[geos-commits] r2476 - in trunk/source: algorithm headers/geos/index headers/geos/index/bintree headers/geos/index/chain index/bintree index/chain noding
svn_geos at osgeo.org svn_geos at osgeo.org
Wed May 6 12:44:07 EDT 2009
Author: strk
Date: 2009-05-06 12:44:06 -0400 (Wed, 06 May 2009)
New Revision: 2476
   trunk/source/algorithm/MCPointInRing.cpp
   trunk/source/headers/geos/index/SpatialIndex.h
   trunk/source/headers/geos/index/bintree/Bintree.h
   trunk/source/headers/geos/index/bintree/Root.h
   trunk/source/headers/geos/index/chain/MonotoneChain.h
   trunk/source/index/bintree/Bintree.cpp
   trunk/source/index/chain/MonotoneChain.cpp
   trunk/source/index/chain/MonotoneChainBuilder.cpp
   trunk/source/index/chain/MonotoneChainOverlapAction.cpp
   trunk/source/index/chain/MonotoneChainSelectAction.cpp
   trunk/source/noding/MCIndexNoder.cpp
   trunk/source/noding/MCIndexSegmentSetMutualIntersector.cpp
MonotoneChain const-correctness and interface cleanups, cascaded changes. Possibly discovered a leak in MCPointInRing algorithm, needs some unit testing.
Modified: trunk/source/algorithm/MCPointInRing.cpp
--- trunk/source/algorithm/MCPointInRing.cpp	2009-05-06 16:36:14 UTC (rev 2475)
+++ trunk/source/algorithm/MCPointInRing.cpp	2009-05-06 16:44:06 UTC (rev 2476)
@@ -72,14 +72,29 @@
 //	Envelope *env=ring->getEnvelopeInternal();
 	tree=new bintree::Bintree();
 	pts=CoordinateSequence::removeRepeatedPoints(ring->getCoordinatesRO());
-	vector<chain::MonotoneChain*> *mcList=chain::MonotoneChainBuilder::getChains(pts);
-	for(int i=0;i<(int)mcList->size();i++) {
+	// NOTE: we take ownership of mcList and it's elements
+	vector<chain::MonotoneChain*> *mcList =
+		chain::MonotoneChainBuilder::getChains(pts);
+	for(size_t i=0, n=mcList->size(); i<n; ++i)
 		chain::MonotoneChain *mc=(*mcList)[i];
-		Envelope *mcEnv=mc->getEnvelope();
-		interval.min=mcEnv->getMinY();
-		interval.max=mcEnv->getMaxY();
-		tree->insert(&interval,mc);
+		const Envelope& mcEnv = mc->getEnvelope();
+		interval.min = mcEnv.getMinY();
+		interval.max = mcEnv.getMaxY();
+		// TODO: is 'mc' ownership transferred here ? (see below)
+		//       by documentation SpatialIndex does NOT take
+		//       ownership of the items, so unless we query it
+		//       all later we've a leak problem here..
+		//       Need a focused testcase.
+		tree->insert(&interval, mc);
+	// TODO: mcList elements ownership went to tree or what ?
 	delete mcList;
Modified: trunk/source/headers/geos/index/SpatialIndex.h
--- trunk/source/headers/geos/index/SpatialIndex.h	2009-05-06 16:36:14 UTC (rev 2475)
+++ trunk/source/headers/geos/index/SpatialIndex.h	2009-05-06 16:44:06 UTC (rev 2476)
@@ -52,7 +52,13 @@
 	 * Adds a spatial item with an extent specified by the given Envelope
 	 * to the index
-	 * TODO: document ownership of 'itemEnv' and 'item'
+	 * @param itemEnv
+	 *    Envelope of the item, ownership left to caller.
+	 *    TODO: Reference hold by this class ?
+	 * @param item
+	 *    Opaque item, ownership left to caller.
