[geos-commits] r2468 - in trunk: . source/headers/geos/geom source/headers/geos/operation/overlay source/headers/geos/operation/overlay/snap source/headers/geos/precision source/operation/overlay/snap source/precision tests/unit tests/unit/operation/overlay tests/unit/operation/overlay/snap tests/unit/precision
svn_geos at osgeo.org svn_geos at osgeo.org
Tue May 5 06:14:39 EDT 2009
Author: strk
Date: 2009-05-05 06:14:39 -0400 (Tue, 05 May 2009)
New Revision: 2468
Added:
   trunk/source/headers/geos/operation/overlay/snap/Makefile.am
   trunk/tests/unit/operation/overlay/snap/
   trunk/tests/unit/operation/overlay/snap/GeometrySnapperTest.cpp
   trunk/tests/unit/operation/overlay/snap/LineStringSnapperTest.cpp
Removed:
   trunk/source/headers/geos/precision/GeometrySnapper.h
   trunk/source/headers/geos/precision/LineStringSnapper.h
   trunk/source/precision/GeometrySnapper.cpp
   trunk/source/precision/LineStringSnapper.cpp
   trunk/tests/unit/precision/GeometrySnapperTest.cpp
   trunk/tests/unit/precision/LineStringSnapperTest.cpp
   trunk/configure.in
   trunk/source/headers/geos/geom/BinaryOp.h
   trunk/source/headers/geos/operation/overlay/Makefile.am
   trunk/source/headers/geos/operation/overlay/snap/GeometrySnapper.h
   trunk/source/headers/geos/operation/overlay/snap/LineStringSnapper.h
   trunk/source/headers/geos/precision/Makefile.am
   trunk/source/operation/overlay/snap/GeometrySnapper.cpp
   trunk/source/operation/overlay/snap/LineStringSnapper.cpp
   trunk/source/operation/overlay/snap/SnapOverlayOp.cpp
   trunk/source/precision/Makefile.am
   trunk/tests/unit/Makefile.am
Found old GeometrySnapper/LineStringSnapper classes in an unexpected directory. Move them where they belong, sync with JTS-1.10.
Modified: trunk/configure.in
--- trunk/configure.in	2009-05-05 00:04:34 UTC (rev 2467)
+++ trunk/configure.in	2009-05-05 10:14:39 UTC (rev 2468)
@@ -321,6 +321,7 @@
 	source/headers/geos/operation/distance/Makefile
 	source/headers/geos/operation/linemerge/Makefile
+	source/headers/geos/operation/overlay/snap/Makefile
 	source/headers/geos/operation/polygonize/Makefile
 	source/headers/geos/operation/predicate/Makefile
 	source/headers/geos/operation/relate/Makefile
Modified: trunk/source/headers/geos/geom/BinaryOp.h
--- trunk/source/headers/geos/geom/BinaryOp.h	2009-05-05 00:04:34 UTC (rev 2467)
+++ trunk/source/headers/geos/geom/BinaryOp.h	2009-05-05 10:14:39 UTC (rev 2468)
@@ -53,7 +53,9 @@
 #include <geos/geom/PrecisionModel.h>
 #include <geos/precision/CommonBitsRemover.h>
 #include <geos/precision/SimpleGeometryPrecisionReducer.h>
-#include <geos/precision/GeometrySnapper.h>
+#include <geos/operation/overlay/snap/GeometrySnapper.h>
 #include <geos/simplify/TopologyPreservingSimplifier.h>
 #include <geos/operation/valid/IsValidOp.h>
 #include <geos/util/TopologyException.h>
@@ -134,7 +136,8 @@
 #define CBR_BEFORE_SNAPPING 1
-	using geos::precision::GeometrySnapper;
+	//using geos::precision::GeometrySnapper;
+	using geos::operation::overlay::snap::GeometrySnapper;
 	// Snap tolerance must be computed on the original
 	// (not commonbits-removed) geoms
Modified: trunk/source/headers/geos/operation/overlay/Makefile.am
--- trunk/source/headers/geos/operation/overlay/Makefile.am	2009-05-05 00:04:34 UTC (rev 2467)
+++ trunk/source/headers/geos/operation/overlay/Makefile.am	2009-05-05 10:14:39 UTC (rev 2468)
@@ -1,8 +1,9 @@
-#SUBDIRS =
+SUBDIRS = snap
 #EXTRA_DIST =
 # Notes:
+# snap/GeometrySnapper.h is needed by geom/BinaryOp.h
 geosdir = $(includedir)/geos/operation/overlay
@@ -21,10 +22,6 @@
 	OverlayNodeFactory.h	\
 	PointBuilder.h		\
 	PolygonBuilder.h	\
-	snap/GeometrySnapper.h	\
-	snap/LineStringSnapper.h \
-	snap/SnapOverlayOp.h	\
-	snap/SnapIfNeededOverlayOp.h	\
 	validate/FuzzyPointLocator.h	\
 	validate/OffsetPointGenerator.h	\
 	validate/OverlayResultValidator.h
Modified: trunk/source/headers/geos/operation/overlay/snap/GeometrySnapper.h
--- trunk/source/headers/geos/operation/overlay/snap/GeometrySnapper.h	2009-05-05 00:04:34 UTC (rev 2467)
+++ trunk/source/headers/geos/operation/overlay/snap/GeometrySnapper.h	2009-05-05 10:14:39 UTC (rev 2468)
@@ -1,10 +1,11 @@
- * $Id$
+ * $Id: GeometrySnapper.h 1948 2006-12-18 18:44:20Z strk $
  * GEOS - Geometry Engine Open Source
  * http://geos.refractions.net
  * Copyright (C) 2009  Sandro Santilli <strk at keybit.net>
+ * Copyright (C) 2006 Refractions Research Inc.
  * This is free software; you can redistribute and/or modify it under
  * the terms of the GNU Lesser General Public Licence as published
@@ -20,15 +21,16 @@
 #ifndef GEOS_OP_OVERLAY_SNAP_GEOMETRYSNAPPER_H
 #define GEOS_OP_OVERLAY_SNAP_GEOMETRYSNAPPER_H
-#include <geos/geom/LineSegment.h> // for composition
-#include <geos/geom/LineString.h> // for inlined ctor
+#include <geos/geom/Coordinate.h>
-//#include <vector>
-#include <memory> // for auto_ptr
+#include <memory>
+#include <vector>
 // Forward declarations
 namespace geos {
-	namespace geom {
+	namespace geom {
+		//class PrecisionModel;
+		class Geometry;
 		class CoordinateSequence;
@@ -39,34 +41,13 @@
 namespace snap { // geos::operation::overlay::snap
 /** \brief
- * Snaps the vertices and segments of a geom::Geometry to another
- * Geometry's vertices.
- * Improves robustness for overlay operations, by eliminating
- * nearly parallel edges (which cause problems during noding and
- * intersection calculation).
+ * Snaps the vertices and segments of a geometry to another's vertices.
+ * Should improve robustness for overlay operations.
-class GeometrySnapper
+class GeometrySnapper {
 public:
-	/** \brief
-	 * Estimates the snap tolerance for a Geometry, taking into account
-	 * its precision model.
-	 * @param g a Geometry
-	 * @return the estimated snap tolerance
-	static double computeOverlaySnapTolerance(const geom::Geometry& g);
-	static double computeSizeBasedSnapTolerance(const geom::Geometry& g);
-	static double computeOverlaySnapTolerance(const geom::Geometry& g0,
-	                                          const geom::Geometry& g1);
 	typedef std::auto_ptr<geom::Geometry> GeomPtr;
 	typedef std::pair<GeomPtr, GeomPtr> GeomPtrPair;
@@ -86,45 +67,63 @@
 	 * Creates a new snapper acting on the given geometry
-	 * @param nSrcGeom the geometry to snap
+	 * @param g the geometry to snap
-	GeometrySnapper(const geom::Geometry& nSrcGeom)
+	GeometrySnapper(const geom::Geometry& g)
-		srcGeom(nSrcGeom)
+		srcGeom(g)
+	/** \brief
 	 * Snaps the vertices in the component {@link LineString}s
-	 * of the source geometry
-	 * to the vertices of the given snap geometry.
