[geos-commits] r2546 - in trunk/source: geomgraph
headers/geos/geomgraph
svn_geos at osgeo.org
Fri Jun 5 08:42:14 EDT 2009
Author: strk
Date: 2009-06-05 08:42:14 -0400 (Fri, 05 Jun 2009)
New Revision: 2546
trunk/source/geomgraph/GeometryGraph.cpp
trunk/source/headers/geos/geomgraph/GeometryGraph.h
trunk/source/headers/geos/geomgraph/GeometryGraph.inl
Add support for custom BoundaryNodeRule bringing GeometryGraph to JTS-1.10
Modified: trunk/source/geomgraph/GeometryGraph.cpp
--- trunk/source/geomgraph/GeometryGraph.cpp 2009-06-05 12:07:52 UTC (rev 2545)
+++ trunk/source/geomgraph/GeometryGraph.cpp 2009-06-05 12:42:14 UTC (rev 2546)
@@ -14,11 +14,12 @@
- * Last port: geomgraph/GeometryGraph.java rev. 1.5 (JTS-1.7)
+ * Last port: geomgraph/GeometryGraph.java rev. 1.9 (JTS-1.10)
#include <geos/algorithm/CGAlgorithms.h>
+#include <geos/algorithm/BoundaryNodeRule.h>
#include <geos/util/UnsupportedOperationException.h>
@@ -435,7 +436,7 @@
// determine the boundary status of the point according to the
// Boundary Determination Rule
- int newLoc=determineBoundary(boundaryCount);
+ int newLoc = determineBoundary(boundaryNodeRule, boundaryCount);
lbl->setLocation(argIndex,newLoc);
@@ -494,6 +495,55 @@
return invalidPoint;
+GeometryGraph::GeometryGraph(int newArgIndex,
+ const geom::Geometry *newParentGeom)
+ PlanarGraph(),
+ parentGeom(newParentGeom),
+ useBoundaryDeterminationRule(true),
+ boundaryNodeRule(algorithm::BoundaryNodeRule::OGC_SFS_BOUNDARY_RULE),
+ argIndex(newArgIndex),
+ hasTooFewPointsVar(false)
+ if (parentGeom!=NULL) add(parentGeom);
+ const geom::Geometry *newParentGeom,
+ const algorithm::BoundaryNodeRule& bnr)
+ PlanarGraph(),
+ boundaryNodeRule(bnr),
+GeometryGraph::GeometryGraph()
+ PlanarGraph(),
+ parentGeom(NULL),
+ argIndex(-1),
+/* public static */
+int
+GeometryGraph::determineBoundary(
+ const algorithm::BoundaryNodeRule& boundaryNodeRule,
+ int boundaryCount)
+ return boundaryNodeRule.isInBoundary(boundaryCount)
+ ? Location::BOUNDARY : Location::INTERIOR;
} // namespace geos.geomgraph
} // namespace geos
Modified: trunk/source/headers/geos/geomgraph/GeometryGraph.h
--- trunk/source/headers/geos/geomgraph/GeometryGraph.h 2009-06-05 12:07:52 UTC (rev 2545)
+++ trunk/source/headers/geos/geomgraph/GeometryGraph.h 2009-06-05 12:42:14 UTC (rev 2546)
@@ -14,7 +14,7 @@
* EXPOSED GEOS HEADER
@@ -47,6 +47,7 @@
namespace algorithm {
class LineIntersector;
+ class BoundaryNodeRule;
namespace geomgraph {
class Edge;
@@ -61,7 +62,9 @@
namespace geos {
namespace geomgraph { // geos.geomgraph
-class GeometryGraph: public PlanarGraph {
+class GeometryGraph: public PlanarGraph
using PlanarGraph::add;
using PlanarGraph::findEdge;
@@ -86,6 +89,8 @@
bool useBoundaryDeterminationRule;
+ const algorithm::BoundaryNodeRule& boundaryNodeRule;
* the index of this geometry as an argument to a spatial function
* (used for labelling)
@@ -123,6 +128,13 @@
void insertPoint(int argIndex, const geom::Coordinate& coord,
int onLocation);
+ /** \brief
+ * Adds candidate boundary points using the current
+ * algorithm::BoundaryNodeRule.
+ * This is used to add the boundary
+ * points of dim-1 geometries (Curves/MultiCurves).
void insertBoundaryPoint(int argIndex, const geom::Coordinate& coord);
void addSelfIntersectionNodes(int argIndex);
@@ -143,10 +155,17 @@
static int determineBoundary(int boundaryCount);
+ static int determineBoundary(
+ int boundaryCount);
GeometryGraph();
GeometryGraph(int newArgIndex, const geom::Geometry *newParentGeom);
+ GeometryGraph(int newArgIndex, const geom::Geometry *newParentGeom,
+ const algorithm::BoundaryNodeRule& boundaryNodeRule);
virtual ~GeometryGraph();
@@ -202,6 +221,9 @@
const geom::Coordinate& getInvalidPoint();
+ const algorithm::BoundaryNodeRule& getBoundaryNodeRule() const
+ { return boundaryNodeRule; }
Modified: trunk/source/headers/geos/geomgraph/GeometryGraph.inl
--- trunk/source/headers/geos/geomgraph/GeometryGraph.inl 2009-06-05 12:07:52 UTC (rev 2545)
+++ trunk/source/headers/geos/geomgraph/GeometryGraph.inl 2009-06-05 12:42:14 UTC (rev 2546)
@@ -13,7 +13,7 @@
@@ -52,30 +52,6 @@
-INLINE
-GeometryGraph::GeometryGraph(int newArgIndex,
- const geom::Geometry *newParentGeom)
- PlanarGraph(),
- parentGeom(newParentGeom),
- useBoundaryDeterminationRule(true),
- argIndex(newArgIndex),
- hasTooFewPointsVar(false)
- if (parentGeom!=NULL) add(parentGeom);
-INLINE
-GeometryGraph::GeometryGraph()
- PlanarGraph(),
- parentGeom(NULL),
- argIndex(-1),
} // namespace geos::geomgraph
} // namespace geos
More information about the geos-commits
