[geos-commits] r2572 - in trunk/source: headers/geos/operation/valid operation/valid
svn_geos at osgeo.org svn_geos at osgeo.org
Mon Jun 8 18:10:55 EDT 2009
Author: strk
Date: 2009-06-08 18:10:55 -0400 (Mon, 08 Jun 2009)
New Revision: 2572
   trunk/source/headers/geos/operation/valid/ConnectedInteriorTester.h
   trunk/source/headers/geos/operation/valid/IsValidOp.h
   trunk/source/headers/geos/operation/valid/QuadtreeNestedRingTester.h
   trunk/source/headers/geos/operation/valid/RepeatedPointTester.h
   trunk/source/headers/geos/operation/valid/SimpleNestedRingTester.h
   trunk/source/headers/geos/operation/valid/SweeplineNestedRingTester.h
   trunk/source/headers/geos/operation/valid/TopologyValidationError.h
   trunk/source/operation/valid/ConnectedInteriorTester.cpp
   trunk/source/operation/valid/IndexedNestedRingTester.cpp
   trunk/source/operation/valid/IndexedNestedRingTester.h
   trunk/source/operation/valid/IsValidOp.cpp
   trunk/source/operation/valid/QuadtreeNestedRingTester.cpp
   trunk/source/operation/valid/RepeatedPointTester.cpp
   trunk/source/operation/valid/SimpleNestedRingTester.cpp
   trunk/source/operation/valid/SweeplineNestedRingTester.cpp
   trunk/source/operation/valid/TopologyValidationError.cpp
JTS-1.10 port sync. The whole 'operation' namespace is complete on this.
Modified: trunk/source/headers/geos/operation/valid/ConnectedInteriorTester.h
--- trunk/source/headers/geos/operation/valid/ConnectedInteriorTester.h	2009-06-08 21:53:35 UTC (rev 2571)
+++ trunk/source/headers/geos/operation/valid/ConnectedInteriorTester.h	2009-06-08 22:10:55 UTC (rev 2572)
@@ -12,6 +12,10 @@
  * by the Free Software Foundation.
  * See the COPYING file for more information.
+ * Last port: operation/valid/ConnectedInteriorTester.java rev. 1.15 (JTS-1.10)
 #ifndef GEOS_OP_CONNECTEDINTERIORTESTER_H
Modified: trunk/source/headers/geos/operation/valid/IsValidOp.h
--- trunk/source/headers/geos/operation/valid/IsValidOp.h	2009-06-08 21:53:35 UTC (rev 2571)
+++ trunk/source/headers/geos/operation/valid/IsValidOp.h	2009-06-08 22:10:55 UTC (rev 2572)
@@ -14,7 +14,7 @@
- * Last port: operation/valid/IsValidOp.java rev. 1.41 (JTS-1.9)
+ * Last port: operation/valid/IsValidOp.java rev. 1.41 (JTS-1.10)
Modified: trunk/source/headers/geos/operation/valid/QuadtreeNestedRingTester.h
--- trunk/source/headers/geos/operation/valid/QuadtreeNestedRingTester.h	2009-06-08 21:53:35 UTC (rev 2571)
+++ trunk/source/headers/geos/operation/valid/QuadtreeNestedRingTester.h	2009-06-08 22:10:55 UTC (rev 2572)
@@ -12,6 +12,10 @@
+ * Last port: operation/valid/QuadtreeNestedRingTester.java rev. 1.12 (JTS-1.10)
 #ifndef GEOS_OP_QUADTREENESTEDRINGTESTER_H
Modified: trunk/source/headers/geos/operation/valid/RepeatedPointTester.h
--- trunk/source/headers/geos/operation/valid/RepeatedPointTester.h	2009-06-08 21:53:35 UTC (rev 2571)
+++ trunk/source/headers/geos/operation/valid/RepeatedPointTester.h	2009-06-08 22:10:55 UTC (rev 2572)
@@ -12,6 +12,10 @@
+ * Last port: operation/valid/RepeatedPointTester.java rev. 1.8 (JTS-1.10)
 #ifndef GEOS_OP_REPEATEDPOINTTESTER_H
Modified: trunk/source/headers/geos/operation/valid/SimpleNestedRingTester.h
--- trunk/source/headers/geos/operation/valid/SimpleNestedRingTester.h	2009-06-08 21:53:35 UTC (rev 2571)
+++ trunk/source/headers/geos/operation/valid/SimpleNestedRingTester.h	2009-06-08 22:10:55 UTC (rev 2572)
@@ -12,6 +12,10 @@
+ * Last port: operation/valid/SimpleNestedRingTester.java rev. 1.14 (JTS-1.10)
 #ifndef GEOS_OP_SIMPLENESTEDRINGTESTER_H
Modified: trunk/source/headers/geos/operation/valid/SweeplineNestedRingTester.h
--- trunk/source/headers/geos/operation/valid/SweeplineNestedRingTester.h	2009-06-08 21:53:35 UTC (rev 2571)
+++ trunk/source/headers/geos/operation/valid/SweeplineNestedRingTester.h	2009-06-08 22:10:55 UTC (rev 2572)
@@ -12,6 +12,10 @@
+ * Last port: operation/valid/SweeplineNestedRingTester.java rev. 1.12 (JTS-1.10)
 #ifndef GEOS_OP_SWEEPLINENESTEDRINGTESTER_H