+	 * of the source geometry to the vertices of the given snap geometry
+	 * with a given snap tolerance
-	 * @param snapGeom a geometry to snap the source to
+	 * @param g a geometry to snap the source to
 	 * @param snapTolerance
 	 * @return a new snapped Geometry
-	GeomPtr snapTo(const geom::Geometry& snapGeom, double snapTolerance);
+	std::auto_ptr<geom::Geometry> snapTo(const geom::Geometry& g,
+	                                     double snapTolerance);
-	// why is this public ??
-	void extractTargetCoordinates(const geom::Geometry& g,
-	                    std::vector<const geom::Coordinate*>& target);
+	/** \brief
+	 * Estimates the snap tolerance for a Geometry, taking into account
+	 * its precision model.
+	 * @param g a Geometry
+	 * @return the estimated snap tolerance
+	static double computeOverlaySnapTolerance(const geom::Geometry& g);
+	static double computeSizeBasedSnapTolerance(const geom::Geometry& g);
+	/** \brief
+	 * Computes the snap tolerance based on input geometries;
+	static double computeOverlaySnapTolerance(const geom::Geometry& g1,
+			const geom::Geometry& g2);
 private:
-	static const double SNAP_PRECISION_FACTOR; // = 10e-10;
+	// eventually this will be determined from the geometry topology
+	//static const double snapTol; //  = 0.000001;
+	static const double snapPrecisionFactor; //  = 10e-10
 	const geom::Geometry& srcGeom;
+	/// Extract target (unique) coordinates
+	std::auto_ptr<geom::Coordinate::ConstVect> extractTargetCoordinates(
+			const geom::Geometry& g);
 } // namespace geos::operation::overlay::snap
 } // namespace geos
-#endif // ndef GEOS_OP_OVERLAY_SNAP_GEOMETRYSNAPPER_H
+#endif // GEOS_OP_OVERLAY_SNAP_GEOMETRYSNAPPER_H
- * $Log$
Modified: trunk/source/headers/geos/operation/overlay/snap/LineStringSnapper.h
--- trunk/source/headers/geos/operation/overlay/snap/LineStringSnapper.h	2009-05-05 00:04:34 UTC (rev 2467)
+++ trunk/source/headers/geos/operation/overlay/snap/LineStringSnapper.h	2009-05-05 10:14:39 UTC (rev 2468)
@@ -5,6 +5,7 @@
@@ -13,24 +14,26 @@
- * Last port: operation/overlay/snap/LineStringSnapper.java rev 1.5 (JTS-1.10)
+ * Last port: operation/overlay/snap/lineStringSnapper.java rev 1.5 (JTS-1.10)
 #ifndef GEOS_OP_OVERLAY_SNAP_LINESTRINGSNAPPER_H
 #define GEOS_OP_OVERLAY_SNAP_LINESTRINGSNAPPER_H
+#include <geos/geom/CoordinateSequence.h>
+#include <geos/geom/CoordinateList.h>
-#include <vector>
+#include <memory>
 namespace geos {
-	namespace geom {
-		class Coordinate;
-		class CoordinateSequence;
+	namespace geom {
+		//class CoordinateSequence;
+		class CoordinateList;
+		class Geometry;
@@ -51,130 +54,80 @@
 public:
-	 * Creates a new snapper using the points in the given LineString
-	 * as source snap points.
-	 * @param srcLline a LineString to snap
-	 * @param nSnapTolerance the snap tolerance to use
-	LineStringSnapper(const geom::LineString& srcLline,
-	                  double nSnapTolerance)
-		snapTolerance(nSnapTolerance),
-		srcPts(*(srcLline.getCoordinatesRO())),
-		seg(),
-		isClosed(false)
 	 * Creates a new snapper using the given points
 	 * as source points to be snapped.
 	 * @param nSrcPts the points to snap
-	LineStringSnapper(const geom::CoordinateSequence& nSrcPts,
+	LineStringSnapper(const geom::Coordinate::Vect& nSrcPts,
+	                                          double nSnapTol)
 		srcPts(nSrcPts),
-		seg(),
-		isClosed(false)
+		snapTolerance(nSnapTol)
+		size_t s = srcPts.size();
+		isClosed = ( s < 2 || srcPts[0].equals2D(srcPts[s-1]) );
-	 * Snaps the vertices and segments of the source points
-	 * to the given set of target snap points.
-	 * @param snapPts the vertices to snap to
-	 * @return a sequence formed by the snapped points
-	std::auto_ptr<geom::CoordinateSequence> snapTo(
-	                 const geom::CoordinateSequence& snapPts);
+	// Snap points are assumed to be all distinct points (a set would be better, uh ?)
+	std::auto_ptr<geom::Coordinate::Vect> snapTo(const geom::Coordinate::ConstVect& snapPts);
-	                 const std::vector<const geom::Coordinate*>& snapPts);
 private:
-	 * Snap source vertices to vertices in the target.
-	 * @param srcCoords the points to snap
-	 * @param snapPts the points to snap to
-	void snapVertices(geom::CoordinateSequence& srcCoords,
+	const geom::Coordinate::Vect& srcPts;
+	double snapTolerance;
+	bool isClosed;
-	// return pointer into snapPts memory, or null
-	const geom::Coordinate*
-	findSnapForVertex(const geom::Coordinate& pt,
+	// Modifies first arg
+	void snapVertices(geom::CoordinateList& srcCoords,
+			const geom::Coordinate::ConstVect& snapPts);
-	 * Snap segments of the source to nearby snap vertices.
-	 * Source segments are "cracked" at a snap vertex, and further
-	 * snapping takes place on the modified list of segments.
-	 * For each distinct snap vertex, at most one source segment
-	 * is snapped to.  This prevents "cracking" multiple segments
-	 * at the same point, which would almost certainly cause the result
-	 * to be invalid.
-	 * @param snapPts
-	void snapSegments(geom::CoordinateSequence& srcCoords,
+	// Returns snapPts.end() if no snap point is close enough (within snapTol distance)
+	geom::Coordinate::ConstVect::const_iterator findSnapForVertex(const geom::Coordinate& pt,
-	/** \brief
-	 * Finds a src segment which snaps to (is close to)
-	 * the given snap point.
-	 * Only one segment is determined - this is to prevent                           * snapping to multiple segments, which would almost certainly
-	 * cause invalid geometry to be created.
-	 * (The heuristic approach of snapping is really only appropriate when
-	 * snap pts snap to a unique spot on the src geometry.)
-	 * @param snapPt the point to snap to
-	 * @param srcCoords the source segment coordinates
-	 * @return the index of the snapped segment
-	 * @return -1 if no segment snaps
-	int findSegmentIndexToSnap(const geom::Coordinate& snapPt,
-	                      const geom::CoordinateSequence& srcCoords);
+	void snapSegments(geom::CoordinateList& srcCoords,
-	double snapTolerance;
+	/// \brief
+	/// Finds a src segment which snaps to (is close to) the given snap
+	/// point.
+	/// Only one segment is determined - this is to prevent
+	/// snapping to multiple segments, which would almost certainly cause
+	/// invalid geometry to be created.
+	/// (The heuristic approach of snapping is really only appropriate
+	///  when snap pts snap to a unique spot on the src geometry.)
