth[i][j] != NULL_VALUE)
return false;
@@ -97,13 +101,13 @@
bool
Depth::isNull(int geomIndex) const
- return depth[geomIndex][1] == DEPTHNULL;
+ return depth[geomIndex][1] == NULL_VALUE;
bool
Depth::isNull(int geomIndex, int posIndex) const
- return depth[geomIndex][posIndex] == DEPTHNULL;
+ return depth[geomIndex][posIndex] == NULL_VALUE;
int
Modified: trunk/source/geomgraph/GeometryGraph.cpp
--- trunk/source/geomgraph/GeometryGraph.cpp 2009-06-05 10:23:23 UTC (rev 2543)
+++ trunk/source/geomgraph/GeometryGraph.cpp 2009-06-05 11:03:53 UTC (rev 2544)
@@ -12,6 +12,10 @@
+ * Last port: geomgraph/GeometryGraph.java rev. 1.5 (JTS-1.7)
#include <geos/algorithm/CGAlgorithms.h>
@@ -167,30 +171,35 @@
//throw (UnsupportedOperationException *)
if (g->isEmpty()) return;
// check if this Geometry should obey the Boundary Determination Rule
// all collections except MultiPolygons obey the rule
- // FIXME - mloskot: Make this condition readable and use paranthesis
- if ((typeid(*g)==typeid(GeometryCollection)) ||
- (typeid(*g)==typeid(MultiPoint)) ||
- (typeid(*g)==typeid(MultiLineString)) &&
- !(typeid(*g)==typeid(MultiPolygon)))
- useBoundaryDeterminationRule=true;
- if (typeid(*g)==typeid(Polygon))
+ if ( dynamic_cast<const MultiPolygon*>(g) )
+ useBoundaryDeterminationRule = false;
+ if ( dynamic_cast<const Polygon*>(g) )
addPolygon((Polygon*) g);
- else if (typeid(*g)==typeid(LineString))
+ // LineString also handles LinearRings
+ else if ( dynamic_cast<const LineString*>(g) )
addLineString((LineString*) g);
- else if (typeid(*g)==typeid(LinearRing))
- addLineString((LineString*) g);
- else if (typeid(*g)==typeid(Point))
+ else if ( dynamic_cast<const Point*>(g) )
addPoint((Point*) g);
- else if (typeid(*g)==typeid(MultiPoint))
+ else if ( dynamic_cast<const MultiPoint*>(g) )
addCollection((MultiPoint*) g);
- else if (typeid(*g)==typeid(MultiLineString))
+ else if ( dynamic_cast<const MultiLineString*>(g) )
addCollection((MultiLineString*) g);
- else if (typeid(*g)==typeid(MultiPolygon))
+ else if ( dynamic_cast<const MultiPolygon*>(g) )
addCollection((MultiPolygon*) g);
- else if (typeid(*g)==typeid(GeometryCollection))
+ else if ( dynamic_cast<const GeometryCollection*>(g) )
addCollection((GeometryCollection*) g);
else {
string out=typeid(*g).name();
throw util::UnsupportedOperationException("GeometryGraph::add(Geometry *): unknown geometry type: "+out);
Modified: trunk/source/geomgraph/GraphComponent.cpp
--- trunk/source/geomgraph/GraphComponent.cpp 2009-06-05 10:23:23 UTC (rev 2543)
+++ trunk/source/geomgraph/GraphComponent.cpp 2009-06-05 11:03:53 UTC (rev 2544)
@@ -12,6 +12,10 @@
+ * Last port: geomgraph/GraphComponent.java rev. 1.3 (JTS-1.10)
#include <cassert>
Modified: trunk/source/geomgraph/NodeMap.cpp
--- trunk/source/geomgraph/NodeMap.cpp 2009-06-05 10:23:23 UTC (rev 2543)
+++ trunk/source/geomgraph/NodeMap.cpp 2009-06-05 11:03:53 UTC (rev 2544)
@@ -12,6 +12,10 @@
+ * Last port: geomgraph/NodeMap.java rev. 1.3 (JTS-1.10)
#include <geos/geomgraph/NodeMap.h>
Modified: trunk/source/geomgraph/PlanarGraph.cpp
--- trunk/source/geomgraph/PlanarGraph.cpp 2009-06-05 10:23:23 UTC (rev 2543)
+++ trunk/source/geomgraph/PlanarGraph.cpp 2009-06-05 11:03:53 UTC (rev 2544)
@@ -14,7 +14,7 @@
- * Last port: geomgraph/PlanarGraph.java rev. 1.4 (JTS-1.7)
+ * Last port: geomgraph/PlanarGraph.java rev. 1.6 (JTS-1.10)