@@ -56,7 +60,6 @@
 private:
 	geomgraph::GeometryGraph *graph;  // used to find non-node vertices
 	std::vector<geom::LinearRing*> rings;
-	geom::Envelope *totalEnv;
 	index::sweepline::SweepLineIndex *sweepLine;
 	geom::Coordinate *nestedPt;
 	void buildIndex();
@@ -67,14 +70,12 @@
 		graph(newGraph),
 		rings(),
-		totalEnv(new geom::Envelope()),
 		sweepLine(new index::sweepline::SweepLineIndex()),
 		nestedPt(NULL)
 	~SweeplineNestedRingTester()
-		delete totalEnv;
 		delete sweepLine;
Modified: trunk/source/headers/geos/operation/valid/TopologyValidationError.h
--- trunk/source/headers/geos/operation/valid/TopologyValidationError.h	2009-06-08 21:53:35 UTC (rev 2571)
+++ trunk/source/headers/geos/operation/valid/TopologyValidationError.h	2009-06-08 22:10:55 UTC (rev 2572)
@@ -12,6 +12,10 @@
+ * Last port: operation/valid/TopologyValidationError.java rev. 1.16 (JTS-1.10)
 #ifndef GEOS_OP_TOPOLOGYVALIDATIONERROR_H
Modified: trunk/source/operation/valid/ConnectedInteriorTester.cpp
--- trunk/source/operation/valid/ConnectedInteriorTester.cpp	2009-06-08 21:53:35 UTC (rev 2571)
+++ trunk/source/operation/valid/ConnectedInteriorTester.cpp	2009-06-08 22:10:55 UTC (rev 2572)
@@ -14,7 +14,7 @@
- * Last port: operation/valid/ConnectedInteriorTester.java rev. 1.14
Modified: trunk/source/operation/valid/IndexedNestedRingTester.cpp
--- trunk/source/operation/valid/IndexedNestedRingTester.cpp	2009-06-08 21:53:35 UTC (rev 2571)
+++ trunk/source/operation/valid/IndexedNestedRingTester.cpp	2009-06-08 22:10:55 UTC (rev 2572)
@@ -13,7 +13,7 @@
- * Last port: operation/valid/IndexedNestedRingTester.java rev. 1.1 (JTS-1.9)
+ * Last port: operation/valid/IndexedNestedRingTester.java rev. 1.1 (JTS-1.10)
Modified: trunk/source/operation/valid/IndexedNestedRingTester.h
--- trunk/source/operation/valid/IndexedNestedRingTester.h	2009-06-08 21:53:35 UTC (rev 2571)
+++ trunk/source/operation/valid/IndexedNestedRingTester.h	2009-06-08 22:10:55 UTC (rev 2572)
@@ -13,7 +13,7 @@
Modified: trunk/source/operation/valid/IsValidOp.cpp
--- trunk/source/operation/valid/IsValidOp.cpp	2009-06-08 21:53:35 UTC (rev 2571)
+++ trunk/source/operation/valid/IsValidOp.cpp	2009-06-08 22:10:55 UTC (rev 2572)
@@ -14,7 +14,7 @@
Modified: trunk/source/operation/valid/QuadtreeNestedRingTester.cpp
--- trunk/source/operation/valid/QuadtreeNestedRingTester.cpp	2009-06-08 21:53:35 UTC (rev 2571)
+++ trunk/source/operation/valid/QuadtreeNestedRingTester.cpp	2009-06-08 22:10:55 UTC (rev 2572)
@@ -14,7 +14,7 @@
- * Last port: operation/valid/QuadtreeNestedRingTester.java rev. 1.11
Modified: trunk/source/operation/valid/RepeatedPointTester.cpp
--- trunk/source/operation/valid/RepeatedPointTester.cpp	2009-06-08 21:53:35 UTC (rev 2571)
+++ trunk/source/operation/valid/RepeatedPointTester.cpp	2009-06-08 22:10:55 UTC (rev 2572)
@@ -13,6 +13,8 @@
 #include <geos/operation/valid/RepeatedPointTester.h>
Modified: trunk/source/operation/valid/SimpleNestedRingTester.cpp
--- trunk/source/operation/valid/SimpleNestedRingTester.cpp	2009-06-08 21:53:35 UTC (rev 2571)
+++ trunk/source/operation/valid/SimpleNestedRingTester.cpp	2009-06-08 22:10:55 UTC (rev 2572)
@@ -12,6 +12,10 @@
 #include <geos/operation/valid/SimpleNestedRingTester.h>
Modified: trunk/source/operation/valid/SweeplineNestedRingTester.cpp
--- trunk/source/operation/valid/SweeplineNestedRingTester.cpp	2009-06-08 21:53:35 UTC (rev 2571)
+++ trunk/source/operation/valid/SweeplineNestedRingTester.cpp	2009-06-08 22:10:55 UTC (rev 2572)
@@ -12,6 +12,10 @@
 #include <geos/operation/valid/SweeplineNestedRingTester.h>
Modified: trunk/source/operation/valid/TopologyValidationError.cpp
--- trunk/source/operation/valid/TopologyValidationError.cpp	2009-06-08 21:53:35 UTC (rev 2571)
+++ trunk/source/operation/valid/TopologyValidationError.cpp	2009-06-08 22:10:55 UTC (rev 2572)
@@ -14,7 +14,7 @@
- * Last port: operation/valid/TopologyValidationError.java rev. 1.14 (JTS-1.7)
More information about the geos-commits mailing list