+	/// @param from
+	///        an iterator to first point of first segment to be checked
+	/// @param too_far
+	///        an iterator to last point of last segment to be checked
+	/// @returns too_far if no segment needs snapping
+	///          (either none within snapTol distance,
+	///	      or one fond on the snapPt)
+	geom::CoordinateList::iterator findSegmentToSnap(
+			const geom::Coordinate& snapPt,
+			geom::CoordinateList::iterator from,
+			geom::CoordinateList::iterator too_far);
-	const geom::CoordinateSequence& srcPts;
-	geom::LineSegment seg; // for reuse during snapping
-	bool isClosed;
 } // namespace geos
-#endif // ndef GEOS_OP_OVERLAY_SNAP_LINESTRINGSNAPPER_H
+#endif // GEOS_OP_OVERLAY_SNAP_LINESTRINGSNAPPER_H
- * $Log$
Added: trunk/source/headers/geos/operation/overlay/snap/Makefile.am
--- trunk/source/headers/geos/operation/overlay/snap/Makefile.am	                        (rev 0)
+++ trunk/source/headers/geos/operation/overlay/snap/Makefile.am	2009-05-05 10:14:39 UTC (rev 2468)
@@ -0,0 +1,17 @@
+#SUBDIRS =
+#EXTRA_DIST =
+# Notes:
+geosdir = $(includedir)/geos/operation/overlay/snap
+geos_HEADERS = \
+	GeometrySnapper.h
+noinst_HEADERS =  \
+	LineStringSnapper.h \
+	SnapOverlayOp.h	\
+	SnapIfNeededOverlayOp.h
Deleted: trunk/source/headers/geos/precision/GeometrySnapper.h
--- trunk/source/headers/geos/precision/GeometrySnapper.h	2009-05-05 00:04:34 UTC (rev 2467)
+++ trunk/source/headers/geos/precision/GeometrySnapper.h	2009-05-05 10:14:39 UTC (rev 2468)
@@ -1,110 +0,0 @@
- * $Id$
- * GEOS - Geometry Engine Open Source
- * http://geos.refractions.net
- * Copyright (C) 2006 Refractions Research Inc.
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
- * Last port: operation/overlay/snap/GeometrySnapper.java rev. 1.6
- * (we should move in GEOS too, probably)
-#ifndef GEOS_PRECISION_GEOMETRYSNAPPER_H
-#define GEOS_PRECISION_GEOMETRYSNAPPER_H
-#include <geos/geom/Coordinate.h>
-#include <memory>
-#include <vector>
-// Forward declarations
-namespace geos {
-	namespace geom {
-		//class PrecisionModel;
-		class Geometry;
-namespace geos {
-namespace precision { // geos.precision
-/** \brief
- * Snaps the vertices and segments of a geometry to another's vertices.
- * Should improve robustness for overlay operations.
-class GeometrySnapper {
-public:
-	GeometrySnapper(const geom::Geometry& g)
-		srcGeom(g)
-	/** \brief
-	 * Snaps the vertices in the component {@link LineString}s
-	 * of the source geometry to the vertices of the given geometry
-	 * with a given snap tolerance
-	 * @param g
-	 * @param snapTolerance
-	 * @return a new snapped Geometry
-	std::auto_ptr<geom::Geometry> snapTo(const geom::Geometry& g, double snapTolerance);
-	/** \brief
-	/** \brief
-	 * Computes the snap tolerance based on input geometries;
-	static double computeOverlaySnapTolerance(const geom::Geometry& g1,
-			const geom::Geometry& g2);
-private:
-	// eventually this will be determined from the geometry topology
-	//static const double snapTol; //  = 0.000001;
-	static const double snapPrecisionFactor; //  = 10e-10
-	const geom::Geometry& srcGeom;
-	/// Extract target (unique) coordinates
-	std::auto_ptr<geom::Coordinate::ConstVect> extractTargetCoordinates(
-			const geom::Geometry& g);
-} // namespace geos.precision
-#endif // GEOS_PRECISION_GEOMETRYSNAPPER_H
- * $Log$
- * Revision 1.1  2006/07/21 17:09:14  strk
- * Added new precision::LineStringSnapper class + test
- * and precision::GeometrySnapper (w/out test)
Deleted: trunk/source/headers/geos/precision/LineStringSnapper.h
--- trunk/source/headers/geos/precision/LineStringSnapper.h	2009-05-05 00:04:34 UTC (rev 2467)
+++ trunk/source/headers/geos/precision/LineStringSnapper.h	2009-05-05 10:14:39 UTC (rev 2468)
@@ -1,126 +0,0 @@
- * $Id$
- * Last port: operation/overlay/snap/lineStringSnapper.java rev. 1.1
-#ifndef GEOS_PRECISION_LINESTRINGSNAPPER_H
-#define GEOS_PRECISION_LINESTRINGSNAPPER_H
-#include <geos/geom/CoordinateSequence.h>
-#include <geos/geom/CoordinateList.h>
-#include <memory>
-namespace geos {
-	namespace geom {
-		//class CoordinateSequence;
-		class CoordinateList;
-		class Geometry;
-namespace geos {
-/** \brief
- * Snaps the vertices and segments of a LineString to another's vertices.
-class LineStringSnapper {
-public:
-	LineStringSnapper(const geom::Coordinate::Vect& nSrcPts, double nSnapTol)
-		srcPts(nSrcPts),
-		snapTolerance(nSnapTol)
-		size_t s = srcPts.size();
-		isClosed = ( s < 2 || srcPts[0].equals2D(srcPts[s-1]) );
-	// Snap points are assumed to be all distinct points (a set would be better, uh ?)
-	std::auto_ptr<geom::Coordinate::Vect> snapTo(const geom::Coordinate::ConstVect& snapPts);
-private:
-	const geom::Coordinate::Vect& srcPts;
-	bool isClosed;
-	// Modifies first arg
-	void snapVertices(geom::CoordinateList& srcCoords,
-			const geom::Coordinate::ConstVect& snapPts);
-	// Returns snapPts.end() if no snap point is close enough (within snapTol distance)
-	geom::Coordinate::ConstVect::const_iterator findSnapForVertex(const geom::Coordinate& pt,
-	void snapSegments(geom::CoordinateList& srcCoords,
-	/// \brief
-	/// Finds a src segment which snaps to (is close to) the given snap
-	/// point.
-	/// Only one segment is determined - this is to prevent
-	/// snapping to multiple segments, which would almost certainly cause
-	/// invalid geometry to be created.
-	/// (The heuristic approach of snapping is really only appropriate
-	///  when snap pts snap to a unique spot on the src geometry.)