+	 *    Reference hold by this class.
 	virtual void insert(const geom::Envelope *itemEnv, void *item) = 0;
Modified: trunk/source/headers/geos/index/bintree/Bintree.h
--- trunk/source/headers/geos/index/bintree/Bintree.h	2009-05-06 16:36:14 UTC (rev 2475)
+++ trunk/source/headers/geos/index/bintree/Bintree.h	2009-05-06 16:44:06 UTC (rev 2476)
@@ -52,7 +52,18 @@
 public:
-	static Interval* ensureExtent(Interval *itemInterval, double minExtent);
+	 * Ensure that the Interval for the inserted item has non-zero extents.
+	 * Use the current minExtent to pad it, if necessary
+	 * NOTE: in GEOS this function always return a newly allocated object
+	 *       with ownership transferred to caller. TODO: change this ?
+	 * @param itemInterval
+	 *      Source interval, ownership left to caller, no references hold.
+	static Interval* ensureExtent(const Interval *itemInterval,
+	                                                 double minExtent);
 	Bintree();
@@ -64,7 +75,13 @@
 	int nodeSize();
-	void insert(Interval *itemInterval,void* item);
+	/// @param itemInterval
+	///     Ownership left to caller, NO reference hold by this class.
+	/// @param item
+	///     Ownership left to caller, reference kept by this class.
+	void insert(Interval *itemInterval, void* item);
 	std::vector<void*>* iterator();
Modified: trunk/source/headers/geos/index/bintree/Root.h
--- trunk/source/headers/geos/index/bintree/Root.h	2009-05-06 16:36:14 UTC (rev 2475)
+++ trunk/source/headers/geos/index/bintree/Root.h	2009-05-06 16:44:06 UTC (rev 2476)
@@ -55,7 +55,13 @@
 	~Root() {}
+	///     Ownership left to caller, references kept in this class.
+	/// @param item
 protected:
Modified: trunk/source/headers/geos/index/chain/MonotoneChain.h
--- trunk/source/headers/geos/index/chain/MonotoneChain.h	2009-05-06 16:36:14 UTC (rev 2475)
+++ trunk/source/headers/geos/index/chain/MonotoneChain.h	2009-05-06 16:44:06 UTC (rev 2476)
@@ -22,6 +22,8 @@
 #include <geos/geom/Envelope.h> // for inline
+#include <memory> // for auto_ptr
 // Forward declarations
 namespace geos {
 	namespace geom {
@@ -84,30 +86,40 @@
 public:
-	MonotoneChain(const geom::CoordinateSequence* pts,
+	/// @param pts
+	///   Ownership left to caller, this class holds a reference.
+	/// @param start
+	/// @param end
+	/// @param context
+	MonotoneChain(const geom::CoordinateSequence& pts,
                   size_t start, size_t end, void* context);
 	~MonotoneChain();
 	/// Returned envelope is owned by this class
-	geom::Envelope* getEnvelope();
+	const geom::Envelope& getEnvelope() const;
-	size_t getStartIndex() { return start; }
+	size_t getStartIndex() const { return start; }
-	size_t getEndIndex() { return end; }
+	size_t getEndIndex() const { return end; }
-	/// Set given LineSegment with points of the segment starting
-	/// at the given index.
-	void getLineSegment(unsigned int index, geom::LineSegment *ls);
+	/** \brief
+	 *  Set given LineSegment with points of the segment starting
+	 *  at the given index.
+	void getLineSegment(unsigned int index, geom::LineSegment& ls) const;
 	 * Return the subsequence of coordinates forming this chain.