Modified: trunk/source/headers/geos/geomgraph/Depth.h
--- trunk/source/headers/geos/geomgraph/Depth.h 2009-06-05 10:23:23 UTC (rev 2543)
+++ trunk/source/headers/geos/geomgraph/Depth.h 2009-06-05 11:03:53 UTC (rev 2544)
@@ -12,6 +12,12 @@
+ * NON-EXPOSED GEOS HEADER
@@ -50,9 +56,8 @@
std::string toString() const;
private:
enum {
- DEPTHNULL=-1 //Replaces NULL
+ NULL_VALUE=-1 //Replaces NULL
-// static const int DEPTHNULL=-1; //Replaces NULL
int depth[2][3];
Modified: trunk/source/headers/geos/geomgraph/EdgeEnd.h
--- trunk/source/headers/geos/geomgraph/EdgeEnd.h 2009-06-05 10:23:23 UTC (rev 2543)
+++ trunk/source/headers/geos/geomgraph/EdgeEnd.h 2009-06-05 11:03:53 UTC (rev 2544)
@@ -16,6 +16,8 @@
* Last port: geomgraph/EdgeEnd.java rev. 1.5 (JTS-1.7)
+ * EXPOSED GEOS HEADER
Modified: trunk/source/headers/geos/geomgraph/EdgeEndStar.h
--- trunk/source/headers/geos/geomgraph/EdgeEndStar.h 2009-06-05 10:23:23 UTC (rev 2543)
+++ trunk/source/headers/geos/geomgraph/EdgeEndStar.h 2009-06-05 11:03:53 UTC (rev 2544)
@@ -16,6 +16,8 @@
* Last port: geomgraph/EdgeEndStar.java rev. 1.4 (JTS-1.7)
Modified: trunk/source/headers/geos/geomgraph/EdgeList.h
--- trunk/source/headers/geos/geomgraph/EdgeList.h 2009-06-05 10:23:23 UTC (rev 2543)
+++ trunk/source/headers/geos/geomgraph/EdgeList.h 2009-06-05 11:03:53 UTC (rev 2544)
@@ -14,8 +14,10 @@
- * Last port: geomgraph/EdgeList.java rev. 1.4 (JTS-1.9)
+ * Last port: geomgraph/EdgeList.java rev. 1.4 (JTS-1.10)
Modified: trunk/source/headers/geos/geomgraph/GeometryGraph.h
--- trunk/source/headers/geos/geomgraph/GeometryGraph.h 2009-06-05 10:23:23 UTC (rev 2543)
+++ trunk/source/headers/geos/geomgraph/GeometryGraph.h 2009-06-05 11:03:53 UTC (rev 2544)
@@ -12,6 +12,12 @@
Modified: trunk/source/headers/geos/geomgraph/GeometryGraph.inl
--- trunk/source/headers/geos/geomgraph/GeometryGraph.inl 2009-06-05 10:23:23 UTC (rev 2543)
+++ trunk/source/headers/geos/geomgraph/GeometryGraph.inl 2009-06-05 11:03:53 UTC (rev 2544)
@@ -11,6 +11,12 @@
#ifndef GEOS_GEOMGRAPH_GEOMETRYGRAPH_INL
@@ -52,7 +58,7 @@
PlanarGraph(),
parentGeom(newParentGeom),
- useBoundaryDeterminationRule(false),
+ useBoundaryDeterminationRule(true),
argIndex(newArgIndex),
hasTooFewPointsVar(false)
@@ -64,7 +70,7 @@
PlanarGraph(),
parentGeom(NULL),
argIndex(-1),
Modified: trunk/source/headers/geos/geomgraph/GraphComponent.h
--- trunk/source/headers/geos/geomgraph/GraphComponent.h 2009-06-05 10:23:23 UTC (rev 2543)
+++ trunk/source/headers/geos/geomgraph/GraphComponent.h 2009-06-05 11:03:53 UTC (rev 2544)
@@ -12,6 +12,12 @@
Modified: trunk/source/headers/geos/geomgraph/Node.h
--- trunk/source/headers/geos/geomgraph/Node.h 2009-06-05 10:23:23 UTC (rev 2543)
+++ trunk/source/headers/geos/geomgraph/Node.h 2009-06-05 11:03:53 UTC (rev 2544)
@@ -16,6 +16,8 @@
* Last port: geomgraph/Node.java rev. 1.6 (JTS-1.7)
Modified: trunk/source/headers/geos/geomgraph/NodeMap.h
--- trunk/source/headers/geos/geomgraph/NodeMap.h 2009-06-05 10:23:23 UTC (rev 2543)
+++ trunk/source/headers/geos/geomgraph/NodeMap.h 2009-06-05 11:03:53 UTC (rev 2544)
@@ -12,6 +12,12 @@
Modified: trunk/source/headers/geos/geomgraph/PlanarGraph.h
--- trunk/source/headers/geos/geomgraph/PlanarGraph.h 2009-06-05 10:23:23 UTC (rev 2543)
+++ trunk/source/headers/geos/geomgraph/PlanarGraph.h 2009-06-05 11:03:53 UTC (rev 2544)
@@ -14,8 +14,10 @@
More information about the geos-commits