-	/// @param from
-	///        an iterator to first point of first segment to be checked
-	/// @param too_far
-	///        an iterator to last point of last segment to be checked
-	/// @returns too_far if no segment needs snapping
-	///          (either none within snapTol distance,
-	///	      or one fond on the snapPt)
-	geom::CoordinateList::iterator findSegmentToSnap(
-			const geom::Coordinate& snapPt,
-			geom::CoordinateList::iterator from,
-			geom::CoordinateList::iterator too_far);
-#endif // GEOS_PRECISION_LINESTRINGSNAPPER_H
- * $Log$
Modified: trunk/source/headers/geos/precision/Makefile.am
--- trunk/source/headers/geos/precision/Makefile.am	2009-05-05 00:04:34 UTC (rev 2467)
+++ trunk/source/headers/geos/precision/Makefile.am	2009-05-05 10:14:39 UTC (rev 2468)
@@ -14,9 +14,7 @@
 	CommonBitsOp.h				\
 	CommonBitsRemover.h			\
 	EnhancedPrecisionOp.h			\
-	GeometrySnapper.h			\
 noinst_HEADERS = 				\
-	CommonBits.h				\
-	LineStringSnapper.h
+	CommonBits.h
Modified: trunk/source/operation/overlay/snap/GeometrySnapper.cpp
--- trunk/source/operation/overlay/snap/GeometrySnapper.cpp	2009-05-05 00:04:34 UTC (rev 2467)
+++ trunk/source/operation/overlay/snap/GeometrySnapper.cpp	2009-05-05 10:14:39 UTC (rev 2468)
@@ -5,6 +5,7 @@
@@ -19,22 +20,20 @@
 #include <geos/operation/overlay/snap/LineStringSnapper.h>
-#include <geos/geom/PrecisionModel.h>
-#include <geos/geom/util/GeometryTransformer.h> // SnapTransformer inheritance
-#include <geos/util/UniqueCoordinateArrayFilter.h>
+#include <geos/geom/util/GeometryTransformer.h> // inherit. of SnapTransformer
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/CoordinateSequenceFactory.h>
+#include <geos/geom/PrecisionModel.h>
+#include <geos/util/UniqueCoordinateArrayFilter.h>
+#include <geos/util.h>
-#include <cassert>
-#include <limits> // for numeric_limits
+#include <vector>
+#include <memory>
+#include <algorithm>
-#include <algorithm> // for std::min
-#ifndef GEOS_DEBUG
-#define GEOS_DEBUG 0
-#endif
-using namespace std;
+//using namespace std;
 using namespace geos::geom;
 namespace geos {
@@ -42,55 +41,94 @@
 namespace overlay { // geos.operation.overlay
 namespace snap { // geos.operation.overlay.snap
-namespace { // anonymous
+const double GeometrySnapper::snapPrecisionFactor = 10e-10;
-class SnapTransformer : public geom::util::GeometryTransformer
+class SnapTransformer: public geos::geom::util::GeometryTransformer {
+private:
+	double snapTol;
+	const Coordinate::ConstVect& snapPts;
+	CoordinateSequence::AutoPtr snapLine(
+			const CoordinateSequence* srcPts)
+		using std::auto_ptr;
+		assert(srcPts);
+		assert(srcPts->toVector());
+		LineStringSnapper snapper(*(srcPts->toVector()), snapTol);
+		auto_ptr<Coordinate::Vect> newPts = snapper.snapTo(snapPts);
+		const CoordinateSequenceFactory* cfact = factory->getCoordinateSequenceFactory();
+		return auto_ptr<CoordinateSequence>(cfact->create(newPts.release()));
 public:
-	const vector<const Coordinate*>& snapPts;
-	SnapTransformer(double nSnapTolerance,
-			const vector<const Coordinate*>& nSnapPts)
+	SnapTransformer(double nSnapTol,
+			const Coordinate::ConstVect& nSnapPts)
+		snapTol(nSnapTol),
 		snapPts(nSnapPts)
-protected:
-	virtual CoordinateSequence::AutoPtr transformCoordinates(
-		const CoordinateSequence* coords,
-		const Geometry* parent)
+	CoordinateSequence::AutoPtr transformCoordinates(
+			const CoordinateSequence* coords,
+			const Geometry* parent)
-		return snapLine(*coords, snapPts);
+        UNREFERENCED_PARAMETER(parent);
+		return snapLine(coords);
-private:
-	auto_ptr< CoordinateSequence >
-	snapLine(const CoordinateSequence& srcPts,
-	         const vector<const Coordinate*>& snapPts)
-		// TODO: make the LineStringSnapper a private member...
-		LineStringSnapper snapper(srcPts, snapTolerance);
-		return snapper.snapTo(snapPts);
-} // anonymous namespace
+/*private*/
+std::auto_ptr<Coordinate::ConstVect>
+GeometrySnapper::extractTargetCoordinates(const Geometry& g)
+	std::auto_ptr<Coordinate::ConstVect> snapPts(new Coordinate::ConstVect());
+	util::UniqueCoordinateArrayFilter filter(*snapPts);
+	g.apply_ro(&filter);
+	// integrity check
+	assert( snapPts->size() <= g.getNumPoints() );
+	return snapPts;
-/* private static */
-const double GeometrySnapper::SNAP_PRECISION_FACTOR = 10e-10;
+/*public*/
+std::auto_ptr<geom::Geometry>
+GeometrySnapper::snapTo(const geom::Geometry& g, double snapTolerance)
+	using geom::util::GeometryTransformer;
+	// Get snap points
+	auto_ptr<Coordinate::ConstVect> snapPts=extractTargetCoordinates(g);
-/* public static */
+	// Apply a SnapTransformer to source geometry
+	// (we need a pointer for dynamic polymorphism)
+	auto_ptr<GeometryTransformer> snapTrans(new SnapTransformer(snapTolerance, *snapPts));
+	return snapTrans->transform(&srcGeom);
+/*public static*/
 double
-GeometrySnapper::computeOverlaySnapTolerance(const Geometry& g)
+GeometrySnapper::computeSizeBasedSnapTolerance(const geom::Geometry& g)
+	const Envelope* env = g.getEnvelopeInternal();
+	double minDimension = std::min(env->getHeight(), env->getWidth());
+	double snapTol = minDimension * snapPrecisionFactor;
+	return snapTol;
+/*public static*/
+double
+GeometrySnapper::computeOverlaySnapTolerance(const geom::Geometry& g)
 	double snapTolerance = computeSizeBasedSnapTolerance(g);
@@ -102,35 +140,26 @@
 	 * the distance from a corner of a precision grid cell
 	 * to the centre point of the cell.
+	assert(g.getPrecisionModel());
 	const PrecisionModel& pm = *(g.getPrecisionModel());
-	if (pm.getType() == PrecisionModel::FIXED) {
+	if (pm.getType() == PrecisionModel::FIXED)
 		double fixedSnapTol = (1 / pm.getScale()) * 2 / 1.415;
-		if (fixedSnapTol > snapTolerance)
+		if ( fixedSnapTol > snapTolerance )
 			snapTolerance = fixedSnapTol;
 	return snapTolerance;
+/*public static*/
 double
-GeometrySnapper::computeSizeBasedSnapTolerance(const geom::Geometry& g)
+GeometrySnapper::computeOverlaySnapTolerance(const geom::Geometry& g1,
-	const Envelope& env = *(g.getEnvelopeInternal());
-	double minDimension = std::min(env.getHeight(), env.getWidth());
-	double snapTol = minDimension * SNAP_PRECISION_FACTOR;
-	return snapTol;
+        return std::min(computeOverlaySnapTolerance(g1), computeOverlaySnapTolerance(g2));
 /* public static */
-double
-GeometrySnapper::computeOverlaySnapTolerance(const geom::Geometry& g0,
-	return std::min(computeOverlaySnapTolerance(g0),
-			computeOverlaySnapTolerance(g1));
 void
 GeometrySnapper::snap(const geom::Geometry& g0,
@@ -152,30 +181,9 @@
 //	cout << *snapGeom.first << endl;
