[geos-commits] r2282 - trunk/capi
svn_geos at osgeo.org svn_geos at osgeo.org
Fri Mar 20 21:01:44 EDT 2009
Author: mloskot
Date: 2009-03-20 21:01:44 -0400 (Fri, 20 Mar 2009)
New Revision: 2282
   trunk/capi/geos_ts_c.cpp
Fixed deprecated conversion from string constant to char* in GEOSisValidReason_r. Small refactoring.
Modified: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp	2009-03-21 00:47:22 UTC (rev 2281)
+++ trunk/capi/geos_ts_c.cpp	2009-03-21 01:01:44 UTC (rev 2282)
@@ -528,43 +528,49 @@
         return NULL;
-    using geos::operation::valid::IsValidOp;
-    using geos::operation::valid::TopologyValidationError;
-    IsValidOp ivo(g1);
-    try {
-        char *result = NULL;
-		char *validstr = "Valid Geometry";
+    try
+        using geos::operation::valid::IsValidOp;
+        using geos::operation::valid::TopologyValidationError;
+        char* result = 0;
+		char const* const validstr = "Valid Geometry";
 		const std::size_t validstrlen = std::strlen(validstr) + 1;
+        IsValidOp ivo(g1);
         bool isvalid = ivo.isValid();
         if ( ! isvalid )
             TopologyValidationError *err = ivo.getValidationError();
             std::string errmsg = err->getMessage();
             std::string errloc = err->getCoordinate().toString();
-            const std::size_t msglen = errmsg.length();
-            const std::size_t loclen = errloc.length();
-            result = (char*)std::malloc(msglen + loclen + 3);
-            sprintf(result, "%s [%s]", errmsg.c_str(), errloc.c_str());
+            const std::size_t resultlen = errmsg.length() + errloc.length() + 3;
+            result = static_cast<char*>(std::malloc(resultlen));
+            if (0 != result)
+                std::memset(result, '\0', resultlen);
+                sprintf(result, "%s [%s]", errmsg.c_str(), errloc.c_str());
-        else {
-			result = (char*)std::malloc(validstrlen);
+        else
+			result = static_cast<char*>(std::malloc(validstrlen));
 			std::memcpy(result, validstr, validstrlen);
         return result;
     catch (const std::exception &e)
         handle->ERROR_MESSAGE("%s", e.what());
-        return NULL;
     catch (...)
         handle->ERROR_MESSAGE("Unknown exception thrown");
-        return NULL;
+    return 0;
More information about the geos-commits mailing list