 	 * Allocates a new CoordinateSequence to hold the Coordinates
-	 * TODO: return by auto_ptr
-	geom::CoordinateSequence* getCoordinates();
+	std::auto_ptr<geom::CoordinateSequence> getCoordinates() const;
 	 * Determine all the line segments in the chain whose envelopes overlap
@@ -121,25 +133,25 @@
 	void setId(int nId) { id=nId; }
-	inline int getId() { return id; }
+	inline int getId() const { return id; }
 	void* getContext() { return context; }
 private:
 	void computeSelect(const geom::Envelope& searchEnv,
-			unsigned int start0,
-			unsigned int end0,
+			size_t start0,
+			size_t end0,
 			MonotoneChainSelectAction& mcs);
-	void computeOverlaps(int start0, int end0, MonotoneChain* mc,
-			int start1, int end1, MonotoneChainOverlapAction* mco);
+	void computeOverlaps(size_t start0, size_t end0, MonotoneChain& mc,
+			int start1, int end1, MonotoneChainOverlapAction& mco);
-	/// Externally owned (could be a reference)
-	const geom::CoordinateSequence* pts;
+	/// Externally owned
+	const geom::CoordinateSequence& pts;
 	/// Owned by this class, lazely created
-	geom::Envelope* env;
+	mutable geom::Envelope* env;
 	/// user-defined information
 	void* context;
Modified: trunk/source/index/bintree/Bintree.cpp
--- trunk/source/index/bintree/Bintree.cpp	2009-05-06 16:36:14 UTC (rev 2475)
+++ trunk/source/index/bintree/Bintree.cpp	2009-05-06 16:44:06 UTC (rev 2476)
@@ -25,23 +25,26 @@
 using namespace std;
-* Ensure that the Interval for the inserted item has non-zero extents.
-* Use the current minExtent to pad it, if necessary
 Interval*
-Bintree::ensureExtent(Interval *itemInterval, double minExtent)
+Bintree::ensureExtent(const Interval* itemInterval, double minExtent)
-	double min=itemInterval->getMin();
-	double max=itemInterval->getMax();
+	double min = itemInterval->getMin();
+	double max = itemInterval->getMax();
 	// has a non-zero extent
-	if (min!=max) return new Interval(itemInterval);
+	if (min != max)
+		// GEOS forces a copy here to be predictable wrt
+		// memory management. May change in the future.
+		return new Interval(*itemInterval);
 	// pad extent
-	if (min==max) {
-		min=min-minExtent/2.0;
-		max=min+minExtent/2.0;
+	if (min==max)
+		min = min-minExtent/2.0;
+		max = min+minExtent/2.0;
-//	delete itemInterval;
 	return new Interval(min, max);
Modified: trunk/source/index/chain/MonotoneChain.cpp
--- trunk/source/index/chain/MonotoneChain.cpp	2009-05-06 16:36:14 UTC (rev 2475)
+++ trunk/source/index/chain/MonotoneChain.cpp	2009-05-06 16:44:06 UTC (rev 2476)
@@ -31,9 +31,15 @@
 namespace index { // geos.index
 namespace chain { // geos.index.chain
-MonotoneChain::MonotoneChain(const geom::CoordinateSequence *newPts,
+MonotoneChain::MonotoneChain(const geom::CoordinateSequence& newPts,
                              size_t nstart, size_t nend, void* nContext)
-: pts(newPts), env(0), context(nContext), start(nstart), end(nend), id(-1)
+	pts(newPts),
+	env(0),
+	context(nContext),
+	start(nstart),
+	end(nend),
+	id(-1)
@@ -42,48 +48,44 @@
     delete env;
-Envelope*
-MonotoneChain::getEnvelope()
+const Envelope&
+MonotoneChain::getEnvelope() const
     if (0 == env)
-        const Coordinate& p0 = pts->getAt(start);
-        const Coordinate& p1 = pts->getAt(end);
+        const Coordinate& p0 = pts[start];
+        const Coordinate& p1 = pts[end];
         env = new Envelope(p0, p1);
-    return env;
+    return *env;
 void
-MonotoneChain::getLineSegment(unsigned int index, LineSegment *ls)
+MonotoneChain::getLineSegment(unsigned int index, LineSegment& ls) const
-    ls->p0=pts->getAt(index);
-    ls->p1=pts->getAt(index+1);
+    ls.p0 = pts[index];
+    ls.p1 = pts[index+1];
-* Return the subsequence of coordinates forming this chain.