 //	cout << *snapGeom.second << endl;
-	//return snapGeom;
-/*public*/
-GeometrySnapper::GeomPtr
-GeometrySnapper::snapTo(const geom::Geometry& snapGeom, double snapTolerance)
-	vector<const Coordinate*> snapPts;
-	extractTargetCoordinates(snapGeom, snapPts);
-	SnapTransformer snapTrans(snapTolerance, snapPts);
-	return snapTrans.transform(&srcGeom);
-/*public*/
-void
-GeometrySnapper::extractTargetCoordinates(const Geometry& g,
-	  vector<const Coordinate*>& target)
-	util::UniqueCoordinateArrayFilter filter(target);
-	g.apply_ro(&filter);
 } // namespace geos.operation.snap
 } // namespace geos.operation.overlay
Modified: trunk/source/operation/overlay/snap/LineStringSnapper.cpp
--- trunk/source/operation/overlay/snap/LineStringSnapper.cpp	2009-05-05 00:04:34 UTC (rev 2467)
+++ trunk/source/operation/overlay/snap/LineStringSnapper.cpp	2009-05-05 10:14:39 UTC (rev 2468)
@@ -5,6 +5,7 @@
@@ -13,22 +14,31 @@
+#include <geos/geom/LineSegment.h>
-#include <cassert>
+#include <vector>
+#include <memory>
 #ifndef GEOS_DEBUG
 #endif
+#if GEOS_DEBUG
+#include <iostream>
+using std::cerr;
+using std::endl;
+#endif
 namespace geos {
@@ -37,177 +47,216 @@
 /*public*/
-auto_ptr<CoordinateSequence>
-LineStringSnapper::snapTo(const CoordinateSequence& snapPts)
+std::auto_ptr<Coordinate::Vect>
+LineStringSnapper::snapTo(const geom::Coordinate::ConstVect& snapPts)
-	auto_ptr<CoordinateSequence> coordList(snapPts.clone());
+	geom::CoordinateList coordList(srcPts);
-	snapVertices(*coordList, snapPts);
-	snapSegments(*coordList, snapPts);
+	snapVertices(coordList, snapPts);
+	snapSegments(coordList, snapPts);
-	return coordList;
+	return coordList.toCoordinateArray();
-/*public*/
-LineStringSnapper::snapTo(const vector<const Coordinate*>& snapPts)
+/*private*/
+void
+LineStringSnapper::snapVertices(geom::CoordinateList& srcCoords,
-	auto_ptr<CoordinateSequence> coordList(srcPts.clone());
+	using geom::CoordinateList;
+	geom::Coordinate::ConstVect::const_iterator not_found = snapPts.end();
-	return coordList;
+	// try snapping vertices
+	// assume src list has a closing point (is a ring)
+	CoordinateList::iterator it = srcCoords.begin();
+	CoordinateList::iterator end = srcCoords.end();
+	CoordinateList::iterator last = end; --last;
+	for ( ; it != end; ++it )
+		Coordinate& srcPt = *it;
-/*private*/
-void
-LineStringSnapper::snapVertices(geom::CoordinateSequence& srcCoords,
-    // try snapping vertices
-    // assume src list has a closing point (is a ring)
-    for (size_t i = 0; i < srcCoords.size() - 1; i++) {
-      const Coordinate& srcPt = srcCoords.getAt(i);
-      const Coordinate* snapVert = findSnapForVertex(srcPt, snapPts);
-      if (snapVert != NULL) {
-        // update src with snap pt
-        srcCoords.setAt(*snapVert, i);
-        // keep final closing point in synch (rings only)
-        if (i == 0 && isClosed)
-          srcCoords.setAt(*snapVert, srcCoords.size() - 1);
+#if GEOS_DEBUG
+cerr << "Checking for a snap for source coordinate " << srcPt << endl;
+#endif
-/*private*/
-void
+		geom::Coordinate::ConstVect::const_iterator found = findSnapForVertex(srcPt, snapPts);
+		if ( found == not_found )
+		{	// no snaps found (or no need to snap)
+#if GEOS_DEBUG
+cerr << "No snap found" << endl;
+#endif
+			continue;
-/*private*/
-const geom::Coordinate*
-LineStringSnapper::findSnapForVertex(const geom::Coordinate& pt,
-    for (size_t i = 0; i < snapPts.size(); i++) {
-      // if point is already equal to a src pt, don't snap
-      if (pt.equals2D(snapPts[i]))
-        return 0;
-      if (pt.distance(snapPts[i]) < snapTolerance)
-        return &(snapPts[i]);
-    return 0;
+		assert(*found);
+		const Coordinate& snapPt = *(*found);
+#if GEOS_DEBUG
+cerr << "Found snap point " << snapPt << endl;
+#endif
-/*private*/
-      if (pt.equals2D(*snapPts[i]))
-        return 0;
-      if (pt.distance(*snapPts[i]) < snapTolerance)
-        return snapPts[i];
-    return 0;
+		// update src with snap pt
+		*it = snapPt;
+#if GEOS_DEBUG
+cerr << "Source point became " << srcPt << endl;
+#endif
+		// keep final closing point in synch (rings only)
+		if (it == srcCoords.begin() && isClosed)
+			*last = snapPt;
 /*private*/
-void
-LineStringSnapper::snapSegments(geom::CoordinateSequence& srcCoords,
+Coordinate::ConstVect::const_iterator
+LineStringSnapper::findSnapForVertex(const Coordinate& pt,
+			const Coordinate::ConstVect& snapPts)
-    int distinctPtCount = snapPts.size();
-    // check for duplicate snap pts.
-    // Need to do this better - need to check all points for dups (using a Set?)
-    if (snapPts[0].equals2D(snapPts[snapPts.size() - 1]))
-        distinctPtCount = snapPts.size() - 1;
+	// TODO: use std::find_if
+	Coordinate::ConstVect::const_iterator end=snapPts.end();
+	for ( Coordinate::ConstVect::const_iterator
+			it=snapPts.begin();
+			it != end;
+			++it)
+		assert(*it);
+		const Coordinate& snapPt = *(*it);
-    for (int i = 0; i < distinctPtCount; i++) {
-      const Coordinate& snapPt = snapPts[i];
-      int index = findSegmentIndexToSnap(snapPt, srcCoords);
-       * If a segment to snap to was found, "crack" it at the snap pt.
-       * The new pt is inserted immediately into the src segment list,
-       * so that subsequent snapping will take place on the latest segments.
-       * Duplicate points are not added.
-      if (index >= 0) {
-        srcCoords.add(index + 1, snapPt, false);
+#if GEOS_DEBUG
+cerr << " misuring distance between snap point " << snapPt << " and source point " << pt << endl;
+#endif
+		// shouldn't we look for *all* segments to be snapped rather then a single one?
+		if ( snapPt.equals2D(pt) )
+#if GEOS_DEBUG
+cerr << " points are equal, returning not-found " << endl;
+#endif
+			return end;
+			//continue;
+		double dist = snapPt.distance(pt);
+		if ( dist < snapTolerance )
+#if GEOS_DEBUG
+cerr << " points are within distance (" << dist << ") returning iterator to snap point" << endl;
+#endif
+			return it;
+#if GEOS_DEBUG
+cerr << " No snap point within distance, returning not-found" << endl;
+#endif
+	return end;
 /*private*/
 void
+LineStringSnapper::snapSegments(geom::CoordinateList& srcCoords,
-    if (snapPts[0]->equals2D(*snapPts[snapPts.size() - 1]))
+#if GEOS_DEBUG
+cerr << " Snapping segment from: " << srcCoords << endl;
+#endif
-      const Coordinate& snapPt = *(snapPts[i]);
-      if (index >= 0) {
+			it=snapPts.begin(), end=snapPts.end();
+			it != end;
+			++it)
+		assert(*it);
+#if GEOS_DEBUG
+cerr << "Checking for a segment to snap to snapPt " << snapPt << endl;
+#endif
+		// rather then a single one?
