[geos-commits] r2510 - branches/3.0/source/operation/buffer
svn_geos at osgeo.org svn_geos at osgeo.org
Thu May 14 15:27:19 EDT 2009
Author: pramsey
Date: 2009-05-14 15:27:19 -0400 (Thu, 14 May 2009)
New Revision: 2510
   branches/3.0/source/operation/buffer/SubgraphDepthLocater.cpp
Port r2503 from trunk back to 3.0
Modified: branches/3.0/source/operation/buffer/SubgraphDepthLocater.cpp
--- branches/3.0/source/operation/buffer/SubgraphDepthLocater.cpp	2009-05-13 12:35:00 UTC (rev 2509)
+++ branches/3.0/source/operation/buffer/SubgraphDepthLocater.cpp	2009-05-14 19:27:19 UTC (rev 2510)
@@ -55,7 +55,7 @@
 private:
-	geom::LineSegment& upwardSeg;
+	geom::LineSegment upwardSeg;
 	 * Compare two collinear segments for left-most ordering.
@@ -80,7 +80,8 @@
 	int leftDepth;
-	DepthSegment(geom::LineSegment &seg, int depth)
+	/// @param seg will be copied to private space
+	DepthSegment(constgeom::LineSegment &seg, int depth)
 		upwardSeg(seg),
 		leftDepth(depth)
More information about the geos-commits mailing list