-* Allocates a new array to hold the Coordinates
-CoordinateSequence*
-MonotoneChain::getCoordinates()
+std::auto_ptr<CoordinateSequence>
+MonotoneChain::getCoordinates() const
-    return pts->clone();
+    return std::auto_ptr<CoordinateSequence>(pts.clone());
 void
 MonotoneChain::select(const Envelope& searchEnv, MonotoneChainSelectAction& mcs)
-    computeSelect(searchEnv,start,end,mcs);
+    computeSelect(searchEnv, start, end, mcs);
 void
 MonotoneChain::computeSelect(const Envelope& searchEnv,
-                             unsigned int start0, unsigned int end0,
+                             size_t start0, size_t end0,
                              MonotoneChainSelectAction& mcs )
-    const Coordinate& p0=pts->getAt(start0);
-    const Coordinate& p1=pts->getAt(end0);
+    const Coordinate& p0=pts[start0];
+    const Coordinate& p1=pts[end0];
     mcs.tempEnv1->init(p0,p1);
     //Debug.println("trying:"+p0+p1+" [ "+start0+","+end0+" ]");
@@ -113,37 +115,42 @@
+/* public */
 void
-MonotoneChain::computeOverlaps(MonotoneChain *mc, MonotoneChainOverlapAction *mco)
+MonotoneChain::computeOverlaps(MonotoneChain *mc,
+                               MonotoneChainOverlapAction *mco)
-    computeOverlaps(start,end,mc,mc->start,mc->end,mco);
+    computeOverlaps(start, end, *mc, mc->start, mc->end, *mco);
+/*private*/
 void
-MonotoneChain::computeOverlaps(int start0, int end0, MonotoneChain *mc,
-                               int start1, int end1, MonotoneChainOverlapAction *mco)
+MonotoneChain::computeOverlaps(size_t start0, size_t end0,
+                               MonotoneChain& mc,
+                               MonotoneChainOverlapAction& mco)
     //Debug.println("computeIntersectsForChain:"+p00+p01+p10+p11);
     // terminating condition for the recursion
     if (end0-start0==1 && end1-start1==1)
-        mco->overlap(this,start0,mc,start1);
+        mco.overlap(this, start0, &mc, start1);
         return;
-    const Coordinate& p00=pts->getAt(start0);
-    const Coordinate& p01=pts->getAt(end0);
-    const Coordinate& p10=mc->pts->getAt(start1);
-    const Coordinate& p11=mc->pts->getAt(end1);
+    const Coordinate& p00 = pts[start0];
+    const Coordinate& p01 = pts[end0];
+    const Coordinate& p10 = mc.pts[start1];
+    const Coordinate& p11 = mc.pts[end1];
     // nothing to do if the envelopes of these chains don't overlap
-    mco->tempEnv1->init(p00,p01);
-    mco->tempEnv2->init(p10,p11);
-    if (!mco->tempEnv1->intersects(mco->tempEnv2)) return;
+    mco.tempEnv1->init(p00, p01);
+    mco.tempEnv2->init(p10, p11);
+    if (!mco.tempEnv1->intersects(mco.tempEnv2)) return;
     // the chains overlap,so split each in half and iterate (binary search)
-    int mid0=(start0+end0)/2;
-    int mid1=(start1+end1)/2;
+    size_t mid0=(start0+end0)/2;
+    size_t mid1=(start1+end1)/2;
     // Assert: mid != start or end (since we checked above for
     // end-start <= 1)
@@ -151,17 +158,17 @@
     if (start0<mid0)
         if (start1<mid1)
-            computeOverlaps(start0,mid0,mc,start1,mid1,mco);
+            computeOverlaps(start0, mid0, mc, start1, mid1, mco);
         if (mid1<end1)
-            computeOverlaps(start0,mid0,mc,mid1,end1,mco);
+            computeOverlaps(start0, mid0, mc, mid1, end1, mco);
     if (mid0<end0)
         if (start1<mid1)
-            computeOverlaps(mid0,end0,mc,start1,mid1,mco);
+            computeOverlaps(mid0, end0, mc, start1, mid1, mco);
         if (mid1<end1)