+		CoordinateList::iterator too_far = srcCoords.end(); --too_far;
+		CoordinateList::iterator segpos =
+			findSegmentToSnap(snapPt, srcCoords.begin(), too_far);
+		if ( segpos == too_far)
+#if GEOS_DEBUG
+cerr << " No segment to snap" << endl;
+#endif
+			continue;
+#if GEOS_DEBUG
+cerr << " Segment to be snapped found, inserting point" << endl;
+#endif
+		// insert must happen one-past first point (before next point)
+		++segpos;
+		srcCoords.insert(segpos, snapPt);
+#if GEOS_DEBUG
+cerr << " After segment snapping, srcCoors are: " << srcCoords << endl;
+#endif
 /*private*/
-int
-LineStringSnapper::findSegmentIndexToSnap(const geom::Coordinate& snapPt,
+CoordinateList::iterator
+LineStringSnapper::findSegmentToSnap(
+			const Coordinate& snapPt,
+			CoordinateList::iterator from,
+			CoordinateList::iterator too_far)
-    double minDist = numeric_limits<double>::max();
-    int snapIndex = -1;
-      seg.p0 = srcCoords.getAt(i);
-      seg.p1 = srcCoords.getAt(i + 1);
+	LineSegment seg;
+	double minDist = snapTolerance+1; // make sure the first closer then
+	                                  // snapTolerance is accepted
+	CoordinateList::iterator match=too_far;
-       * If the snap pt is already in the src list, don't snap
-      if (seg.p0.equals2D(snapPt) || seg.p1.equals2D(snapPt))
-        return -1;
+	for ( ; from != too_far; ++from)
+		seg.p0 = *from;
+		CoordinateList::iterator to = from;
+		++to;
+		seg.p1 = *to;
-      double dist = seg.distance(snapPt);
-      if (dist < snapTolerance && dist < minDist) {
-        minDist = dist;
-        snapIndex = i;
-    return snapIndex;
+#if GEOS_DEBUG
+cerr << " Checking segment " << seg << " for snapping against point " << snapPt << endl;
+#endif
+		if ( seg.p0.equals2D(snapPt) || seg.p1.equals2D(snapPt) )
+#if GEOS_DEBUG
+cerr << " One of segment endpoints equal snap point, returning too_far" << endl;
+#endif
+			// If the snap pt is already in the src list,
+			// don't snap
+			return too_far;
+		double dist = seg.distance(snapPt);
+#if GEOS_DEBUG
+cerr << " dist=" << dist << " minDist=" << minDist << " snapTolerance=" << snapTolerance << endl;
+#endif
+		if ( dist < minDist && dist < snapTolerance )
+#if GEOS_DEBUG
+cerr << " Segment/snapPt distance within tolerance and closer then previous match (" << dist << ") " << endl;
+#endif
+			match = from;
+			minDist = dist;
+	return match;
Modified: trunk/source/operation/overlay/snap/SnapOverlayOp.cpp
--- trunk/source/operation/overlay/snap/SnapOverlayOp.cpp	2009-05-05 00:04:34 UTC (rev 2467)
+++ trunk/source/operation/overlay/snap/SnapOverlayOp.cpp	2009-05-05 10:14:39 UTC (rev 2468)
@@ -20,7 +20,7 @@
 #include <geos/operation/overlay/snap/SnapOverlayOp.h>
-//#include <geos/geom/CoordinateSequence.h>
+#include <geos/geom/Geometry.h>
 #include <cassert>
Deleted: trunk/source/precision/GeometrySnapper.cpp
--- trunk/source/precision/GeometrySnapper.cpp	2009-05-05 00:04:34 UTC (rev 2467)
+++ trunk/source/precision/GeometrySnapper.cpp	2009-05-05 10:14:39 UTC (rev 2468)
@@ -1,170 +0,0 @@
- * $Id$
-#include <geos/precision/LineStringSnapper.h>
-#include <geos/geom/util/GeometryTransformer.h> // inherit. of SnapTransformer
-#include <geos/geom/GeometryFactory.h>
-#include <geos/geom/CoordinateSequenceFactory.h>
-#include <geos/util.h>
-#include <vector>
-#include <memory>
-//using namespace std;
-using namespace geos::geom;
-namespace geos {
-const double GeometrySnapper::snapPrecisionFactor = 10e-10;
-class SnapTransformer: public geos::geom::util::GeometryTransformer {
-private:
-	double snapTol;
-	const Coordinate::ConstVect& snapPts;
-	CoordinateSequence::AutoPtr snapLine(
-			const CoordinateSequence* srcPts)
-		using std::auto_ptr;
-		assert(srcPts);
-		assert(srcPts->toVector());
-		LineStringSnapper snapper(*(srcPts->toVector()), snapTol);
-		auto_ptr<Coordinate::Vect> newPts = snapper.snapTo(snapPts);
-		const CoordinateSequenceFactory* cfact = factory->getCoordinateSequenceFactory();
-		return auto_ptr<CoordinateSequence>(cfact->create(newPts.release()));
-public:
-	SnapTransformer(double nSnapTol,
-			const Coordinate::ConstVect& nSnapPts)
-		snapTol(nSnapTol),
-		snapPts(nSnapPts)
-	CoordinateSequence::AutoPtr transformCoordinates(
-        UNREFERENCED_PARAMETER(parent);
-		return snapLine(coords);
-/*private*/
-std::auto_ptr<Coordinate::ConstVect>
-GeometrySnapper::extractTargetCoordinates(const Geometry& g)
-	std::auto_ptr<Coordinate::ConstVect> snapPts(new Coordinate::ConstVect());
-	util::UniqueCoordinateArrayFilter filter(*snapPts);
-	// integrity check
-	assert( snapPts->size() <= g.getNumPoints() );
-	return snapPts;
-/*public*/
-std::auto_ptr<geom::Geometry>
-GeometrySnapper::snapTo(const geom::Geometry& g, double snapTolerance)
-	using geom::util::GeometryTransformer;
-	// Get snap points
-	auto_ptr<Coordinate::ConstVect> snapPts=extractTargetCoordinates(g);
-	// Apply a SnapTransformer to source geometry
-	// (we need a pointer for dynamic polymorphism)
-	auto_ptr<GeometryTransformer> snapTrans(new SnapTransformer(snapTolerance, *snapPts));
-	return snapTrans->transform(&srcGeom);
-/*public static*/
-double
-	const Envelope* env = g.getEnvelopeInternal();
-	double minDimension = std::min(env->getHeight(), env->getWidth());
-	double snapTol = minDimension * snapPrecisionFactor;
-	return snapTol;
-/*public static*/
-double
-GeometrySnapper::computeOverlaySnapTolerance(const geom::Geometry& g)
-	double snapTolerance = computeSizeBasedSnapTolerance(g);
-	 * Overlay is carried out in most precise precision model of inputs.
-	 * If this precision model is fixed, then the snap tolerance
-	 * must reflect the grid size.
-	 * Precisely, the snap tolerance should be at least
-	 * the distance from a corner of a precision grid cell
-	 * to the centre point of the cell.
-	assert(g.getPrecisionModel());
-	const PrecisionModel& pm = *(g.getPrecisionModel());
-		double fixedSnapTol = (1 / pm.getScale()) * 2 / 1.415;
-		if ( fixedSnapTol > snapTolerance )
-			snapTolerance = fixedSnapTol;
-	return snapTolerance;
-/*public static*/
-double
-GeometrySnapper::computeOverlaySnapTolerance(const geom::Geometry& g1,
-        return std::min(computeOverlaySnapTolerance(g1), computeOverlaySnapTolerance(g2));
- * $Log$
Deleted: trunk/source/precision/LineStringSnapper.cpp
--- trunk/source/precision/LineStringSnapper.cpp	2009-05-05 00:04:34 UTC (rev 2467)
+++ trunk/source/precision/LineStringSnapper.cpp	2009-05-05 10:14:39 UTC (rev 2468)
@@ -1,273 +0,0 @@
- * $Id$
-#include <vector>
-#include <memory>
-#ifndef GEOS_DEBUG
-#endif
-#if GEOS_DEBUG
-#include <iostream>
-using std::cerr;
-using std::endl;
-#endif
-namespace geos {
-/*public*/
-std::auto_ptr<Coordinate::Vect>
-LineStringSnapper::snapTo(const geom::Coordinate::ConstVect& snapPts)
-	geom::CoordinateList coordList(srcPts);
-	snapVertices(coordList, snapPts);
-	snapSegments(coordList, snapPts);
-	return coordList.toCoordinateArray();
-/*private*/
-void
-LineStringSnapper::snapVertices(geom::CoordinateList& srcCoords,
-	using geom::CoordinateList;
-	geom::Coordinate::ConstVect::const_iterator not_found = snapPts.end();
-	CoordinateList::iterator it = srcCoords.begin();
-	CoordinateList::iterator end = srcCoords.end();
-	CoordinateList::iterator last = end; --last;
-	for ( ; it != end; ++it )
-		Coordinate& srcPt = *it;
-#if GEOS_DEBUG
-cerr << "Checking for a snap for source coordinate " << srcPt << endl;
-#endif
-		geom::Coordinate::ConstVect::const_iterator found = findSnapForVertex(srcPt, snapPts);
-		if ( found == not_found )
-		{	// no snaps found (or no need to snap)
-#if GEOS_DEBUG
-cerr << "No snap found" << endl;
-#endif
-			continue;
-		assert(*found);
-		const Coordinate& snapPt = *(*found);
-#if GEOS_DEBUG
-cerr << "Found snap point " << snapPt << endl;
-#endif
-		*it = snapPt;
-#if GEOS_DEBUG
-cerr << "Source point became " << srcPt << endl;
-#endif
-		if (it == srcCoords.begin() && isClosed)
-			*last = snapPt;
-/*private*/
-Coordinate::ConstVect::const_iterator
-LineStringSnapper::findSnapForVertex(const Coordinate& pt,
-			const Coordinate::ConstVect& snapPts)
-	// TODO: use std::find_if
-	Coordinate::ConstVect::const_iterator end=snapPts.end();
-	for ( Coordinate::ConstVect::const_iterator
-			it=snapPts.begin();
-			it != end;
-			++it)
-		assert(*it);
-		const Coordinate& snapPt = *(*it);
-#if GEOS_DEBUG
-cerr << " misuring distance between snap point " << snapPt << " and source point " << pt << endl;
-#endif
-		// shouldn't we look for *all* segments to be snapped rather then a single one?
