[geos-commits] r2570 - in trunk/source: headers/geos/operation/predicate operation/predicate
svn_geos at osgeo.org svn_geos at osgeo.org
Mon Jun 8 13:15:46 EDT 2009
Author: strk
Date: 2009-06-08 13:15:46 -0400 (Mon, 08 Jun 2009)
New Revision: 2570
   trunk/source/headers/geos/operation/predicate/RectangleIntersects.h
   trunk/source/headers/geos/operation/predicate/SegmentIntersectionTester.h
   trunk/source/operation/predicate/RectangleIntersects.cpp
   trunk/source/operation/predicate/SegmentIntersectionTester.cpp
Sync to JTS-1.10 (port info in SegmentIntersectionTester was wrong, btw)
Modified: trunk/source/headers/geos/operation/predicate/RectangleIntersects.h
--- trunk/source/headers/geos/operation/predicate/RectangleIntersects.h	2009-06-08 17:12:04 UTC (rev 2569)
+++ trunk/source/headers/geos/operation/predicate/RectangleIntersects.h	2009-06-08 17:15:46 UTC (rev 2570)
@@ -13,7 +13,7 @@
- * Last port: operation/predicate/RectangleIntersects.java rev 1.3 (JTS-1.7)
+ * Last port: operation/predicate/RectangleIntersects.java rev 1.4 (JTS-1.10)
Modified: trunk/source/headers/geos/operation/predicate/SegmentIntersectionTester.h
--- trunk/source/headers/geos/operation/predicate/SegmentIntersectionTester.h	2009-06-08 17:12:04 UTC (rev 2569)
+++ trunk/source/headers/geos/operation/predicate/SegmentIntersectionTester.h	2009-06-08 17:15:46 UTC (rev 2570)
@@ -13,7 +13,7 @@
- * Last port: operation/predicate/SegmentIntersectionTester.java rev. 1.6 (JTS-1.7)
+ * Last port: operation/predicate/SegmentIntersectionTester.java rev. 1.3 (JTS-1.10)
@@ -38,7 +38,7 @@
 /** \brief
  * Tests if any line segments in two sets of CoordinateSequences intersect.
- * Optimized for small geometry size.
+ * Optimized for use when at least one input is of small size.
  * Short-circuited to return as soon an intersection is found.
Modified: trunk/source/operation/predicate/RectangleIntersects.cpp
--- trunk/source/operation/predicate/RectangleIntersects.cpp	2009-06-08 17:12:04 UTC (rev 2569)
+++ trunk/source/operation/predicate/RectangleIntersects.cpp	2009-06-08 17:15:46 UTC (rev 2570)
@@ -13,7 +13,7 @@
Modified: trunk/source/operation/predicate/SegmentIntersectionTester.cpp
--- trunk/source/operation/predicate/SegmentIntersectionTester.cpp	2009-06-08 17:12:04 UTC (rev 2569)
+++ trunk/source/operation/predicate/SegmentIntersectionTester.cpp	2009-06-08 17:15:46 UTC (rev 2570)
@@ -13,7 +13,7 @@
More information about the geos-commits mailing list
