[geos-commits] r2566 - in trunk/source: headers/geos/operation/overlay/validate operation/overlay/validate
svn_geos at osgeo.org svn_geos at osgeo.org
Mon Jun 8 12:46:33 EDT 2009
Author: strk
Date: 2009-06-08 12:46:33 -0400 (Mon, 08 Jun 2009)
New Revision: 2566
   trunk/source/headers/geos/operation/overlay/validate/FuzzyPointLocator.h
   trunk/source/headers/geos/operation/overlay/validate/OffsetPointGenerator.h
   trunk/source/headers/geos/operation/overlay/validate/OverlayResultValidator.h
   trunk/source/operation/overlay/validate/FuzzyPointLocator.cpp
   trunk/source/operation/overlay/validate/OffsetPointGenerator.cpp
   trunk/source/operation/overlay/validate/OverlayResultValidator.cpp
Port info and sync for operation::overlay::validate
Modified: trunk/source/headers/geos/operation/overlay/validate/FuzzyPointLocator.h
--- trunk/source/headers/geos/operation/overlay/validate/FuzzyPointLocator.h	2009-06-08 16:26:36 UTC (rev 2565)
+++ trunk/source/headers/geos/operation/overlay/validate/FuzzyPointLocator.h	2009-06-08 16:46:33 UTC (rev 2566)
@@ -13,8 +13,7 @@
- * Last port: operation/overlay/validate/FuzzyPointLocator.java rev. 1.1
- * (we should move in GEOS too, probably)
+ * Last port: operation/overlay/validate/FuzzyPointLocator.java rev. 1.1 (JTS-1.10)
Modified: trunk/source/headers/geos/operation/overlay/validate/OffsetPointGenerator.h
--- trunk/source/headers/geos/operation/overlay/validate/OffsetPointGenerator.h	2009-06-08 16:26:36 UTC (rev 2565)
+++ trunk/source/headers/geos/operation/overlay/validate/OffsetPointGenerator.h	2009-06-08 16:46:33 UTC (rev 2566)
@@ -13,7 +13,7 @@
- * Last port: operation/overlay/validate/OffsetPointGenerator.java rev. 1.1
+ * Last port: operation/overlay/validate/OffsetPointGenerator.java rev. 1.1 (JTS-1.10)
Modified: trunk/source/headers/geos/operation/overlay/validate/OverlayResultValidator.h
--- trunk/source/headers/geos/operation/overlay/validate/OverlayResultValidator.h	2009-06-08 16:26:36 UTC (rev 2565)
+++ trunk/source/headers/geos/operation/overlay/validate/OverlayResultValidator.h	2009-06-08 16:46:33 UTC (rev 2566)
@@ -13,7 +13,7 @@
- * Last port: operation/overlay/validate/OverlayResultValidator.java rev. 1.1
+ * Last port: operation/overlay/validate/OverlayResultValidator.java rev. 1.4 (JTS-1.10)
@@ -41,15 +41,19 @@
 /** \brief
  * Validates that the result of an overlay operation is
- * geometrically correct within a given tolerance.
+ * geometrically correct within a determined tolerance.
- * Uses fuzzy point location, which only works with polygonal
- * components of geometries.
+ * Uses fuzzy point location to find points which are
+ * definitely in either the interior or exterior of the result
+ * geometry, and compares these results with the expected ones.
- * This is a heuristic test, and may return incorrect results.
+ * This algorithm is only useful where the inputs are polygonal.
+ * This is a heuristic test, and may return false positive results
+ * (I.e. it may fail to detect an invalid result.)
  * It should never return a false negative result, however
- * (I.e. reporting a valid result as invalid.)
+ * (I.e. it should never report a valid result as invalid.)