-		if ( snapPt.equals2D(pt) )
-#if GEOS_DEBUG
-cerr << " points are equal, returning not-found " << endl;
-#endif
-			return end;
-			//continue;
-		double dist = snapPt.distance(pt);
-		if ( dist < snapTolerance )
-#if GEOS_DEBUG
-cerr << " points are within distance (" << dist << ") returning iterator to snap point" << endl;
-#endif
-			return it;
-#if GEOS_DEBUG
-cerr << " No snap point within distance, returning not-found" << endl;
-#endif
-	return end;
-/*private*/
-void
-LineStringSnapper::snapSegments(geom::CoordinateList& srcCoords,
-#if GEOS_DEBUG
-cerr << " Snapping segment from: " << srcCoords << endl;
-#endif
-			it=snapPts.begin(), end=snapPts.end();
-			it != end;
-			++it)
-		assert(*it);
-#if GEOS_DEBUG
-cerr << "Checking for a segment to snap to snapPt " << snapPt << endl;
-#endif
-		// rather then a single one?
-		CoordinateList::iterator too_far = srcCoords.end(); --too_far;
-		CoordinateList::iterator segpos =
-			findSegmentToSnap(snapPt, srcCoords.begin(), too_far);
-		if ( segpos == too_far)
-#if GEOS_DEBUG
-cerr << " No segment to snap" << endl;
-#endif
-			continue;
-#if GEOS_DEBUG
-cerr << " Segment to be snapped found, inserting point" << endl;
-#endif
-		// insert must happen one-past first point (before next point)
-		++segpos;
-		srcCoords.insert(segpos, snapPt);
-#if GEOS_DEBUG
-cerr << " After segment snapping, srcCoors are: " << srcCoords << endl;
-#endif
-/*private*/
-CoordinateList::iterator
-LineStringSnapper::findSegmentToSnap(
-			const Coordinate& snapPt,
-			CoordinateList::iterator from,
-			CoordinateList::iterator too_far)
-	LineSegment seg;
-	double minDist = snapTolerance+1; // make sure the first closer then
-	                                  // snapTolerance is accepted
-	CoordinateList::iterator match=too_far;
-	for ( ; from != too_far; ++from)
-		seg.p0 = *from;
-		CoordinateList::iterator to = from;
-		++to;
-		seg.p1 = *to;
-#if GEOS_DEBUG
-cerr << " Checking segment " << seg << " for snapping against point " << snapPt << endl;
-#endif
-		if ( seg.p0.equals2D(snapPt) || seg.p1.equals2D(snapPt) )
-#if GEOS_DEBUG
-cerr << " One of segment endpoints equal snap point, returning too_far" << endl;
-#endif
-			// If the snap pt is already in the src list,
-			// don't snap
-			return too_far;
-#if GEOS_DEBUG
-cerr << " dist=" << dist << " minDist=" << minDist << " snapTolerance=" << snapTolerance << endl;
-#endif
-		if ( dist < minDist && dist < snapTolerance )
-#if GEOS_DEBUG
-cerr << " Segment/snapPt distance within tolerance and closer then previous match (" << dist << ") " << endl;
-#endif
-			match = from;
-			minDist = dist;
-	return match;
- * $Log$
- * Revision 1.2  2006/07/21 17:59:05  strk
- * Fixed preprocessor directive use
Modified: trunk/source/precision/Makefile.am
--- trunk/source/precision/Makefile.am	2009-05-05 00:04:34 UTC (rev 2467)
+++ trunk/source/precision/Makefile.am	2009-05-05 10:14:39 UTC (rev 2468)
@@ -8,8 +8,6 @@
 	CommonBits.cpp \
 	CommonBitsOp.cpp \
 	CommonBitsRemover.cpp \
-	GeometrySnapper.cpp \
-	LineStringSnapper.cpp \
 	EnhancedPrecisionOp.cpp \
 	SimpleGeometryPrecisionReducer.cpp
Modified: trunk/tests/unit/Makefile.am
--- trunk/tests/unit/Makefile.am	2009-05-05 00:04:34 UTC (rev 2467)
+++ trunk/tests/unit/Makefile.am	2009-05-05 10:14:39 UTC (rev 2468)
@@ -70,12 +70,12 @@
 	operation/overlay/validate/FuzzyPointLocatorTest.cpp \
 	operation/overlay/validate/OffsetPointGeneratorTest.cpp \
 	operation/overlay/validate/OverlayResultValidatorTest.cpp \
+	operation/overlay/snap/GeometrySnapperTest.cpp \
+	operation/overlay/snap/LineStringSnapperTest.cpp \
 	operation/union/CascadedPolygonUnionTest.cpp \
 	operation/valid/IsValidTest.cpp \
 	operation/valid/ValidClosedRingTest.cpp \
 	operation/valid/ValidSelfTouchingRingFormingHoleTest.cpp \
-	precision/GeometrySnapperTest.cpp \
-	precision/LineStringSnapperTest.cpp \
 	precision/SimpleGeometryPrecisionReducerTest.cpp \
 	simplify/DouglasPeuckerSimplifierTest.cpp \
 	simplify/TopologyPreservingSimplifierTest.cpp \
Copied: trunk/tests/unit/operation/overlay/snap/GeometrySnapperTest.cpp (from rev 2455, trunk/tests/unit/precision/GeometrySnapperTest.cpp)
--- trunk/tests/unit/operation/overlay/snap/GeometrySnapperTest.cpp	                        (rev 0)
+++ trunk/tests/unit/operation/overlay/snap/GeometrySnapperTest.cpp	2009-05-05 10:14:39 UTC (rev 2468)
@@ -0,0 +1,97 @@
+// $Id$
+// Test Suite for geos::operation::overlay::snap::GeometrySnapper class.
+// tut
+#include <tut.hpp>
+// geos
+#include <geos/io/WKTReader.h>
+// std
+#include <memory>
+#include <string>
+#include <vector>
+namespace tut
+    // Test Group
+    // Common data used by tests
+    struct test_geometrysnapper_data
+	typedef std::auto_ptr<geos::geom::Geometry> GeomAutoPtr;
+	geos::geom::GeometryFactory factory;
+	geos::io::WKTReader reader;
+	GeomAutoPtr src;
+	geos::operation::overlay::snap::GeometrySnapper snapper;
+        test_geometrysnapper_data()
+		factory(), // initialize before use!