-            computeOverlaps(mid0,end0,mc,mid1,end1,mco);
+            computeOverlaps(mid0, end0, mc, mid1, end1, mco);
Modified: trunk/source/index/chain/MonotoneChainBuilder.cpp
--- trunk/source/index/chain/MonotoneChainBuilder.cpp	2009-05-06 16:36:14 UTC (rev 2475)
+++ trunk/source/index/chain/MonotoneChainBuilder.cpp	2009-05-06 16:44:06 UTC (rev 2476)
@@ -63,7 +63,7 @@
 		size_t n = nindexes - 1;
 		for(size_t i = 0; i < n; i++)
-			MonotoneChain* mc = new MonotoneChain(pts, startIndex[i], startIndex[i+1], context);
+			MonotoneChain* mc = new MonotoneChain(*pts, startIndex[i], startIndex[i+1], context);
 			mcList.push_back(mc);
Modified: trunk/source/index/chain/MonotoneChainOverlapAction.cpp
--- trunk/source/index/chain/MonotoneChainOverlapAction.cpp	2009-05-06 16:36:14 UTC (rev 2475)
+++ trunk/source/index/chain/MonotoneChainOverlapAction.cpp	2009-05-06 16:44:06 UTC (rev 2476)
@@ -41,16 +41,13 @@
- * This function can be overridden if the original chains are needed
 void
 MonotoneChainOverlapAction::overlap(MonotoneChain *mc1, int start1,
 		MonotoneChain *mc2, int start2)
-	mc1->getLineSegment(start1,overlapSeg1);
-	mc2->getLineSegment(start2,overlapSeg2);
-	overlap(overlapSeg1,overlapSeg2);
+	mc1->getLineSegment(start1, *overlapSeg1);
+	mc2->getLineSegment(start2, *overlapSeg2);
+	overlap(overlapSeg1, overlapSeg2);
 } // namespace geos.index.chain
Modified: trunk/source/index/chain/MonotoneChainSelectAction.cpp
--- trunk/source/index/chain/MonotoneChainSelectAction.cpp	2009-05-06 16:36:14 UTC (rev 2475)
+++ trunk/source/index/chain/MonotoneChainSelectAction.cpp	2009-05-06 16:44:06 UTC (rev 2476)
@@ -39,7 +39,7 @@
 void
 MonotoneChainSelectAction::select(MonotoneChain& mc, unsigned int start)
-	mc.getLineSegment(start, selectedSegment);
+	mc.getLineSegment(start, *selectedSegment);
 	select(selectedSegment);
Modified: trunk/source/noding/MCIndexNoder.cpp
--- trunk/source/noding/MCIndexNoder.cpp	2009-05-06 16:36:14 UTC (rev 2475)
+++ trunk/source/noding/MCIndexNoder.cpp	2009-05-06 16:44:06 UTC (rev 2476)
@@ -72,7 +72,7 @@
 		MonotoneChain* queryChain = *i;
 		assert(queryChain);
 		vector<void*> overlapChains;
-		index.query(queryChain->getEnvelope(), overlapChains);
+		index.query(&(queryChain->getEnvelope()), overlapChains);
 		for (vector<void*>::iterator
 			j=overlapChains.begin(), jEnd=overlapChains.end();
 			j != jEnd;
@@ -117,7 +117,7 @@
 		assert(mc);
 		mc->setId(idCounter++);
-		index.insert(mc->getEnvelope(), mc);
+		index.insert(&(mc->getEnvelope()), mc);
 		// MonotoneChain objects deletion delegated to destructor
 		monoChains.push_back(mc);
Modified: trunk/source/noding/MCIndexSegmentSetMutualIntersector.cpp
--- trunk/source/noding/MCIndexSegmentSetMutualIntersector.cpp	2009-05-06 16:36:14 UTC (rev 2475)
+++ trunk/source/noding/MCIndexSegmentSetMutualIntersector.cpp	2009-05-06 16:44:06 UTC (rev 2476)
@@ -45,7 +45,7 @@
         MonotoneChain * mc = (*segChains)[i];
         mc->setId(indexCounter++);
-        index->insert(mc->getEnvelope(), mc);
+        index->insert(&(mc->getEnvelope()), mc);
@@ -59,7 +59,7 @@
         MonotoneChain * queryChain = (MonotoneChain *)((*monoChains)[i]);
         std::vector<void*> overlapChains;
-        index->query( queryChain->getEnvelope(), overlapChains);
+        index->query( &(queryChain->getEnvelope()), overlapChains);
         for (std::size_t j = 0, nj = overlapChains.size(); j < nj; j++)
More information about the geos-commits mailing list