  * @see OverlayOp
 class OverlayResultValidator {
@@ -75,6 +79,8 @@
 private:
+	double boundaryDistanceTolerance;
 	const geom::Geometry& g0;
 	const geom::Geometry& g1;
@@ -89,8 +95,6 @@
 	geom::Coordinate invalidLocation;
-	static double _TOLERANCE; // 0.000001
 	std::vector<geom::Coordinate> testCoords;
 	void addTestPts(const geom::Geometry& g);
@@ -103,6 +107,10 @@
 	bool isValidResult(OverlayOp::OpCode overlayOp,
 			std::vector<geom::Location::Value>& location);
+	static double computeBoundaryDistanceTolerance(
+		const geom::Geometry& g0, const geom::Geometry& g1);
 } // namespace geos::operation::overlay::validate
Modified: trunk/source/operation/overlay/validate/FuzzyPointLocator.cpp
--- trunk/source/operation/overlay/validate/FuzzyPointLocator.cpp	2009-06-08 16:26:36 UTC (rev 2565)
+++ trunk/source/operation/overlay/validate/FuzzyPointLocator.cpp	2009-06-08 16:46:33 UTC (rev 2566)
@@ -13,7 +13,7 @@
Modified: trunk/source/operation/overlay/validate/OffsetPointGenerator.cpp
--- trunk/source/operation/overlay/validate/OffsetPointGenerator.cpp	2009-06-08 16:26:36 UTC (rev 2565)
+++ trunk/source/operation/overlay/validate/OffsetPointGenerator.cpp	2009-06-08 16:46:33 UTC (rev 2566)
@@ -13,7 +13,7 @@
Modified: trunk/source/operation/overlay/validate/OverlayResultValidator.cpp
--- trunk/source/operation/overlay/validate/OverlayResultValidator.cpp	2009-06-08 16:26:36 UTC (rev 2565)
+++ trunk/source/operation/overlay/validate/OverlayResultValidator.cpp	2009-06-08 16:46:33 UTC (rev 2566)
@@ -13,13 +13,14 @@
 #include <geos/operation/overlay/validate/OverlayResultValidator.h>
 #include <geos/operation/overlay/validate/FuzzyPointLocator.h>
 #include <geos/operation/overlay/validate/OffsetPointGenerator.h>
+#include <geos/operation/overlay/snap/GeometrySnapper.h>
 #include <geos/geom/CoordinateSequence.h>
 #include <geos/geom/MultiPoint.h>
 #include <geos/geom/GeometryFactory.h>
@@ -29,7 +30,7 @@
 #include <functional>
 #include <vector>
 #include <memory> // for auto_ptr
-#include <algorithm>
+#include <algorithm> // for std::min etc.
 #ifndef GEOS_DEBUG
 #define GEOS_DEBUG 0
@@ -53,8 +54,6 @@
 namespace overlay { // geos.operation.overlay
 namespace validate { // geos.operation.overlay.validate
-double OverlayResultValidator::_TOLERANCE = 0.000001;
 namespace { // anonymous namespace
 bool
@@ -103,12 +102,15 @@
 		const Geometry& geom1,
 		const Geometry& result)
+	boundaryDistanceTolerance(
+		computeBoundaryDistanceTolerance(geom0, geom1)
 	g0(geom0),
 	g1(geom1),
 	gres(result),
-	fpl0(g0, _TOLERANCE),
-	fpl1(g1, _TOLERANCE),
-	fplres(gres, _TOLERANCE),
+	fpl0(g0, boundaryDistanceTolerance),
+	fpl1(g1, boundaryDistanceTolerance),
+	fplres(gres, boundaryDistanceTolerance),
 	invalidLocation()
@@ -151,7 +153,7 @@
 void
 OverlayResultValidator::addTestPts(const Geometry& g)
-	OffsetPointGenerator ptGen(g, 5 * _TOLERANCE);
+	OffsetPointGenerator ptGen(g, 5 * boundaryDistanceTolerance);
 	auto_ptr< vector<geom::Coordinate> > pts = ptGen.getPoints();
 	testCoords.insert(testCoords.end(), pts->begin(), pts->end());
@@ -230,7 +232,17 @@
 	return isValid;
+/*private static*/
+double
+OverlayResultValidator::computeBoundaryDistanceTolerance(
+	using geos::operation::overlay::snap::GeometrySnapper;
+	return std::min(GeometrySnapper::computeSizeBasedSnapTolerance(g0),
+                        GeometrySnapper::computeSizeBasedSnapTolerance(g1));
 } // namespace geos.operation.overlay.validate
More information about the geos-commits mailing list