+		reader(&factory),
+		src(reader.read(
+			"POLYGON ((0 0, 0 100, 100 100, 100 0, 0 0))"
+		snapper( *(src.get()) )
+    typedef test_group<test_geometrysnapper_data> group;
+    typedef group::object object;
+    group test_geometrysnapper_group("geos::operation::overlay::snap::GeometrySnapper");
+    // Test Cases
+    // Test vertices snapping
+    template<>
+    template<>
+    void object::test<1>()
+	GeomAutoPtr snap(reader.read(
+		"MULTIPOINT ((0 0), (0 100.0000001), (100 100), (100 0))"
+	GeomAutoPtr expected(reader.read(
+		"POLYGON ((0 0, 0 100.0000001, 100 100, 100 0, 0 0))"
+	GeomAutoPtr ret(snapper.snapTo( *(snap.get()), 0.000001 ));
+	ensure( ret->equalsExact(expected.get(),0) );
+    template<>
+    template<>
+    void object::test<2>()
+		"MULTIPOINT ((0.0000001 50))"
+		"POLYGON ((0 0, 0.0000001 50, 0 100, 100 100, 100 0, 0 0))"
+} // namespace tut
Property changes on: trunk/tests/unit/operation/overlay/snap/GeometrySnapperTest.cpp
___________________________________________________________________
   + text/plain
   + Id
   + native
Copied: trunk/tests/unit/operation/overlay/snap/LineStringSnapperTest.cpp (from rev 2455, trunk/tests/unit/precision/LineStringSnapperTest.cpp)
--- trunk/tests/unit/operation/overlay/snap/LineStringSnapperTest.cpp	                        (rev 0)
+++ trunk/tests/unit/operation/overlay/snap/LineStringSnapperTest.cpp	2009-05-05 10:14:39 UTC (rev 2468)
@@ -0,0 +1,115 @@
+// $Id$
+// Test Suite for geos::operation::overlay::snap::LineStringSnapper class.
+// tut
+#include <tut.hpp>
+// geos
+#include <geos/operation/overlay/snap/LineStringSnapper.h>
+#include <geos/geom/CoordinateArraySequence.h>
+// std
+#include <string>
+#include <vector>
+namespace tut
+    // Test Group
+    struct test_linestringsnapper_data
+        test_linestringsnapper_data() {}
+    typedef test_group<test_linestringsnapper_data> group;
+    group test_linestringsnapper_group("geos::operation::overlay::snap::LineStringSnapper");
+    // Test Cases
+    template<>
+    template<>
+		using geos::geom::Coordinate;
+		using geos::operation::overlay::snap::LineStringSnapper;
+		typedef std::auto_ptr<Coordinate::Vect> CoordsVectAptr;
+		// source coordinates
+		Coordinate src_a(0, 0);
+		Coordinate src_b(10, 10);
+		// snap coordinates
+		Coordinate snp_a(0.1, 0);
+		Coordinate snp_b(10, 10.1);
+		Coordinate::Vect srcCoords;
+		srcCoords.push_back( src_a );
+		srcCoords.push_back( src_b );
+		Coordinate::ConstVect snpCoords;
+		snpCoords.push_back( &snp_a );
+		snpCoords.push_back( &snp_b );
+		LineStringSnapper snapper(srcCoords, 0.4);
+		CoordsVectAptr ret(snapper.snapTo(snpCoords));
+		// both points should have been snapped
+		ensure_equals(ret->operator[](0), snp_a);
+		ensure_equals(ret->operator[](1), snp_b);
+    // Test segment snapping
+    template<>
+    template<>
+		Coordinate snp_a(0.4, 0);
+		Coordinate snp_b(10, 10.4);
+		LineStringSnapper snapper(srcCoords, 0.3);
+		// snap point a should be inserted
+		ensure_equals(ret->size(), 3u);
+		ensure_equals(ret->operator[](0), src_a);
+		ensure_equals(ret->operator[](1), snp_a);
+		ensure_equals(ret->operator[](2), src_b);
+} // namespace tut
Property changes on: trunk/tests/unit/operation/overlay/snap/LineStringSnapperTest.cpp
   + text/plain
   + Id
   + native
Deleted: trunk/tests/unit/precision/GeometrySnapperTest.cpp
--- trunk/tests/unit/precision/GeometrySnapperTest.cpp	2009-05-05 00:04:34 UTC (rev 2467)
+++ trunk/tests/unit/precision/GeometrySnapperTest.cpp	2009-05-05 10:14:39 UTC (rev 2468)
@@ -1,97 +0,0 @@
-// $Id$
-// Test Suite for geos::precision::GeometrySnapper class.
-// tut
-#include <tut.hpp>
-// geos
-#include <geos/geom/Geometry.h>
-#include <geos/io/WKTReader.h>
-// std
-#include <memory>
-#include <string>
-#include <vector>
-namespace tut
-    // Test Group
-    // Common data used by tests
-    struct test_geometrysnapper_data
-	typedef std::auto_ptr<geos::geom::Geometry> GeomAutoPtr;
-	geos::geom::GeometryFactory factory;
-	geos::io::WKTReader reader;
-	GeomAutoPtr src;
-	geos::precision::GeometrySnapper snapper;
-        test_geometrysnapper_data()
-		factory(), // initialize before use!
-		reader(&factory),
-		src(reader.read(
-			"POLYGON ((0 0, 0 100, 100 100, 100 0, 0 0))"
-		snapper( *(src.get()) )
-    typedef test_group<test_geometrysnapper_data> group;
-    typedef group::object object;
-    group test_geometrysnapper_group("geos::precision::GeometrySnapper");
-    // Test Cases
-    // Test vertices snapping
-    template<>
-    template<>
-    void object::test<1>()
-	GeomAutoPtr snap(reader.read(
-		"MULTIPOINT ((0 0), (0 100.0000001), (100 100), (100 0))"
-	GeomAutoPtr expected(reader.read(
-		"POLYGON ((0 0, 0 100.0000001, 100 100, 100 0, 0 0))"
-	GeomAutoPtr ret(snapper.snapTo( *(snap.get()), 0.000001 ));
-	ensure( ret->equalsExact(expected.get(),0) );
-    template<>
-    template<>
-    void object::test<2>()
-		"MULTIPOINT ((0.0000001 50))"
-		"POLYGON ((0 0, 0.0000001 50, 0 100, 100 100, 100 0, 0 0))"
-} // namespace tut
Deleted: trunk/tests/unit/precision/LineStringSnapperTest.cpp
--- trunk/tests/unit/precision/LineStringSnapperTest.cpp	2009-05-05 00:04:34 UTC (rev 2467)
+++ trunk/tests/unit/precision/LineStringSnapperTest.cpp	2009-05-05 10:14:39 UTC (rev 2468)
@@ -1,115 +0,0 @@
-// $Id$
-// Test Suite for geos::precision::LineStringSnapper class.
-// tut
-#include <tut.hpp>
-// geos
-#include <geos/geom/CoordinateArraySequence.h>
-// std
-#include <string>
-#include <vector>
-namespace tut
-    // Test Group
-    struct test_linestringsnapper_data
-        test_linestringsnapper_data() {}
-    typedef test_group<test_linestringsnapper_data> group;
-    group test_linestringsnapper_group("geos::precision::LineStringSnapper");
-    // Test Cases
-    template<>
-    template<>
-		using geos::geom::Coordinate;
-		using geos::precision::LineStringSnapper;
-		typedef std::auto_ptr<Coordinate::Vect> CoordsVectAptr;
-		// source coordinates
-		Coordinate src_a(0, 0);
-		Coordinate src_b(10, 10);
-		// snap coordinates
-		Coordinate snp_a(0.1, 0);
-		Coordinate snp_b(10, 10.1);
-		Coordinate::Vect srcCoords;
-		srcCoords.push_back( src_a );
-		srcCoords.push_back( src_b );
-		Coordinate::ConstVect snpCoords;
-		snpCoords.push_back( &snp_a );
-		snpCoords.push_back( &snp_b );
-		LineStringSnapper snapper(srcCoords, 0.4);
-		CoordsVectAptr ret(snapper.snapTo(snpCoords));
-		// both points should have been snapped
-		ensure_equals(ret->operator[](0), snp_a);
-		ensure_equals(ret->operator[](1), snp_b);
-    // Test segment snapping
-    template<>
-    template<>
-		Coordinate snp_a(0.4, 0);
-		Coordinate snp_b(10, 10.4);
-		LineStringSnapper snapper(srcCoords, 0.3);
-		// snap point a should be inserted
-		ensure_equals(ret->size(), 3u);
-		ensure_equals(ret->operator[](0), src_a);
-		ensure_equals(ret->operator[](1), snp_a);
-		ensure_equals(ret->operator[](2), src_b);
-} // namespace tut
More information about the geos-commits mailing list
