[geos-commits] r2597 - trunk/tests/unit/capi
svn_geos at osgeo.org svn_geos at osgeo.org
Mon Jun 22 15:14:11 EDT 2009
Author: strk
Date: 2009-06-22 15:14:11 -0400 (Mon, 22 Jun 2009)
New Revision: 2597
   trunk/tests/unit/capi/GEOSBufferTest.cpp
Add tests for limited mitre join (now working)
Modified: trunk/tests/unit/capi/GEOSBufferTest.cpp
--- trunk/tests/unit/capi/GEOSBufferTest.cpp	2009-06-22 19:02:03 UTC (rev 2596)
+++ trunk/tests/unit/capi/GEOSBufferTest.cpp	2009-06-22 19:14:11 UTC (rev 2597)
@@ -375,6 +375,75 @@
+    // Buffer with limited mitre  (1)
+    template<>
+    template<>
+    void object::test<14>()
+        geom1_ = GEOSGeomFromWKT("POLYGON((0 0, 10 0, 10 10, 0 0))");
+        ensure( 0 != geom1_ );
+        geom2_ = GEOSBufferWithStyle(geom1_, 2, 200, GEOSBUF_CAP_FLAT,
+                                     GEOSBUF_JOIN_MITRE, 1);
+        ensure( 0 != geom2_ );
+        wkt_ = GEOSGeomToWKT(geom2_);
+        ensure_equals(GEOSGetNumCoordinates(geom2_), 7);
+        ensure(GEOSArea(geom2_, &area_));
+        ensure_distance(area_, 127.452, 0.001);
+    // Buffer with limited mitre  (2)
+    template<>
+    template<>
+    void object::test<15>()
+                                     GEOSBUF_JOIN_MITRE, 2);
+        ensure_equals(GEOSGetNumCoordinates(geom2_), 6);
+        ensure_distance(area_, 139.043, 0.001);
+    // Buffer with limited mitre  (3)
+    template<>
+    template<>
+    void object::test<16>()
+                                     GEOSBUF_JOIN_MITRE, 3);
+        ensure_equals(GEOSGetNumCoordinates(geom2_), 4);
+        ensure_distance(area_, 141.598, 0.001);
 } // namespace tut
More information about the geos-commits mailing list
